- Jun 26, 2014
- 1,403
- 2,115
- Newcastle, England
- C?ID=24330
A friend of mine has asked if his car has a modified ECU - as his 'butt dyno' seems to think so.
Reports some peculiar Mode 9 results, I would have expected more, but I don't know if it too early to report meaningful stuff in there. Thank You.
AutoScan:
Mode 9:
AutoScan:
Monday,10,December,2018,15:26:02:19335
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4447.4
VIN: WVWZZZ1KZ5W168670 License Plate:
Mileage: 128550km-79877mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ5W168670 Mileage: 128550km-79877miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 HW:
Component: 2.0l R4/4V TFSI 00 0070
Revision: --H01--- Serial number: VWZ7Z0D1162876
Coding: 0403000318070060
Shop #: WSC 00400 210 83214
VCID: E386EF2B221EBF5228-80B6
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Load: 0.0 %
Temperature: 4.0°C
Temperature: 6.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.192 V
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: BA38724FF5149E9A5B-80EE
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
VCID: E89CF807DB38DC0AFD-80BC
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001262021
Coding: E58D8F0600041800001400001400000000087F075C
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00218142
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 08 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD02PA0U
Coding: 0012344
Shop #: WSC 01269 785 00200
VCID: AC1444170F40302AD9-80F8
Subsystem 1 - Serial number: 6332MSME077801093
Subsystem 2 - Serial number: 6342MSME077823076
Subsystem 3 - Serial number: 6351HSME051F175CD
Subsystem 4 - Serial number: 6361HSME053E41713
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0000012
VCID: B5226173DC0A71E2B6-80E0
Part No: 1K6 920 960 D
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0003403
Shop #: WSC 57250 067 57207
VCID: B02C5067236854CAE5-80E4
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B1906B3
Coding: 3D3F0340070003
VCID: A91ABD0300B2250222-80FC
Component: IMMO VDD 0812
Shop #: WSC 01287 111 53348
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0148
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: B12A556328625DC2EA-80E4
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80C802087F2D8505485FC69010
Shop #: WSC 36501 001 1048576
VCID: FBB6B74BBAAE679200-80AE
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Subsystem 3 - Component: IRUE No Answer
01134 - Alarm Horn (H12)
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Part No: 1K0 035 186 L
Component: Radio BVX 012 0022
Coding: 0040402
VCID: AF2E531B3E564B32FC-80FA
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
End----------(Elapsed Time: 01:11, VBatt start/end: 14.0V/14.2V)-----------
Mode 9:
Monday,10,December,2018,15:50:11:19335
Mileage: Repair Order: Ian
Type 04 - Calibration ID : 1K0907115 0070 (Address 10)
