Results 1 to 6 of 6
Thread: Passat b6 ABS Coding
    Sep 2018
    Poland
    Hello.
    i've got trouble with passat WVWZZZ3CZAE107992
    Car was originaly from UK, and i made swap of all electrical for right hand drive.(Yes i know it was suicide).
    Except few errors in connections (door modules) i got big trouble with ABS. in errors it says it's not proper coded.
    Could someone send me proper coding? I added auto hold switch to parking brake. And im not sure if this abs comes from this vehicle (i wasn't doing the mechanical swap of parts, only electrical is on my head)
    Wednesday,09,January,2019,09:11:04:16157
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ3CZAE107992   License Plate:
    Mileage: 230090km-142971mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56
    VIN: WVWZZZ3CZAE107992   Mileage: 230090km-142971miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 QC    HW: 03L 907 309
       Component: R4 2.0l TDI G000SG  9977
       Revision: 13H03---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 53078 002 1048576
       VCID: 76B5E59304C4CC67B49-8022
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 000 - Electrical Malfunction
                        Mileage: 230099 km
                        Date: 2013.06.01
                        Time: 02:36:21
                        Temperature: 16.2C
                        Temperature: 19.8C
                        Temperature: 12.6C
                        Lambda: 9.5 %
                        Lambda: 0.0 %
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000705112590
       Coding: 0005395
       Shop #: WSC 11111 551 00000
       VCID: 629DA9C3B84C40C7E81-8036
    02543 - Vacuum Sensor for Brake Booster (G483)
                        Fault Status: 00101100
                        Reset counter: 115
                        Mileage: 230099 km
                        Date: 2013.06.01
                        Time: 02:36:45
                        Hex Value: 0x0000
                        Voltage: 14.00 V
                        Bin. Bits: 00111110
                        Count: 132
                        Hex Value: 0x0000
                        Reset counter: 115
                        Hex Value: 0x0000
                        Voltage: 0.00 V
                        Bin. Bits: 00011111
                        Count: 227
                        Hex Value: 0x0000
                        Reset counter: 115
                        Hex Value: 0x0000
                        Voltage: 0.00 V
                        Bin. Bits: 00011111
                        Count: 149
                        Hex Value: 0x0000
                        Reset counter: 115
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 BT    HW: 3C0 907 044 BT
       Component: ClimatronicPQ46 122 0707
       Revision: 00122021    Serial number: 00000000000000
       VCID: 74B1DF9B12B8DE778AD-8020
       Revision: 00H54000    Serial number: 00000003626974
       Coding: 00800F0700041A00470A00000F000000000859435C000120000000000000
       Shop #: WSC 05124 000 00000
       VCID: 323D1983A82C9047581-8066
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 030707 003  0205
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__00J VW10 HI   1916
       Revision: 20013000    Serial number: 003E2PC9163W
       Coding: 0012362
       Shop #: WSC 05311 000 00000
       VCID: 44D14F5B02982EF7FAD-8010
       Subsystem 1 - Serial number: 6332MTS608923419
       Subsystem 2 - Serial number: 6342MTS671913449
       Subsystem 3 - Serial number: 6351HTS6VDN386KJ
       Subsystem 4 - Serial number: 6361HTS671A186KR
    00532 - Supply Voltage B+
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2013.06.01
                        Time: 18:29:21
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Component: LENKS.MODUL   009 0122
       Revision: FF010035    Serial number: 20100203100980
       Coding: 0182270002
       Shop #: WSC 05311 115 00000
       ASAM Dataset: EV_VW360SteerWheelUDS A03002
       VCID: 72BDD983642CD047981-8026
       Coding: E20000
    365080 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 18:29:25
       Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
       Component: KOMBI         H03 0305
       Coding: 060F00
       Shop #: WSC 05314 115 12345
       VCID: 2D070AFFBD92CFBF053-8078
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3620P10205045D
       Coding: F9801F06000202001002
       Shop #: WSC 05314 123 12345
       VCID: 2F3B10F7BB1EBDAF37F-807A
                        Fault Frequency: 11
                        Reset counter: 115
                        Mileage: 230099 km
    01304 - Radio
                        Reset counter: 115
                        Mileage: 230099 km
       Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
       Component:    IMMO         044 0383
       Revision: 00044000    Serial number: VWZCZ000000000
       VCID: 79AFEEAF35DAA31FD9B-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
       Part No SW: 3C0 959 701     HW: 3C0 959 793
       Component: TUER-SG FT    002 0306
       Revision: 13101005    Serial number: 0000368121
       Coding: 000035
       Shop #: WSC 05311 115 12345
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 6597B2DFA5E237FF0D3-8030
    65537 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN TSG-BF]
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 02:30:23
    68098 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN KSG]
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 02:29:49
    68099 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN Clima]
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 02:30:03
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.135 H08 1901
       VCID: 3537229F5942877F7D3-8060
       Component:    KSG PQ46 ELV 044 0612
       Coding: 10910A0801860E763004941570085BCE403C01
       Shop #: WSC 05311 123 12345
       Part No SW: 3C0 959 702     HW: 3C0 959 792
       Component: TUER-SG BT    002 0306
       Revision: 15101005    Serial number: 0000377226
       Coding: 000034
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 6695B5D358E43CE7049-8032
              U1111 00 [008] - -
              [Front CAN KSG]
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 01:32:03
              U1111 00 [008] - -
              [Front CAN Clima]
                        Reset counter: 155
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 02:30:27
    65793 - Supply voltage
              U1011 00 [009] - Voltage too Low
              [Front DCU undervoltage]
                        Reset counter: 115
                        Mileage: 230099 km
                        Date: 2019.01.09
                        Time: 01:09:30
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000158619
       Coding: 0000057
       VCID: 2C0107FB8A08C6B712D-8078
    Address 56: Radio
    End----(Elapsed Time: 01:08, VBatt start/end: 10.2V/10.1V. VIgn 10.0V)-----
    Thanks for posting the scan with the drive-side swap details.
