Hi folks!
I have a Passat 2008 2.0 TDI (3C) With DSG tranny. It has an adaptive cruise Control (ACC). After an accident, hitting a deer, the radar unit is physical damaged.
The info in the dash board is lock to the message "ACC Fault", and is not possible to get rid of it.
Replacement of the "radar unit" is possible, but very expensive. We are talking of something like $ 3500, - By the way, I know Norway is an expensive country :-)
I hope is possible to alter the "ACC" to regular cruise control "CC", recoding using VCDC software.
If this alteration from "ACC" to "CC" is not possible, can this function be disabled in any way?
Any tips are appreciated :-)
Best regards
Helge Gjelstad
Best regards
Helge Gjelstad
Thursday,27,December,2018,14:51:43:43328
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
VIN: License Plate: LJ28576
Mileage: 264650km-164445mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 13 15 16 17 18 19 25 36 42 44 46 47 52 53 55
56 62 69 6D 72
VIN: WVWZZZ3CZ8E032211 Mileage: 264650km-164445miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EM HW: 03G 906 018 EM
Component: R4 2.0l PPD1.2 G 4369
Revision: --H42--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 38999 002 1048576
VCID: 74B1DE94A2B1BBA78A3-8020
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 006 -
Fault Status: 01100001
Reset counter: 40
Mileage: 261573 km
Date: 2018.08.14
Time: 12:27:02
RPM: 800 /min
Torque: 40.0 Nm
Bin. Bits: 00000000
Text: Kein Messwert verfuegbar
Raw, Form. N/A: 000 000 000
005715 - Please check DTC Memory of ABS Controller
P1653 - 006 -
Reset counter: 40
Mileage: 261573 km
Date: 2018.08.14
Time: 12:27:02
RPM: 800 /min
Torque: 40.0 Nm
Lateral Accel.: 0.00 m/s^2
Bin. Bits: 00000000
Bin. Bits: 01000001
0.00 %
005782 - Powertrain Data Bus
P1696 - 008 - Implausible Message from Steering Column Controller
Reset counter: 40
Mileage: 261573 km
Date: 2018.08.14
Time: 12:27:03
RPM: 800 /min
Torque: 40.0 Nm
0.00 %
Voltage: 13.90 V
Bin. Bits: 11001100
Bin. Bits: 01000000
Readiness: N/A
Part No SW: 02E 300 050 C HW: 02E 927 770 AD
Component: GSG DSG 082 1403
Revision: 04808020 Serial number: 00000808020112
Shop #: WSC 04940 001 00001
VCID: 127DB80CB865159738F-8046
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 E HW: 3C0 614 109 E
Component: J104 C4 440 V3 0003
Revision: --020--- Serial number: 00000775429667
Coding: 0002333
Shop #: WSC 05311 000 00000
VCID: 2019E2C446C97707BEB-8074
Reset counter: 223
Mileage: 261566 km
Date: 2018.08.14
Time: 09:16:06
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 155
Reset counter: 223
Mileage: 261566 km
Date: 2018.08.14
Time: 09:16:06
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 218
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CB HW: 3C0 907 044 CB
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
VCID: 6393ADC8175F2C1FE39-8036
Fault Status: 00111110
Fault Frequency: 40
Reset counter: 217
Mileage: 262676 km
Date: 2018.10.29
Time: 06:52:40
Revision: 00H54000 Serial number: 01000007259181
Coding: EF8A8F0700041A00470A00000F000000000B5D435C000100000000000000
Shop #: WSC 05124 000 08193
VCID: 71BFD780DDA38E8F615-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 150507 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 220607 020 0105
Coding: 00208933
Shop #: WSC 05124
Reset counter: 196
Mileage: 264482 km
Date: 2018.12.18
Time: 19:58:00
Voltage: 13.60 V
Address 13: Auto Dist. Reg
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 19 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2PBEJ4SV
Coding: 0012601
VCID: 313F17801D23CE8F215-8064
Subsystem 1 - Serial number: 6332MSME187315512
Subsystem 2 - Serial number: 6342MSME1C2E7245J
Subsystem 3 - Serial number: 6351HTS6D3KK52S6K
Subsystem 4 - Serial number: 6361HTS6D3KCS886M
Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
Component: J0527 0015
Revision: 00006000 Serial number: 3C9953507BH
Coding: 0001222
Shop #: WSC 05311 000 08193
VCID: 34311E94E231FBA74A3-8060
Component: E0221 002 0010
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 39116 002 1048576
VCID: 2615F4DC24ED9937C47-8072
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
Shop #: WSC 00851 218 178586
VCID: 3635249CF44DE9B7747-8062
00664 - Fuel gauge
Reset counter: 38
Mileage: 250383 km
Date: 2017.10.20
Time: 05:57:28
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 27
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 D HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1300Q07515017E
Coding: FD85FF46120A022002
Shop #: WSC 05314 000 00000
VCID: 221DE8CC48C56517A8F-8076
Reset counter: 196
Mileage: 261566 km
Date: 2018.08.14
Time: 09:16:18
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 392F2FA0C55306CF995-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 235
Mileage: 264521 km
Date: 2018.12.22
Time: 11:50:30
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D070BF0011BAA6F05D-8078
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000532978523
Coding: 0000503
VCID: 3C2136B4CA6133E7823-8068
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.136 H08 1901
VCID: 35372390E94BE2AF7DD-8060
Component: KSG PQ46 ELV 042 0472
Coding: 01900A00D1030E76300494157008CFCE707800
Component: Neigungssensor 004 0611
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 F HW: 3C0 035 456 F
Component: DSP 10 Kanal 0013
Revision: 00010000 Serial number: 00000000003218
VCID: 2313EDC857DF6C1FA39-8076
Reset counter: 223
Mileage: 261566 km
Date: 2018.08.14
Time: 09:16:11
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000009578608
Coding: 0000502
VCID: 3D273BB0D17B3AEFB5D-8068
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000063292
Coding: 0000057
VCID: 290FFFE035F3B64FE95-807C
Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
Component: AFS-Steuergeraet X014
Revision: H01 Serial number:
Coding: 2301953
VCID: 323D188C1825F59758F-8066
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0002
Coding: 00000035
Part No SW: 3C0 035 195 B HW: 3C0 035 195 B
Component: Radio PM6 010 0018
Revision: 00010000 Serial number: VWZ5Z7G1088439
Coding: 0010010
VCID: 1F1BE1387BB748FF871-804A
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1119
Revision: 11006001 Serial number: 00000001874166
Coding: 0000208
Address 69: Trailer (J345) Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 B HW: 1K0 907 383 B
Component: Anhaenger H14 0050
Revision: 3A002001 Serial number: 00000105019726
Coding: 0100000200000000
VCID: 2C0106F43601A367123-8078
02562 - Trailer; Brake Lamps
Fault Status: 11101010
Reset counter: 81
Mileage: 262709 km
Date: 2018.11.01
Time: 09:17:30
02564 - Trailer; Left Tail Lamps (M60)
Reset counter: 81
Mileage: 262709 km
Date: 2018.11.01
Time: 09:17:30
Part No SW: 3C9 827 383 B HW: 3C9 827 383 E
Component: J605 HECKDECKEL 0600
Revision: 00H21001
Shop #: WSC 23250 384 715754
VCID: 303912841629C7872EB-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0600
Subsystem 2 - Serial number: 0700H21001001C0138ÿ
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1119
Revision: 11006001 Serial number: 00000001875212
Coding: 0000208
VCID: 3E253CBCDC7D21F7AC7-806A
End----------(Elapsed Time: 02:04, VBatt start/end: 14.1V/14.2V)-----------
