Results 1 to 4 of 4
Thread: 2010 skoda fabia 1.6 tdi setting up new turbo boost actuator ? limp code P2564
    Apr 2017
    replaced turbo actuator with similar fault to the one now present, diaphragm had hole, no movement with vacuum.
    initially set rod in similar position with thread count, checked with gauge initial movement locked at 0.17 bar.
    workshop notes a bit confusing, with which sequence to lock rod in position.
    on first road test seemed ok, customer back a day later with apparently the same fault,
    diaphragm in tact, lever moves freely, rechecked settings, seemed to be correct.
    noticed goes into limp at low rpm, might just be light carbon build up?
    anyone have an installation sequence for a new actuator?
    log below, faults will clear but come back on road test after a couple of miles.
    Wednesday,09,January,2019,17:11:14:32699
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: TMBFL25J0B3146124   License Plate: AP60CAE
    Mileage: 157350km-97772mi   Repair Order:
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: TMBFL25J0B3146124   Mileage: 157350km-97772miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LN    HW: 03L 906 023 LK
       Component: 1,6l R4 CR td H33 9972
       Revision: --H33---    Serial number:
       Coding: 00114016000500080000
       Shop #: WSC 13765 031 00015
       ASAM Dataset: EV_ECM16TDI02103L906023LN 003010
       ROD: EV_ECM16TDI02103L906023LL.rod
       VCID: 7DB2239EEC8ED5A2BE-8028
    7411 - Turbocharger Boost Control Position Sensor Circuit
              P2564 00 [036] - Signal too Low
                        Mileage: 157351 km
                        Date: 2019.01.09
                        Time: 15:58:26
                        Coolant temperature: 14 C
                        Intake air temperature: 14 C
                        Voltage terminal 30: 11.972 V
                        Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: 99.997 %
                        Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
                        High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 4.999 %
                        High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 4.995 V
                        Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
                        Turbocharger boost control: offset closed-V_BPA_TOL[0]: 4.199 V
                        High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 0
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 400100DB007100B8022600E400D500000000
       Shop #: WSC 13765 790 00017
       VCID: 4ED0B4521DA89E3A17-801A
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 5J0 820 045 C    HW: 5J0 820 045 C
       Component: Man AC         02 0101
       Revision: 0003S 02
       VCID: 25022BFE2C9EBD6286-8070
       Part No SW: 6R7 937 087 H    HW: 6R7 937 087 H
       Component: PQ25 BCM      H12 0022
       Revision: -1------    Serial number: 1002480801
       Coding: 25980B3808C92400922000003E0B08C00000400F600000000000
       Shop #: WSC 13765 790 00015
       VCID: 49DA874EE0C6B90242-801C
    01134 - Alarm Horn (H12)
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagT2C H09 0020
       Revision: --------    Serial number: 003GX00CLY0X
       Coding: 003243
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4AD8B842EDC0B21A4B-801E
       Part No SW: 5J0 920 910 D    HW: 5J0 920 910 D
       Component: KOMBI         H17 0206
       Coding: 420A00
       VCID: 281C22CA538CA00ABD-807C
       Part No SW: 6N0 909 901     HW: 6R7 937 087 H
       Component: GW-K-CAN TP20 0022
       Revision: -1------
       Coding: 032300
       VCID: 70AC0AAAA3DCA8CA25-8024
       Component: IMMO          H17 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
       VCID: 6A9818C28D00521A6B-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10110
       Shop #: WSC 13765
       VCID: 2F2EC9D6EA62F7327C-807A
       Part No SW: 5J0 035 161 C    HW: 5J0 035 161 C
       Component: Radio-SWING   009 0034
       Revision: -----09S    Serial number: SKZ4Z2K1433431
       Coding: 050004000006
       VCID: 220830E23DB04A5AE3-8076
                        Reset counter: 188
                        Mileage: 157351 km
                        Date: 2013.06.01
                        Time: 13:27:12
    End----(Elapsed Time: 00:33, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Did you linearize the turbo WG for ADP?
    Apr 2017
    Do you mean the turbo adaption in basic settings ? Yes, logged in revs rose, checked measuring blocks for anything turbo related, couldn't see any changes happening, the be display said, running, no display, not sure what that means. Let it run for 5 mins,it didn't finish it's cycle, so shut everything down, then after 5 mins tried a second time, similar senario, no change in the blocks, can't find any notes for a procedure.
    Is car FOD modified?
    Basic settings must be completed & manually control the rod to verify it can make boost by checking in blocks or even lineraize the rod yourself indeed can work during the ADP some have reported to me.
    Verify full mechanical travel and sweep or control of the VNT.
