#hndoc:?docid=0000493B&xt=hnh:F99EB5271B9423F28EDE07BBECF0FC066F54F887F7AD77830D63676285029EC1
Sat,Jan,12,2019,15:30:13
VCDS Mobile 0.4451.0.4
VIN: WVWZZZ3CZKE006801
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 69 6C 75
A5 BB BC CF D6 D7
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
Address 01: Engine (DFHA J623) Labels: 04-01.clb
Part No SW: 04L 906 026 TM HW: 04L 907 309 P
Component: R4 2.0l TDI H25 6312
Revision: B4H25---
Coding: 01250412047405083000
Shop #: WSC 05311 115 00307
ASAM Dataset: EV_ECM20TDI01104L906026TM 005001
ROD: N/A
VCID: 88538B2397F033CB6442B8-80DD
No ASAM data for: "EV_ECM20TDI01104L906026TM"
015733 - ROD - Unknown faultcode
Address 02: Auto Trans (J743) Labels: 0G-02.clb
Part No SW: 0GC 300 043 HW: 0GC 927 711 H
Component: GSG DQ381 H06 2303
Revision: 00H06V07
ROD: EV_TCMDQ381061.rod
VCID: E48BBF934B98B7ABA8FAAC-80B1
No fault codes found.
Address 03: ABS Brakes (J104) Labels: 5Q-03.clb
Part No SW: 5Q0 614 517 DH HW: 5Q0 614 517 AH
Component: ESC H62 0754
Revision: 00000000
Coding: 0FEC6A8F34200B72477F060060C449F0562CD0E2600692713862F078CAA9420B00000012121212B835351919323200
Shop #: WSC 00015 115 08193
VCID: 7AB761EB591CD15BE2D622-802F
Part No SW: 3Q0 959 435 K HW: 3Q0 959 435 K
Component: VWKESSYMQB 027 1204
Revision: 00027000
Coding: 002F0F0723
VCID: 42C7D90B714C599BFA86BA-8017
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] -
Part No SW: 5G0 907 044 DP HW: 5G0 907 044 DP
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1202010420211001111510000010182A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: 78B37BE36710C34B94A248-802D
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
Subsystem 4 -
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] -
B10CD 00 [008] - -
Address 09: Cent. Elect. (J519) Labels: 5Q-09.clb
Part No SW: 5Q0 937 086 BQ HW: 5Q0 937 086 BQ
Revision: --------
ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
VCID: 8A57B12B89FC41DB727692-80DF
Subsystem 1 - Part No SW: 3G1-955-119-A Labels: 5Qx-955-119-V1.clb
Component: WWS 180630042 0607
Serial Number: 180705114556
Subsystem 2 - Part No SW: 5Q0-955-547-B Labels: 5Q0-955-547.clb
Component: RLHS 052 0107
Serial Number: SAY18M08D13H20M45S07
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0-941-633-H
Component: E1 - LDS MQB H01 0032
Serial Number: 31 05 2018 10000413
Subsystem 4 -
Subsystem 5 - Part No SW: 5Q1-953-521-M
Component: Lenks.Modul H03 0160
Serial Number: 0100050820180C400444
545557 - Databus
Address 10: Park/Steer Assist (J446) Labels: 5Q-10.lbl
Part No SW: 5QA 919 294 E HW: 5QA 919 294
Component: PDC 8 Kanal
Coding: 0471155911
Shop #: WSC 05311 115 00073
VCID: 4EDFFD3BB514ADFB6E1E3E-801B
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H05 0196
Coding: 320467DA5DFFC728949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 352DB2D73082FE234F0429-8060
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0712
Revision: --------
Coding: 88CCC000000000005C5400CF000840000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW21TS6VW48X_VW48.rod
Subsystem 1 - Part No SW: 4M0-980-945-A
Component: BeltPretRevFL106 1040
Serial Number: 3G0857705 0226S00424
Coding: 80000D
Subsystem 2 - Part No SW: 4M0-980-946-A
Component: BeltPretRevFR106 1040
Serial Number: 3G0857706 0227S00155
Coding: 80000D
Subsystem 3 - Part No SW: --------------
Component: SideSensor_Df008 0887
Serial Number: 357000000005E735513F
Subsystem 4 - Part No SW: --------------
Component: SideSensor_Pf008 0887
Serial Number: 358000000007192D113A
Subsystem 5 - Part No SW: --------------
Component: SideSensor_Dr301 0148
Serial Number: 35100E00B8715000000C
Subsystem 6 - Part No SW: --------------
Component: SideSensor_Pr301 0148
Serial Number: 3520047C55A15000000G
Part No SW: 3G0 920 791 D HW: 3G0 920 791 D
Component: KOMBI 403 4191
