Results 1 to 10 of 10
Thread: 2015 Q7 steering column reset help
    Aug 2018
    Helllo,
    I am having an issue with my wifes 2015 Audi Q7. We purchased it used about a year ago and have had no issues up until about a month ago when the steering column stopped responding to the up command. Now it isn't moving at all. After searching on the internet it seems like this is a common enough issue however the only fix I have found is a dealership reset on the column. Can this reset be done with the vcds? I have scanned the car and found no trouble codes to investigate. Any help on this would be greatly appreciated.
    If you've scanned it, please post the scan so people can see exactly how the vehicle is equipped. Even if you didn't explicitly save the scan, there should be an archival copy of it in your Scans sub-folder.
    Tartu, Estonia
    The world is my oyster...
  4. Likes Uwe liked this post
    Aug 2018
    Here is a scan from today as requested.
    Wednesday,09,January,2019,12:02:10:63587
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WA1LGBFE2FD011021   License Plate: Q7 1-9-19
    Mileage: 111940km-69556mi   Repair Order:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
              55 56 5F 62 6C 6D 6F 72
    VIN: WA1LGBFE2FD011021   Mileage: 111940km-69556miles
    Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4L0 910 551 P    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0030
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0128
       Shop #: WSC 31414 790 00001
       VCID: 3537DD89A94EF09F7D3-8060
       Part No SW: 0C8 927 750 N    HW: 0C8 927 750 N
       Component: AL1000 AISIN  002 2441
       Coding: 001378
       Shop #: WSC 42420 001 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 372BD781BFC2028F6FF-8062
       Revision: 00H02001
       Coding: 0099409
       VCID: 3431E08DA234E9974AD-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0210
       Revision: 00H08000    Serial number: 10603902170038
       Coding: 0000135
       VCID: 25170DC919EE801FCD3-8070
       Component: FBSAUDIC6 EZS   H04 0020
    00191 - Passenger's Door Handle Touch Sensor (G416)
                007 - Short to Ground
                        Fault Status: 01110111
                        Reset counter: 143
                        Mileage: 105556 km
                        Date: 2018.10.07
                        Time: 11:08:22
                        Fault Frequency: 7
                        Reset counter: 252
                        Mileage: 105556 km
                        Date: 2018.10.07
                        Time: 11:08:22
    02639 - Antenna Reader for Keyless Access Authorization
                        Reset counter: 65
                        Mileage: 110951 km
                        Date: 2018.12.24
                        Time: 19:46:52
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
       Revision: 00---031    Serial number: 00000030357689
       Coding: 000CC026
       VCID: 25170DC915EE801FCD3-8070
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0139123
       VCID: 6E8532E58C9883477C9-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55931429300602
       Coding: 24011E
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3431E08DAEB4E9974AD-8060
       Component: 72 AIRBAG AUDI8RH45 0230
       Revision: 09H45000    Serial number: 0038QD90DH03
       Coding: 0014130
       VCID: 2B03FBF17F0AB66F1B7-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME0B4714529
       Subsystem 3 - Serial number: 6342QSME73470742A
       Subsystem 4 - Serial number: 6352QSME6F473E56.
