Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Thread: Mmi shut down by battery energy management
  1. #61
    Nov 2014
    I was thinking that testing voltage to amp pins would be sufficient, but as you have described that I need to test correctly, what kind of tester would do this and is this done through the pins?
  2. #62
    Nov 2014
    Does anyone know which pis I need to check for the power to the amp??????
  3. #63
    Tartu, Estonia
    T32h/1 - Power
    T32h/2 - Ground
    Test them both. Put a load of 10A on the wire, if it passes that test, wire is OK and amp is bad.
    The world is my oyster...
  4. #64
    Nov 2014
    Thanks Golfi. How do I put a load of 10a on the wire. Is that just a case of staring the engine?
  5. #65
    Tartu, Estonia
    You take a powerful lamp, 120w for instance. Because of the ohm law P=u*1 and I=P/U
    So it makes I=120W/12v, I=10A.
    Hope you understand. PS bulb has to be rated for 12v.
  6. Likes Jack@European_Parts liked this post
  7. #66
    Nov 2014
    Sorry Golfi. My brains fried, I have no idea what all that meant. I have read it five times and the more I read it the confused I get.
    Is there an easy way to tell me what to do without any complicated stuff.
    Sorry I need an idiot guide.....
  8. #67
    Tartu, Estonia
    Put 120W/12v or similar power bulb at the pins of amp. If the bulb lights up fine and bright your wiring is good.
    But i would suggest at this point, to seek out a help of experienced electrician.
  9. Likes Jack@European_Parts liked this post
  10. #68
    Nov 2014
    This is what I have done so far. I have a pencil voltage tester that tells me the voltage when I touch a live wire. I unplugged the amp and I found that when I first did it I got a 12v reading off the the first pin and nothing from the second and then the power went down totally. What I found was that when I unplugged the amp, the mmi went blank and the power cut off to all the units with the amp like DVD, radio and tv. I don't get any readings at this point, I'm guessing when it's plugged out, it cuts the power to the cable
  11. #69
    Nov 2014
    Can anyone help and give me an easy guide to test my amplifier with a voltage tester pencil
  12. #70
    For the ones who don't understand what Golf_vend was saying.........
    http://forums.ross-tech.com/showthre...vids-and-more)
    Sunny will show ya.
