Autoscan says missing asam files and crash
knudch
C?ID=351027
I have now tried many times....
During autoscan VCDS-Mobile says "missing asam files you will be req. to download them..."
When that moment comes it download partly and suddenly returns to autoscan mainpage.
(corrections: "It fails the update, check your internet connections")
When I ignore the download proposal, autoscan finish and I can upload the log.
(Takes very long time, several minutes, before the log files are visibel at VCDS-cloud)
I wonder that if I select the car manual, it does have my car in the list.
Car: Passat variant 2,0 TDI Premium HL, produces in sept. 2018
HEX-NET interface is brandnew with latest Beta sw.
Using a Laptop with Linux (have tried WIndows also, no difference)
Using VCDS Windows prog in a VirtualBox on the same laptop connecting to HEX-NET via wifi works without any problems
Internet connection (and wifi) is quite good.
Fiber connection and tried with the AP standing in the garage a few meters from the car.
Regarding VCDS-mobile:
It would be nice to have the possibility to save the log files directly at the laptop instead of VCDS-cloud
Any other information I shall provide ?
Knud
Once you've done an Auto-Scan, try using VCIConfig to update your HEX-NET. It should request and load all ASAM (.ROD) files for car(s) you have scanned.
If you wish to save files stored on the HEX-NET to your laptop, start a browser on your laptop, point it at the HEX-NET's IP address, and click [View Saved Files] from the main VCDS-Mobile menu. As the saved files are plain text, they will happily display in your browser, and from there, you can right-click and [Save As].
knudch
C?ID=351027
Update from VCI-config:
Its says "you are updated"
If I try to select one of these 3 modules which acording to the partial autoscan file miss ASAM files ( 75, D6, D7)
I can connect to these modules and VCDS-Mobiles says "no local asam file" and tries to download files but end up saying
"Checking for updates..No ASAM data found. This module may not currently be supported, or this could be a ReDir fail."
Anything with that my B8 is not showing up in the list af selectable cars ???
The issue with saved files.... they did show up after a long time until just recently now (1/2 hour), now they appear very quick
Option point only had "View, email".....now they have 4 options "Re-upload, view, email, delete"
Knud
knudch
C?ID=351027
If I check the 3 modules with VCDS prg (Windows) there exist asam files for them by checking advanced ID
Show us your Auto-Scan please. It's possible the server for VCDS-Mobile does not yet have the requite files for those modules.
Shouldn't matter. Modern cars with a proper Gateway Installation list don't need to be selected manually.
I don't think I've ever seen the behavior you are describing. If you want to View them (and possibly save them locally) you can also just click on the filename in the left-most column.
knudch
C?ID=351027
#hndoc:?docid=0000493B&xt=hnh:F99EB5271B9423F28EDE07BBECF0FC066F54F887F7AD77830D63676285029EC1
Sat,Jan,12,2019,15:30:13
VCDS Mobile 0.4451.0.4
VIN: WVWZZZ3CZKE006801
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 69 6C 75
	 A5 BB BC CF D6 D7
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
Address 01: Engine  (DFHA J623)	Labels: 04-01.clb
	Part No SW: 04L 906 026 TM	HW: 04L 907 309 P
	Component: R4 2.0l TDI   H25 6312
	Revision: B4H25---
	Coding: 01250412047405083000
	Shop #: WSC 05311 115 00307
	ASAM Dataset: EV_ECM20TDI01104L906026TM 005001
	ROD: N/A
	VCID: 88538B2397F033CB6442B8-80DD
	No ASAM data for: "EV_ECM20TDI01104L906026TM"
015733 - ROD - Unknown faultcode
Address 02: Auto Trans  (J743)	Labels: 0G-02.clb
	Part No SW: 0GC 300 043	HW: 0GC 927 711 H
	Component: GSG DQ381     H06 2303
	Revision: 00H06V07
	ASAM Dataset: EV_TCMDQ381061 001
	ROD: EV_TCMDQ381061.rod
	VCID: E48BBF934B98B7ABA8FAAC-80B1
No fault codes found.
