Results 1 to 8 of 8
Thread: Mk7 Golf Fault Code
    Jan 2019
    Mk7 Golf Fault Code
    HI
    Im awaiting for my cable to arrive (tomorrow) and will be verified then.
    The other day i was swapping the infotainment out for my Pioneer unit with the connect2 infoadapter, everything was going to plan until the epb warning light came on.
    I forgot to connect the park cable (green) to the pioneer unit.
    I have the fault code :-
    32837 - Lamp in Switch for Electronic Parking Brake
    C1145 13 [009] - Open Circuit
    Have I blown the lamp in the parking brake switch? I connected the 2 cables together after the warning light came on.
    Do I need to get a new switch or can i get a replacement lamp, will i need to disconnect the battery first before i do this work?
    Is this the correct diagnosis?
    Thanks in advance
    Dave
    Hi and welcome to our forum.
    Please post a proper Auto-Scan when you get your real cable tomorrow.
    Apr 2018
    ITALY
    and disconnect the battery! take it as a good habit when you perform any kind of electrical installation/repair.
    Jan 2019
    So my cable has arrived and here is the auto scan as requested
      Friday,11,January,2019,14:52:05:13806
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WVWZZZAUZFW090998   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
    VIN: WVWZZZAUZFW090998   Mileage: 112887km-70144miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
       Component: R4 2,0L EDC   H22 7539
       Revision: 81H22---
       Coding: 01190012034505082000
       ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
       ROD: EV_ECM20TDI01104L906021AE.rod
       VCID: 77ABE8371F4E1A5FAF1-8022
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 62134000000140
       Coding: 01FA8AA13429096C0380060941CB2980512C90C0608294F5F4605078C009
       VCID: 074B98F76FAE6ADFDF1-8052
              C1145 13 [137] - Open Circuit
                        Reset counter: 138
                        Mileage: 112647 km
                        Date: 2019.01.07
                        Time: 15:47:00
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   H03 0907
       Revision: 00001K08
       Coding: 00120114202100011005000000101000
       VCID: 73B3DC270B36767F939-8026
    1048834 - Functional Limitation due to Energy Management
              B10CD 00 [009] -  -
              [PTC-Reduzierung durch BCM]
                        Fault Frequency: 50
                        Reset counter: 139
                        Mileage: 110633 km
                        Date: 2018.10.30
                        Time: 17:27:42
                        Voltage terminal 30: 14.0 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 2
                        Auxiliary heater: in stages-Act.val.: 1
              P1719 00 [008] - -
              [PTC-Reduzierung durch MSG]
                        Fault Frequency: 149
                        Reset counter: 179
                        Mileage: 110633 km
                        Date: 2018.10.16
                        Time: 11:21:04
                        Voltage terminal 30: 13.6 V
    459025 - Databus
              [Radio - kein Signal/Kommunikation]
                        Reset counter: 174
                        Mileage: 112647 km
                        Date: 2019.01.07
                        Time: 15:42:35
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011421804296
       Coding: 03100A46C24122FB0BA44080B10C07281000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 005983EB4A805DE79EB-8054
       Component: WWS    140724  042 0551
       Serial number:         140728105227
       Component: RLHS  037 0059
       Serial number: S4Y14M08D18H02M34S13
       Coding: 00A8DD
       Serial number: 000000000ZY1420200U3
       Serial number: 00000000000060218428
       Sun Roof:
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO31547633
       Coding: 181901
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Fault Frequency: 84
                        Reset counter: 116
                        Time: 00:00:00
    460041 - Heated Rear Window
              B1265 14 [008] - Open or Short to Ground
                        Reset counter: 178
                        Mileage: 112878 km
                        Date: 2019.01.09
                        Time: 16:35:16
    919560 - Light Switch
              B126A 29 [008] - Signal Implausible
                        Reset counter: 178
                        Mileage: 112878 km
                        Date: 2019.01.09
                        Time: 16:35:16
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39331420904094
       Coding: 0071051001
       VCID: 3D273A1F7DF2F00FB5D-8068
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 11081477030458
