Results 1 to 2 of 2
Thread: 6R GTI Mechatronic
    New User
    Nov 2018
    South Africa
    6R GTI Mechatronic
    Hi Guys
    I've got a 2013 Polo GTI and the mechatronic unit failed after it was repaired and reinstalled i reset the car as instructed by the guy who fixed it.
    " Disconnect Mechatronics unit, remove both battery terminals.
    Touch the terminals together for about 5 seconds.
    Reconnect the Mechatronics unit and leave the battery disconnected for 120 mins.
    Reconnect the battery and switch the ignition on and leave it on in the on position for 45 mins.
    Switch the key off and remove the key from the ignition.
    put key back in the ignition and switch it back on, depress the accelerator completely until the switch make contact, hold it there for 2 seconds and let go (repeat this
    process 5 times)
    Then start the car"
    When i try and start the car it tells me to put it in P/N, The gear selector was tested, it indicates on the dash if the gear selector is moved or not, it was rested using vag com, and also indicates all movements made.
    All fuses check out fine.
    any help will be appreciated please
    Hi and welcome to our forum.
    Please [url=https://forums.ross-tech.com/showthread.php?101]post an Auto-Scan for context.
