Results 1 to 8 of 8
Thread: Parking assistance Audi A5 8T 2014
    Jan 2019
    park assistance Audi A5 2014
    I try to enable the park assistance in the MMI display on an Audi A5 2014. The car has only parking sensor at the back. But the module 10 isn't available. In the MMI menu I could only configure the parking sound. When I enable the module 10 in the gateway installatiemonteur list I get an error message when I do the autoscan. Hopefully anybody has aan idea How I Could fix this?
    VIN: WAUZZZ8T3EA047960 License Plate:
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
    VIN: WAUZZZ8T3EA047960 Mileage: 91140km-56631miles
    You can't just enable a module that doesn't exist.
    Please post your whole scan. There's not much that can be seen from just the Gateway Installation List.
    Jan 2019
    Thursday,20,December,2018,19:11:12:05254
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: Bittuning
    VIN: WAUZZZ8T3EA047960   License Plate: 6TJH45
    Mileage: 91140km-56631mi   Repair Order:
    Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
       Part No SW: 8K0 906 264 A    HW: 8K0 906 264
       Component: 1.8l R4 TFSI  H09 0004
       Revision: --H09---
       Coding: 1A030032242401022000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
       ROD: EV_ECM18TFS0218K0906264A.rod
       VCID: AF2E6EA0F6094A32FC-80FA
    15077 - Idle Control System RPM
              P0507 00 [096] - Higher than Expected.
    15262 - Oxygen (Lambda) Sensor B1 S1
              P2196 00 [096] - Signal too High (Rich)
    14880 - No Communications with HVAC Control Module (J301)
              U0164 00 [032] - -
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 8K5 927 155 F    HW: 0AW 927 156 K
       Component: 0AW_18TFSIRdW H06 0004
       Revision: --H06---    Serial number: 0000001495
       Coding: 000002
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMVL381 A02433
       ROD: EV_TCMVL381.rod
       VCID: BB364AF03271A69240-80EE
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CL    HW: 8K0 907 379 CL
       Component: ESP8 front    H09 0020
       Coding: 05154401
       VCID: 8542EC080C35206266-80D0
       Part No SW: 8K0 907 064 JE    HW: 8K0 907 064 JE
       Component: BCM2 2.0      H14 0650
       Coding: 01A44000000000000000
       VCID: FCB489EC7FFF61AA09-80A8
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0514000003964007
       Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
       Component: KLIMA 1 ZONE  H02 0121
       Revision: A1000000    Serial number: 01160120142670
       Coding: 642002C000
       VCID: B73E56C0065982F2A4-80E2
       Revision: 08016001    Serial number: 00000058767701
       Coding: 260000108034AFC00081400300001D0D001C430826090201000004004401020100000020000000
       VCID: F8BC95FC4BC74D8A6D-80AC
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 160114  H15 0080
       Serial number: SWF14010165042
       Coding: 00FD11
       Serial number: 22144122
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000801141780
       Serial number: 7559C907000000000001
    01854 - Heated Seat; Front Right (Z46)
                        Reset counter: 242
                        Mileage: 89387 km
                        Date: 2018.10.03
                        Time: 20:27:45
    01853 - Heated Seat; Left Front (Z45)
                        Reset counter: 243
                        Mileage: 89388 km
                        Date: 2018.10.12
                        Time: 10:28:02
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003KFDB3R39I
       Coding: 30513938363030303030554A304C38543053
       VCID: C8DC253C73A7FD0ADD-809C
       Serial number: 6334MSME416A451BF
       Serial number: 6344MSME416D1914D
       Serial number: 6352QSME6B3B1B4C-
       Serial number: 6362QSME733B0678N
       Serial number: 63732SME0A3C1D465
       Serial number: 63832SME0A3C2E6CG
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NAI000UC
       Coding: 000016
       VCID: C8DC253C7BA7FD0ADD-809C
       Part No SW: 8T0 920 932 L    HW: 8T0 920 932 L
       Component: KOMBIINSTR.   H35 0564
       Revision: 00000000    Serial number: Z9D30861F
       Coding: 13873000020100080D0000
       VCID: C1CA3818589DCC421A-8094
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y141030839
       Coding: 80CF07FF00
       VCID: CAD81F3465AB0F1ACB-809E
       Serial number: 8000132203
       Serial number: 14010004675011200181
       Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
       Component: TSG FA        H09 0305
       Coding: 011003624000450005
