Results 1 to 9 of 9
Thread: 2014 VW Touareg TPMS reset question
    Jan 2019
    Canada
    Hey guys,
    New here, hopefully someone can help! Searched online for days with no answers ...
    I have a 2014 Touareg, Using my VCDS I want to have my car scan for TPMS sensors. I currently have a fault code saying the system was deactivated since I installed tires without TPMS sensors (winter wheels). Instead of having to drive the car. I want to reset the system?
    How to???
    Thanks,
    Mark
    How and by whom was it de-activated?
    I just looked at the data for a 2015 Touareg TPMS, which I assume is practically the the same as yours. I do not see any way to force it to scan for sensors.
    I'm still curious how it was "deactivated" though. So please post an Auto-Scan for context.
    Apr 2018
    ITALY
    when I retrofitted the active system, I was wondering how I was gonna pair the sensors to the TPMS ECU, because there is no explicit command to do that. I found out that the ECU learned the sensors automatically after I drove the car a little bit.
    I had bought the ECU used, so it was originally paired to other sensors.
    I assume it just scans and sees if sensors are in range, and it pairs to the strongest signal, which would mean the closest four. go figure.
    long story short, just try driving.
    Apr 2015
    South Africa
    I far as my knowledge is, In South Africa Touareq TPMS work through ABS contr module and there is no way one can alter/program different pressures.
    Quote Originally Posted by RyMar View Post
    I am skeptical. Have you got a scan from one that works like that?
  7. #7
    Jan 2019
    Canada
    The TPMS system deactivates
    Itself when it doesn’t detect any sensors present ... (winter wheels have no TPMS sensors.
    I was hoping I could wake up the system using my VCDS. I guess not ;(.
    Thanks,
    Mark
  8. #8
    Apr 2015
    South Africa
    Scan: Wanted to adjust TPMS shown in instrument cluster/radio but no functions available.
    Thursday,22,November,2018,15:15:53:48706
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: RyMar Auto
    Workshop Code: 000 00000 001753
    VIN: WVGZZZ7PZED046597   License Plate: DCH031L
    Mileage: 122287km-75985mi   Repair Order:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 34 36 42 46 52 53 55 56
              5F 62 65 69 6C 6D 72
    VIN: WVGZZZ7PZED046597   Mileage: 122287km-75985miles
    Address 01: Engine (J623-CRCA)       Labels: None
       Part No SW: 7P1 907 401 D    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H41 0001
       Revision: 53H41---
       Coding: 292A4012233E01020000
       Shop #: WSC 01753 996 00000
       ASAM Dataset: EV_ECM30TDI0117P1907401D 001002
       ROD: EV_ECM30TDI0117P1907401D.rod
       VCID: 312AF029609718C26A-8064
       Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
       Component: AL1000 AISIN  002 2530
       Coding: 003568
       Shop #: WSC 28742 001 1048576
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_002.rod
       VCID: 7CB4111DF75525AA89-8028
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
       Component: MK25A         H36 0446
       Revision: --------    Serial number: 404240010EC815
       Coding: 5B6B13C30B282559DAF9C89CD0D9A450F700
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 4AD887C5ED014B1A4B-801E
       Part No SW: 4H0 907 064 EM    HW: 4H0 907 064 EM
       Component: BCM2 2.0      H36 0521
       Coding: 01B60010000000000000
       VCID: 78BC0D0DCB6D098AED-802C
       Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
       Component: FBSTOUAREGIDG  H08 0084
       Serial number: 0514000051769009
       Serial number: 0214000081006012
       Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
       Component: Klima 2 Zonen H21 1306
       Coding: 36A6200A90
       VCID: 054274F9849F6462E6-8050
       Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
       Revision: 15012002    Serial number: 00000001740004
       Coding: 26001010D1345D010021000300005D0C431D670807010241000000020000
       VCID: 6C94215D8F35B52A19-8038
       Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
       Component: WWS    140422  033 0021
       Serial number: 90243401140429215255
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 20307858
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
       Component: E1 - LDS  H04 0031
       Serial number: 00000000002904140357
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       VCID: 23060A61226BBA52E8-8076
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H05 0026
       Revision: --------    Serial number: 28231412301050
       Coding: 318501
       ASAM Dataset: EV_VW526ParkiAssis2 001012
