Results 1 to 10 of 12
Thread: Autoscan says missing asam files and crash
    Jan 2019
    I have now tried many times....
    During autoscan VCDS-Mobile says "missing asam files you will be req. to download them..."
    When that moment comes it download partly and suddenly returns to autoscan mainpage.
    (corrections: "It fails the update, check your internet connections")
    When I ignore the download proposal, autoscan finish and I can upload the log.
    (Takes very long time, several minutes, before the log files are visibel at VCDS-cloud)
    I wonder that if I select the car manual, it does have my car in the list.
    Car: Passat variant 2,0 TDI Premium HL, produces in sept. 2018
    HEX-NET interface is brandnew with latest Beta sw.
    Using a Laptop with Linux (have tried WIndows also, no difference)
    Using VCDS Windows prog in a VirtualBox on the same laptop connecting to HEX-NET via wifi works without any problems
    Internet connection (and wifi) is quite good.
    Fiber connection and tried with the AP standing in the garage a few meters from the car.
    Regarding VCDS-mobile:
    It would be nice to have the possibility to save the log files directly at the laptop instead of VCDS-cloud
    Any other information I shall provide ?
    Knud
    Once you've done an Auto-Scan, try using VCIConfig to update your HEX-NET. It should request and load all ASAM (.ROD) files for car(s) you have scanned.
    If you wish to save files stored on the HEX-NET to your laptop, start a browser on your laptop, point it at the HEX-NET's IP address, and click [View Saved Files] from the main VCDS-Mobile menu. As the saved files are plain text, they will happily display in your browser, and from there, you can right-click and [Save As].
    Jan 2019
    Update from VCI-config:
    Its says "you are updated"
    If I try to select one of these 3 modules which acording to the partial autoscan file miss ASAM files ( 75, D6, D7)
    I can connect to these modules and VCDS-Mobiles says "no local asam file" and tries to download files but end up saying
    "Checking for updates..No ASAM data found. This module may not currently be supported, or this could be a ReDir fail."
    Anything with that my B8 is not showing up in the list af selectable cars ???
    The issue with saved files.... they did show up after a long time until just recently now (1/2 hour), now they appear very quick
    Option point only had "View, email".....now they have 4 options "Re-upload, view, email, delete"
    Knud
    Jan 2019
    If I check the 3 modules with VCDS prg (Windows) there exist asam files for them by checking advanced ID
    Quote Originally Posted by knudch View Post
    Show us your Auto-Scan please. It's possible the server for VCDS-Mobile does not yet have the requite files for those modules.
    Shouldn't matter. Modern cars with a proper Gateway Installation list don't need to be selected manually.
    I don't think I've ever seen the behavior you are describing. If you want to View them (and possibly save them locally) you can also just click on the filename in the left-most column.
    Jan 2019
    #hndoc:?docid=0000493B&xt=hnh:F99EB5271B9423F28EDE07BBECF0FC066F54F887F7AD77830D63676285029EC1
    Sat,Jan,12,2019,15:30:13
    VCDS Mobile 0.4451.0.4
    VIN: WVWZZZ3CZKE006801
    Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 69 6C 75
    	 A5 BB BC CF D6 D7
    BB-Door Rear Drv Side -- Status: OK 0000
    BC-Door Rear Pass Side -- Status: OK 0000
    Address 01: Engine  (DFHA J623)	Labels: 04-01.clb
    	Part No SW: 04L 906 026 TM	HW: 04L 907 309 P
    	Component: R4 2.0l TDI   H25 6312
    	Revision: B4H25---
    	Coding: 01250412047405083000
    	Shop #: WSC 05311 115 00307
    	ASAM Dataset: EV_ECM20TDI01104L906026TM 005001
    	ROD: N/A
    	VCID: 88538B2397F033CB6442B8-80DD
    	No ASAM data for: "EV_ECM20TDI01104L906026TM"
    015733 - ROD - Unknown faultcode
    Address 02: Auto Trans  (J743)	Labels: 0G-02.clb
    	Part No SW: 0GC 300 043	HW: 0GC 927 711 H
    	Component: GSG DQ381     H06 2303
    	Revision: 00H06V07
    	ASAM Dataset: EV_TCMDQ381061 001
    	ROD: EV_TCMDQ381061.rod
    	VCID: E48BBF934B98B7ABA8FAAC-80B1
    No fault codes found.
    Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
    	Part No SW: 5Q0 614 517 DH	HW: 5Q0 614 517 AH
    	Component: ESC           H62 0754
    	Revision: 00000000
    	Coding: 0FEC6A8F34200B72477F060060C449F0562CD0E2600692713862F078CAA9420B00000012121212B835351919323200
    	Shop #: WSC 00015 115 08193
    	VCID: 7AB761EB591CD15BE2D622-802F
    Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
    	Part No SW: 3Q0 959 435 K	HW: 3Q0 959 435 K
    	Component: VWKESSYMQB    027 1204
    	Revision: 00027000
    	Coding: 002F0F0723
    	VCID: 42C7D90B714C599BFA86BA-8017
    	U1400 00 [008] -
    Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
    	Part No SW: 5G0 907 044 DP	HW: 5G0 907 044 DP
    	Component: Climatronic   H04 2001
    	Revision: 00001K10
    	Coding: 1202010420211001111510000010182A
    	ASAM Dataset: EV_ACClimaBHBVW37X 006146
    	VCID: 78B37BE36710C34B94A248-802D
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    	Subsystem 4 -
    	P1719 00 [008] -
    	B10CD 00 [008] -  -
    Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
    	Part No SW: 5Q0 937 086 BQ	HW: 5Q0 937 086 BQ
    	Component: BCM PQ37BOSCH 036 0265
    	Revision: --------
    	ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
    	ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
    	VCID: 8A57B12B89FC41DB727692-80DF
    	Subsystem 1 - 	Part No SW: 3G1-955-119-A	Labels: 5Qx-955-119-V1.clb
    	Component: WWS    180630042 0607
    	Serial Number:         180705114556
    	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
    	Component: RLHS         052 0107
    	Serial Number: SAY18M08D13H20M45S07
    	Coding: 00A8DD
    	Subsystem 3 - 	Part No SW: 3G0-941-633-H
    	Component: E1 - LDS MQB H01 0032
    	Serial Number: 31 05 2018  10000413
    	Subsystem 4 -
    	Subsystem 5 - 	Part No SW: 5Q1-953-521-M
    	Component: Lenks.Modul  H03 0160
    	Serial Number: 0100050820180C400444
    545557 - Databus
    Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
    	Part No SW: 5QA 919 294 E	HW: 5QA 919 294
    	Component: PDC 8 Kanal
    	Coding: 0471155911
    	Shop #: WSC 05311 115 00073
    	VCID: 4EDFFD3BB514ADFB6E1E3E-801B
    Address 13: Auto Dist. Reg  (J428)	Labels: 3Q0-907-572.clb
    	Part No SW: 3Q0 907 572 C	HW: 3Q0 907 572 C
    	Component: ACC BOSCH MQB H05 0196
    	Coding: 320467DA5DFFC728949C8045
    	ROD: EV_ACCBOSCHVW48X.rod
    	VCID: 352DB2D73082FE234F0429-8060
    Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
    	Part No SW: 3Q0 959 655 BK	HW: 3Q0 959 655 BK
    	Component: Airbag VW21   006 0712
    	Revision: --------
    	Coding: 88CCC000000000005C5400CF000840000065
    	Shop #: WSC 05311 000 08193
    	ROD: EV_AirbaVW21TS6VW48X_VW48.rod
    	Subsystem 1 - 	Part No SW: 4M0-980-945-A
    	Component: BeltPretRevFL106 1040
    	Serial Number: 3G0857705 0226S00424
    	Coding: 80000D
    	Subsystem 2 - 	Part No SW: 4M0-980-946-A
    	Component: BeltPretRevFR106 1040
    	Serial Number: 3G0857706 0227S00155
    	Coding: 80000D
    	Subsystem 3 - 	Part No SW: --------------
    	Component: SideSensor_Df008 0887
    	Serial Number: 357000000005E735513F
