2019 Skoda Octavia 2.0TFSI 6SPD Manual
SkodaNZ
New Zealand
C?ID=353136
Would have taken my first scan at delivery before Christmas but only received my Dongle today.
This is the virgin scan before making some changes :-) Hope it helps others as others have helped me!
Monday,14,January,2019,11:21:14:03969
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
VIN: TMBKU7NE7K00   License Plate:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 32 36 3C 42 44 47 4B
          52 5F 6C 6D A5 A9 BB BC D6 D7
VIN: TMBKU7NE7K00   Mileage: 1340km-832miles
BB-Door Rear Drv -- Status: Not registered 0001
Address 01: Engine (J623-DKTB)       Labels: None
   Part No SW: 5G0 906 259 S    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0C1940322444050B1000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TFS0205G0906259S 001003
   ROD: EV_ECM20TFS0205G0906259S.rod
   VCID: 3E253CCB60F74DE7AC7-806A
15183 - Unknown Error Code
          P086B 00 [096] - -
                    Mileage: 518 km
                    Date: 2018.12.29
                    Time: 08:20:55
                    Engine speed: 2680.75 /min
                    Vehicle speed: 62 km/h
                    Coolant temperature: 101 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.609 V
                    Unlearning counter according OBD: 25
                    PV: 0.00 %
                    Engine: operating status: PUC
                    T_IGK: 655.35 s
Address 03: ABS Brakes (J104)       Labels:* None
   Part No SW: 5Q0 614 517 DF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0974
   Revision: 00000000    Serial number: 62608000001067
   Coding: 250793915426216E407B060260CA68A4C92A8402600616763443F0B1C0A9430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_SK37.rod
   VCID: 78A9EAD30253B3D7A6B-802C
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0494442355
   Coding: 032C0C0623
   Shop #: WSC 73430 790 00063
   VCID: 43D34D3F0B15200FC39-8016
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 02110004000100011005000C0010102A
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 74B1DEE31E3BD7B78A3-8020
   Part No SW: 5Q0 937 086 BR    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 865828091800T0
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0B43A51F63C5A84FFB9-805E
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180817  051 0916
   Serial number: 887253F0401822902086
   Coding: 164DDD
   Component: RLHS  052 0107
   Serial number: SAY18M10D04H00M16S03
   Coding: 00885D
   Sun Roof:
   Subsystem 3 - Part No SW: 5E9 959 591 B    HW: 6R0 959 591 D
   Component: J245 PS24.402  H04 0005
   Serial number: 0000FST00263W4B00000
   Coding: 991800
   Roof Blind:
   Subsystem 4 - Part No SW: 5E9 959 591 C    HW: 8V3 959 591 A
   Component: J394 PS24.402  H04 0005
   Serial number: 0000FST00267U9I00000
   Coding: 991800
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618199
   Coding: 0371167041
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 51FF7777C169C29F415-8004
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B0060C141FFC428949C810510300600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14E230E1B2737FA3-8010
   Serial number: 18081841350097
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292AD342D373D766B-806C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PL3YSN1
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0557932745A1DE3FADD-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 001 309 18
   Serial number: 3570000000053C8C423L
   Subsystem 2 - Part No SW: -----------    HW: 454 001 509 18
   Serial number: 3580000000080C4D423J
   Subsystem 3 - Part No SW: -----------    HW: 454 802 209 18
   Serial number: 35100F8BA7116000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 801 809 18
   Serial number: 35200B0016516000000/
   Subsystem 5 - Part No SW: -----------    HW: 454 802 808 18
   Serial number: 355002D828F15000000O
   Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF036036    Serial number: 20181004500795
   Coding: 6404
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F6C3366B9FF7C23-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 60
                    Mileage: 10 km
                    Date: 2018.12.17
                    Time: 08:39:39
                    Ubat 30 Voltage: 14.40 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 239
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
   Part No SW: 5E0 920 756 F    HW: 5E0 920 756 F
   Component: KOMBI         312 2501
