Results 1 to 10 of 12
Thread: 2005 A6 C6 faults
    Jan 2019
    Indiana
    2005 A6 C6 faults
    Greetings to all! Not new to VAG, but new to hex-net and still learning how to use it. This is a scan off a 2005 A6 3.2 saloon.
    Cleared faults on 1-6-2019 with a OBD11, which explains that date. Can read what I found and think, or skip to scan.
    07: 01964 - Control Module for Seat & Steering Column Memory (J136)
    Memory in drivers seat 1, 2 work. Not sure what steering column means, it's manual to adjust.
    08: 00256 - A/C Pressure/Temperature Sensor (G395)
    Low on freon I would assume? Can it be checked by vcds?
    09: Address 0F: Digital Radio Cannot be reached
    Is this the tuner/radio? It works fine.
    15: 2 Faults Found:
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    007 - Short to Ground - Intermittent - MIL ON
    008 - Implausible Signal - Intermittent - MIL ON
    I've come to the conclusion that this is most likely a broken wire between the body and door? This error started last couple of weeks.
    19: 2 Faults Found: 01044 - Control Module Incorrectly Coded
    02230 - Digital Radio (DAB) (R147) 004 - No Signal/Communication
    I'm lost on this one, for real.
    61: 4 Faults Found 02273, 02274, 02276, 02277
    This was a new battery installed prior to me getting the car. Don't think it was ever adapted to the car by seller, but the problem I'm having is slow battery drain.
    The MMI Car version is
    SW: C6-HU 6360 10.7.0 0437
    HW: c6-HU 6360D2.0
    FC SW: 041144AFC6AB320010
    FC PS:0010 FC HW: h07
    3.2 had the following work done to it past summer before seller/friend (who did the work due to failed tensioner) sold it to me for a tenth of what they were new. New exhaust, intake valves, machined and cleaned cylinder heads, head gasket kit, head bolts, timing kit, camshaft adjusters, camshaft oil control actuators, O.E. spark plugs, ignition coils, rear main seal. Don't know if this info pertains to the faults, but added it just in case. Friend does not have a vcds, but rather a snap-on verus european software.
    So that's where I stand. Sorry for the long rant, and thanks for taking the time to read this. Any help or direction would be appreciated. I wrench on my all machines, so not afraid to tackle a task.
    Sunday,13,January,2019,16:03:09:45417
    VCDS Version: 18.9.0.4 (x64)  HEX-NET CB: 0.4437.4
    VIN: WAUDG74F35N094886   License Plate:
    Mileage: 182750km-113555mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 72 77
    VIN: WAUDG74F35N094886   Mileage: 182750km-113555miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    37-Navigation -- Status: Not registered 0001
    Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
       Part No SW: 4F1 910 559 B    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0050
       Revision: --H15---    Serial number:
       Coding: 01050106190F0120
       Shop #: WSC 02325 785 00200
       VCID: 2A1805CE854E401AA5-807E
       Part No SW: 4F1 910 156 H    HW: 09L 927 156
       Component: AG6 09L 3.2 FSI USA 0020
       Revision: --H01---    Serial number:        0092061
       Shop #: WSC 02327 785 00200
       VCID: 291AFAC280484B02AC-807C
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Coding: 0020895
       VCID: 2D120ED2B4A0572240-8078
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10602901714383
       Coding: 0000011
       Shop #: WSC 06158 444 105036
       VCID: 2502F6F2EC506F6288-8070
       Subsystem 1 - Part No: 4F0 910 131 J
       Component: FBSAUDIC6 EZS   H43 0070
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H36 0040
       Part No SW: 4F0 910 730 E    HW: 4E0 035 729
       Component: Interfacebox    H43 1070
       Revision: 00000000    Serial number: 360AB057515420
       Coding: 0000003
       Shop #: WSC 12345 111 45725
       VCID: 2306E8EAE2649152E6-8076
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000099393
       Subsystem 3 - Serial number: 0119.01.050000000100010155ÿ
       Subsystem 4 - Serial number: 010155ÿ
                        Fault Frequency: 10
                        Reset counter: 84
                        Mileage: 182611 km
                        Date: 2019.01.06
                        Time: 12:02:34
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000025    Serial number: 00000000106531
       Coding: 0524326
       VCID: 5BF6900A9A94E992EE-800E
                        Reset counter: 79
                        Mileage: 182620 km
                        Date: 2019.01.06
                        Time: 14:05:27
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0013123
       Shop #: WSC 02335 785 00200
       VCID: 6680B1FE51D6A47A41-8032
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBD7107320
       VCID: 1B76D00ADA14A9922E-804E
       Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
       Component: 56 AIRBAG AUDI8RH29 0310
       Revision: 10H29000    Serial number: 00359D086M3Q
       Coding: 0013622
       Shop #: WSC 06158 444 83892
       VCID: 2600F1FE9156647A81-8072
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 633  SME
       Subsystem 3 - Serial number: 6342CSME077646091
       Subsystem 4 - Serial number: 6351HSME057B1775A
       Subsystem 5 - Serial number: 6361HSME0623740E4
       Subsystem 6 - Serial number: 6371VSME05761A11E
       Subsystem 7 - Serial number: 6381VSME060301284
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026050150270
       Coding: 0002041
       Shop #: WSC 02323 785 00200
       Component: Lenkradmodul    H06 0080
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
       Component: KOMBIINSTR. M73 H10 0570
       Revision: 00200000    Serial number: 4R814WJ15
       Coding: 2113203
       VCID: 1E70D91EC906BCBAC9-804A
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
       Revision: 09          Serial number: 08008051230175
       Coding: 6CFE73CC1B1904
       Shop #: WSC 11111 123 12345
       VCID: 271EFCFA965C7D72BA-8072
                        Reset counter: 34
                        Mileage: 182587 km
                        Date: 2019.01.05
                        Time: 15:17:50
                        Reset counter: 34
                        Mileage: 182587 km
                        Date: 2019.01.05
                        Time: 15:18:45
       Coding: 0082946
       VCID: 618AA2E2B8F8C342B4-8034
       Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
       Component: MNS US          H51 0990
       Revision: 00000000    Serial number: 395AU087508408
       VCID: 312A12A2A89833C264-8064
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00-00000
       Coding: 0035563
       Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
       Component: Komfortgeraet   H15 0100
       Revision: 01000015    Serial number: 01002508770000
       Coding: 0423997
       VCID: 2C1403D68FBA5E2A57-8078
       Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
       Component: DSP-High C6     H14 0310
       Revision: PROD_01     Serial number: 00000000021668
       Coding: 0000016
       VCID: 2404EBF6E76A966A9F-8070
       Component: ILM Beifahrer   H09 0050
       Revision:             Serial number: 00000000059538
       Coding: 0001114
       VCID: 5EF0991E8986FCBA89-800A
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00-00000
       Coding: 0035563
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       Shop #: WSC 02334 785 00200
       VCID: 5DF29E128480E7A290-8008
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Coding: 0000016
       Subsystem 1 - Part No: 4F0 941 329 A
       Component: AFS-Modul links H05 0010
       Subsystem 2 - Part No: 4F0 941 329 A
       Component: AFS-Modul rechtsH05 0010
       Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 394AO057512627
       Component: ENERGIEMANAGER  H12 0470
       Revision: 00000000    Serial number: 00000000008308
       Shop #: WSC 06158 444 58780
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  2501260391
       Coding: 344630393135313035432056413032353031323630333931
       Shop #: WSC 00000 384 00290
                000 -  -  - Intermittent
                        Fault Frequency: 11
                        Mileage: 182611 km
                        Date: 2019.01.06
                        Time: 05:29:50
    02276 - Quiescent Current Stage 5
                        Fault Frequency: 10
                        Mileage: 182611 km
                        Date: 2019.01.06
                        Time: 05:30:01
    02274 - Quiescent Current Stage 3
                        Fault Frequency: 10
                        Mileage: 182611 km
                        Date: 2019.01.06
                        Time: 05:30:11
                        Fault Frequency: 10
                        Mileage: 182611 km
                        Date: 2019.01.06
                        Time: 05:30:21
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H09 0010
       Coding: 0035370
       VCID: 699ABAC240C88B026C-803C
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H09 0010
       Coding: 0035370
       Part No SW: 4F0 910 336 A    HW: 4E0 862 335
       Component: Handyvorb2      H10 0120
       Revision: 00000000    Serial number: 00000007513912
       Coding: 0010900
       Shop #: WSC 02313 785 00200
       VCID: 210AE2E2F8788342F4-8074
    End----------(Elapsed Time: 01:46, VBatt start/end: 14.1V/14.1V)-----------
    Let's start with the easiest one first. Looks like someone has removed the Satellite Radio tuner without informing the Gateway. To fix:
    [Select]
    [19-CAN Gateway]
    [Installation List]
    Scroll down to 0F: Digital Radio and un-check it.