Coding: 07A409086F8C000801886B2B1001000800000000
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 2A1791ABE93CA1DBD2B6B2-807F
Address 19: CAN Gateway (J533) Labels: 3Q-19.clb
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Coding: 030300345F087300FB00025E1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW48.rod
VCID: 3D3DAAF708B226638774C1-8068
Subsystem 1 - Component: 1-00-03-00-04
Subsystem 2 - Part No SW: 5G0-959-442-AB Labels: 3C8-959-537.clb
Component: E221__MFL-DC1H17 0052
Serial Number: 39180001548450108297
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0-915-181-J
Component: J367-BDMContiH03 1050
Serial Number: 75886002001808250814
Subsystem 4 - Part No SW: 3G0-919-204-C
Component: Analoguhr 111 1004
Serial Number: 2407201800010074ª814
Address 3C: Lane Change (J769) Labels: 3Q0-907-566.clb
Part No SW: 3Q0 907 566 G HW: 3Q0 907 566
Component: MRR1Rear H23 0530
Revision: --------
Coding: 14C002
VCID: 3C3BA7F313A82F6BB04AF4-8069
Address 42: Door Elect, Driver (J386) Labels: 5Q-42.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS
Coding: 003F0B20D000028000001000
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 44CBDF136B5857ABC8BA8C-8011
Address 44: Steering Assist (J500) Labels: 5Q-44.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Coding: 0100001100400110
Shop #: WSC 00015 115 00307
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
VCID: 2B1994AFE6C6B8D329A0BF-807E
Address 4B: Multifunc. Module (J745) Labels: None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0342
Coding: 00000006090003CA00004F01020000040000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002004
ROD: EV_MultiModulContiVW48X_002_VW48.rod
Subsystem 1 - Part No SW: 3G0-941-329
Component: Leimo links H02 0003
Coding: E02400
Subsystem 2 - Part No SW: 3G0-941-329
Component: Leimo rechts H02 0003
Coding: E02400
Address 52: Door Elect, Pass. (J387) Labels: 5Q-52.clb
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS
Coding: 003F0120DC00028000001000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 43C9DC0F6E565093F1B087-8016
Address 5F: Information Electr. (J794) Labels: 3Q-5f.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Coding: 02840201FF0000005111010100880A001F0500E4012000008E
ROD: EV_MUStd4CDELP_VW48.rod
VCID: 322789CBC1ECE91B6AE64A-8067
Subsystem 1 - Part No SW: 5G6-919-605-B
Component: ABT_Std-2_NavH52 8130
Serial Number: VWZ6ZHV1930375
Subsystem 2 - Part No SW: 5NA-919-866
Component: ECE1 2018/19 --- 1030
Serial Number: --------------------
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_VW37.rod
Address 6C: Back-up Cam. (J772) Labels: 5Q0-980-556.clb
Component: RVC Compact H15 0231
Coding: 0184020163002017000040
VCID: 3935BEE71C9A1A43AB2C15-806C
Address 75: Telematics (J949) Labels: 5N-75.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0824
Revision: --------
Coding: 02840201EA42180D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: N/A
No ASAM data for: "EV_OCULowMQBLGE"
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q-a5.clb
Part No SW: 3Q0 980 653 F HW: 3Q0 980 653
Component: MQB_B_MFK H13 0171
Coding: 00040802000004010022134F8150A900980094300040
ROD: EV_MFKBoschMQBB_001_VW48.rod
001275 - 001275 - Unknown faultcode
Address BB: Door Rear Drv Side (J388) Labels: None
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS
Coding: 000E01200100028000001000
Address BC: Door Rear Pass Side (J389) Labels: None
Component: TSG HBFS
Address CF: Lane Chge Asst 2 (J770) Labels: 3Q-cf.clb
Part No SW: 3Q0 907 590 G HW: 3Q0 907 590
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ROD: N/A
VCID: 966FD55BCD44953BE6CE16-80C3
No ASAM data for: "EV_LEDModLeftMELCOAU736"
Component: LED1R H09 0003
ROD: N/A
No ASAM data for: "EV_LEDModRightMELCOAU736"
End--(Elapsed Time: 03:09, VBatt start/end: 12.2/12.2 Vign: 0.0)-
