Results 1 to 9 of 9
Thread: Skoda octavia 3 errors (MK100ESP)
    Feb 2015
    Romania
    please advice ...after batery disconected...
    Wednesday,09,January,2019,19:08:25:42611
    VCDS Version: 18.9.0.2 (x64)
    VIN: TMBAF7NE3G0110163   License Plate:
    Mileage: 222990km-138559mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: TMBAF7NE3G0110163   Mileage: 222990km-138559miles
    Address 01: Engine (2D2D2-CXXA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 056 CS    HW: 04L 907 445 B
       Component: R4 1.6l TDI   H06 2509
       Revision: 22004001
       Coding: 01114012432411090000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM16TDI03004L906056CS 002006
       ROD: EV_ECM16TDI03004L906056_002_VW37.rod
       VCID: 000FB0BF9BA5704AD5-8054
    25126 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:38:14
                        Coolant temperature: 44 C
                        Intake air temperature: 23 C
                        Voltage terminal 30: 12.093 V
                        CAN status - engine control module: 0
                        Cruise Control System (CCS): status: Initializing
    Readiness: N/A
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 52705000000188
       Shop #: WSC 73430 031 00063
       VCID: 4B955793E263631270-801E
    7 Faults Found:
    0195 - Control module not coded
              U1013 00 [137] - -
                        Reset counter: 204
                        Date: 2019.01.07
                        Time: 00:31:42
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 204
                        Date: 2019.01.07
                        Time: 00:31:42
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 204
                        Date: 2019.01.07
                        Time: 00:31:42
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 204
                        Date: 2019.01.07
                        Time: 00:31:42
    0295 - Steering angle sensor
                        Reset counter: 204
                        Date: 2019.01.07
                        Time: 00:31:42
    8306 - Databus
              U1122 00 [137] - Implausible Message
                        Reset counter: 204
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:31:47
    8308 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Fault Frequency: 20
                        Reset counter: 206
                        Date: 2019.01.07
                        Time: 00:31:42
       Part No SW: 5E0 820 047 M    HW: 5E0 820 047 M
       Component: AC Manuell    H05 1202
       Revision: 00001K07
       Coding: 01010104000100001000000000400000
       ASAM Dataset: EV_ACManueBHBVW37X 003129
       ROD: EV_ACManueBHBVW37X_003_SK37.rod
       VCID: 2C57340F47AD442A59-8078
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 084 AP    HW: 5Q0 937 084 AK
       Component: BCM MQBAB B   H24 0175
       Serial number: 01061526701270
       Coding: 0C0008424207005347E04000000407080000000000000000000000000000
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0603A6A7B9815E7AEF-8052
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 150902  041 0570
       Serial number:         150912194229
       Coding: 065DDD
       Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SQPL5QAJY
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 0F2D8383D6FB1F325C-805A
       Subsystem 1 - Part No SW: -----------    HW: 454 002 909 15
       Serial number: 3576U00000049445B619
       Subsystem 2 - Part No SW: -----------    HW: 454 003 009 15
       Serial number: 3586U000000EB288761N
       Subsystem 3 - Part No SW: -----------    HW: 454 802 709 15
       Serial number: 3516RC25889080000008
       Subsystem 4 - Part No SW: -----------    HW: 454 802 909 15
       Serial number: 3526R2E829F08000000F
       Subsystem 5 - Part No SW: -----------    HW: 454 801 108 15
       Serial number: 3556V7D1DA407000000J
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:45:42
       Part No SW: 5Q0 953 521 N    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20151006401347
       Coding: 1600
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D71094BACD7DDA2FE-8068
       Part No SW: 5E0 920 721 B    HW: 5E0 920 721 B
       Component: KOMBI         123 6420
       Coding: 0724020021000008010808001000000000000000
       VCID: 2149D53B306F9942FA-8074
    16776973 - Databus
                        Reset counter: 204
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:44:08
       Part No SW: 5Q0 907 530 AD    HW: 5Q0 907 530 D
       Component: GW MQB Low    126 1223
       Revision: --------    Serial number: 0004026482
       Coding: 030000040F087300EB000048080F00010001050000000000000000000000
       VCID: 73E5EF73DA135BD2D8-8026
       Subsystem 2 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185704001510121691
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 0000170393425
       Coding: 001001208000040100001100
       VCID: 458161ABC4079562A6-8010
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0103
       VCID: 44877CAFCF3DAC6AB1-8010
    15875 - Steering angle sensor
                        Reset counter: 204
                        Mileage: 150190 km
                        Date: 2018.12.10
                        Time: 00:00:02
                        Motor status: 00
                        Supply voltage: 12.00 V
                        Temperature: 0.0 C
                        KFC: 3E
                        KFA: 00 03
                        Environmental conditions: 5F
                        uAdSensI_U1V2Filtered_gdu16: 1.19 V
                        uioUdNotFilt_xdu16: 12.14 V
                        uAdSensI_SwitchedKl30_xdu16: 12.14 V
    19204 - Databus
                        Reset counter: 246
                        Mileage: 222968 km
                        Date: 2019.01.07
                        Time: 00:00:34
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 11.25 V
                        Temperature: 3.0 C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 11.52 V
                        uAdSensI_SwitchedKl30_xdu16: 11.52 V
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 0000169904120
       Part No SW: 5E0 035 867 C    HW: 5E0 035 867 C
       Component: MU-E--ER      852 6490
       Serial number: 02091500020527
       Coding: 037301003C0000005011000100000000000000C40000010000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 2A5B32174D595A1AAB-807E
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 204
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:36:48
                        Voltage terminal 30: 11.8 V
                        BAP-BAP_Function_ID: 00
    7206 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 204
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:36:48
    7203 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 246
                        Mileage: 222971 km
                        Date: 2019.01.07
                        Time: 00:45:26
    End-------------------------(Elapsed Time: 02:57)--------------------------
    A battery disconnect should not cause ABS to lose coding. What else happened to this car?