    	Subsystem 4 - 	Part No SW: --------------
    	Component: SideSensor_Pf008 0887
    	Serial Number: 358000000007192D113A
    	Subsystem 5 - 	Part No SW: --------------
    	Component: SideSensor_Dr301 0148
    	Serial Number: 35100E00B8715000000C
    	Subsystem 6 - 	Part No SW: --------------
    	Component: SideSensor_Pr301 0148
    	Serial Number: 3520047C55A15000000G
    Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
    	Part No SW: 3G0 920 791 D	HW: 3G0 920 791 D
    	Component: KOMBI         403 4191
    	Coding: 07A409086F8C000801886B2B1001000800000000
    	VCID: 2A1791ABE93CA1DBD2B6B2-807F
    Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
    	Part No SW: 3Q0 907 530 Q	HW: 3Q0 907 530 C
    	Component: GW MQB High   518 5344
    	Coding: 030300345F087300FB00025E1C0F00010001070000000000000000000000
    	ROD: EV_GatewNF_VW48.rod
    	VCID: 3D3DAAF708B226638774C1-8068
    	Subsystem 1 - 	Component: 1-00-03-00-04
    	Subsystem 2 - 	Part No SW: 5G0-959-442-AB	Labels: 3C8-959-537.clb
    	Component: E221__MFL-DC1H17 0052
    	Serial Number: 39180001548450108297
    	Coding: 2DFFFF
    	Subsystem 3 - 	Part No SW: 5Q0-915-181-J
    	Component: J367-BDMContiH03 1050
    	Serial Number: 75886002001808250814
    	Subsystem 4 - 	Part No SW: 3G0-919-204-C
    	Component: Analoguhr    111 1004
    	Serial Number: 2407201800010074ª814
    Address 3C: Lane Change  (J769)	Labels: 3Q0-907-566.clb
    	Part No SW: 3Q0 907 566 G	HW: 3Q0 907 566
    	Component: MRR1Rear      H23 0530
    	Revision: --------
    	Coding: 14C002
    	VCID: 3C3BA7F313A82F6BB04AF4-8069
    Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
    	Part No SW: 5Q0 959 593 F	HW: 5Q0 959 593 F
    	Component: TSG FS
    	Coding: 003F0B20D000028000001000
    	ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
    	VCID: 44CBDF136B5857ABC8BA8C-8011
    Address 44: Steering Assist  (J500)	Labels: 5Q-44.clb
    	Part No SW: 5Q0 910 143 C	HW: 5Q0 910 143
    	Component: MQB_VWBS_GEN2 212 2211
    	Coding: 0100001100400110
    	Shop #: WSC 00015 115 00307
    	ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
    	ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
    	VCID: 2B1994AFE6C6B8D329A0BF-807E
    Address 4B: Multifunc. Module  (J745)	Labels: None
    	Part No SW: 3Q0 907 338 C	HW: 3Q0 907 338 C
    	Component: FCM MQB Low   002 0342
    	Coding: 00000006090003CA00004F01020000040000000000000000000000000000
    	ASAM Dataset: EV_MultiModulContiVW48X 002004
    	ROD: EV_MultiModulContiVW48X_002_VW48.rod
    	Subsystem 1 - 	Part No SW: 3G0-941-329
    	Component: Leimo links  H02 0003
    	Coding: E02400
    	Subsystem 2 - 	Part No SW: 3G0-941-329
    	Component: Leimo rechts H02 0003
    	Coding: E02400
    Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
    	Part No SW: 5Q0 959 592 F	HW: 5Q0 959 592 F
    	Component: TSG BFS
    	Coding: 003F0120DC00028000001000
    	ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
    	VCID: 43C9DC0F6E565093F1B087-8016
    Address 5F: Information Electr.  (J794)	Labels: 3Q-5f.clb
    	Part No SW: 3Q0 035 874 C	HW: 3Q0 035 874 C