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Part No SW: 5Q0 614 517 DH	HW: 5Q0 614 517 AH
	Component: ESC           H62 0754
	Revision: 00000000
	Coding: 0FEC6A8F34200B72477F060060C449F0562CD0E2600692713862F078CAA9420B00000012121212B835351919323200
	Shop #: WSC 00015 115 08193
	VCID: 7AB761EB591CD15BE2D622-802F
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 3Q0 959 435 K	HW: 3Q0 959 435 K
	Component: VWKESSYMQB    027 1204
	Revision: 00027000
	Coding: 002F0F0723
	VCID: 42C7D90B714C599BFA86BA-8017
	U1400 00 [008] -
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5G0 907 044 DP	HW: 5G0 907 044 DP
	Component: Climatronic   H04 2001
	Revision: 00001K10
	Coding: 1202010420211001111510000010182A
	ASAM Dataset: EV_ACClimaBHBVW37X 006146
	VCID: 78B37BE36710C34B94A248-802D
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	P1719 00 [008] -
	B10CD 00 [008] -  -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	Part No SW: 5Q0 937 086 BQ	HW: 5Q0 937 086 BQ
	Component: BCM PQ37BOSCH 036 0265
	Revision: --------
	ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
	ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
	VCID: 8A57B12B89FC41DB727692-80DF
	Subsystem 1 - 	Part No SW: 3G1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: WWS    180630042 0607
	Serial Number:         180705114556
	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
	Component: RLHS         052 0107
	Serial Number: SAY18M08D13H20M45S07
	Coding: 00A8DD
	Subsystem 3 - 	Part No SW: 3G0-941-633-H
	Component: E1 - LDS MQB H01 0032
	Serial Number: 31 05 2018  10000413
	Subsystem 4 -
	Subsystem 5 - 	Part No SW: 5Q1-953-521-M
	Component: Lenks.Modul  H03 0160
	Serial Number: 0100050820180C400444
545557 - Databus
Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
	Part No SW: 5QA 919 294 E	HW: 5QA 919 294
	Component: PDC 8 Kanal
	Coding: 0471155911
	Shop #: WSC 05311 115 00073
	VCID: 4EDFFD3BB514ADFB6E1E3E-801B
Address 13: Auto Dist. Reg  (J428)	Labels: 3Q0-907-572.clb
	Part No SW: 3Q0 907 572 C	HW: 3Q0 907 572 C
	Component: ACC BOSCH MQB H05 0196
	Coding: 320467DA5DFFC728949C8045
	ROD: EV_ACCBOSCHVW48X.rod
	VCID: 352DB2D73082FE234F0429-8060
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 3Q0 959 655 BK	HW: 3Q0 959 655 BK
	Component: Airbag VW21   006 0712
	Revision: --------
	Coding: 88CCC000000000005C5400CF000840000065
	Shop #: WSC 05311 000 08193
	ROD: EV_AirbaVW21TS6VW48X_VW48.rod
	Subsystem 1 - 	Part No SW: 4M0-980-945-A
	Component: BeltPretRevFL106 1040
	Serial Number: 3G0857705 0226S00424
	Coding: 80000D
	Subsystem 2 - 	Part No SW: 4M0-980-946-A
	Component: BeltPretRevFR106 1040
	Serial Number: 3G0857706 0227S00155
	Coding: 80000D
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Df008 0887
	Serial Number: 357000000005E735513F
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Pf008 0887
	Serial Number: 358000000007192D113A
	Subsystem 5 - 	Part No SW: --------------
	Component: SideSensor_Dr301 0148
	Serial Number: 35100E00B8715000000C
	Subsystem 6 - 	Part No SW: --------------
	Component: SideSensor_Pr301 0148
	Serial Number: 3520047C55A15000000G
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 3G0 920 791 D	HW: 3G0 920 791 D
	Component: KOMBI         403 4191
	Coding: 07A409086F8C000801886B2B1001000800000000
	VCID: 2A1791ABE93CA1DBD2B6B2-807F
Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
	Part No SW: 3Q0 907 530 Q	HW: 3Q0 907 530 C
	Component: GW MQB High   518 5344
	Coding: 030300345F087300FB00025E1C0F00010001070000000000000000000000
	ROD: EV_GatewNF_VW48.rod
	VCID: 3D3DAAF708B226638774C1-8068
	Subsystem 1 - 	Component: 1-00-03-00-04
