Results 1 to 10 of 10
Thread: Coding Rejected, Error 31: Request out of range (ESP9.0i)
    New User
    Jan 2019
    Turkey
    I have a problem with abs coding. When I try to enter abs code, get an error like "Coding Rejected, Error 31: Request out of range". I am generating code with esp calculator. Could you help me please?
    New User
    Jan 2019
    Turkey
    Auto scan log is
    Sunday,13,January,2019,01:32:03:57798
    VCDS Version: 18.9.0.4 (x64)
    Dealer/Shop Name: INNOVA
    VIN: WVWZZZ6RZDY234899   License Plate:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 02 03 04 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZDY234899   Mileage: 96590km-60018miles
    Address 01: Engine (J623-CTHE)       Labels:. 03C-907-309-V1.clb
       Part No SW: 03C 906 026 K    HW: 03C 907 309 N
       Component: 1.4l R4 TSI   X02 6414
       Revision: LNX02---    Serial number:
       Coding: 00250012000400000000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ECM14TSI01103C906026K 001006
       ROD: GV_ECM14TSI011PQ25.rod
       VCID: 285F01B15312DD0AB3-807C
    4660 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [047] - -
                        Mileage: 94315 km
                        Date: 2018.12.07
                        Time: 09:51:05
                        Coolant temperature: 30 C
                        Intake air temperature: 60 C
                        Ambient air pressure: 470 mbar
                        Voltage terminal 30: 50.033 V
    2998 - Boost Pressure Control Valve (N249)
              P2261 00 [096] - Mechanical Malfunction
                        Mileage: 96570 km
                        Date: 2019.01.12
                        Time: 16:31:30
                        Engine speed: 1346.50 /min
                        Normed load value: 8.6 %
                        Vehicle speed: 38 km/h
                        Coolant temperature: 6 C
                        Intake air temperature: 57 C
                        Ambient air pressure: 550 mbar
                        Voltage terminal 30: 8.305 V
    4043 - Boost Pressure Regulation
              P0234 00 [101] - Limit Exceeded (Overboost Condition)
                        Mileage: 95396 km
                        Date: 2018.12.23
                        Time: 08:41:28
                        Engine speed: 6952.50 /min
                        Normed load value: 92.2 %
                        Vehicle speed: 154 km/h
                        Coolant temperature: 36 C
                        Intake air temperature: 61 C
                        Voltage terminal 30: 2.161 V
    14751 - EVAP Emission Control Sys
              P0441 00 [096] - Incorrect Flow
       Part No SW: 0AM 300 060 A    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6563
       Revision: 00043014    Serial number: CU501302187614
       Shop #: WSC 17810 002 1048576
       VCID: 285F01B19B12DD0AB3-807C
       Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
       Component: ESP9.0i front H02 0002
       Serial number: --------------
       Shop #: WSC 01383 785 00200
       ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
       ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
       VCID: 0F2D4A2DD6BCAA3252-805A
    6 Faults Found:
    0943 - ABS/ESP Control Module
              U10C5 00 [137] - No or Incorrect Basic Setting
                        Reset counter: 154
                        Mileage: 90855 km
                        Date: 2018.10.25
                        Time: 00:00:12
    0993 - Steering angle sensor
                        Reset counter: 246
                        Mileage: 94315 km
                        Date: 2018.12.07
                        Time: 09:51:09
    0887 - Control Module
              C104A F0 [129] - Incorrect VIN
    0896 - Control Module
              C104A F0 [009] - Incorrect VIN
                        Reset counter: 63
                        Mileage: 96515 km
                        Date: 2019.01.12
                        Time: 10:13:24
    0897 - Coding Not Possible
              U10BC 00 [009] - -
                        Reset counter: 65
                        Mileage: 96594 km
                        Date: 2019.01.13
                        Time: 00:27:46
    0883 - Control module not coded
              U1013 00 [137] - -
                        Reset counter: 246
                        Time: 00:00:00
       Component: LENKW.SENSOR  H06 0070
       Serial number: 07031304650059
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF307E9E116B3BAA9-802A
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 3979D4F5B0B85482DC-806C
       Part No SW: 6R0 937 087 M    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H32 0407
       Revision: BF032001    Serial number: 0540 060131888
       Coding: 64B02B3F08A10000003808002D2B0CD00040410F60060000200000000000
       VCID: 479DA20DF64C32725A-8012
       Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  008 1611
       Serial number: KU0KU001031300010743
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  008 1611
       Serial number: KU0KU027021300010674
       Coding: 18BC30
       Subsystem 3 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Serial number: 0116612
       Coding: 830000
       Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
       Component: J388__TSG_HL  008 1611
       Serial number: KU0KU021021300015227
       Coding: 18BC32
       Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Component: J389__TSG_HR  008 1611