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 43C6AAE1CA2B9A5288-8016
       Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
       Component: VW10Airbag06D H06 0026
       Revision: --------    Serial number: 003L5005CTE3
       Coding: 000000000000000000000000000000003644
       VCID: 42C8AFE5D531935A83-8016
       Serial number: 3575LRB40552E3MI39LD
       Serial number: 3585LRB40572E3MI6OR/
       Serial number: 3515RRB400O52JN2J0FK
       Serial number: 3525RRB400S52JN2OI1Y
       Serial number: 3555NRB400250V9SA242
       Serial number: 3565NRB400E50V9SFOD8
       Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
       Revision: --------    Serial number: 01335NE1000S1
       Coding: 000C35
       VCID: 383CCD0D8BEDC98A2D-806C
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H04 0028
       Serial number: 0045905 TRW 20140402
       Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
       Component: Kombi         H13 0419
       Revision: 13240270    Serial number: 658080514592027
       Coding: 333733003B00000800000C
       ASAM Dataset: EV_KombiUDSRBVW526 001020
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 47DEBEF1FE13B67254-8012
       Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6032
       Revision: --------    Serial number: 00000001374592
       Coding: 000D07AD00
       ASAM Dataset: EV_GatewVW526UDS 001007
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3FCEA611A6C3FEB2EC-806A
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 31114N33345701138474
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
       Serial number: 14120003127011200181
    Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
       Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
       Component: PASM          H04 1800
       Revision: 00000000    Serial number: 00000141140089
       Coding: 14210000
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
       VCID: 76A00335C9797FFAFF-8022
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000099030547
       Coding: 0078130000004001000001010101202020202121202020
       VCID: 3424F93D97852DEA01-8060
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000100967564
       Coding: 011D0620DE01451005080002
       VCID: 7AB81705F5611B9A9B-802E
       Revision: 00002001    Serial number: 0333874429
       Coding: 019A162228B9108080200624210000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000100984247
       Coding: 011D0620DE01451005080000
       VCID: 48DCBDCDFB0DB90A5D-801C
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1450200505
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 3620C33589F93FFA3F-8062
       Slave 3:
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 01AE00000F000200
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0003
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0006
       Coding: 130000
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 227EV0E8002348
       Coding: 060005020100000003
       VCID: 2600137551594F7A8F-8072
       Part No SW: 7P6 035 764 E    HW: 7P6 035 764 A
       Component: H-BNT-RW      H40 0816
       Revision: --------    Serial number: 445D-0E7501268
       Coding: 010901050040E1EF41002B0E00000003F00001030000000000
       VCID: 3B36D201BADBE292C0-806E
       Subsystem 1 - Part No: 8R0 060 884 BN
       Component: ROW 2014  0605
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9PA2014VT
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: CD-Database  5571
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000101610730
       Coding: 011806200001251005080000
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000133952
       ROD: EV_RDKBERU25_VW52.rod
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 J    HW: 7P0 907 383 C
       Component: Anhaenger     H11 0130
       Revision: 5H001001    Serial number: 00008200334952
       Coding: 0106040000000000
       VCID: 3FCEA611AEC3FEB2EC-806A
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H08000    Serial number: 525 PA8J441430
       Coding: 0030001
       VCID: 373ECE3146F3C6F224-8062
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 114400584
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202142
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000101713126
    End----------(Elapsed Time: 02:11,
  9. #9
    Hmm, this one is different than the similar one I looked at yesterday. It has this Basic Setting:
    IDE03536-ENG100805 Tire pressure sensor communication check - SchneltriggermodeStart
    That looks relatively promising.
    FWIW, the one I looked at yesterday was from an NAR 2015 model. I wonder if the difference, specifically the "Self De-activating" is due to the TPMS being a regulatory requirement here and not there?