	Subsystem 2 - 	Part No SW: 5G0-959-442-AB	Labels: 3C8-959-537.clb
	Component: E221__MFL-DC1H17 0052
	Serial Number: 39180001548450108297
	Coding: 2DFFFF
	Subsystem 3 - 	Part No SW: 5Q0-915-181-J
	Component: J367-BDMContiH03 1050
	Serial Number: 75886002001808250814
	Subsystem 4 - 	Part No SW: 3G0-919-204-C
	Component: Analoguhr    111 1004
	Serial Number: 2407201800010074ª814
Address 3C: Lane Change  (J769)	Labels: 3Q0-907-566.clb
	Part No SW: 3Q0 907 566 G	HW: 3Q0 907 566
	Component: MRR1Rear      H23 0530
	Revision: --------
	Coding: 14C002
	VCID: 3C3BA7F313A82F6BB04AF4-8069
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	Part No SW: 5Q0 959 593 F	HW: 5Q0 959 593 F
	Component: TSG FS
	Coding: 003F0B20D000028000001000
	ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
	VCID: 44CBDF136B5857ABC8BA8C-8011
Address 44: Steering Assist  (J500)	Labels: 5Q-44.clb
	Part No SW: 5Q0 910 143 C	HW: 5Q0 910 143
	Component: MQB_VWBS_GEN2 212 2211
	Coding: 0100001100400110
	Shop #: WSC 00015 115 00307
	ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
	ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
	VCID: 2B1994AFE6C6B8D329A0BF-807E
Address 4B: Multifunc. Module  (J745)	Labels: None
	Part No SW: 3Q0 907 338 C	HW: 3Q0 907 338 C
	Component: FCM MQB Low   002 0342
	Coding: 00000006090003CA00004F01020000040000000000000000000000000000
	ASAM Dataset: EV_MultiModulContiVW48X 002004
	ROD: EV_MultiModulContiVW48X_002_VW48.rod
	Subsystem 1 - 	Part No SW: 3G0-941-329
	Component: Leimo links  H02 0003
	Coding: E02400
	Subsystem 2 - 	Part No SW: 3G0-941-329
	Component: Leimo rechts H02 0003
	Coding: E02400
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	Part No SW: 5Q0 959 592 F	HW: 5Q0 959 592 F
	Component: TSG BFS
	Coding: 003F0120DC00028000001000
	ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
	VCID: 43C9DC0F6E565093F1B087-8016
Address 5F: Information Electr.  (J794)	Labels: 3Q-5f.clb
	Part No SW: 3Q0 035 874 C	HW: 3Q0 035 874 C
	Component: MU-S-ND-ER    853 0891
	Coding: 02840201FF0000005111010100880A001F0500E4012000008E
	ROD: EV_MUStd4CDELP_VW48.rod
	VCID: 322789CBC1ECE91B6AE64A-8067
	Subsystem 1 - 	Part No SW: 5G6-919-605-B
	Component: ABT_Std-2_NavH52 8130
	Serial Number: VWZ6ZHV1930375
	Subsystem 2 - 	Part No SW: 5NA-919-866
	Component: ECE1 2018/19 --- 1030
	Serial Number: --------------------
Address 69: Trailer  (J345)	Labels: 5Q0-907-383.clb
	Part No SW: 5Q0 907 383 N	HW: 5Q0 907 383 N
	Component: Anhaenger     H27 0264
	Revision: 8A001003
	Coding: 0100000202000000
	ROD: EV_TrailFunctGener2Hella_VW37.rod
Address 6C: Back-up Cam.  (J772)	Labels: 5Q0-980-556.clb
	Part No SW: 5Q0 980 556 B	HW: 5Q0 980 556 B
	Component: RVC Compact   H15 0231
	Coding: 0184020163002017000040
	VCID: 3935BEE71C9A1A43AB2C15-806C
Address 75: Telematics  (J949)	Labels: 5N-75.clb
	Part No SW: 5NA 035 284 C	HW: 5NA 035 284 C
	Component: OCULowMQBLGE  H19 0824
	Revision: --------
	Coding: 02840201EA42180D3F1CBE000045400382E608
	ASAM Dataset: EV_OCULowMQBLGE 004049
	ROD: N/A
	No ASAM data for: "EV_OCULowMQBLGE"
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
	Part No SW: 3Q0 980 653 F	HW: 3Q0 980 653
	Component: MQB_B_MFK     H13 0171
	Coding: 00040802000004010022134F8150A900980094300040
	ROD: EV_MFKBoschMQBB_001_VW48.rod
001275 - 001275 - Unknown faultcode
Address BB: Door Rear Drv Side  (J388)	Labels: None
	Part No SW: 8W1 959 595 D	HW: 8W1 959 595 D
	Component: TSG HFS
	Coding: 000E01200100028000001000
Address BC: Door Rear Pass Side  (J389)	Labels: None
	Component: TSG HBFS
Address CF: Lane Chge Asst 2  (J770)	Labels: 3Q-cf.clb
	Part No SW: 3Q0 907 590 G	HW: 3Q0 907 590
	Revision: --------
