Results 1 to 10 of 10
Thread: Enable HBA on MLBevo cars
    Jun 2017
    Hi all,
    this script applies to all new Audi MLBevo cars like Audi A4 B9
    It enables the simple High Beam Assist when absolutely no headlight assist is equipped.
    StartVCDS()
    OpenUnit("A5")
    	TestComponent("BVS",1) ;coding does not apply on ultra new zFAS cameras like VW Touareg 3
    	ChangeCoding("21:5","")
    CloseUnit()
    OpenUnit("09")
    	ChangeCoding("5:0,5,6","")
    CloseUnit()
    ClearAllDTCs()
    There is an exception for the ultra new zFAS cameras with 85 Byte coding (VW Touareg 3) as this is not possible there with that script.
    Cheers,
    hadez16
  2. Likes Uwe, jyoung8607 liked this post
  3. #2
    Apr 2020
    Hi all,
    StartVCDS()
    OpenUnit("A5")
    CloseUnit()
    OpenUnit("09")
    CloseUnit()
    ClearAllDTCs()
    Cheers,
    hadez16
    Will this script work on a B9 RS5 that already has HBA, to make the setting stick post re-start?
    Factory equipped vehicles are coded to turn this off at every restart.
    Makes no sense being as the MLB-EVO cars like the A6's are factory coded to remain the same as they were when the vehicle shut down.
    VCDS Distributor AINils's Avatar
    Apr 2020
    Germany (AIB)
    no this script only activate the HBA
    Tartu, Estonia
    That is 09 adaption on mqb cars. I'd check there. It was named something about "reset".
    The world is my oyster...
    May 2014
    correct (for MQB) - see here
    Jun 2017
    Deactivating the HBA reset on MLBevo cars is not possible via coding. Probably somewhere deep in parameters.
    Audi B9 Facelift has the new behaviour = Reset is deactivated.
    Apr 2020
    So essentially, the B9 cars are the only cars with the reset.
    B8.5's could do it, A6's on the MLB-EVO can do it, but they took the feature out for 3-4 years on a new model?
    I seriously don't get how Audi thinks sometimes.
    Maybe when the B9.5's come out, we can compare coding at the bit/byte levels?
    It also makes me wonder about if Audi finally decided to use the Ambient lights as part of the welcome home/coming home feature of the B9.5's, like they do on the A6's....
  9. #8
    Jun 2017
    Quote Originally Posted by rs5iswicked View Post
    B9.5 is out since MY20. As I said, no bit that is changeable regarding HBA reset.
  10. #9
    Apr 2020
    Interesting.
    I was told in enough thread that the HBA was now sticky in the B9.5s....
    Do you know if they changed the behavior of the ambient lighting to make it part of the leaving/coming home lighting?
  11. #10
    Jun 2017
    Interesting.
    It is "sticky". HBA reset is deactivated in B9.5
    Ambient lighting: I don't know