    Do you have a scan from before whatever happened to this car occurred?
    Feb 2015
    Romania
    thx for fast reply.... is not my car..
    one of my customer ask for my help
    I asked him and told me .... disconnected the cluster instruments/immo with battery connected,
    then disconnected the battery ....and hope solve the problem (double mistake)
    -can i recode abs?
    -can i recode abs?
    Now that sounds plausible to me and so does a battery disconnect if happens the right way with a possible faulty ground or while key is ON!
    What's the consistency for VIN numbers and KM?
    Feb 2015
    Romania
    vin and km are ok and real ..but i think is tampered by immo disconected
    Quote Originally Posted by bob7 View Post
    -can i recode abs?
    Is it possible, yes, I think so.
    The problem will be finding the correct coding.
    Try this one:
    1C0762911421096C0078060641C6243846289000608224F200400070C002
  7. Likes Jack@European_Parts, bob7 liked this post
    Feb 2015
    Romania
    Thx Uwe for long coding its work.. but now i have a big issue whit basic settings...i try all...
    please see auto-scan again ...i need advice.
    Thursday,10,January,2019,19:36:44:42611
    Mileage: 223031km-138585mi   Repair Order:
    VIN: TMBAF7NE3G0110163   Mileage: 223031km-138585miles
       Revision: 22004001
    25126 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 05:13:32
                        Engine speed: 772.00 /min
                        Normed load value: 23.1 %
                        Coolant temperature: 86 C
                        Intake air temperature: 41 C
                        Voltage terminal 30: 14.648 V
                        Cruise Control System (CCS): status: passive
    Readiness: N/A
       Coding: 1C0762911421096C0078060641C6243846289000608224F200400070C002
                        Reset counter: 209
                        Date: 2019.01.08
                        Time: 05:02:26
    8299 - Databus
                        Reset counter: 209
                        Date: 2019.01.08
                        Time: 05:02:26
    16412 - Display for Tire Pressure Monitoring
              C1146 02 [009] - Signal Failure
                        Reset counter: 209
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 05:07:29
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 209
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 05:07:29
       Revision: 00001K07
       Coding: 065DDD
              B13BC F2 [008] - No function
                        Mileage: 222990 km
                        Date: 2019.01.07
                        Time: 04:56:23
       Coding: 1600
    16776973 - Databus
                        Reset counter: 249
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 04:57:17
       Coding: 0103
    19204 - Databus
                        Reset counter: 249
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 04:57:13
                        Motor status: 01
                        Supply voltage: 14.25 V
                        Temperature: 33.0 C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 25
                        uioUdNotFilt_xdu16: 14.48 V
                        uAdSensI_SwitchedKl30_xdu16: 14.48 V
    6919 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 249
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 04:57:28
                        Voltage terminal 30: 14.3 V
    6950 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 249
                        Mileage: 223031 km
                        Date: 2019.01.08
                        Time: 04:57:28
                        Voltage terminal 30: 14.2 V
              U1111 00 [008] - -
                        Reset counter: 249
                        Mileage: 222990 km
                        Date: 2019.01.07
                        Time: 04:56:26
              U1111 00 [008] - -
                        Reset counter: 249
                        Mileage: 222990 km
                        Date: 2019.01.07
                        Time: 04:56:26
              U1111 00 [008] - -
                        Reset counter: 249
                        Mileage: 222997 km
                        Date: 2019.01.07
                        Time: 16:31:32
                        Voltage terminal 30: 11.5 V
    End-------------------------(Elapsed Time: 02:51)--------------------------
    Last edited by Bruce; 01-10-2019 at 03:15 PM. Reason: put "/" inside closing "[/code]" tag
  9. Likes Jack@European_Parts liked this post
  10. #8
    Now do the adaptions and maybe even in 0x44 too.
    Is SAS G85 functioning when observed in blocks?
  11. #9
    Feb 2015
    Romania
    ok ..suggest to go on 03 abs 10 adaptation and perform g85 basic settings?
    you have procedure for MK100? on ross-tech wiki a find only for MK60
