Results 1 to 10 of 15
Thread: 2005 VW Transporter - 2.5Tdi PD
    Hi
    We have a VW Transporter with an uneven tickover when warm I've been checking all the readings and the KW reading in MVB 04.4 seem very low at -4.9
    Has anyone got an acceptable range for this please?
    Cheers
    Toby
    ;SW:070-906-016-BA   HW:028-101-166-4 ---  Engine
    ;Component:R5 2	5L EDC G000SG  7001	 Coding:0000132
    ;Thursday	3	January	2019	16:09:13:06091
    ;VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
    ;VCID: D0EC264142F478CA86-5184
    Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4
    1	819 /min		4.9 mg/str		7.1KW		86.4C
    2	798 /min		0.00%		 0 01  0		86.4C
    3	777 /min		245.0 mg/str		240.0 mg/str		43.00%
    4	777 /min		5.0 BTDC		7.7KW		-4.9KW
    5	798 /min		20.6 mg/str		48		86.4C
    6	0.0 km/h		1000		0.00%		10
    7	66.6C		 		22.5C		87.3C
    8	819 /min		0.0 Nm		187.9 Nm		126.9 Nm
    9	798 /min		-1280.0 Nm		500.2 Nm		126.9 Nm
    10	240.0 mg/str		1030.2 mbar		1030.2 mbar		0.00%
    11	777 /min		1020.0 mbar		1030.2 mbar		80.50%
    12	11111111		0.00 s		14.52 V		87.3C
    13	0.16 mg/str		0.47 mg/str		0.05 mg/str		0.00 mg/str
    14	-0.71 mg/str
    15	819 /min		36.6 Nm		0.60 l/h		0.0 Nm
    16	35.70%		 		 		14.59 V
    17	0		0		0		0
    18	0		0		0		0
    19	0
    20	777 /min		51.2 Nm		1270.0 Nm		-1280.0 Nm
    21	0		 		0		100
    22	1		1		0		16
    23	-28		-23		-45		-23
    24	-57
    25	1848 /min		 		4		0
    26	E27E
    27	1		 		0.0 km/h		190.0 km/h
    28	0.304 V		 		 0 01  0		0.00%
    29	88.2C		44.0 mm
    51	819 /min		399 /min		48		1010000
    55	0		0		100000		100000
    56	100000		100000		100000		0xFF00
    62	86.4C		35.1C		4.5C		23.4C
    64	86.4C		35.1C		10.10%
    80	BPG-810 31.01.05 12345678 1883 0106
    81	WV1ZZZ7HZ5H078895 VWZ7Z0E1560290 1234567
    82	0020078502756 <> 78  020L 79   <>
    125	 		ABS 1		Instruments 1		Airbag 1
    126	 		 		Cent. Elect. 1
    131	16		5.2 mg/str		 		86.4C
    133	798 /min		235.0 mg/str		1030.2 mbar		0
    134	35.70%		14.52 V
    140	-0.56 mg/str
    145	0
    150	-51
    213	798 /min		0.00%		0.0 km/h		0
    225	0		0		0		0
    226	0		 		0		0
    227	0		0		0		0
    228	0		0
    229	 		 		0		0
    252	 		 		Cent. Elect. 1
    May 2016
    TOBY, THINK FOLKS WILL WANT A. FULL SCAN HERE FOR EVALUATION, THANKS.
