Results 1 to 2 of 2
Thread: Byte 18 Canadian 2012 Tiguan Comfortline
    Jan 2019
    Canada
    Hi, all
    Bought this car 2 months ago and with the cold weather, we tried to enable remote with ignition on so I can lock it while warming it up in the morning. Comfortline is probably the US SE model as we have Trendline, Comfortline and Highline up here.
    Anyone knows the proper byte 18 for this car? The 09 was overwritten with a garbage code by a friends clone cable and has 00 in the original coding. Restored it with my new genuine Hex-V2 but not yet perfect.
    Car has dual halogen in front and dual brake/position lights in the back, no rear fog. DRL was the low beam dimmed, Scandinavian???
    Coding to 51 restored some functionality but still no DRL and outside brake/position hence the error code.
    Seems the 2 codes (50, 51) are both for Xenon with LED DRL-s.
    Also found AD and AE being used on some models?
    Any help would be greatly appreciated, I've been searching for 3 days now for a definitive answer. But I learned a lot about these tweaks .
    Here is my full scan:
    Wednesday,09,January,2019,20:17:56:04460
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WVGBV7AXXCW5xxxxxx   License Plate:
    Mileage: 111230km-69115mi   Repair Order:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 42 44 46 4C 4F 52 53 56
              62 72 77
    VIN: WVGBV7AXXCW553377   Mileage: 111230km-69115miles
    2E-Media Player 3 -- Status: Malfunction 0010
       Part No SW: 06J 997 029 P    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2    1519
       Revision: P3H07---    Serial number:
       Coding: 0423010A190F0160
       Shop #: WSC 44486 001 1048576
       VCID: 44D14E93829AC9E7FA3-8010
       Part No SW: 09G 927 750 NK    HW: 09G 927 750 LR
       Component: AQ 250 6F           2248
       Revision: 00H90000    Serial number:
       Coding: 0000328
       Shop #: WSC 26875 001 1048576
       VCID: 074B999FF32C22FFDF1-8052
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
       Component: J104   C6 450M VDAC 0005
       Revision: --H07---    Serial number: 00000005108059
       Coding: 0005161
       VCID: 79AFEF67B5D8440FD95-802C
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0304
       Revision: 00001016
       Coding: 0000004002
       VCID: 00598283DA8215C79EB-8054
       Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
       Component: BCM PQ35 M    021 0064
       Revision: BJ021001
       Coding: 6F180ABB88232EC4000800C1140085C448210086524D8D60648040000040
       VCID: 3FDB417FE77CAA3FA71-806A
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 08121  013 0203
       Serial number: N1955119   °203!
       Coding: 009795
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 172
                        Mileage: 111236 km
                        Date: 2013.06.01
                        Time: 20:12:59
                            Term 15 On
                        Voltage: 11.70 V
                        Reset counter: 172
                        Mileage: 111236 km
                        Date: 2013.06.01
                        Time: 20:12:59
                            Term 15 On
                        Voltage: 11.70 V
       Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
       Component: J234__204 VW10 HI   1918
       Revision: 23016000    Serial number: 003GJPPN8QW5
       Coding: 0012340
       VCID: 4ACD60ABA0BE1F9700F-801E
       Subsystem 1 - Part No: 5N0 959 339 B
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 00000000007F9K
       Subsystem 3 - Serial number: 0029.10.110000300000630025˙†63
       Subsystem 4 - Serial number: 630025˙†6332MTS618093181 ˙†63
       Subsystem 5 - Serial number: 93181 ˙†6342MTS631033171 ˙†63
       Subsystem 6 - Serial number: 33171 ˙†6351HTS6MEHNV9KJ ˙†63
       Subsystem 7 - Serial number: NV9KJ ˙†6361HTS6TI69R9KR ˙†63
       Subsystem 8 - Serial number: 9R9KR ˙†63727TS6G4GMV9KJ ˙†63
       Subsystem 9 - Serial number: MV9KJ ˙†63827TS69QQ4U9KJ ˙
       Subsystem 10 - Serial number: 4U9KJ ˙
       Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
       Revision: FF010040    Serial number: 20111202301303
       Coding: 198A100000
       VCID: 7CA1F673B66A7127C23-8028
       Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Coding: 820000
       Part No SW: 5N0 920 872 B    HW: 5N0 920 872 B
       Component: KOMBI         H04 0617
       Coding: 311F01
       VCID: 313F174721A84C4F215-8064
