Hi guys
I´m a newbi here, and have just purchased a very nice S6 from 2000 (C5 4B). I have purchased the Hex enthusiast from Ross-tech and have started to play with it. I have no knowledge about this tool, but will hopefully learn by reading and practice. The tool lists a number of faults which I will try to look into one by one, but today the car works almost perfect.
Originally this car was installed with a RNS-D, but a previous owner has ripped this out and put in a Android unit which I didn´t like at all. I have now retrofitted a RNS-E, and after some challenges, everything is now working fine. Info from the unit to the DIS, illumination in the buttons, turns on and off with the ignition. All seem to work fine. However the VDCS log lists a number of faults, but I don´t know if I can live with these or not. Any ideas from you will highly appreciated.
The issue I am struggling with now is the buttons on the original steering wheel. The previous owner may have changed the code when the Android was installe, but I am not able to change the existing code (00100). Even if I don´t get any error messages when trying, it just jumps back to the current code. I don´t have any security access code (if this is needed), but VCDS suggests 12345. Do I need a different code, or do you have any other ideas.
I have attached the last log. Is it possible to read the date / time when the different faults are logged? Any ideas how to move on here? Any special fault that shows up as more serious than other ?
Sunday,13,January,2019,12:51:16:57730
VCDS Version: 18.9.0.4 HEX-V2 CB: 0.4436.4
VIN: License Plate: 13.01
Mileage: 143190km-88974mi Repair Order:
Chassis Type: XX (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 143190km-88974miles
Part No: 4D0 907 558
Component: 4.2L V8/5V G 0002
Coding: 05752
VCID: 6A8DC086E561F17720F-513C
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 BT
Component: AG5 01L 4.2l5V RdW 1314
Coding: 00001
Shop #: WSC 02325
VCID: 7AADF0C695C141F7D0F-513C
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 F
Component: ABS/ESP allrad D36
Coding: 06397
Shop #: WSC 02325
VCID: 363524F6E1596597747-5160
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00080
Shop #: WSC 02325
VCID: 2313EDA242CBE03FA39-25AE
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 E
Component: Airbag Front+Kopf 1001
Coding: 00404
Shop #: WSC 02324
VCID: 323D18E60D3179B758F-513C
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487
Component: A Lenkradelektronik D 11
Coding: 00100
Shop #: WSC 12345
VCID: 698FBF8AE067FA6F295-4B9A
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 932 B
Component: C5-KOMBIINSTR. VDO D05
Coding: 01183
Shop #: WSC 05572
VCID: 211FE7AA58D7F22FB15-513C
XXXXXXXXXXXXXXXXX AUZ7Z0Y1342348
01304 - Radio
01311 - Information Data Bus
37-10 - Faulty - Intermittent
80-10 - Single-Wire Operation - Intermittent
Address 35: Centr. Locks Labels:. 4B0-962-258.lbl
Part No: 4B0 962 258 E
Component: Zentralverrieg.,DWA D33
Coding: 04683
Shop #: WSC 00050
VCID: 2B0305822A1B287F1B9-4EEA
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Part No: 4B0 959 760 A
Component: Sitzmemory D05
VCID: 2B0305822A1B287F1B9-4B00
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E HIGH EU H74 0650
Revision: 05S Serial number: AUZBZ7G1164583
Coding: 0509155
Shop #: WSC 45503 002 104857
VCID: 353723FAF95F6E8F7DD-513C
Reset counter: 23
Date: 2013.01.12
Time: 15:32:11
Mileage: 655350 km
Count: 1201
Clock: 15:31
16353 - Control Module - Internal Malfunction
014 - Defective
Fault Status: 01101110
Reset counter: 26
Date: 2013.01.13
Time: 12:33:26
Bin. Bits: 11
01326 - Control Module for Multi-Function Steering Wheel (J453)
Reset counter: 23
Date: 2013.01.12
Time: 15:32:06
Reset counter: 23
Date: 2013.01.12
Time: 15:31:33
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
VCID: 2615F4B631F91517C47-51A8
01349 - Alarm via Theft Warning System; Front
35-00 - -