    [Save Coding].
    A bunch of your other fault codes are flagged "Intermittent". That means the fault condition that set the code did not exist (or could not be detected) at the time the scan was performed. Clear 'em and see if/when they come back.
    The faults in 61 are pretty normal if the battery was ever low. Have a look at Battery History Data.
    [Applications]
    [History Data]
    Select 61 (not 19) and let it read the data.
    There should be an Analyze button, or you can post the data here.
  3. Likes PetrolDave liked this post
    Jan 2019
    Indiana
    Thx Uwe for quick reply and advice.
    Unchecked 0F in Gateway list, clear and new scan. Btw, charged battery to full, it was at 27% according to charger. It drains daily if I drive it or not. Will do a fresh scan Tuesday after running it on the road.
    Question-What does shop # mean?
    Monday,14,January,2019,19:49:26:45417
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
              55 56 61 62 72 77
       Coding: 0020895
       Coding: 0000011
       Coding: 0000003
       Coding: 0524326
       Coding: 0013123
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Coding: 0013622
       Subsystem 2 - Serial number: 6332CSME08710040O
                007 - Short to Ground - MIL ON
       Coding: 0002041
       Coding: 2113203
       Coding: 6CFE73CC1B1104
                        Reset counter: 44
                        Mileage: 182751 km
                        Date: 2019.01.14
                        Time: 19:45:52
       Coding: 0082946
       Revision: 00-00000
       Coding: 0035563
       Coding: 0423997
       Coding: 0000016
       Coding: 0001114
       Revision: 00-00000
       Coding: 0035563
       Revision: C63C0030
       Coding: 0005022
       Coding: 0000016
       Coding: 0035370
       Coding: 0035370
       Coding: 0010900
    End----------(Elapsed Time: 01:43, VBatt start/end: 14.1V/14.1V)-----------
    And battery history.
    ;Monday,14,January,2019,19:38:41:45417
    ;                Address 61: Battery Regul.
    ;Control Module Part Number: 4F0 910 181 E
    ;  Component and/or Version: ENERGIEMANAGER  H12 0470
    ;           Software Coding:
    ;            Work Shop Code: WSC 06158
    ;                      VCID: 2306E8EAE2649152E6-8076
    ;           Additional Info: 4F0915105C  von VA0  2501260391
    ;           Additional Info: Geraet 58780
    ;History Data
    Record 1/18: No-load voltage underranging
    2019-01-13,18:00:00*0021*001**
    2019-01-12,21:00:00*0018*001**
    2019-01-12,12:00:00*0001*001**
    2019-01-10,13:00:00*0046*001*41914***
    2019-01-13,12:00:00*0003*001**
    2019-01-10,13:00:00*0046*001*10804***
    2004-10-05,14:00:00*0008*001**
    2004-10-24,15:00:00*0207*001**
    2004-10-22,19:00:00*0043*001**
    2004-10-22,11:00:00*0002*001*00880***
    Record 2/18: No-load current overranging
    2019-01-14,19:00:00*0000*02.66*001**
    2019-01-14,16:00:00*0000*01.78*001**
    2019-01-12,18:00:00*0000*01.33*001**
    2019-01-12,14:00:00*0000*00.00*001**
    2019-01-12,13:00:00*0000*02.49*001**
    2019-01-12,11:00:00*0001*00.75*001**
    2019-01-08,20:00:00*0001*00.58*001**
    2019-01-06,05:00:00*0001*00.72*001**
    2019-01-03,20:00:00*0001*00.71*001**
    2019-01-03,14:00:00*0001*00.90*001*06418***
    Record 3/18: Energy-critical vehicle states
    00.00*07.52*-08.95*38*04*+9999*-03565*180165*2004-10-11,08:24:40*0-0-0-0-0-0*00.0*00.0*000.0*00*01*01*001**
    Record 4/18: Shut-off stage history
    6*2*+00.56*36*2019-01-14,19:26:19*0-0-0-0-0-0*00.0**
    3*2*-02.20*40*2019-01-14,16:23:14*0-0-0-0-0-0*00.0**
    5*2*-02.30*40*2019-01-14,16:23:04*0-0-0-0-0-0*00.0**
    2*2*-02.40*40*2019-01-14,16:22:54*0-0-0-0-0-0*00.0**
    6*0*+00.75*65*2019-01-12,18:24:38*0-0-0-0-0-0*00.0**
