Results 1 to 5 of 5
Thread: Is this Golf 'Chipped'
    Jun 2014
    Newcastle, England
    A friend of mine has asked if his car has a modified ECU - as his 'butt dyno' seems to think so.
    Reports some peculiar Mode 9 results, I would have expected more, but I don't know if it too early to report meaningful stuff in there. Thank You.
    AutoScan:
    Monday,10,December,2018,15:26:02:19335
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4447.4
    VIN: WVWZZZ1KZ5W168670   License Plate:
    Mileage: 128550km-79877mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ5W168670   Mileage: 128550km-79877miles
       Part No SW: 1K0 907 115     HW:
       Component: 2.0l R4/4V TFSI  00 0070
       Revision: --H01---    Serial number: VWZ7Z0D1162876
       Coding: 0403000318070060
       Shop #: WSC 00400 210 83214
       VCID: E386EF2B221EBF5228-80B6
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Temperature: 4.0°C
                        Temperature: 6.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.192 V
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0004738
       Shop #: WSC 01279 785 00200
       VCID: BA38724FF5149E9A5B-80EE
       Part No: 1K0 907 044 AC
       Component: ClimatronicPQ35 066 0404
       VCID: E89CF807DB38DC0AFD-80BC
       Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000001262021
       Coding: E58D8F0600041800001400001400000000087F075C
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00218142
       Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
       Component: 08 AIRBAG VW8   013 2100
       Revision: 02013000    Serial number: 0033HD02PA0U
       Coding: 0012344
       Shop #: WSC 01269 785 00200
       VCID: AC1444170F40302AD9-80F8
       Subsystem 1 - Serial number: 6332MSME077801093
       Subsystem 2 - Serial number: 6342MSME077823076
       Subsystem 3 - Serial number: 6351HSME051F175CD
       Subsystem 4 - Serial number: 6361HSME053E41713
       Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
       Component: Lenksäulenmodul 521 0050
       Coding: 0000012
       VCID: B5226173DC0A71E2B6-80E0
       Part No: 1K6 920 960 D
       Component: KOMBIINSTRUMENT VDD 0812
       Coding: 0003403
       Shop #: WSC 57250 067 57207
       VCID: B02C5067236854CAE5-80E4
       Part No SW: 1K0 907 530 E    HW: 1K0 907 951
       Component: Gateway         H09 0110
       Revision: 09          Serial number: 2700104B1906B3
       Coding: 3D3F0340070003
       VCID: A91ABD0300B2250222-80FC
       Component: IMMO            VDD 0812
       Shop #: WSC 01287 111 53348
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0148
       Coding: 0000052
       Part No: 1K2 909 144 H
       Component: EPS_ZFLS Kl.12      1502
       VCID: B12A556328625DC2EA-80E4
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 80C802087F2D8505485FC69010
       Shop #: WSC 36501 001 1048576
       VCID: FBB6B74BBAAE679200-80AE
       Component: LIN BACKUP HORN H02 1301
       Subsystem 2 - Part No: 1K0 907 719 B
       Component: Neigungssensor  004 0003
       Subsystem 3 - Component:      IRUE No Answer
    01134 - Alarm Horn (H12)
    00849 - S-contact at Ignition/Starter Switch (D)
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       Part No: 1K0 035 186 L
       Component: Radio BVX       012 0022
       Coding: 0040402
       VCID: AF2E531B3E564B32FC-80FA
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 06 0213
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Coding: 0000016
    End----------(Elapsed Time: 01:11, VBatt start/end: 14.0V/14.2V)-----------
    Mode 9:
    Monday,10,December,2018,15:50:11:19335
    Mileage:    Repair Order: Ian
    Mode 9 : Calibration Identification
    Type 04 - Calibration ID : 1K0907115   0070 (Address 10)
    Part No SW: 1K0 907 115 HW: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< <<<< MIA! 8P0?
    Did you log the actual versus requested boost but most likely is modified since the 8P0 hardware base project display data is missing in the VCDS scan after the software part number?
    Is that all the Mode 9 data?
  3. Likes Zenerdiode liked this post
    Jun 2014
    Newcastle, England
    Thanks Jack
    I haven't; as I grabbed the scan in the car park before I broke up from work before Christmas. And yes, that is indeed all of the Mode 9 data available. Of course, I'd like to dump the flash now to see if I can find any tuners' 'signatures' but it's his daily so won't be able to do that anytime soon.
    Thanks Jack
    Yeah I love how the tuners are so proud.........
    I been noticing less of them are doing so and are not so proud in last 3 years especially!
    Yep. Even when they do their best to "stealth", a log of requested and actual boost on a turbo engine can be very telling.