    I'm going to move this to Retrofits. I'll edit this post if I have any coding suggestions.
    Edit. You already changed 19 to LHD so that's good. Address 17 isn't coded for GB/Northern Ireland anymore so that's good.
    Providing Coding: 0005395 was original that's still (L0R) Right-hand drive. 0000459 would be the LHD version of that 03-ABS coding. Please post another scan with that coding saved after clearing faults so we can see where you are.
    0005395 | 1513
    0000459 | 1113
  3. Likes Uwe liked this post
    Whoops. I missed address 46. That module has a bit in Byte 14 (LC,14,4,Model (0 = Left-Hand-Drive/ 1 = Right-Hand-Drive) so you need to un-check that. You already tweaked 42 and 52 so the window motors should be going up/down in the proper directions.
    Sep 2018
    Poland
    Thx for pointing that adress 46, i've missed.
    I can't code that ABS. It says: error 31: Coding out of range
    Sep 2018
    Poland
    ok i did code 0000275.
    So now i got one error less.
    That sensor G483 i thinks comes from donor car which had BKU engine, and in car is CBAB.
    Does this make any difference ? I didn't saw any vaccum measurments on ABS. Maybe that coding is not proper ? But on previous coding there was same error.
    im trying to get to that sensor, but thats not easy job.
    Friday,11,January,2019,09:56:50:16157
    Mileage: 230090km-142971mi   Repair Order: second
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56
       Coding: 0000072
                        Mileage: 230099 km
                        Date: 2013.06.01
                        Time: 02:36:21
                        Temperature: 16.2C
                        Temperature: 19.8C
                        Temperature: 12.6C
                        Lambda: 9.5 %
                        Lambda: 0.0 %
       Coding: 0000275
                        Reset counter: 115
                        Mileage: 230099 km
                        Date: 2013.06.03
                        Time: 13:36:31
                        Hex Value: 0x0000
                        Voltage: 13.75 V
                        Bin. Bits: 00011110
                        Count: 132
                        Hex Value: 0x0000
                        Reset counter: 115
                        Mileage: 230099 km
                        Date: 2013.06.03
                        Time: 13:36:31
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 0012362
       Coding: 0182270002
       Coding: E20000
       Coding: 060F00
       Coding: F9801F06400202001002
                        Reset counter: 115
                        Mileage: 230099 km
                        Reset counter: 115
                        Mileage: 230099 km
    01304 - Radio
                        Reset counter: 115
                        Mileage: 230099 km
    Address 37: Navigation
       Coding: 000035
       Coding: 10910A0801860E763004941570084BCE403C01
       Coding: 000034
       Coding: 0000057
    Address 56: Radio
    End----------(Elapsed Time: 01:26, VBatt start/end: 13.5V/13.0V)-----------
    EDIT
    now i checked my servo and it looks like dont have hole for that sensor.
    3c1 614 105 AH
    And on ABS there are no wires on pins 8 20 21 33
    So ABS is still not coded for that car
    I Tried all below coding with results:
    3c0 614 109 af
    0000 1000 0000 0000 + tpms
    0000019		0000 0000 0001 0011 g483 error
    0000259		0000 0001 0000 0011 out of range
    0000273		0000 0001 0001 0001 out of range
    0000274		0000 0001 0001 0010 out of range
    0000275 	0000 0001 0001 0011 G483 error
    0000279		0000 0001 0001 0111 out of range
    0000283		0000 0001 0001 1011 out of range
    0000307		0000 0001 0011 0011 out of range
    0000339		0000 0001 0101 0011 out of range
    0000403		0000 0001 1001 0011 out of range
    0000459         0000 0001 1100 1011 OUT OF RANGE
    0001219 	0000 0101 0001 0011 out of range
    0001297		0000 0101 0001 0001 out of range
    0002067         0000 1000 0001 0011 G483 error
    0002307		0000 1001 0000 0011 OUT OF RANGE
    0002321         0000 1001 0001 0001 out of range
    0002323 	0000 1001 0001 0011 G483 error
    0002327		0000 1001 0001 0111 OUT Of range
    0002331		0000 1001 0001 1011 out of range
    0002351		0000 1001 0011 0011 out of range
    0002387		0000 1001 0101 0011 out of range
    0002451		0000 1001 1001 0011 out of range
    0002819		0000 1011 0000 0011 out of range
    0002835		0000 1011 0001 0011 G483 error
    0003347		0000 1101 0001 0011 NOT CODED RIGHT. G483,J533
    0003331		0000 1101 0000 0011 out of range
    0005395		0001 0101 0001 0011 ORIGINAL
    0006163		0001 1000 0001 0011 G483 ERROR
    0006419		0001 1001 0001 0011 G483 ERROR
    0007187		0001 1100 0001 0011 NOT CODED RIGHT, J533
    0007427		0001 1101 0000 0011 OUT OF RANGE
    0007443		0001 1101 0001 0011 NOT CODED RIGHT
    Sep 2018
    Poland
    kind of solved.
    i added that stupid sensor, set coding to 0002323 and all errors are gone.
    i got enough of that car
