Results 1 to 6 of 6
Thread: Display of "sensor for reducing agent fill level" may be misreading
    Acton, Ontario, Canada
    I have a 2011 Touareg TDI and have checked the DEF level under "advanced measuring values"/"sensor for reducing agent fill level" and it displayed 80.40% and fluctuated up to 80.42%. Oddly I watched a youtube video and this and his displayed the same thing. I then added 9.5L of DEF and checked the sensor for reducing agent fill level and it displayed the same thing again with no change.
    Odd that both video and my results are the same thing ( https://www.youtube.com/watch?v=z7kkQJO_Oaw) 3:49 time line.
    Thanks Brett
    VCDS shows what the ECU tells it.
    PS: We've seen this ~80% stuff in a number of different TDIs with Adblue. I believe at one point, we checked with ODIS and it shows the same thing for that value. Unfortunately, we don't have such a TDI on-site at the moment to check with ODIS again.
  3. Likes Dana liked this post
    Tuesday,08,January,2019,17:54:21:08843
    VCDS Version: 18.9.0.2 (x64)
    VIN: WV   License Plate:
    Mileage: 205785km-127868mi   Repair Order: Jan 8
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 56 5F 62 65 69
              6D 72
    VIN: WVGFK9BP0BD006617   Mileage: 205785km-127868miles
    Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
       Component: 3.0TDI FSA    H17 0008
       Revision: 56H17---
       Coding: 292A4012233600050000
       Shop #: WSC 93363 999 00000
       ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
       ROD: EV_ECM30TDI0117P0907401J_002.rod
       VCID: 366328098965F6FA3F-8062
    8863 - Diesel Particulate Filer
              P2459 00 [096] - Regeneration Frequency
       Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
       Component: AL1000 AISIN  001 3407
       Coding: 001368
       Shop #: WSC 57463 002 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 306F1E116B01D8CA65-8064
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
       Component: MK25A         H36 0418
       Revision: --------    Serial number: 410510010EC010
       Coding: 5B7613C349242559DAFAC89492D9A4407700
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A00700.rod
       VCID: 45815FC5C4836D62A6-8010
       Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
       Component: BCM2 2.0      H24 0217
       Coding: 0D860000000000000000
       VCID: 72EBD419AD8DAADAD3-8026
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 3216000013415007
    03285 - Sensor for Contact with Door Handle; Front Left
                        Reset counter: 149
                        Mileage: 201172 km
                        Date: 2018.11.12
                        Time: 11:16:56
       Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
       Component: Klima 2 Zonen H18 0613
       Coding: B686000A80
       VCID: 79F9E335F8FBD98292-802C
       Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0092
       Revision: 15012002    Serial number: 00000001038483
       Coding: 69000012873C5D010004000380005F5F431C660882000261800000000000
       VCID: 31691B15680BD1C26A-8064
       Component: WWS    110410  31  0020
       Serial number: 90243400110414020710
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10156813
       Coding: 035223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000000604110089
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0CFB06
       Subsystem 5 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA102408000000239210
       Coding: 010300
       Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
       Component: VW10Airbag025 H05 0023
       Revision: --------    Serial number: 003JX002AHA8
       Coding: 000000000000000000000000000000003235
       VCID: 408F4ED1DBA1484A95-8014
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R10B0902D28
       Serial number: 3575LRB40590G690EGJ5
       Serial number: 3585LRB40590G69071HP
       Serial number: 3515RRB405B0GQ8Q8P81
       Serial number: 3525RRB405B0GQ8QK8K9
       Serial number: 3555NRB405V0HBQUKP8+
       Serial number: 3565NRB405V0HBQUFOM7
       Part No SW: 4H0 953 568 B    HW: 7P6 953 507 A
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KDD0002D
       Coding: 000C15
       VCID: 326B14196D0DEADA13-8066
       Serial number: 0073674
       Part No SW: 7P6 920 880 P    HW: 7P6 920 880 P
       Component: Kombi         H13 0239
       Revision: 11240062    Serial number: 658170411593006
       Coding: 0B37310023000008020004
       Shop #: WSC 93222 999 00000
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 489F56F1F391700A5D-801C
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000130987
       Coding: 0001037500
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 387F26318371008A2D-806C
       Serial number: 00000000005650308704
       Revision: AA000000    Serial number: 00000006072418
       Coding: 00581B0000004001000001010101202020202121202020
       VCID: 346712019719E4EA01-8060
       Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
       Component: TSG FA        H07 0162
       Revision: --------    Serial number: 0000115321792
       Coding: 011D17205E00453005080000