    3*2*-06.00*37*2019-01-12,13:50:40*0-0-0-0-0-0*00.0**
    5*2*-06.00*37*2019-01-12,13:50:30*0-0-0-0-0-0*00.0**
    2*2*-05.60*37*2019-01-12,13:50:20*0-0-0-0-0-0*00.0**
    6*2*-00.37*37*2019-01-12,13:47:11*0-0-0-0-0-0*00.0**
    3*2*-05.00*37*2019-01-12,11:22:55*0-0-0-0-0-0*00.0**
    5*2*-05.00*37*2019-01-12,11:22:45*0-0-0-0-0-0*00.0**
    2*2*-05.30*37*2019-01-12,11:22:35*0-0-0-0-0-0*00.0**
    6*0*-00.05*33*2019-01-10,06:00:17*0-0-0-0-0-0*00.0**
    3*2*-05.00*45*2019-01-09,19:00:18*0-0-0-0-0-0*00.0**
    5*2*-05.10*45*2019-01-09,19:00:08*0-0-0-0-0-0*00.0**
    Record 5/18: Battery change history
    000*2501260391*2000-01-01,00:00:00*+00000*+0000**
    000*----------*2000-01-01,00:00:00*+00000*+0000**
    Record 6/18: Energy balances (last 5 trips)
    +000.3*000.1**
    +000.2*000.0**
    +000.1*000.0**
    +000.1*000.3**
    +000.5*000.3**
    Record 7/18: Energy balances (last 5 standing times)
    +000.3*026.6**
    -001.3*020.1**
    -000.3*000.0**
    -000.1*000.0**
    +000.9*054.6**
    Record 8/18: Battery manipulation (e.g. charging)
    -009.5*001**
    Record 9/18: Battery aging
    0000.2*0000.5
    Record 10/18: Dynamic energy management
    00.0*00.0
    Record 11/18: Recuperation
    0064.16*0000.00*0000.00*0000.00
    Record 12/18: Start-Stop
    00.00*00.00*00.00*00.00
    Record 13/18: Sporadic alternator faults
    0028.8*0034.8
    Record 14/18: Small battery for hybrid vehicle
    00.0*00.0
    Record 15/18: Local activ.
    99*99*32*02*99
    Record 16/18: Vehicle energy balance
    00*99*00*00*00
    Record 18/18: Date reprogramming in instrument cluster
    15**
    2000-01-01,12:00:00*2012-11-04,19:00:00**
    2012-11-04,19:00:00*2000-01-01,12:00:00**
    2005-01-07,00:00:00*2005-05-09,08:00:00**
    2000-01-01,12:00:00*2004-10-05,12:00:00**
    I previously missed the fact that your 37-Navigartion is "Not Registered'. Please repeat the process in the Gateway, but put a check-mark next to 37-Navigartion.
    You've clearly got No-load current overranging events happening with some regularity, but it's no clear why.
    If I'm reading the Battery History correctly, this car has never been told it has a new battery, and given that it's a 2005, I would think the one that was recently installed is at least the second replacement. I would head for the 61-Battery Regul, select the first sub-system, and either enter the BEM code (assuming the battery has one) or at least change one digit in the existing serial number using the battery coding assistant:
    Oh, and where/how are you connecting the charger? The jump-start terminals under the hood are good; connecting directly to the battery terminals isn't. You can connect directly to the battery's positive terminal, but the negative lead of the charger must be connected to the chassis of the car, not the negative battery terminal, otherwise the 61-Battery module won't "see" the battery's charge being replenished.
  6. Likes Jack@European_Parts liked this post
    Jan 2019
    Indiana
    If I'm not mistaken, Navi is checked, but I'll double check here in a few hours. It comes up on the MMI, but seems to be off by a few hundred yards on its location.
    Under the hood to charge. No BEM sticker. Duracell battery, part no. 49 (H8) CA@32°F 1080 CCA@0°F 900 with a UPC of 8399630015. No other info visible on top. I research everything if I'm not sure, and have the factory OEM complete service/repair manual for 2005 A6 which includes saloon and Avant and all engines, trans. of all platforms for that year. 11,725 pgs. in .pdf if you would like a copy.
    Quote Originally Posted by budvidua View Post
    Well, this:
    Makes me pretty confident it isn't checked.
    OK, just change the serial number of the battery then. That will cause the battery module in think there's a fresh battery installed.