    	Component: MU-S-ND-ER    853 0891
    	Coding: 02840201FF0000005111010100880A001F0500E4012000008E
    	ROD: EV_MUStd4CDELP_VW48.rod
    	VCID: 322789CBC1ECE91B6AE64A-8067
    	Subsystem 1 - 	Part No SW: 5G6-919-605-B
    	Component: ABT_Std-2_NavH52 8130
    	Serial Number: VWZ6ZHV1930375
    	Subsystem 2 - 	Part No SW: 5NA-919-866
    	Component: ECE1 2018/19 --- 1030
    	Serial Number: --------------------
    Address 69: Trailer  (J345)	Labels: 5Q0-907-383.clb
    	Part No SW: 5Q0 907 383 N	HW: 5Q0 907 383 N
    	Component: Anhaenger     H27 0264
    	Revision: 8A001003
    	Coding: 0100000202000000
    	ROD: EV_TrailFunctGener2Hella_VW37.rod
    Address 6C: Back-up Cam.  (J772)	Labels: 5Q0-980-556.clb
    	Part No SW: 5Q0 980 556 B	HW: 5Q0 980 556 B
    	Component: RVC Compact   H15 0231
    	Coding: 0184020163002017000040
    	VCID: 3935BEE71C9A1A43AB2C15-806C
    Address 75: Telematics  (J949)	Labels: 5N-75.clb
    	Part No SW: 5NA 035 284 C	HW: 5NA 035 284 C
    	Component: OCULowMQBLGE  H19 0824
    	Revision: --------
    	Coding: 02840201EA42180D3F1CBE000045400382E608
    	ASAM Dataset: EV_OCULowMQBLGE 004049
    	ROD: N/A
    	No ASAM data for: "EV_OCULowMQBLGE"
    Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
    	Part No SW: 3Q0 980 653 F	HW: 3Q0 980 653
    	Component: MQB_B_MFK     H13 0171
    	Coding: 00040802000004010022134F8150A900980094300040
    	ROD: EV_MFKBoschMQBB_001_VW48.rod
    001275 - 001275 - Unknown faultcode
    Address BB: Door Rear Drv Side  (J388)	Labels: None
    	Part No SW: 8W1 959 595 D	HW: 8W1 959 595 D
    	Component: TSG HFS
    	Coding: 000E01200100028000001000
    Address BC: Door Rear Pass Side  (J389)	Labels: None
    	Component: TSG HBFS
    Address CF: Lane Chge Asst 2  (J770)	Labels: 3Q-cf.clb
    	Part No SW: 3Q0 907 590 G	HW: 3Q0 907 590
    	Revision: --------
    	Coding: 14C002
    Address D6: Light Ctrl Left 2  (A31)	Labels: 7PP-941-572.clb
    	Part No SW: 7PP 941 572 AB	HW: 7PP 941 572 A
    	ROD: N/A
    	VCID: 966FD55BCD44953BE6CE16-80C3
    	No ASAM data for: "EV_LEDModLeftMELCOAU736"
    Address D7: Light Ctrl Right 2  (A27)	Labels: 7PP-941-572.clb
    	ROD: N/A
    	No ASAM data for: "EV_LEDModRightMELCOAU736"
    End--(Elapsed Time: 03:09, VBatt start/end: 12.2/12.2 Vign: 0.0)-
  7. #7
    Jan 2019
    Saved files:
    I discovered that sometimes the menu point "view saved files" guide me to the "separate" web site were I need to login
    There I only get the 2 mentioned option posibilities
    Right now it jumps directly from menu point "view saved files" to the overview of my saved files
    Knud
  8. #8
    Yes, I think you're going to have to wait for the next DS update before those files will be available for Mobile.
  9. #9
    Jan 2019
    DS Update
    Ok...any idea when that can be ?
    Just confusing that VCDS WIN program works fine....thought that the used the same definition library
    Knud
  10. #10
    DS Update
    I believe it's a work in progress at the moment, but I cannot give you a date.
    The full VCDS program is where new things are implemented first, and this is a brand-new car, from the 2019 model year.