       Serial number: KU0KU021021300010072
       Coding: 18BC32
    00975 - Heated Rear Window (Z1)
                        Fault Status: 00101011
                        Reset counter: 68
                        Mileage: 94315 km
                        Date: 2013.04.29
                        Time: 11:15:21
       Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
       Component: VW10Airbag01Q H10 0020
       Revision: --------    Serial number: 003GZ001AGA5
       Coding: 003151
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4C979D21E72AD12A77-8018
       Serial number: 3575HRB400650FBC69ES
       Serial number: 3585HRB401C50FBI6PEF
       Serial number: 3515RRB400G50ENAO9LX
       Serial number: 3525RRB400C50ENAOOQ7
       Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
       Component: KOMBI         H05 0607
       Coding: 140801
       Shop #: WSC 00000 219 00000
       VCID: 3467E5C19FDAA9EA0F-8060
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H32 0407
       Revision: BF032001
       Coding: 002200
       VCID: 70EF29D1A342D5CA2B-8024
       Component: IMMO          H05 0607
       VCID: 6ADB3BB98D9E2F1A65-803E
       Part No: 6R0 423 156 C
       Component: LenkhilfeTRW        V278
       Coding: 11241
       Shop #: WSC 00788
       VCID: 306FE9D1F7C295CA6B-8064
       Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
       Component: Radio RCD510  007 0236
       Revision: 00000001    Serial number: VWZ1Z3R1018765
       Coding: 05000400020001
       Shop #: WSC 25830 002 1048576
       VCID: 24471581273A396A9F-8070
    00856 - Radio Antenna
                        Fault Frequency: 86
                        Reset counter: 64
                        Mileage: 94571 km
                        Date: 2013.05.04
                        Time: 10:09:45
                        Reset counter: 246
                        Mileage: 94315 km
                        Date: 2013.04.29
                        Time: 09:51:31
    End-------------------------(Elapsed Time: 02:24)--------------------------
  3. Likes Dana liked this post
    Very nice.
  5. Likes darkchina811, jyoung8607, iichel liked this post
  6. #4
    With the fault codes:
    0887 - Control Module - Incorrect VIN and 0897 - Coding Not Possible, one might think that this module would reject any coding at all, even a correct one.
    What's the back-story here?
    What parts have been changed and why?
    New User
    Jan 2019
    Turkey
    No parts changed. this issue occurred when locksmith make the copy key.
    I cannot assist with that coding but make sure you checked both of these folders on any PCs used with VCDS to scan that vehicle prior to the lost coding:
    C:\Ross-Tech\VCDS\Logs
    C:\Ross-Tech\VCDS\Scans
    If you can locate a scan with the original coding it should be accepted.
  9. Likes Uwe liked this post
  10. #7
    Aug 2016
    Switzerland
    What about this coding? 21DD6885432602C4841C1672C25A404d1505
    If rejected, please post the advanced ID of the engine ECU and the immobiliser.
  11. Likes Uwe liked this post
  12. #8
    Aug 2016
    Switzerland
  13. #9
    New User
    Jan 2019
    Turkey
    I am getting same error.
    Ecu advanced ID
    Tuesday,15,January,2019,15:33:51:57798
    VIN:    License Plate: ZP4873
    Mileage:    Repair Order: ecu-advid
                    Address 01: Engine
    Control Module Part Number: 03C 906 026 K
      Component and/or Version: 1.4l R4 TSI   X02 6414
               Software Coding: 00250012000400000000
                Work Shop Code: WSC 00046
    Advanced Identification/FAZIT
         Identification: RB8-658
         Revision: LNX02---
         Date: 02.02.13
         Manufacturer number: 1360
         Test stand number: 0859
    Flash Status
         Programming Attempts(application): 3/2/2/3/4
         Successful Attempts(application): 3/2/2/2/4
         Flash Date: 00.00.00
    Misc.
         Hardware number: 03C 907 309 N
         Workshop System Name: J623
         ASAM Dataset Revision: 001006
    Car Info
         Chassis Number: WVWZZZ6RZDY234899
         Engine code: CTHE
    VCDS Info:
           Labels: 03C-907-309-V1.clb
           Readiness: No script available
    Immobilizer Advanced ID
    Tuesday,15,January,2019,15:35:28:57798
    VIN: WVWZZZ6RZDY234899   License Plate: ZP4873
    Mileage:    Repair Order: immo-advid
                    Address 25: Immobilizer
    Control Module Part Number: 5K0 953 234
      Component and/or Version: IMMO          H05 0607
               Software Coding: 000000
                Work Shop Code: WSC 00000
         Identification: VD1-048
         Date: 27.02.13
         Manufacturer number: 7394
         Test stand number: 2968
    Flash Status
    Software
         BAP: 01.04.01
         OSEK-OS: 03.14.00
         HiSpd Net: 01.12.01
    Misc.
         Hardware number: 5K0 953 234
         Workshop System Name: J334
         Equipment/PR Code: 2D2D2D2D2D2D2D2D
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: ------------------
         ASAM Dataset Revision: A03709
    Car Info
         Chassis Number: WV
    Z
    Immobilizer
         Transponder ID (Current val.): C93AEF3B
         Transponder ID 1: C93AE752
         Transponder ID 2: C93AEF3B
         Transponder ID 3: 50C793E3
    VCDS Info:
           Labels: 5K0-920-xxx-25.clb
  14. #10
    Aug 2016
    Switzerland
    Is the cluster the original cluster that comes with the car? Does the engine start?
  15. Likes Uwe liked this post
