Results 1 to 3 of 3
Thread: Hi
    Jan 2019
    Hi
    My first post on here and I have a 2011 Audi A8L that shows service due on the display. How do I reset it? I did a auto scan with the Hex V2 so I'm including the results.
    Tuesday,08,January,2019,23:58:35:08589
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WAURVAFD1BN022584   License Plate:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
              46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 84 85 88 89 8A 8B
              8D 8E 8F 90
    VIN: WAURVAFD1BN022584   Mileage: 137478km-85424miles
    48-Seat, Rear, DS -- Status: OK 0000
    5B-Seat,Rear,PS -- Status: OK 0000
    84-Night Vision -- Status: OK 0000
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Component: 4.2l V8/4V    H07 0004
       Revision: N5H07---
       Coding: 0106000A290F0268
       Shop #: WSC 44331 000 1048576
       ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
       ROD: EV_ECM42FSI0114H0907560C.rod
       VCID: 2A0E0BCDEC7D3187E0F-807E
    7 Faults Found:
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [096] - Implausible Signal
    10434 - Catalyst System; Bank 1
              P0420 00 [096] - Efficiency Below Threshold
    10203 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [096] - -
                        Mileage: 135605 km
                        Date: 2018.12.17
                        Time: 12:20:06
                        Engine speed: 1190.50 /min
                        Normed load value: 37.3 %
                        Coolant temperature: 11 C
                        Intake air temperature: 10 C
                        Voltage terminal 30: 13.829 V
                        Unlearning counter according OBD: 28
                        AFS dm: 60.5 kg/h
                        Median injection timing: 2.347 ms
    10594 - Cylinder 4
              P0304 00 [096] - Misfire Detected
                        Mileage: 135605 km
                        Date: 2018.12.17
                        Time: 12:21:14
                        Engine speed: 936.50 /min
                        Normed load value: 35.3 %
                        Vehicle speed: 5 km/h
                        Coolant temperature: 13 C
                        Intake air temperature: 12 C
                        Voltage terminal 30: 14.206 V
                        AFS dm: 44.9 kg/h
                        Median injection timing: 1.818 ms
                        Engine operating condition: Part. load
                        Engine operating condition-Test_Program_Channel 87: 6
    10598 - Cylinder 8
              P0308 00 [096] - Misfire Detected
                        Mileage: 135605 km
                        Date: 2018.12.17
                        Time: 12:20:11
                        Engine speed: 794.50 /min
                        Normed load value: 43.1 %
                        Coolant temperature: 10 C
                        Intake air temperature: 11 C
                        Voltage terminal 30: 13.923 V
                        AFS dm: 45.5 kg/h
                        Median injection timing: 2.826 ms
    10592 - Cylinder 2
              P0302 00 [096] - Misfire Detected
                        Mileage: 134850 km
                        Date: 2018.11.11
                        Time: 10:01:33
                        Engine speed: 1557.50 /min
                        Normed load value: 38.8 %
                        Vehicle speed: 24 km/h
                        Coolant temperature: 12 C
                        Intake air temperature: 8 C
                        Voltage terminal 30: 13.900 V
                        Unlearning counter according OBD: 11
                        AFS dm: 88.5 kg/h
                        Median injection timing: 2.039 ms
    9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
              P0106 00 [104] - Implausible Signal
                        Mileage: 135600 km
                        Date: 2018.12.15
                        Time: 13:15:57
                        Engine speed: 1407.00 /min
                        Normed load value: 19.2 %
                        Vehicle speed: 28 km/h
                        Coolant temperature: 102 C
                        Intake air temperature: 55 C
                        Voltage terminal 30: 12.675 V
                        Unlearning counter according OBD: 29
                        AFS dm: 33.0 kg/h
       Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
       Component: 0BK 42 FSIUSA H08 1006
       Revision: --H08---
       Coding: 000002
       ASAM Dataset: EV_TCMALX51011 002018
       ROD: EV_TCMALX51011.rod
       VCID: 72BED3AD042D394798F-8026
    2505 - Torque Management Feedback Signal A
              P2637 00 [040] - -
                        Mileage: 135600 km
                        Date: 2018.12.15
                        Time: 13:15:59
                        Voltage terminal 30: 12.550 V
                        Transmission output speed: 405.00 /min
                        Driving position: d
                        M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                        M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                        M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                        Transfer speed from ESP: valid