    LARIMORE
    Here is the autoscan
    Tuesday,11,December,2018,09:30:55:06091
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: DG Motor Services
    VIN: WV1ZZZ7HZ5H078895   License Plate:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ5H07****   Mileage: 189270km-117606miles
    Address 01: Engine        Labels: 070-906-016-AXD.clb
       Part No SW: 070 906 016 BA    HW: 028 101 166 4
       Component: R5 2,5L EDC G000SG  7001
       Revision: 12345678    Serial number: VWZ7Z0E1560290
       Coding: 0000132
       Shop #: WSC 02756 785 00200
       VCID: D0EC264142F478CA85-5184
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS-A.lbl
       Part No: 7H0 907 379 B
       Component: ABS/EDS ALLRAD MK25 0102
       Coding: 0007706
       VCID: B4244AD1D62C24EA81-513C
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 K
       Component: BORDNETZ SGVER 1.0  1901
       Coding: 0000229
       VCID: BA3864E9F448D29A5B-513C
    00909 - Windshield Wiper Motor (V) Stage 1/2
    00991 - Interior Lights
    00968 - Right Turn Signals
       Part No: 1C0 909 605 A
       Component: 3B AIRBAG VW51      0008
       Coding: 13122
       Shop #: WSC 02756
       VCID: A208BC892CD8BA5A63-513C
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 850 G
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 01412
       VCID: AE1058B968000E3AF7-513C
       WV1ZZZ7HZ5H078***     VWZ7Z0E1560290
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02756
       VCID: F0AC86C1B2B458CAA5-513C
       Part No: 7H0 907 554 A
       Component: HALDEX 4Motion      0105
       Shop #: WSC 02771 785 00200
       VCID: AE1058B938000E3AF7-513C
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C2B Komfortgert     0004
       Coding: 00069
       Shop #: WSC 02756
       VCID: B2284CC97C382ADA93-4B1E
       Subsystem 1 - Part No: 7H2959802
       Component: Trsteuer.FS KLO 0203
       Subsystem 2 - Part No: 7H2959801
       Component: Trsteuer.BF KLO 0203
    End----(Elapsed Time: 06:05, VBatt start/end: 12.0V/10.6V. VIgn 10.9V)-----
    May 2016
    Dgmotors, noted ending battery voltage 10,6 , started at 12 after 6 minutes. DID it drop this far while obtain auto scan? Would like to see how well it rebounded once started.
    This issue happens when warm, wondering if charging system just keeping up while running. What is the condition of battery?, age, conditions of post ECT.
    LARIMORE
    Quote Originally Posted by Larry Manton View Post
    LARIMORE
    Cheers Larry
    The autoscan was done with the engine off and the battery has been replaced as the autoscan was 11 December. in the logs you can see the voltage is 14.52 volts with the engine running.
    Mar 2014
    Have a good look at the injector loom. Running in the hot oil they can fracture (often when the engine is warm). I have the 174 HP version of that van, I could see what mine shows tomorrow if you are stuck. There is no engine label file for my AXE engine though.
  7. Likes DGMotors liked this post
    Quote Originally Posted by Guitarman View Post
    Good shout on the injector loom.
    If you could please check your reading that would be good, I know on the 1.9 PD the KW should be as close to 0 and if to far out from this figure causes idle problems.
    On this van it starts at -3.9 when cold and works it way to -4.9 with a hot engine (86c)
  9. #8
    Mar 2014
    Had a look at mine (don't know how to log that many groups together as you have) but in group 4, fields 3 and 4 are marked 'Idle stabilization'. Field 3 changes about slightly on revving but is at 7.1kw at idle. Field 4 changes just after starting for about half a second but then settles at -3.4 and will not change on revving. This was with a warm engine. There are other 'Idle Stabilization blocks' in other groups but curiously only four for the five cylinders the van has.
    I thought the idle stabilization system was there to add/subtract fuel from each cylinder to smooth out variations caused by engine wear over time but I've never seen it shown in KW before and with such a range. I wonder if fields 3 and 4 refer to something else?
    I did once have an idle speed problem on mine but it was more like a sudden electrical load being applied, slowing the engine occasionally rather than a misfire or an injector problem. Do you know if it's had a cam btw? Once they get past about 100-120k most are on borrowed time!
    I just remembered I took this screenshot.
  10. Likes DGMotors liked this post
  11. #9
    Cheers Guitarman
    To make a controller channel map see this link just use 01 for engine and output as a .csv file
    On the 1.9/2.0 PD this figure is changed by altering the camshaft in relation to the crankshaft, click this link to myturbodiesel.com for more info
    Ive had quite a few 4 cylinder pd run bad on idle when the figure is to far out, 0 +or-3 but 2.5PD engine all seem to run quite a high negative value,
    Problem van is -4.9
    Guitarman -3.4
    2005 AXD Van with 60K on the clock -2.9
    So I'm guessing -2 to-4 is correct with the problem van being slightly out
    Might pop the rocker cover off and have a look when it comes back in.
  12. #10
    Mar 2014
    Interesting. I knew you could use the channel map function for making a pre-label file to send up to Ross-Tech but I didn't realize you could use it 'live' like that. I'll make a map of mine. I wonder why the that figure on mine is frozen once the engine is running?
    If there was a reliable figure for that perhaps it could be used to confirm correct setting up of a new cam. The special tools should do that but a lot of folks seem to manage to muck it up!