       VCID: D7FEF640A61962F244-8082
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0003179000
       Coding: 100000000001
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: B5225CC8145570E2B6-80E0
       Revision: 00002001    Serial number: 0323372658
       Coding: 013B0638A0B900008330043680000047
       Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
       Component: TSG BF        H08 0305
       Coding: 011003224000450005
       VCID: D6E0FB44A1135BFA5F-8082
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 10000000313226
       ROD: EV_ParkiBrake_AU48.rod
       VCID: B93A50F8384D948252-80EC
       Part No SW: 4G1 035 053 H    HW: 4G1 035 053
       Component: Radio U Basic H41 0134
       Revision: AB001007    Serial number: 226AZ0E7874116
       Coding: 010003020100000001
       VCID: A404918CA7CFF96A11-80F0
       Part No SW: 8R1 035 652 D    HW: 8R1 035 652
       Component: B-BN-EU       H62 0188
       Revision: --------    Serial number: 148A-0E7762640
       Coding: 01010004000681ED01800B4E000000030001
       VCID: B42461CC172F69EA81-80E0
       Subsystem 1 - Part No: 4G0 919 884 N
       Component: EUR 2014  1702
       Subsystem 2 - Part No SW: 8T0 919 604 B    HW: 8T0 919 604 B
       Component: DU6 Basic  H43 0098
       Serial number: 9465LB0D2696295
       Subsystem 3 - Part No SW: 8T0 919 611     HW: 8T0 919 611
       Component: E0380 Bedient  H01 0100
       Serial number: 00000001725012
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0305
       Coding: 010003224000450005
       VCID: D9FAF078D00D748272-808C
       Component: TSG HR        H07 0305
    End----------(Elapsed Time: 01:37, VBatt start/end: 13.8V/13.7V)-----------
    Address 5F,8R1 035 652 D,channel 6,adapted from,0,to,1,
    Address 19,8R0 907 468 N,recoded (Installation List),from,FF30742C00028100,to,FF30742D00028100,,
    Address 19,8R0 907 468 N,recoded (Installation List),from,FF30742D00028100,to,FF30742C00028100,,
    Address 19: DTCs cleared
    Address 09: DTCs cleared
    Gateway Installation List:  8R0 907 468 N
    Address 52,8T0 959 792 Q,recoded (Long Coding),from,011003224000450005,to,011003224C00450005,(06325/000/00000),Thursday,20,December,2018,20:02:19:05254
       Revision: --H09---
              U0164 00 [032] - -
       Coding: 000002
       Coding: 05154401
       Coding: 642002C000
       Coding: 260000118134AFE01481400300001D0D009C430826090201000004004401020100000020000000
       Coding: 00FD11
       Coding: 02005D
       Coding: 000016
       Coding: 138F3000020100080D0000
       Coding: 80CF07FF00
       Coding: 011003224C00450005
       Coding: 01010004000681ED05800F4E000000030001
    End----------(Elapsed Time: 01:35, VBatt start/end: 13.8V/13.8V)-----------
    Address 09,8K0 907 063 DH,recoded (Long Coding),from,260000118134AFE01481400300001D0D009C430826090201000004004401020100000020000000,to,260080118134AFE01481400300001D0D009C430826090201000004004401020100000020000000,(06325/000/00000),
    Address 09-02,8U0 955 559 B,recoded (Long Coding),from,02005D,to,03005D,(06325/000/00000),
    Address 44,8K0 909 144 G,recoded (Long Coding-exp),from,100000000001,to,100000010001,(06324/000/00000),
    Address 09,8K0 907 063 DH,recoded (Long Coding),from,260080118134AFE01481400300001D0D009C430826090201000004004401020100000020000000,to,260080118134AFE01481400000001D0D009C430826090201000004004401020100000020000000,(06325/000/00000),
    Thursday,20,December,2018,21:01:45:05254
       Revision: --H09---
              U0164 00 [032] - -
       Coding: 000002
       Coding: 05154401
       Coding: 642002C000
       Coding: 260080118134AFE01781400000001D0D009C430826090201000004004401020100000020000000
       Coding: 00FD11
       Coding: 03005D
       Coding: 000016
       Coding: 80CF07FF00
       Coding: 100000010001
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.2V)-----------
    Jan 2019
    thanks for the fast response, hopefully you had a solution. thanks for reaction.
    I don't think I understand exactly what it is you are trying to accomplish.
    Jan 2019
    https://www.bing.com/images/search?v...=82&ajaxhist=0
    Hereby an image what I am trying to work
  7. #7
    Jul 2014
    Tallinn, Estonia
    If there are sensors in the back and no module 10, then it could be an aftermarket installation with no integration with the rest of the car. PL24 users can verify if this car is equipped with PDC from the factory.
  8. #8
    Jan 2019
    Thanks for reaction, in my opion the sensors are from factory default because they are integrated in the MMI for the sound settings.