	Coding: 14C002
Address D6: Light Ctrl Left 2  (A31)	Labels: 7PP-941-572.clb
	Part No SW: 7PP 941 572 AB	HW: 7PP 941 572 A
	ROD: N/A
	VCID: 966FD55BCD44953BE6CE16-80C3
	No ASAM data for: "EV_LEDModLeftMELCOAU736"
Address D7: Light Ctrl Right 2  (A27)	Labels: 7PP-941-572.clb
	ROD: N/A
	No ASAM data for: "EV_LEDModRightMELCOAU736"
End--(Elapsed Time: 03:09, VBatt start/end: 12.2/12.2 Vign: 0.0)-
knudch
C?ID=351027
Saved files:
I discovered that sometimes the menu point "view saved files" guide me to the "separate" web site were I need to login
There I only get the 2 mentioned option posibilities
Right now it jumps directly from menu point "view saved files" to the overview of my saved files
Knud
Yes, I think you're going to have to wait for the next DS update before those files will be available for Mobile.
knudch
C?ID=351027
DS Update
Ok...any idea when that can be ?
Just confusing that VCDS WIN program works fine....thought that the used the same definition library
Knud
DS Update
I believe it's a work in progress at the moment, but I cannot give you a date.
The full VCDS program is where new things are implemented first, and this is a brand-new car, from the 2019 model year.
knudch
C?ID=351027
Ok Thanks
Knud
knudch
C?ID=351027
Now we are some what later in time and updates of VCDS / HEX-NET
Problem is still there
Missing asam files....when HEX-NET tries to update the asam's in step 3 of that process aprox a few seconds in that process it returns a error mesg "...check your internet connections..."
Repeated over and over again..same result
Step 1 and 2 works every time
The log file is lost (eg. not uploaded to the cloud)
VCDS prg from windows runs usual without problems (also connected via wifi)
Very annoying as I bought the HEX-NET version because I normaly don't use Windows
Attaching the log from recent windows scan
Knud
Torsdag,18,Juli,2019,11:32:10:57391
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 7 x86(VirtualBox)
VCDS version NEZ 19.6.1.0  HEX-NET CB: 0.4508.4
Dataversion: 20190712 DS310.0
www.vcds.dk
Firma: Knud Christiansen 29911175
Forhandlernr.: 999 12345 015555
Stelnummer: WVWZZZ3CZKE006801   Indreg.nr.:
Kørestrækning: 24261km   Reparationsordre:
Modeltype: 3C-VW48 (3Q0)
Søgt på: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 69 6C 75
          A5 BB BC CF D6 D7
Stelnummer: WVWZZZ3CZKE006801   Kørestrækning: 24261km
01-Motor -- Status: Ok 0000
02-Automatik -- Status: Ok 0000
03-ABS bremser -- Status: Ok 0000
05-Adg./Startkodning -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Fejlfunktion 0010
10-Park.assist. -- Status: Ok 0000
13-Afstandsreg. I -- Status: Fejlfunktion 0010
15-Airbags -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Ok 0000
3C-Kørebaneskiftass. -- Status: Ok 0000
42-Dørelektr. V for -- Status: Ok 0000
44-Servostyring -- Status: Fejlfunktion 0010
4B-Multifunkt.modul -- Status: Ok 0000
52-Dørelektr. H for -- Status: Ok 0000
5F-Informationselek. -- Status: Ok 0000
69-Anhængertræk -- Status: Ok 0000
6C-Bak-kamera -- Status: Ok 0000
75-Nødopk. Kommun. -- Status: Ok 0000
A5-Forsensor førerass. -- Status: Fejlfunktion 0010
BB-Bagdør førerside -- Status: Ok 0000
BC-Bagdør passagerside -- Status: Ok 0000
CF-Kørebaneskiftass.2 -- Status: Ok 0000
D6-V. lysstyring 2 -- Status: Ok 0000
D7-H. lysstyring 2 -- Status: Ok 0000
Styreenhed  01: Motor (J623-DFHA)     Forklaringsfil:. NEZ\04L-907-309-V1.clb
   Styreenhedsnr: SW: 04L 906 026 TM    HW: 04L 907 309 P
   Komponent	: R4 2.0l TDI   H25 6312
   Revision	: B4H25---
   Kodning	: 01250412047405083000
   Forhandler	: WSC 05311 115 00307
   ASAM datasæt	: EV_ECM20TDI01104L906026TM 005001