  9. Likes budvidua liked this post
  10. #7
    Jan 2019
    Indiana
    Well, this:
    You were correct sir, 37-Navigation wasn't checked. Done and status ok.
    Battery-I tried changing last few digits in serial number but it won't accept it. Brings up the VCDS: Re-code Invalid box. Does give 3 options of [Yes] for vcds to use default values, [NO] to try current values, and cancel to manually edit. Haven't read anything here, or I'm missing it. https://forums.ross-tech.com/showthr...ry-Replacement
    Tuesday,15,January,2019,20:23:15:45417
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
              55 56 61 62 72 77
    VIN: WAUDG74F35N094886   Mileage: 182780km-113574miles
       VCID: 2A1805CE854E401AA3-807E
       VCID: 291AFAC280484B02AA-807C
       Coding: 0020895
       VCID: 2D120ED2B4A0572246-8078
       Coding: 0000011
       VCID: 2502F6F2EC506F628E-8070
       Coding: 0000003
       VCID: 2306E8EAE2649152E0-8076
                        Reset counter: 85
                        Mileage: 182751 km
                        Date: 2019.01.15
                        Time: 17:29:19
       Coding: 0524326
       VCID: 5BF6900A9A94E992E8-800E
                        Reset counter: 85
                        Mileage: 182768 km
                        Date: 2019.01.15
                        Time: 18:12:49
       Coding: 0013123
       VCID: 6680B1FE51D6A47A47-8032
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       VCID: 1B76D00ADA14A99228-804E
       Coding: 0013622
       VCID: 2600F1FE9156647A87-8072
       Coding: 0002041
       Coding: 2113203
       VCID: 1E70D91EC906BCBACF-804A
       Coding: 6CFE73CC1B3104
       VCID: 271EFCFA965C7D72BC-8072
                        Reset counter: 84
                        Mileage: 182751 km
                        Date: 2019.01.14
                        Time: 19:45:52
       Coding: 0082946
       VCID: 618AA2E2B8F8C342B2-8034
       VCID: 312A12A2A89833C262-8064
       Revision: 00-00000
       Coding: 0035563
       Coding: 0423997
       VCID: 2C1403D68FBA5E2A51-8078
       Coding: 0000016
       VCID: 2404EBF6E76A966A99-8070
       Coding: 0001114
       VCID: 5EF0991E8986FCBA8F-800A
       Revision: 00-00000
       Coding: 0035563
       Revision: C63C0030
       Coding: 0005022
       VCID: 5DF29E128480E7A296-8008
       Coding: 0000016
                        Mileage: 182751 km
                        Date: 2019.01.14
                        Time: 19:54:05
                        Mileage: 182751 km
                        Date: 2019.01.14
                        Time: 19:54:15
                        Mileage: 182751 km
                        Date: 2019.01.14
                        Time: 19:54:25
                        Mileage: 182751 km
                        Date: 2019.01.14
                        Time: 19:54:35
       Coding: 0035370
       VCID: 699ABAC240C88B026A-803C
       Coding: 0035370
       Coding: 0010900
       VCID: 210AE2E2F8788342F2-8074
    End----------(Elapsed Time: 01:44, VBatt start/end: 14.2V/14.1V)-----------
    Edit: The battery I tried to change last digit serial number is the one that looks like might have been original. Calling Duracell (East Penn) today to see if they can provide BEM for that battery.
  11. #8
    I'd recommend the manual edit. Use your ZIP code as the WSC, 444 as the Importer Number, and some random 5-digit value as the Equipment Number (for the last five digits of your interface serial number).
  12. Likes budvidua liked this post
  13. #9
    Jan 2019
    Indiana
    That did it, ty sir! Filled the blanks as advised and changed last serial number. Fake it and make it still holds true. I had read that WSC needed setup few weeks ago, but got way ahead of myself in reading everything else on here. You're sharp, and much appreciated.
    08-Is likely low freon. I'll deplete and recharge once I check manual for correct ozs.
    15-Maybe frayed/broke wire in harness from door to body? I've read that's a common problem.
    Question-Are there values for window speed up/down? Driver and pass are same speed, which is slow, rear L-R are much faster. Don't know if that's the way Audi set them up.