                        Transfer speed from ESP: 16.53 km/h
       Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
       Component: ESP PREMIUM   H10 0273
       Coding: 44E6F20022674F00E200
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 323E13ADC4AD794758F-8066
    0172 - Function Restriction due to Faults in Other Modules
              U1113 00 [136] - -
              [Can_Motor_03_QBitMotormomente]
                        Reset counter: 71
                        Mileage: 135600 km
                        Date: 2018.12.15
                        Time: 13:15:58
                        VzRef: 1A
                        Bit Info 1: 40
                        Bit Info 2: 40
                        Bit Info 3: 06
                        Bit Info 4: 12
                        F-Path: 28
                        F-Type: 46
                        Uz: A2
    0694 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 65
                        Mileage: 134348 km
                        Date: 2018.11.03
                        Time: 11:17:40
                        VzRef: 59
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 06
                        Bit Info 4: 12
                        F-Path: 47
                        F-Type: 0D
                        Uz: B1
    0717 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Fault Frequency: 13
                        Reset counter: 65
                        Mileage: 133074 km
                        Date: 2018.09.08
                        Time: 19:04:16
                        VzRef: 59
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 06
                        Bit Info 4: 12
                        F-Path: 47
                        F-Type: 04
                        Uz: AC
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
       Component: BCM2 2.0      H24 0510
       Coding: 0D872000000000000000
       Shop #: WSC 44545 000 1048576
       VCID: 6E86C7DD10951DA77C7-803A
       Serial number: 2311000051587004
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 30
                        Mileage: 135605 km
                        Date: 2018.12.17
                        Time: 12:21:44
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000005689672
       Coding: C018B60085043201010001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 353428B135436E7F7DD-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
       Component: Klima 4 Zonen H14 0063
       Coding: 488122BE8C
       VCID: 221EE3ED944DE9C7A8F-8076
    0378 - Coolant Circulation Pump
              B10D0 04 [009] - Internal System Fault
                        Reset counter: 251
                        Mileage: 127544 km
                        Date: 2018.02.22
                        Time: 23:14:26
       Part No SW: 4H0 907 063 G    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0092
       Revision: 11012002    Serial number: 00000000830790
       Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
       VCID: 2C020DD5E6092FB7123-8078
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 110227  H32 0040
       Serial number:         110310152532
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10072438
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
       Component: E1 - LDS  H07 0044
       Serial number: 14 02 2011  00000093
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0DET06
       Serial number: 00000014031100010953
       Coding: 100000
       Serial number: 00000015031100010061
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA101140000000226417
       Coding: 020300
       Serial number: FC28CA95000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       VCID: 2310E6E98BD7E0CFA39-8076
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901105300072
       Coding: 300902
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 372822B92FCF9C6F6F1-8062
       Part No SW: 4H0 907 561 A    HW: 4H0 907 561
       Component: ACC3          H15 0160
       Coding: 3601020201
       ASAM Dataset: EV_AdaptCruisContrAU64X 001012
       ROD: EV_AdaptCruisContrAU64X_001.rod
       VCID: 290CF4C1E97B3A9FE95-807C
    6 Faults Found:
    10240 - Sensor for Automatic Distance Control
              [FAULT_BLR_BLK8_31]
                        Reset counter: 83
                        Mileage: 127972 km
                        Date: 2018.02.24
                        Time: 13:23:43
                        Control Module temperature: 38 C
                        Voltage terminal 15: 12.840 V
                        Velocity_vehicle_reference: 5.94 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.53 m/s
    88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_MAR_SLOW_MISALIGNMENT]
                        Reset counter: 43
                        Mileage: 127310 km
                        Date: 2018.02.20
                        Time: 00:07:40
                        Control Module temperature: 53 C
                        Voltage terminal 15: 14.002 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s
    88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_MAR_FAST_MISALIGNMENT]
