Hi all,
I'm after a little bit of advice to see if my request is at all possible with what I have on my vehicle.
At the moment my mirrors fold when locking the car via the keyfob but only unfold when the ignition is switched on, I would like to have the mirrors unfold on unlocking from the keyfob and not as it is currently when the ignition is switched on. I've also seen it might be possible to code the mirrors to unfold when opening the door and this would be better than my current setup.
Thank you in advance
Saturday,12,January,2019,11:06:43:53776
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8K7DA195*** License Plate:
Mileage: 69710km-43315mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 6D
72
VIN: WAUZZZ8K7DA195*** Mileage: 69710km-43315miles
Address 01: Engine (------CDNC) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0008
Revision: ECH09---
Coding: 12250013242601022000
Shop #: WSC 39619 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115 001010
ROD: EV_ECM20TFS0118K5907115.rod
VCID: 6FBBD05DF7102D7F771-803A
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K2 927 156 G HW: 0B5 927 156 J
Component: 0B5 20TFSIRdW H01 0003
Revision: --H01---
Coding: 000001
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 3A2D3109FCD2B8D790F-806E
Part No SW: 8K0 907 379 CJ HW: 8K0 907 379 CJ
Component: ESP8 quattro H09 0100
Coding: 091544
VCID: 03538CEDCB18391F839-8056
Part No SW: 8K0 907 064 GG HW: 8K0 907 064 FG
Component: BCM2 2.0 H12 0633
Coding: 01B24040000000000000
VCID: 7BA3F40DB3E841DFCB9-802E
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0513000001270004
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000002497011
Part No SW: 8K2 820 043 S HW: 8K2 820 043 S
Revision: D0000000 Serial number: 01170120132520
Coding: 642402C000
VCID: 392F2E05F954B3CF995-806C
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000539872102
Coding: 260000108034AFC00081400000001D0D0F1D470827090201000008004400030100000024000000
VCID: 77ABE83D8FC065BFAF1-8022
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 190113 H06 0080
Serial number: SWF13010190129
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20892535
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001501131186
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 1278CA86000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD97R82I
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 26548 001 1048576
VCID: 48C95BC1B23EDA4716B-801C
Serial number: 6334MSME7741274BG
Serial number: 6344MSME7611722DD
Serial number: 6352QSME152708606
Serial number: 6362QSME4F284358R
Serial number: 63732SME4527004CX
Serial number: 63832SME45274F688
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130121000641
Coding: 000037
VCID: 4FFB70DD57D00D7F571-801A
Component: E221 - MFL H03 0004
Part No SW: 8K0 920 982 C HW: 8K0 920 982 C
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UVM75CJ1E
Coding: 2FB7110002012600010000
VCID: 34311F31DE364EA74A3-8060
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y13115065C
Coding: 80CF07FF00
VCID: 4ACD61C9ACB2285700F-801E
Serial number: 7176399001
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 13012001485021200410
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000049136979
Coding: 011C02205C01410001
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0008170815
Coding: 100000000001
Shop #: WSC 06334 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311F31DEB64EA74A3-8060
Revision: 00002001 Serial number: 0300030847
Coding: 013B162220B93094803002368000000F
Shop #: WSC 06335 123 12345
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 15
Mileage: 69491 km
Date: 2019.01.02
Time: 19:53:41
02616 - Fuel Tank Cap; Unlock
Reset counter: 15
Mileage: 69491 km
Date: 2019.01.02
Time: 19:53:44
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813009757102
VCID: 2D070A553D1C1F6F05D-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000048966551
Coding: 011C02205E01410001
VCID: 4EC56DD950DA04775C7-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000202033
ROD: EV_ParkiBrake_AU48.rod
VCID: 38292B01C2DEAAC766B-806C
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109A-0D7607763
Coding: 010103010000000001
Part No SW: 8R2 035 666 L HW: 8R2 035 666 C
Component: H-BN-EU H45 1036
Revision: -------- Serial number: 206AS0D7515138
Coding: 0F0101010106C1ED01808B5E00000403E40000020000000000
VCID: 42DD49E99482F017C8F-8016
Subsystem 1 - Part No: 8R0 060 884 FK
Component: EUR 2018/2019 2702
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130LZ0C2630389
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000001382328
Component: CD-Database 4949
00862 - Antenna for GPS Navigation (R50/R52)
Reset counter: 35
Mileage: 69719 km
Date: 2019.01.12
Time: 11:03:52
Voltage: 11.90 V
03623 - Invalid Secruity/Release Code
Reset counter: 35
Mileage: 69719 km
Date: 2019.01.12
Time: 11:03:42
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000048979147
Coding: 010C02204001210001
VCID: 46D555F9B8AACC37E47-8012
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H52 0330
Revision: -------- Serial number: 8K9827851A
VCID: 3C213711F66686E7823-8068
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H52 0330
Serial number: 8K9827852A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000048984863
End----(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