   ROD: EV_ECM20TDI01104L906026KA_005_VW48.rod
   VCID: 885CE42033D3940F51-80DD
1 fejl fundet:
15733 - SCR NOx-katalysator (Række 1)
          P20EE 00 [096] - Virkningsgrad for lav
          Periodisk - Ikke bekræftet - Testet siden sletning af hukommelse
Styreenhed  02: Automatik (J743)     Forklaringsfil:. NEZ\0BH-927-711.clb
   Styreenhedsnr: SW: 0GC 300 043     HW: 0GC 927 711 H
   Komponent	: GSG DQ381     H06 2303
   Revision	: 00H06V07
   Kodning	: 0014
   Forhandler	: WSC 00000 000 00000
   ASAM datasæt	: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: E484D090EFBB106F9D-80B1
Ingen fejlkoder fundet.
Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\5Q0-907-379-IPB-V1.clb
   Styreenhedsnr: SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
   Komponent	: ESC           H62 0754
   Revision	: 00000000    Serienummer	: 62218000001929
   Kodning	: 0FEC6A8F34200B72477F060060C449F0562CD0E2600692713862F078CAA9420B00000012121212B835351919323200
   Forhandler	: WSC 00015 115 08193
   ASAM datasæt	: EV_Brake1UDSContiMK100IPB 037009
   VCID: FAB88EE87D3FF69F57-80AF
Styreenhed  05: Adg./Startkodning (J518)     Forklaringsfil:| NEZ\5Q0-959-435.clb
   Styreenhedsnr: SW: 3Q0 959 435 K    HW: 3Q0 959 435 K
   Komponent	: VWKESSYMQB    027 1204
   Revision	: 00027000    Serienummer	: 0489904889
   Kodning	: 002F0F0723
   ASAM datasæt	: EV_KessyHellaMQBAB 004046
   VCID: C2C83608556F7E5F4F-8097
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil:| NEZ\5G0-907-044.clb
   Styreenhedsnr: SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Komponent	: Climatronic   H04 2001
   Revision	: 00001K10
   Kodning	: 1202010420211001111510000010182A
   ASAM datasæt	: EV_ACClimaBHBVW37X 006146
   VCID: F8BC94E04333E48F21-80AD
   Styreenhed til friskluftblæser (foran):
   Luftkvalitetssensor:
   Føler for luftfugtighed udvendig:
Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\5Q0-937-08X-V2.clb
   Styreenhedsnr: SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Komponent	: BCM PQ37BOSCH 036 0265
   Revision	: --------    Serienummer	: 865808081801W3
   Kodning	: 000000000000000000000000000000000000000000000000000000000000
   ASAM datasæt	: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 8A58DE282DDFE61F47-80DF
   Styreenhed til viskermotor:
   Undersystem 1 - Styreenhedsnr: SW: 3G1 955 119 A    HW: 3G1 955 119   Forklaringsfil: NEZ\5QX-955-119-V1.CLB
   Komponent	: WWS    180630  042 0607
   Serienummer	:         180705114556
   Kodning	: 0E4DDD
   Regn- og lyssensor:
   Undersystem 2 - Styreenhedsnr: SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Forklaringsfil: NEZ\5Q0-955-547.CLB
   Komponent	: RLHS  052 0107
   Serienummer	: SAY18M08D13H20M45S07
   Kodning	: 00A8DD
   Lyskontakt:
   Undersystem 3 - Styreenhedsnr: SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Komponent	: E1 - LDS MQB  H01 0032
   Serienummer	: 31 05 2018  10000413
   Føler for luftfugtighed indvendig:
   ratstammekontakt:
   Undersystem 5 - Styreenhedsnr: SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Komponent	: Lenks.Modul  H03 0160
   Serienummer	: 0100050820180C400444
1 fejl fundet:
545557 - Databus
          U1121 00 [008] - Manglende besked
          [EA_03 Datenbus fehlende Botschaft]
          Periodisk - Bekræftet - Testet siden sletning af hukommelse
             Fryserammedata:
                    Fejl status  : 00000001
                    Fejlprioritet: 6
                    Fejlhyppighed: 5
                    Nulstiltæller: 30
                    Kørestrækning: 22586 km
                    Dato: 2019.07.02
                    Tid: 19:23:56