   Coding: 27AD09107D800008018A6B0B5001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009066
   VCID: 2D070B87BD91C67F05D-8078
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008603853
   Coding: 030100047F085900EB0002FB880F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D273BC76DF156FFB5D-8068
   Subsystem 2 - Part No SW: 3V0 919 719 G    HW: 3V0 919 719 G
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000D1671310718
   Serial number: 758860020018100108E7
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000310569012
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F17F7A1A9A29F215-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00029.06.18
   Coding: 0201
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD787BC46FB98778F-8006
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RID28326
   Coding: 0014000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Component: HRE_Master    H12 0081
   Serial number: 0494258472
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0494016392
   Coding: 020112
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000346798352
   Coding: 001D0920DE01020000001100
   VCID: 48C95A133233035716B-801C
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000024492932
   Coding: 1D0200
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2136C376EB5FF7823-8068
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1JJE05UKBU
   Coding: 0373020000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EF8F5799998ADFB95-800C
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 04101810520845
   Coding: 000000070900046E06003D01010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353723E755C18EBF7DD-8060
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000346744628
   Coding: 001D0120DE01020000001100
   VCID: 47CB592F3F2D0C2F1F1-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000024563100
   Coding: 050200
   Part No SW: 565 035 045 C    HW: 565 035 045
   Component: MU-H-N-RW     H55 1382
   Serial number: A858I0JS004953
   Coding: 037352080000000041510002000000002F0101E601200500FF
   VCID: 1471BE633EFB77B72A3-8040
   Subsystem 1 - Part No SW: 5E0 919 606 D    HW: 5E0 919 606 D
   Component: ABT_High-2  H52 9130
   Serial number: SKZ6ZHV2794967
   Subsystem 2 - Part No SW: V03 959 801 KE    HW: -----------
   Component: ROW 2018/2019  --- 0071
   Component: Gracenote2  --- 4013
   Component: RVC Compact   H15 0231
   Coding: 047302010600201F000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
   VCID: 392F2FD779D96ADF995-806C
   Part No SW: 5E0 959 107 B    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0747
   Revision: 42001003    Serial number: 251801282
   Coding: 1233074002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2B03059F8385C84F1B9-807E
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 27081841K23041
   Coding: 020307020000010100022354C150A90084000E200000
   VCID: 08499A1372B3C357D6B-805C
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0002
   Serial number: 180904200061
   VCID: 698FBF9749F91A5F295-803C
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_SK26.rod
   VCID: 7EA5FCCB20778DE7EC7-802A
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_SK26.rod
End----------(Elapsed Time: 02:05, VBatt start/end: 12.1V/12.1V)-----------
darkchina811
ITALY
C?ID=333184
congratulations for the new car. funny on how the dealer will deliver a car which is not clear of faults.
SkodaNZ
New Zealand
C?ID=353136
Thought it was a little weird but granted the Engine Fault Code (unknown) only came up at 500 odd kms, the Steering Wheel one at 10km lines up with when the car was still being prepared by the dealer so would have thought they'd clear that one.
Engine fault should be: "Neutral Position Sensor 1", but it is flagged "Intermittent - Not Confirmed". Try un-checking "Use Agressive Mode" and see if it's still there.
I'm puzzled why a car with a manual trans would throw this fault at all.
golfi_vend
Tartu, Estonia
C?ID=195131
For Start/Stop to determine that Neutral gear is selected. Sensor/Switch is located on gearbox selection tower.
SkodaNZ
New Zealand
C?ID=353136
Will try next time and see if theres any difference.
Emailed through my Auto-Scan and AdMaps for 17, 5F and 09; I think there were quite a few missing labels etc. or * No Label File so hoping those will help in the future.
automech
Poland
C?ID=14925
Hi, can you send me 09 adpmaps? I'm doing full led retrofit and it would help me a lot :)
SkodaNZ
New Zealand
C?ID=353136
Sure, PM with email address and Ill send them through