    Thursday,17,January,2019,18:37:07:45417
    Workshop Code: 444 46561 004666
    Mileage: 182810km-113592mi   Repair Order: 1/17/19-1
              55 56 61 62 72 77
    VIN: WAUDG74F35N094886   Mileage: 182810km-113592miles
       Coding: 0020895
       Coding: 0000011
       Coding: 0000003
       Coding: 0524326
                        Reset counter: 88
                        Mileage: 182786 km
                        Date: 2019.01.17
                        Time: 16:42:38
       Coding: 0013123
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Coding: 0013622
       Coding: 0002041
       Coding: 2113203
       Coding: 0082946
       Revision: 00-00000
       Coding: 0035563
       Coding: 0423997
       Coding: 0000016
       Coding: 0001114
       Revision: 00-00000
       Coding: 0035563
       Revision: C63C0030
       Coding: 0005022
       Coding: 0000016
       Component: von VA0  2501260392
       Coding: 344630393135313035432056413032353031323630333932
       Shop #: WSC 46561 384 00290
       Coding: 0035370
       Coding: 0035370
       Coding: 0010900
    End----------(Elapsed Time: 01:42, VBatt start/end: 13.9V/14.1V)-----------
    ;Wednesday,16,January,2019,20:24:20:45417
    ;           Software Coding:
    ;                      VCID: 2306E8EAE2649152E0-8076
    ;           Additional Info: 4F0915105C  von VA0  2501260392
    ;History Data
    2019-01-15,22:00:00*0021*001**
    2019-01-14,21:00:00*0019*001**
    2019-01-12,21:00:00*0018*001*41954***
    2019-01-13,12:00:00*0003*001*10844***
    2019-01-16,19:00:00*0000*06.00*001**
    2019-01-03,20:00:00*0001*00.71*001*06418***
    6*0*-00.03*38*2019-01-16,19:46:58*0-0-0-0-0-0*00.0**
    3*2*-05.10*32*2019-01-15,20:29:19*0-0-0-0-0-0*00.0**
    5*2*-05.10*32*2019-01-15,20:29:09*0-0-0-0-0-0*00.0**
    2*2*-04.60*32*2019-01-15,20:28:59*0-0-0-0-0-0*00.0**
    6*0*-00.63*32*2019-01-15,19:46:55*0-0-0-0-0-0*00.0**
    3*4*-05.00*17*2019-01-15,18:46:19*0-0-0-0-0-0*00.0**
    5*4*-05.10*17*2019-01-15,18:46:09*0-0-0-0-0-0*00.0**
    2*4*-04.60*17*2019-01-15,18:45:59*0-0-0-0-0-0*00.0**
    6*6*-03.84*17*2019-01-15,18:38:39*0-0-0-0-0-0*00.0**
    3*6*-05.10*17*2019-01-15,18:33:52*0-0-0-0-0-0*00.0**
    5*6*-05.00*17*2019-01-15,18:33:42*0-0-0-0-0-0*00.0**
    2*6*-04.70*17*2019-01-15,18:33:32*0-0-0-0-0-0*00.0**
    6*6*-03.93*17*2019-01-15,18:12:31*0-0-0-0-0-0*00.0**
    3*6*-05.10*17*2019-01-15,18:02:48*0-0-0-0-0-0*00.0**
    5*6*-05.00*17*2019-01-15,18:02:38*0-0-0-0-0-0*00.0**
    001*2501260391*2019-01-16,00:00:00*-03619*-9999**
    +000.0*000.0**
    +000.4*000.2**
    +000.3*000.0**
    +000.4*000.2**
    +000.4*000.5**
    -001.4*023.1**
    +000.0*000.0**
    -001.0*001.0**
    -000.3*000.0**
    -000.3*000.0**
    +000.2*002**
    0000.0*0000.0
    00.0*00.0
    0000.00*0000.00*0000.00*0000.00
    0000.0*0000.0
    00.0*00.0
    00*99*00*00*00
    00*99*00*00*00
    15**
    ;Wednesday,16,January,2019,20:24:39:45417
    ;           Software Coding:
    ;History Data
    +000.0*000.0**
    +000.4*000.2**
    +000.3*000.0**
    +000.4*000.2**
    +000.4*000.5**
    -001.4*023.1**
    +000.0*000.0**
    -001.0*001.0**
    -000.3*000.0**
    -000.3*000.0**
    +000.2*002**
    0000.0*0000.0
    00.0*00.0
    0000.0*0000.0
    00.0*00.0
    00*99*00*00*00
    00*99*00*00*00
    15**
  14. Likes Uwe liked this post
  15. #10
    I'm not aware of anything that can change the speed of the windows. I'll ask my daughter to check the one she drives (also a 2005) whether it behaves the same.
  16. Likes budvidua liked this post