Styreenhed  10: Park.assist. (J446)     Forklaringsfil:| NEZ\5QA-919-294.clb
   Styreenhedsnr: SW: 5QA 919 294 E    HW: 5QA 919 294
   Komponent	: PDC 8 KanalH07 0443
   Serienummer	: 000308418018199
   Kodning	: 0471155911
   Forhandler	: WSC 05311 115 00073
   ASAM datasæt	: EV_EPHVA18AU3700000 009035
   VCID: CED0123891378A3FDB-809B
Styreenhed  13: Afstandsreg. I (J428)     Forklaringsfil:| NEZ\3Q0-907-572.clb
   Styreenhedsnr: SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Komponent	: ACC BOSCH MQB H05 0196
   Kodning	: 320467DA5DFFC728949C8045
   ASAM datasæt	: EV_ACCBOSCHVW48X 001009
   VCID: B5225DD414A1D9E7FA-80E1
1 fejl fundet:
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
             Fryserammedata:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 16
                    Dato: 2019.07.02
                    Tid: 19:23:58
                    Styreenhedstemperatur: 24 °C
                    Spænding kl. 15: 13.3 V
                    Hastighed køretøjs reference: 5.31 m/s
                    Længdeakseacceleration for køretøj reference: 1.47 m/s²
                    Status for ACC system: ACC standby
Styreenhed  15: Airbags (J234)     Forklaringsfil:| NEZ\5Q0-959-655.clb
   Styreenhedsnr: SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Komponent	: Airbag VW21   006 0712
   Revision	: --------    Serienummer	: 003W6PGA4V31
   Kodning	: 88CCC000000000005C5400CF000840000065
   Forhandler	: WSC 05311 000 08193
   ASAM datasæt	: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X.rod
   Sikkerhedsselestrammer i venstre side:
   Undersystem 1 - Styreenhedsnr: SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Komponent	: BeltPretRevFL  106 1040
   Serienummer	: 3G0857705 0226S00424
   Kodning	: 80000D
   Sikkerhedsselestrammer i højre side:
   Undersystem 2 - Styreenhedsnr: SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Komponent	: BeltPretRevFR  106 1040
   Serienummer	: 3G0857706 0227S00155
   Kodning	: 80000D
   Crashsensor til sideairbag i førerside:
   Undersystem 3 - Styreenhedsnr: SW: -----------    HW: 454 000 308 18
   Komponent	: SideSensor_Df  008 0887
   Serienummer	: 357000000005E735513F
   Kodning	: 2D2D2D
   Crashsensor til sideairbag i passagerside:
   Undersystem 4 - Styreenhedsnr: SW: -----------    HW: 454 000 308 18
   Komponent	: SideSensor_Pf  008 0887
   Serienummer	: 358000000007192D113A
   Kodning	: 2D2D2D
   Crashsensor til sideairbag bagi i førersiden:
   Undersystem 5 - Styreenhedsnr: SW: -----------    HW: 454 800 208 18
   Komponent	: SideSensor_Dr  301 0148
   Serienummer	: 35100E00B8715000000C
   Kodning	: 2D2D2D
   Crashsensor til sideairbag bagi i passagerside:
   Undersystem 6 - Styreenhedsnr: SW: -----------    HW: 454 803 107 18
   Komponent	: SideSensor_Pr  301 0148
   Serienummer	: 3520047C55A15000000G
   Kodning	: 2D2D2D
   Crashsensor til frontairbag i førerside:
   Undersystem 7 - Styreenhedsnr: SW: -----------    HW: 454 803 107 18
   Komponent	: FrontSensor_D  304 0149
   Serienummer	: 3550039144C150000009
   Kodning	: 2D2D2D
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5G0-920-XXX-17.clb-SRI3
   Styreenhedsnr: SW: 3G0 920 791 D    HW: 3G0 920 791 D
   Komponent	: KOMBI         403 4191
   Kodning	: 07A409086F8C000801886B2B1001000800000000
   ASAM datasæt	: EV_DashBoardVDDMQBAB 009058
   VCID: AA187EA8CD1F861F67-80FF
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:| NEZ\3Q0-907-530-V1.clb
   Styreenhedsnr: SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Komponent	: GW MQB High   518 5344
   Serienummer	: 05081810802703
   Kodning	: 030300345F087300FB00025E1C0F00010001070000000000000000000000