                        Reset counter: 43
                        Mileage: 127310 km
                        Date: 2018.02.20
                        Time: 00:07:40
    12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_MAR_PRE_MISALIGNMENT]
                        Reset counter: 43
                        Mileage: 127310 km
                        Date: 2018.02.20
                        Time: 00:07:40
    105472 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_VDC_FAIL]
                        Reset counter: 83
                        Mileage: 128493 km
                        Date: 2018.03.05
                        Time: 15:56:19
                        Control Module temperature: 30 C
                        Voltage terminal 15: 14.453 V
                        Longitudinal_acceleration_vehicle_reference: -0.23 m/s
    140288 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_ECD_FAIL]
                        Reset counter: 83
                        Mileage: 128508 km
                        Date: 2018.03.10
                        Time: 10:22:42
                        Control Module temperature: 19 C
                        Voltage terminal 15: 14.580 V
                        Velocity_vehicle_reference: 17.05 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.09 m/s
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H41 0041
       Revision: --------    Serial number: 003JS001377P
       Coding: 303143303230303030314A55304C34483053
       Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
       Serial number: 5850000R1130301F16
       Serial number: 3575HRB404V0DUOGE9CH
       Serial number: 3585HRB40590DUOGCH5$
       Serial number: 3515JRB405R0ESAS58TE
       Serial number: 3525JRB405R0ESASF0OC
       Serial number: 3554VRB405R0FUO8M1EL
       Serial number: 3564VRB404R0G2I258LM
       Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KCB0002I
       Coding: 0004BC
       VCID: 323E13ADC42D794758F-8066
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H04 0009
       Serial number: 05 01 2011  33038497
       Part No SW: 4H0 920 880 C    HW: 4H0 920 880
       Component: TBenUSAACCNV- H30 0312
       Revision: 31110017    Serial number: 658170311592019
       Coding: 0B4608015700D705020000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K.rod
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1110315000663
       Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000121104
       Coding: 00C1034A00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 333016A93BB7704F539-8066
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650596967
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H14 0062
       Coding: 0000000000
       ROD: EV_AirCondiHeck.rod
       VCID: 313C1CA1C1AB425F215-8064
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008002
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C020DD5E6892FB7123-8078
    0648 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 71
                        Mileage: 135600 km
                        Date: 2018.12.15
                        Time: 13:15:58
       Revision: AA000000    Serial number: 00000005689486
       Coding: C018BF8085853201030001010101112131313333203333
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA3100F9ZE0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6C82CDD52609EFB7523-8038
       Part No SW: 4H0 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH02 0110
       Revision: 00H02000    Serial number: 6PZ 010 287-00
       Shop #: WSC 27993 002 1048576
       VCID: 6D84C0D11193E6BF45D-8038
       Subsystem 1 - Part No: 4H0 907 568
       Component: J770  SWA Slave H01 0110
       Subsystem 2 - Serial number: 6PZ 010 287-20
       Subsystem 3 - Serial number: 5F19.03.1100H010003CH11600
       Subsystem 4 - Serial number: H11600
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000114060254
       Coding: 011F1F205E0062C202000007
       VCID: 3B203E891367B80F8B9-806E
       Revision: 00002001    Serial number: 0146031522
       Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000023221
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J245  000C  H05 0004
       Serial number: 111200045391
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
       Component: Dachelektroni  H11 0080
       Serial number: A2011000000000356353
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J394  0060  H05 0004
       Serial number: 109700043959
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J392  007A  H05 0004
       Serial number: 111200045385
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J867  00F0  H05 0004
       Serial number: 109700043982
       Coding: 020200
       Revision: CJ007000    Serial number: 00000000026015
       Coding: 030000
       Shop #: WSC 59624 002 1048576
       VCID: 1D64D011ADB3D63F95D-8048
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860     HW: 4H0 959 860
       Component: MEM-FS-Fond   H06 0153
       Revision: AA000000    Serial number: 00001002385433
       Coding: 001892800000300D0A00392038193A2039203B3B202020
       VCID: 71BCDCA101AB025F615-8024
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000114169086
       VCID: 3A2E3B8D1C5D810790F-806E
