Results 1 to 8 of 8
Thread: 2004 transporter tdi speed limit request
    Jan 2019
    Hi, I’m trying to set a 70mph limiter in a customers van. I have used the log in code of 12233 to access the adaption channel 7. The current limit is 255kmh! The stored value is 300. In the drop down menu at the top I have only 3 choices (speed limiter, immobiliser and another immobiliser) when I choose the speed limiter it won’t let me change the value from 300 as if I do change it, the test and save buttons grey out. Am I doing anything wrong or can this vehicle simply not have a limiter applied? Thanks,mark.
    You realize that if you manage to do this, it is most likely irreversible?
    Please post an Auto-Scan so people can see exactly how this van is equipped.
    Jan 2019
    Hi uwe, yes I’m aware that it can’t be reversed without remapping in the future but the van is for a customer, and they understand this too. I will take a scan now and hopefully we can work this out. Thanks for your help
    Jan 2019
    Saturday,12,January,2019,09:23:06:06146
    VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4437.4
    Dealer/Shop Name: eden valley autos
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ4H050771   Mileage: 350910km-218045miles
    Address 01: Engine        Labels: 038-906-016-AXB.clb
       Part No SW: 038 906 016     HW: 028 101 073 4
       Component: R4 1,9L EDC 0000SG  5225
       Revision: 12345678    Serial number: VWZ7Z0C8382643
       Coding: 0000031
       Shop #: WSC 00999 444 64523
       VCID: 51FE83553DF8BAAF418-5160
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
       Part No: 7H0 907 379 E
       Component: ASR FRONT MK25      0103
       Coding: 0007205
       Shop #: WSC 02756 785 00200
       VCID: 372ADDCDB35C049F6FC-513C
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 K
       Component: BORDNETZ SGVER 1.0  1901
       Coding: 0000100
       VCID: 3A2CC4F9804E19F7902-513C
    01598 - Drive Battery Voltage
    00077 - Windshield Wiper Stop Switch (F229)
    00538 - Reference Voltage
                014 - Defective
    00909 - Windshield Wiper Motor (V) Stage 1/2
       Part No: 1C0 909 605 A
       Component: 3B AIRBAG VW51      0008
       Coding: 13122
       Shop #: WSC 02756
       VCID: 221C1C990DDE7137A82-513C
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 950 L
       Component: KOMBI+WEGFAHRSP VDO V01
       Coding: 03411
       VCID: 3430EAC1A72AEF874AE-513C
       WV1ZZZ7HZ4H050771     VWZ7Z0C8382643
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02756
       VCID: 70B826D193B293A76E6-513C
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433
       Component:    Komfortgerát     0004
       Coding: 00069
       Shop #: WSC 02756
       VCID: 70B826D193B293A76E6-4B1E
       Subsystem 1 - Part No: 7H2959802
       Component: Tõrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 7H2959801
       Component: Tõrsteuer.BF KLO 0202
    Address 56: Radio        Labels: 1J0-035-15x-56.lbl
       Part No: 6X0 035 152 C
       Component:  Radio BNO         0006
       Coding: 00001
       Shop #: WSC 02737
       VCID: 313EE3D55838DAAF218-4B00
    00852 - Loudspeaker(s); Front
                36-00 - Open Circuit
    End----------(Elapsed Time: 06:12, VBatt start/end: 12.2V/12.1V)-----------
    Try [Security access-16]
    Do you have data in channel 18 ?
    Jan 2019
    Hi, there is no data in channel 18. Thanks
  7. #7
    Seems like it should indeed be Adaptation Channel 7 in that ECU.
    However, I'm puzzled by:
    Quote Originally Posted by eden-valley-autos View Post
    What makes you think the limit is 255 when the stored value is 300? Surely a ~100hp AXB engine cannot push this van to anywhere near 255 km/h.
  8. #8
    Jan 2019
    The actual data block states the max speed as 255kmh but the value set is 300. Ive just been informed that the van has indeed been remapped several years ago so I’m thinking it may of had its max speed limit altered, although a ~130ish bhp t5 has no hopes of ever achieving that speed anyway. I will load a standard file back on to the Ecu with our kess and see if the value changes. Will be interesting to see what affect that has!
    Thanks,mark.
  9. Likes Uwe liked this post