   ASAM datasæt	: EV_GatewNF 013023
   ROD: EV_GatewNF.rod
   VCID: BD3245F42C9101A732-80E9
   Generator:
   Komponent	: 1-00-03-00-04
   Styreenhed til multifunktionsrat:
   Undersystem 2 - Styreenhedsnr: SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Forklaringsfil: NEZ\3C8-959-537.CLB
   Komponent	: E221__MFL-DC1  H17 0052
   Serienummer	: 39180001548450108297
   Kodning	: 2DFFFF
   Styreenhed til batteriovervågning:
   Undersystem 3 - Styreenhedsnr: SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Komponent	: J367-BDMConti  H03 1050
   Serienummer	: 75886002001808250814
   Analogt ur:
   Undersystem 4 - Styreenhedsnr: SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Komponent	: Analoguhr  111 1004
   Serienummer	: 2407201800010074
Styreenhed  3C: Kørebaneskiftass. (J769)     Forklaringsfil:| NEZ\3Q0-907-566.clb
   Styreenhedsnr: SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Komponent	: MRR1Rear      H23 0530
   Revision	: --------
   Kodning	: 14C002
   ASAM datasæt	: EV_RearRadarS1BoschVW48X 001007
   VCID: BC3448F0378B08AF05-80E9
Styreenhed  42: Dørelektr. V for (J386)     Forklaringsfil:| NEZ\5QX-959-X93-42.clb
   Styreenhedsnr: SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Komponent	: TSG FS001 0287
   Serienummer	: YE007RH220881
   Kodning	: 003F0B20D000028000001000
   ASAM datasæt	: EV_DCU2DriveSideMAXHKLO 001010
   VCID: C4C430104F7B706F7D-8091
Styreenhed  44: Servostyring (J500)     Forklaringsfil:| NEZ\5Q0-910-143.clb
   Styreenhedsnr: SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Komponent	: MQB_VWBS_GEN2 212 2211
   Serienummer	: 856010 00
   Kodning	: 0100001100400110
   Forhandler	: WSC 00015 115 00307
   ASAM datasæt	: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: AB167BACC2E59F179C-80FF
1 fejl fundet:
3158336 - Databus
             Fryserammedata:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 27
                    Kørestrækning: 22872 km
                    Dato: 2019.07.08
                    Tid: 09:42:37
                    Write only channel
Styreenhed  4B: Multifunkt.modul (J745)     Forklaringsfil:| NEZ\3Q0-907-338-V2.clb
   Styreenhedsnr: SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Komponent	: FCM MQB Low   002 0342
   Serienummer	: 01081810801462
   Kodning	: 00000006090003CA00004F01020000040000000000000000000000000000
   ASAM datasæt	: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   Ydelsesmodul til venstre forlygte:
   Undersystem 1 - Styreenhedsnr: SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Komponent	: Leimo links  H02 0003
   Kodning	: E02400
   Ydelsesmodul til højre forlygte:
   Undersystem 2 - Styreenhedsnr: SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Komponent	: Leimo rechts  H02 0003
   Kodning	: E02400
Styreenhed  52: Dørelektr. H for (J387)     Forklaringsfil:| NEZ\5QX-959-X92-52.clb
   Styreenhedsnr: SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Komponent	: TSG BFS001 0287
   Serienummer	: YE007RGU02871
   Kodning	: 003F0120DC00028000001000
   ASAM datasæt	: EV_DCU2PasseSideMAXHKLO 001010
   VCID: C3C6330C4A75775744-8097
Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:| NEZ\5G0-035-MIB-STD2.clb
   Styreenhedsnr: SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Komponent	: MU-S-ND-ER    853 0891
   Serienummer	:
   Kodning	: 02840201FF0000005111010100880A001F0500E4012000008E
   ASAM datasæt	: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: B22866C8E5CFCEDFDF-80E7
   Visnings- og betjeningsenhed 1 til informationselektronik:
   Undersystem 1 - Styreenhedsnr: SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Komponent	: ABT_Std-2_Nav  H52 8130