       Coding: 00000300FE0739
       VCID: 38292B0B52D0D52766B-806C
       Component: AirbagVW20    014 0386
       Serial number: 003MLR07UDSM
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5B0017377E221FE71-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169677B18081470610
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169676B14081441038
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 408 14
       Serial number: 35767000000E5931A01S
       Subsystem 4 - Part No SW: -----------    HW: 480 001 408 14
       Serial number: 35867000000A4C7C901+
       Subsystem 5 - Part No SW: -----------    HW: 480 401 108 14
       Serial number: 3516502BB16DB81391BM
       Subsystem 6 - Part No SW: -----------    HW: 480 401 208 14
       Serial number: 35265029D16FC225A35K
       Subsystem 7 - Part No SW: -----------    HW: 480 401 408 14
       Serial number: 3556502B916DB811D13I
       Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 12081404220638
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7BA3F40723663E3FCB9-802E
       Part No SW: 5G1 920 957     HW: 5G1 920 957
       Component: KOMBI         301 4270
       Coding: 27AD09002F80260001886A011400000000000000
       VCID: 6D87CA5F6D12A08F45D-8038
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002351792
       Coding: 030100040B087300EF00027E080F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011_VW37.rod
       VCID: 42DD49E3040C8FF7C8F-8016
       Component: E221__MFL-DC1  H10 0038
       Serial number: 27140001959420024324
       Coding: 2CFFFF
       Serial number: 8808324003
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [008] - Performance
              [Globaler Timeout CAN-Infotainment]
                        Reset counter: 174
                        Mileage: 112647 km
                        Date: 2019.01.07
                        Time: 15:42:30
                        Supply voltage: Terminal 30: 11.2 V
                        Terminal 15: On
    66565 - Diagnostic Databus
              U1202 00 [008] - Malfunction
              [Bus defekt CAN-Diagnose]
                        Reset counter: 177
                        Mileage: 112861 km
                        Date: 2019.01.08
                        Time: 18:38:02
                        Terminal 15: On
    8526355 - Voltage Drop in Generator Leads too large
              P30DE 00 [008] - -
                        Fault Frequency: 57
                        Reset counter: 177
                        Mileage: 111317 km
                        Date: 2018.12.13
                        Time: 19:10:34
                        Supply voltage: Terminal 30: 13.6 V
                        Terminal 15: On
       Serial number: 30071401101297
       Coding: 003F0220D001048000001000
       VCID: 40D943EB0A009DE7DEB-8014
       Serial number: 00000000000003469395
       Coding: 1D0000
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3537223F45C2284F7DD-8060
       Serial number: 30071406070075
       Coding: 003F0020DE01048000801000
       VCID: 3FDB401777FEE21FA71-806A
       Serial number: 00000000000003506153
       Coding: 050000
       Coding: 029E01000B000200
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    041 0430
       Serial number: V7F00908142447
       Coding: 02730001FF00000021111201000800001F0202060100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 678BB8774FEE8ADF3F1-8032
       Component: ABT_Std_Nav  H60 0030
       Serial number: VWZ8Z9PS402W7Y
       Subsystem 2 - Part No SW: 5G0 919 866 AG    HW: -----------
       Component:  ECE 2018  --- 0072
       Serial number: 140716200280
       VCID: 6B83C4475306AEBF5B9-803E
    End----------(Elapsed Time: 01:52, VBatt start/end: 12.3V/12.2V)-----------
  5. Likes Uwe liked this post
    Hmm... Are you quite certain that everything is connected properly now?
    Apr 2018
    ITALY
    module 5F is still there and happy so what about the Pioneer?
    Jan 2019
    The Pioneer will be installed another time, im not getting the driver information on the head unit through the infoadapter, im awaiting a call back from connect2 tech support.
    The other issues i have is with the HVAC, the passenger side vents are fine and blow hot from the heater but the two vents, right hand side of centre console and the vent to the right
    of the steering wheel blow cold,
    B10CD 00 [009] - -
    P1719 00 [008] - -
    459025 - Databus
    How do i decipher this into a faulty component?
    Over the weekend i will dl the repair manuals from erwin but any guidance would be appreciated
  9. #8
    Quote Originally Posted by Dave Witchdoktor View Post
    B10CD 00 [009] - -
    P1719 00 [008] - -
    459025 - Databus
    None of these are directly indicative of a fault component.