       VCID: 3C773A21BF492CAAC9-8068
       Revision: 00002001    Serial number: 0147989591
       Coding: 0186123A28B9509580A00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 285102155
       Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
       Component: J245 PS30.050  H07 0006
       Serial number:     WOO11773474
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
       Component: J394 PS30.050  H07 0006
       Serial number:     WOO11781877
       Coding: 191100
    02616 - Fuel Tank Cap; Unlock
                        Fault Status: 00101001
                        Fault Frequency: 18
                        Reset counter: 69
                        Mileage: 202586 km
                        Date: 2018.11.29
                        Time: 17:28:01
    02615 - Fuel Tank Cap; Lock
                        Fault Frequency: 26
                        Reset counter: 67
                        Mileage: 202619 km
                        Date: 2018.12.01
                        Time: 09:59:03
    00984 - Left Tail Light (M4)
                        Fault Status: 00101100
                        Reset counter: 49
                        Mileage: 204599 km
                        Date: 2018.12.21
                        Time: 15:08:23
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0162
       Revision: --------    Serial number: 0000115179356
       VCID: 3B75393DBA472B92C0-806E
       Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
       Component: EPB           H51 1100
       Revision: 00000000    Serial number: A11302000FF
       Coding: 01040000
       ROD: EV_ParkbA7.rod
       VCID: 35612F059463FDE236-8060
       Slave 3:
       Component: Radio U SIRIU H51 0133
       Revision: AB001007    Serial number: 471D+0B7573584
       Coding: 020007020100000001
       VCID: 2447E24127F9746A91-8070
       Part No SW: 7P6 035 664 D    HW: 7P6 035 664
       Component: H-BN-NA       H43 0706
       Revision: --------    Serial number: 445DT0B7514036
       Coding: 010200050040E1EC41022B0C00000003F00001010000000000
       VCID: 39792335B07B1982D2-806C
       Subsystem 1 - Part No: 7P6 060 884 J
       Component: NAR 2017/2018  1602
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H24 0045
       Serial number: VWZ8Z9L2900652
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
    03175 - Invalid Data Set
                        Reset counter: 149
                        Mileage: 201169 km
                        Date: 2018.11.11
                        Time: 19:49:00
                        Voltage: 11.90 V
    03623 - Invalid Secruity/Release Code
                        Reset counter: 149
                        Mileage: 201169 km
                        Date: 2018.11.11
                        Time: 19:49:01
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0162
       Revision: --------    Serial number: 0000115334906
       Coding: 011C17200000253005080000
       VCID: 3A7B3C39B57D129ADB-806E
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000027751
       ROD: EV_RDKBERU25_VW52.rod
       VCID: 3F8D4D2DA65F37B2EC-806A
    8402177 - System Switched Off
              C106D 00 [009] -  -
                        Reset counter: 162
                        Mileage: 201639 km
                        Date: 2018.11.16
                        Time: 15:27:46
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H09 0110
       Revision: 5A001001    Serial number: 00000146664417
       Coding: 020D000000000000
    00335 - Control Circuit Taillights
                010 - Open or Short to Plus - Intermittent - MIL ON
                        Fault Status: 10101010
                        Reset counter: 36
                        Mileage: 204332 km
                        Date: 2018.12.18
                        Time: 10:35:29
    02579 - Trailer; Left Brake Lamps (M65)
                        Fault Status: 11101010
                        Reset counter: 248
                        Mileage: 204332 km
                        Date: 2018.12.18
                        Time: 10:35:29
       Part No SW: 7P6 959 107     HW: 7P6 959 107
       Component: HDSG-Modul    H10 0611
       Revision: 22010001    Serial number: 101100597
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202135
       ROD: EV_HeckkTouar.rod
       VCID: 7CF7FA21F7C9ECAA89-8028
       Component: TSG HR        H09 0162
       Revision: --------    Serial number: 0000115333044
    End-------------------------(Elapsed Time: 04:54)--------------------------
    Thanks Brett
       Revision: 56H17---
    I don't see anything else in there that looks like it might be the amount of DEF in the tank.
    Hopefully I can eyeball the level??
    Thanks Brett
    United States
    The older CAN protocol 3.0L Q7 and T'reg required key on, engine off for a certain time frame before the level would refresh. That's similar to the hood needing to be opened and closed before the MMI/radio oil level will refresh.
    You might want to re-check that in a day or two after the system had had a chance to self-test to see if the advanced measuring value happens to increase.
  8. Likes Eric liked this post