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 031211F2003873
       Coding: 356002
       VCID: 3D273B77ED70B82FB5D-8068
    01304 - Radio
                        Reset counter: 212
                        Mileage: 105964 km
                        Date: 2012.10.04
                        Time: 19:01:08
       Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
       Component: Haldex 4Motion      0043
       Coding: 0000005
       VCID: 4DC76BB751D008AF25D-8018
       Component: IMMO          H04 0617
       VCID: 6A8DC02BCCFEFF9720F-803E
       Revision: A1001003    Serial number: 7661426728
       VCID: 290FFF2709F8348FE95-807C
    01304 - Radio
                        Reset counter: 193
                        Mileage: 110994 km
                        Date: 2013.04.22
                        Time: 20:13:31
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0503
       Revision: 13110009    Serial number: 0003970693
       Coding: 0004F4
       VCID: 38292A63C2D29D0766B-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  007 1504
       Serial number: 00000006111212
       Coding: 000490
    67074 - Motors for Central Locking
              B122B 01 [008] - Electrical Failure
                        Reset counter: 212
                        Mileage: 111215 km
                        Date: 2019.01.07
                        Time: 08:52:05
    67330 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Fault Frequency: 6
                        Reset counter: 211
                        Mileage: 111215 km
                        Date: 2019.01.07
                        Time: 08:52:05
    132610 - Motors for Rear Central Locking
              B122C 01 [008] - Electrical Failure
                        Reset counter: 212
                        Mileage: 111215 km
                        Date: 2019.01.07
                        Time: 08:52:05
    132866 - Switch for Rear Central Locking
              B122E 29 [008] - Signal Implausible
                        Reset counter: 212
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.286 1002
       Revision: 1AH03836    Serial number: 00113370024901
       Coding: 0000258
       Shop #: WSC 00000 028 00001
       VCID: 3C213673FA6AB127823-8068
       Component: EZE_2         H40 1623
       Coding: 050B0500
       VCID: 6FBBD13FF79C1ABF771-803A
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H03 0220
       Component: J394EE20SKB13  H03 0220
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0003959318
       Coding: 0004F4
       VCID: 392F2F67F9D8840F995-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  007 1504
       Serial number: 00000006223730
       Coding: 000490
                        Reset counter: 212
                        Mileage: 111215 km
                        Date: 2019.01.07
                        Time: 08:52:05
                        Fault Frequency: 7
                        Reset counter: 211
                        Mileage: 111215 km
                        Date: 2019.01.07
                        Time: 08:52:05
                        Reset counter: 212
                        Mileage: 111215 km
                        Date: 2019.01.07
                        Time: 08:52:05
                        Reset counter: 212
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000492814
       Coding: 0026156
       VCID: 35372357D940606F7DD-8060
    Address 56: Radio
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661445861
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 270BF91F1F6C02FFFF1-8072
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 211
                        Mileage: 108634 km
                        Date: 2018.07.23
                        Time: 20:00:27
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 211
                        Mileage: 108634 km
                        Date: 2018.07.23
                        Time: 20:00:27
    0022 - Radio
              U1066 00 [008] - No Communication
              [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                        Reset counter: 193
                        Mileage: 110994 km
                        Date: 2018.11.30
                        Time: 20:13:26
    End----(Elapsed Time: 01:24, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
    Address 42: DTCs cleared
    Address 52: DTCs cleared
    Jan 2019
    Canada
    Coding to AD did the trick, all back to normal. Remote also enabled. Great tool, thx Ross-tech!
  3. Likes Uwe liked this post