       Subsystem 5 - Serial number: 6362QSME73472474G
       Subsystem 6 - Serial number: 63734SME22451566W
       Subsystem 7 - Serial number: 63834SME7D441A727
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026142600045
       Coding: 0012242
       VCID: 280904FD6EFC9D77F65-807C
       Component: E0221           H03 0040
       Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
       Component: KOMBIINSTR.   H35 0332
       Revision: 00000000    Serial number: X2R407PAF
       Coding: 8BD663040100CF05020205
       VCID: 44D1B04DFE945917FAD-8010
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB800038    Serial number: 3800M1491904D6
       Coding: 00C303
       VCID: 3FDBBFA197723ACFA7F-806A
       Component: J367-BDM  H07 0125
       Serial number: 31287532274121941088
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Fault Frequency: 79
                        Reset counter: 88
                        Mileage: 105563 km
                        Date: 2018.10.07
                        Time: 15:05:00
                000 -  -  - Intermittent
                        Fault Frequency: 103
                        Reset counter: 88
                        Mileage: 105563 km
                        Date: 2018.10.07
                        Time: 19:05:00
                        Bin. Bits:    00000
                        Voltage: 12.30 V
                        Count: 18
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
       Revision: 00---011    Serial number: 00000030356735
       Coding: 0000006
       VCID: 688944FDAE7C5D77365-803C
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0065
       Revision: AA000000    Serial number: 00000119084875
       Coding: 00581B00000011110000
       VCID: 323DE6955420E7A7581-8066
       Component: J0769_SWA_MasterH03 0050
       Revision: 00H03000    Serial number: 6PZ 009 014-10
       VCID: 2E05F2E54C18C3473C9-807A
       Component: J0770_SWA_Slave_H03 0050
       Subsystem 3 - Serial number: 5F02.10.1400H03000AMS14244’
       Subsystem 4 - Serial number: S14244’
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000121988890
       Coding: 011F57205E40440004
       VCID: 48C9A47DC2BC7D77165-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 82009349590000
       Coding: 3569949
       VCID: 3829D4BDBE5C0DF7665-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000062796
       Coding: 030000
       VCID: 290F01F979F6A47FE9B-807C
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005191074956
       Coding: 0693965
       VCID: 231313D117DA7E2FA37-8076
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000201081
       Coding: 0012001
       VCID: 5EE562257C3813C7CC9-800A
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000121918347
       VCID: 47CBA741CFA2720F1FF-8012
       Serial number: 141021-0002-194
       Coding: 1147A71010020400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 42DDB655E4005727C81-8016
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156J/0E8081641
       Coding: 020007010000000000
       VCID: 241110CD1ED47917DAD-8070
       Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
       Component: H-BNT-NA      H42 0901
       Revision: --------    Serial number: 513JU0E7500117
       Coding: 180200060004E1EF510003456F632003140000000100000000
       Subsystem 1 - Part No: 8R0 060 884 CJ
       Component: NAR 2015  1102
       Component: DU7 High  H42 0104
       Serial number: A130JY0E3163467
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002212355
       Component: CD-Database  5950
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000122643492
       Coding: 010E57204040230004
       VCID: 46D5AA45C8A86B07E49-8012
       Revision: --H09---    Serial number: 525PA8-J49430T
       Coding: 1021201
       Part No SW: 4L0 910 945     HW: 4L0 827 851 F
       Component: ValeoHeckdeckel H58 0500
       Revision: --H58001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C8138EDBA84715752D-8038
       Subsystem 3 - Serial number: RD23.10.14--H58001001C0224’
       Subsystem 4 - Serial number: 1C0224’
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0122994640----
       Coding: 0003595
       VCID: 26150AC564E88B07C49-8072
       Component: J_245_EE16_SKB10H15 0220
       Component: J_394_EE16_SKB10H15 0220
       Component: J_392_EE16_SKB10H15 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000122643491
    End----------(Elapsed Time: 02:02, VBatt start/end: 14.3V/14.3V)-----------
    Address 19: DTCs cleared
  6. Likes Uwe liked this post
    Yes, VCDS should be able to do that.
    [Select]
    [09-Cent. Elect.]
    [Basic Settings]
    Group 001.
    The note I have is: Make sure to approach all 4 end positions (up, down, forward, back) before performing the basic setting.
    You probably should read the TSB posted two messages above.
  8. Likes Fredrick Awuor liked this post
  9. #6
    Mar 2019
    Canada
    The steering column was working in/out but not up/down, was enabled in vcds. Did the vcds basic settings on and now shows as disabled and the steering column does not adjust at all now. First time trying out vcds and i guess i got lots to learn and be careful. Seemed like an easy fix. Appreciate any help on this. Thanks D.
  10. #7
    Jun 2018
    Quote Originally Posted by darren_de_vos View Post
    I did the same exact steps as you. My steering column was only working in/out and not up/down. Basic settings initially showed it as “enabled”, but now after setting basic setting ON, is now showing “disabled” every time I open VCDS and doesn’t work.
    I think the problem might be we both opened the controller and instructed VCDS to set the basic settings, but we didn’t even use or extend or reach the end points for the 4-way toggle switch (not sure how this would have worked for the up or down anyway since my up/down didn’t work before). Now all adjustment is stopped and disabled.
    Is this something that can be reset so the setting displays as enabled or? If so, please advise.
  11. #8
    Jun 2018
    @Uwe - is there an exact procedure to reset the steering column setting so I goes back to enabled?
  12. #9
    Quote Originally Posted by studioRS View Post
    If I knew more than I've already written here, I would gladly share it with you.
  13. #10
    Jun 2018
    Appreciate the quick response, thank you.