       Revision: --------    Serial number: 00000000052305
       ROD: EV_ParkiBrake_VW51.rod
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                        Reset counter: 71
                        Mileage: 135600 km
                        Date: 2018.12.15
                        Time: 13:15:57
                        Voltage terminal 30: 13.1 V
                        Internal Fault ID: 188
                        Vehicle speed: 26 km/h
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Internal Parking Brake state: Dynamic
       Part No SW: 4H0 035 082 H    HW: 4H0 035 082
       Component: Radio U SIRIU H51 0138
       Revision: AB001007    Serial number: 155CY0B7501659
       Coding: 020007010000000001
       VCID: 2616FFFDF8E515E7C47-8072
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H06 0153
       Revision: AA000000    Serial number: 00001002385481
       Coding: 001896800000300D0A00392038193A2039203B3B382020
       Part No SW: 4H0 035 664 Q    HW: 4H0 035 664
       Component: H-BN-NA       H48 1038
       Revision: --------    Serial number: 098CY0B7502418
       Coding: 020200000001F9EF7D168B0E00000003F40001020000000000
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDB1100GHRW
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000033083
       Component: CD-Database  2712
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000114251682
       Coding: 010F1F20420062C202000007
       VCID: 392C2481195B8A1F995-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H04---    Serial number: 525 PA8J12D1MS
       Coding: 1020003
       VCID: 6594B8F1C963DEFF0DD-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 079100099
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B203E8913E7B80F8B9-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000027253
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6390A6E9CBD7A0CFE39-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000114251686
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H05 0081
       Revision: 0L0D5012    Serial number: SN110204  0100
       ASAM Dataset: EV_GSM2x3Mono 001014
       ROD: EV_GSM2x3Mono.rod
       VCID: 2B000EC9E387288F1B9-807E
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 E    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H09 0026
       Serial number: 0K84AE40029727
       Coding: 1200
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H08 0007
       Serial number: 00000000001104810941
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0034
       Coding: E9060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 6594B8F1C5E3DEFF0DD-8030
       Serial number: 00000105096802
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F381AD9D79F54AF371-807A
       Serial number: 00000105104901
       Coding: 364FF2
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Component: IVB           H08 0042
       Serial number: 00000172292502
       Coding: 200F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
       VCID: 2E0607DDD0955DA73C7-807A
       Part No SW: 4H0 907 541 A    HW: 4H0 907 541
       Coding: 3601020201
       ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
       ROD: EV_AdaptCruisContr2AU64X_001.rod
       VCID: 2708F2F9FF6F0CEFFF1-8072
              U1113 00 [008] - -
                        Reset counter: 83
                        Mileage: 128493 km
                        Date: 2018.03.05
                        Time: 15:56:19
                        Voltage terminal 15: 14.349 V
                        Velocity_vehicle_reference: 0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.31 m/s
              U1113 00 [008] - -
                        Reset counter: 83
                        Mileage: 128508 km
                        Date: 2018.03.10
                        Time: 10:22:42
                        Control Module temperature: 20 C
                        Voltage terminal 15: 14.784 V
                        Velocity_vehicle_reference: 16.60 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.04 m/s
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
       Serial number: 00000172229602
       Coding: 200F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
       Part No SW: 4G0 907 107 B    HW: 4H0 907 107
       Component: BV-SG         H28 0034
       Serial number: 000040181103117
       Coding: 02A19A000111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 2514F8F185631EFFCDD-8070
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 0066F609031F007E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FB8DAD9171F14AF771-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70BAD9A50A210B576EB-8024
    End----(Elapsed Time: 03:21, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    From the main screen in VCDS, click [SRI Reset]
    Wait a few moments for VCDS to read the SRI-Related channels.
    When it's done, use the drop-down menu to select a task. There should be two available, just ESI or ESI and FIX. The former resets the just oil change service reminder. The latter does both the oil change service reminder and the inspection service reminders.
    After you've selected a task, click [Perform SRI].
  3. Likes darkchina811 liked this post
    Jan 2019
    Thanks Uwe.
