autolines
New Member
16464 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [039] - -
Mileage: 53323 km
Date: 2019.01.08
Time: 03:55:00
Coolant temperature: 91 °C
Intake air temperature: 67 °C
Voltage terminal 30: 12.226 V
Engine: operating status: ES
Engine temp. management actuator: raw value: 1645
Engine temperature management actuator: stop open: 1645
Engine temperature management actuator: after-run stop: 3948
RVC_SP: 5.75 °
RVC_AV: 110.30 °
RVCPWM: 100.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [036] - -
Mileage: 53323 km
Date: 2019.01.08
Time: 05:50:18
Engine speed: 978.75 /min
Normed load value: 14.9 %
Vehicle speed: 1 km/h
Coolant temperature: 45 °C
Intake air temperature: 41 °C
Voltage terminal 30: 13.964 V
Engine: operating status: IS
Engine temp. management actuator: raw value: 313
Engine temperature management actuator: stop open: 145
RVC_SP: 164.50 °
RVC_AV: 11.27 °
RVCPWM: -100.000 %
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [032] - -
Mileage: 53323 km
Date: 2019.01.08
Time: 03:58:32
Engine speed: 771.00 /min
Normed load value: 6.7 %
Coolant temperature: 89 °C
Intake air temperature: 69 °C
Voltage terminal 30: 12.070 V
Engine temp. management actuator: raw value: 1644
RVC_SP: 88.75 °
RVC_AV: 100.50 °
RVCPWM: 100.000 %
Dears
Kindly help on the following codes...
Regards
