Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 70
Thread: Mmi shut down by battery energy management
  1. #21
    Tartu, Estonia
    It's a part nr.
    The world is my oyster...
  2. Likes jakematic, gupsterg liked this post
  3. #22
    Nov 2014
    Ok, what is the part?
  4. #23
    It's this part:
    http://www.ecstuning.com/Search/4E0_973_802/ES388584/
    It's used to eliminate a module from the optical ring bus temporarily.
  5. Likes jakematic, gupsterg liked this post
  6. #24
    Nov 2014
    Thanks guys, I have just purchased online. Do you know the location of where I need to plug it in?
  7. Likes jakematic liked this post
  8. #25
    In place of whichever module is suspect.
  9. Likes gupsterg, Jack@European_Parts liked this post
  10. #26
    NC USA
    Exactly.
    You unplug the fibre optics from the module and plug them into that loop-back connector.
    It completes the optical 'circuit' and will let the other modules talk.
    When you do this it is recommended you unplug the copper cables for the CANbus and power as well.
    This will eliminate any communication problems there from propagating to other modules.
    The dilemma in all this is, if it alls works after using the loop-back, you'll likely need to replace the module you took out of the loop...
  11. Likes gupsterg, Jack@European_Parts liked this post
  12. #27
    Quote Originally Posted by jakematic View Post
    Before I spent the money replacing a module, I'd check the obvious stuff first, like: Is it getting power? And if not why?
    I give even money odds the problem here is a blown fuse for the 47-Sound System module. ;-)
  13. Likes Jack@European_Parts liked this post
  14. #28
    NC USA
    Agreed - additional diagnostics are necessary after we see what the loop-back shows.
    Until then we don't have an Auto-Scan prior to the event to know that it was working, or know if any jump starts were attempted. [he says with cold clinical analyses]
    Hopefully a power cycle will revive it, or it's something simple
    Otherwise it's a new module and coding....
  15. Likes Jack@European_Parts liked this post
  16. #29
    Nov 2014
    What is a power cyle and how is it carried out?
  17. #30
    I think you will get the MOST out of this thread by checking WD and FUSES!
    Get it.............? MOST
    Seriously check them.
  18. Likes jakematic liked this post