   Serienummer	: VWZ6ZHV1930375
   Medie:
   Undersystem 2 - Styreenhedsnr: SW: 5NA 919 866     HW: -----------
   Komponent	: ECE1 2018/19  --- 1030
   Serienummer	: --------------------
Styreenhed  69: Anhængertræk (J345)     Forklaringsfil:| NEZ\5Q0-907-383.clb
   Styreenhedsnr: SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Komponent	: Anhaenger     H27 0264
   Revision	: 8A001003    Serienummer	: 0484271561
   Kodning	: 0100000202000000
   ASAM datasæt	: EV_TrailFunctGener2Hella 001008
Styreenhed  6C: Bak-kamera (J772)     Forklaringsfil:| NEZ\5Q0-980-556.clb
   Styreenhedsnr: SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Komponent	: RVC Compact   H15 0231
   Kodning	: 0184020163002017000040
   ASAM datasæt	: EV_CamSysRVRVCPANAMQBAB 006009
   VCID: B93A51E438B93D871E-80ED
Styreenhed  75: Nødopk. Kommun. (J949)     Forklaringsfil:| NEZ\5NA-035-284.clb
   Styreenhedsnr: SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Komponent	: OCULowMQBLGE  H19 0824
   Revision	: --------
   Kodning	: 02840201EA42180D3F1CBE000045400382E608
   ASAM datasæt	: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
Styreenhed  A5: Forsensor førerass. (R242)     Forklaringsfil:| NEZ\3Q0-980-65X-A5.clb
   Styreenhedsnr: SW: 3Q0 980 653 F    HW: 3Q0 980 653
   Komponent	: MQB_B_MFK     H13 0171
   Serienummer	: 24071812K12544
   Kodning	: 00040802000004010022134F8150A900980094300040
   ASAM datasæt	: EV_MFKBoschMQBB 001001
1 fejl fundet:
1275 - Frontsensorik til førerassistentsystemer
          B182E F0 [008] - Funktionsbegr. pga. eksterne påvirkninger
             Fryserammedata:
                    Fejlprioritet: 4
                    Fejlhyppighed: 1
                    Nulstiltæller: 245
                    Kørestrækning: 57 km
                    Dato: 2018.09.24
                    Tid: 15:37:20
                    Styreenhedstemperatur: 48 °C
                    Udelufttemperatur: 12.0 °C
                    Kørehastighed: 82.24 km/t
                    Systemdriftstid: 1723.4 s
                    Spænding kl. 15: 12.8 V
                    mid: 01 63
                    Status for kamera: Funktionsklar
                    Motor kører information: 1
                    Software info 4: 1
                    Software info 3: 7
                    Software info 2: 1
                    Software info 1: 0
Styreenhed  BB: Bagdør førerside (J388)     Forklaringsfil:* Ingen
   Styreenhedsnr: SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Komponent	: TSG HFS003 0187
   Serienummer	: YE007RGV19812
   Kodning	: 000E01200100028000001000
   ASAM datasæt	: EV_DCU2RearDriveMAXHKLO 001010
Styreenhed  BC: Bagdør passagerside (J389)     Forklaringsfil:* Ingen
   Komponent	: TSG HBFS003 0187
   Serienummer	: YE007RGV1741D
   ASAM datasæt	: EV_DCU2RearPasseMAXHKLO 001010
Styreenhed  CF: Kørebaneskiftass.2 (J770)     Forklaringsfil:. NEZ\3Q0-907-566.clb
   Styreenhedsnr: SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision	: --------
   Kodning	: 14C002
   ASAM datasæt	: EV_RearRadarS2BoschVW48X 001007
Styreenhed  D6: V. lysstyring 2 (A31)     Forklaringsfil: NEZ\7PP-941-572.clb
   Styreenhedsnr: SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Komponent	: LED1L         H09 0003
   ASAM datasæt	: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
   VCID: 9660BA58696732FFD3-80C3
Styreenhed  D7: H. lysstyring 2 (A27)     Forklaringsfil: NEZ\7PP-941-572.clb
   Komponent	: LED1R         H09 0003
   ASAM datasæt	: EV_LEDModRightMELCOAU736 001004
Slutning-(Forløbet tid: 02:04, VBat. start/slut: 12.0V/12.0V. VIgn 12.0V)--
