Results 1 to 4 of 4
Thread: 2005 VW Transporter - 2.5Tdi PD
    Hi
    We have a VW Transporter with an uneven tickover when warm I've been checking all the readings and the KW reading in MVB 04.4 seem very low at -4.9
    Has anyone got an acceptable range for this please?
    Cheers
    Toby
    ;SW:070-906-016-BA   HW:028-101-166-4 ---  Engine
    ;Component:R5 2	5L EDC G000SG  7001	 Coding:0000132
    ;Thursday	3	January	2019	16:09:13:06091
    ;VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
    ;VCID: D0EC264142F478CA86-5184
    Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4
    1	819 /min		4.9 mg/str		7.1KW		86.4C
    2	798 /min		0.00%		 0 01  0		86.4C
    3	777 /min		245.0 mg/str		240.0 mg/str		43.00%
    4	777 /min		5.0 BTDC		7.7KW		-4.9KW
    5	798 /min		20.6 mg/str		48		86.4C
    6	0.0 km/h		1000		0.00%		10
    7	66.6C		 		22.5C		87.3C
    8	819 /min		0.0 Nm		187.9 Nm		126.9 Nm
    9	798 /min		-1280.0 Nm		500.2 Nm		126.9 Nm
    10	240.0 mg/str		1030.2 mbar		1030.2 mbar		0.00%
    11	777 /min		1020.0 mbar		1030.2 mbar		80.50%
    12	11111111		0.00 s		14.52 V		87.3C
    13	0.16 mg/str		0.47 mg/str		0.05 mg/str		0.00 mg/str
    14	-0.71 mg/str
    15	819 /min		36.6 Nm		0.60 l/h		0.0 Nm
    16	35.70%		 		 		14.59 V
    17	0		0		0		0
    18	0		0		0		0
    19	0
    20	777 /min		51.2 Nm		1270.0 Nm		-1280.0 Nm
    21	0		 		0		100
    22	1		1		0		16
    23	-28		-23		-45		-23
    24	-57
    25	1848 /min		 		4		0
    26	E27E
    27	1		 		0.0 km/h		190.0 km/h
    28	0.304 V		 		 0 01  0		0.00%
    29	88.2C		44.0 mm
    51	819 /min		399 /min		48		1010000
    55	0		0		100000		100000
    56	100000		100000		100000		0xFF00
    62	86.4C		35.1C		4.5C		23.4C
    64	86.4C		35.1C		10.10%
    80	BPG-810 31.01.05 12345678 1883 0106
    81	WV1ZZZ7HZ5H078895 VWZ7Z0E1560290 1234567
    82	0020078502756 <> 78  020L 79   <>
    125	 		ABS 1		Instruments 1		Airbag 1
    126	 		 		Cent. Elect. 1
    131	16		5.2 mg/str		 		86.4C
    133	798 /min		235.0 mg/str		1030.2 mbar		0
    134	35.70%		14.52 V
    140	-0.56 mg/str
    145	0
    150	-51
    213	798 /min		0.00%		0.0 km/h		0
    225	0		0		0		0
    226	0		 		0		0
    227	0		0		0		0
    228	0		0
    229	 		 		0		0
    252	 		 		Cent. Elect. 1
    May 2016
    TOBY, THINK FOLKS WILL WANT A. FULL SCAN HERE FOR EVALUATION, THANKS.
    LARIMORE
    Here is the autoscan
    Tuesday,11,December,2018,09:30:55:06091
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: DG Motor Services
    VIN: WV1ZZZ7HZ5H078895   License Plate:
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ5H07****   Mileage: 189270km-117606miles
    Address 01: Engine        Labels: 070-906-016-AXD.clb
       Part No SW: 070 906 016 BA    HW: 028 101 166 4
       Component: R5 2,5L EDC G000SG  7001
       Revision: 12345678    Serial number: VWZ7Z0E1560290
       Coding: 0000132
       Shop #: WSC 02756 785 00200
       VCID: D0EC264142F478CA85-5184
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS-A.lbl
       Part No: 7H0 907 379 B
       Component: ABS/EDS ALLRAD MK25 0102
       Coding: 0007706
       VCID: B4244AD1D62C24EA81-513C
       Part No: 7H0 937 049 K
       Component: BORDNETZ SGVER 1.0  1901
       Coding: 0000229
       VCID: BA3864E9F448D29A5B-513C
    00909 - Windshield Wiper Motor (V) Stage 1/2
    00991 - Interior Lights
    00968 - Right Turn Signals
       Part No: 1C0 909 605 A
       Component: 3B AIRBAG VW51      0008
       Coding: 13122
       Shop #: WSC 02756
       VCID: A208BC892CD8BA5A63-513C
       Part No: 7H0 920 850 G
       Coding: 01412
       VCID: AE1058B968000E3AF7-513C
       WV1ZZZ7HZ5H078***     VWZ7Z0E1560290
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02756
       VCID: F0AC86C1B2B458CAA5-513C
       Part No: 7H0 907 554 A
       Component: HALDEX 4Motion      0105
       Coding: 0000001
       Shop #: WSC 02771 785 00200
       VCID: AE1058B938000E3AF7-513C
       Part No: 7H0 959 433 B
       Component: C2B Komfortgert     0004
       Coding: 00069
       Shop #: WSC 02756
       VCID: B2284CC97C382ADA93-4B1E
       Subsystem 1 - Part No: 7H2959802
       Component: Trsteuer.FS KLO 0203
       Subsystem 2 - Part No: 7H2959801
       Component: Trsteuer.BF KLO 0203
    End----(Elapsed Time: 06:05, VBatt start/end: 12.0V/10.6V. VIgn 10.9V)-----
    May 2016
    Dgmotors, noted ending battery voltage 10,6 , started at 12 after 6 minutes. DID it drop this far while obtain auto scan? Would like to see how well it rebounded once started.
    This issue happens when warm, wondering if charging system just keeping up while running. What is the condition of battery?, age, conditions of post ECT.
    LARIMORE
