Results 1 to 10 of 13
Thread: [2005 TOUAREG] 00488 - Rear Right Outside Door Handle Central Locking Button (E372)
    Dec 2018
    Terrebonne, Quebec, Canada
    Tuesday,08,January,2019,16:34:00:55476
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
    VCDS Version 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVGMM67L75D055257   License Plate:
    Mileage: 199200km-123777mi   Repair Order:
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGMM67L75D055257   Mileage: 199200km-123777miles
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 M
       Component:                     3001
       Coding: 0105695
       Shop #: WSC 31414 000 00000
       VCID: 46D5543074BA6677E47-5161
    00060 - Foglight Lamps
    Address 32: Differential Locks        Labels: None
       Part No: 0AC 927 771 C
       Component: SG-Quersperre       5020
       VCID: 38292AC80E4E008766B-5161
    02062 - Differential Lock
    02412 - Differential Lock Rear
       Part No: 7L0 959 933 E
       Component: H6 HSG              0201
       Coding: 0000085
       Shop #: WSC 94713 999 59229
       VCID: 3E253CD02C6A3EB7AC7-4B01
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
                007 - Short to Ground
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 392F2FCC3544198F995-5161
    7 Faults Found:
    01629 - Sensor for Parking-Aid; Front Left (G255)
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
    00434 - Left Front Inner Parking Aid Sensor (G332)
    00435 - Front Right Inner Parking Aid Sensor (G333)
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
    01626 - Sensor for Parking-Aid; Front Right (G252)
                006 - Short to Plus
    End----(Elapsed Time: 09:39, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
    Working on my TREG today for a few issues, I decided to look after that one:
    I dismounted that right rear door and tested for the switch. No issue there.
    I found out if I remove the big plug from the window motor, it removes the code.
    Seems like this plug connect to another controller made with the windows motor. What may I do next?
    -->2005 Volkswagen Touareg
    V8 4.2, Air Suspension,
    Lockable Center Differential + Rear Locking Differential
    19" Wheels, Factory Hitch and about 50 electronic issues
    Dec 2018
    I forgot to tell that everything on the door works normally (locking etc.)...
    What happened to that Auto-Scan... a LOT of stuff missing. Please see about getting a FULL Auto-Scan posted.
    The right rear exterior door handle central locking button (E372) looks to be a simple normally open switch. With the right rear door handle, there will be 5 wires:
    /1 = 0.5 br to J389 T12o/7
    /3 = 0.5 gr/br to J389 T12o/10
    Is the switch sticking? Is the wiring shorted to ground?
    46-08-009.4 shows live data of the E372.
    46-08-008.4 shows live data of the left rear exterior door handle (E371) to use as a base line value from a "known good" source.
    What kind of data do you get in groups 008 and 009 as you operate and release those exterior door handle buttons? What data do you get as you unplug the right rear door handles?
    Jef
  4. Likes TkNorris liked this post
    Dec 2018
    Thansk for your help. Him currently working on those.
    Here is a new scan:
    Address 01: Engine        Labels: 077-907-560-AXQ.lbl
       Part No SW: 4D0 907 560 DB    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0010
       Revision: 00000000    Serial number: VWZ3Z0D7284728
       Coding: 0007875
       Shop #: WSC 94713 999 52438
       VCID: 698FBF8C0564690F295-5161
    Readiness: 0110 1101
       Part No: 09D 927 750 AQ
       Component: AL 750 6A           0903
       Coding: 0004153
       VCID: 7DA7FBDC61ECE5AFF5D-5161
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0014594
       VCID: 3D273BDC216C25AFB5D-5161
    02054 - Control Module for Differential Locks (J647)
       Part No SW: 3D0 909 135 R    HW: 5WK 470 26
       Component: 17 Kessy            6610
       Revision: 66105312    Serial number: VWZ3Z0D7284728
       Coding: 0131304
       VCID: 34311EF81226E4E74A3-5161
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77ABE9F443D0CFFFAF1-5161
       Component:                     3001
       Coding: 0105695
       Part No: 3D0 909 601 E
       Component: 0C Airbag 8.4E+ H10 0952
       Coding: 0012355
       VCID: 2517F3BCA9FC8D6FCDD-5161
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 881 D
       Component: KOMBIINSTRUMENT RB8 3135
       Coding: 0005331
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70B9D2E826BE98C76EB-5161
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F5B01D46BE0F7BFE71-5161
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       Shop #: WSC 94706 999 999999
       VCID: 363524F0045AF6F7747-5161
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 C
       Component:      Navigation     0047
       Coding: 0000101
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: 678BB9B413705F7F3F1-5161
       Coding: 0000085
    6 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    01134 - Alarm Horn (H12)
    Address 56: Radio        Labels: 7L6-035-186-CD.lbl
       Part No: 7L6 035 186 A
       Component:        Radio        0047
       Coding: 0014062
       VCID: 313F17ECED34D1CF215-5161
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000855
       Shop #: WSC 31414 000 376832
       VCID: 3C2136D83A762CA7823-5161
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00217125
       Shop #: WSC 31414
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 K
       Component: DACHDISPLAY         0538
       Revision: 00700538    Serial number: 2009289.06
       VCID: 3FDB41D42B6037BFA71-5161
    7 Faults Found:
                006 - Short to Plus
    Wednesday,09,January,2019,10:23:36:55476
       Coding: 0007875
       Coding: 0004153
       Coding: 0014594
       Coding: 0131304
       Component:                     3001
       Coding: 0105695
       Coding: 0012355
       Coding: 0005331
       Coding: 0000006
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       VCID: 45D7533C49BC6D6FEDD-5161
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       Coding: 0000003
       VCID: 6695B4B0147A4677047-5185
       Coding: 0015521
       Coding: 0000101
       Coding: 0000003
       Coding: 0000085
       Coding: 0014062
       Coding: 0000855
       Coding: 00217125
       Shop #: WSC 31414
    End----------(Elapsed Time: 09:49, VBatt start/end: 12.4V/12.4V)-----------
    Dec 2018
    No everyhting is working fine
    Dec 2018
    With your help I found something that may hlp you to help me :-p
    Here is the log of the 46-08-008.4, 46-08-009.4
    Lock, unlock from inside is same on both door for the results. NBoth 2 things are different:
    Wednesday,09,January,2019,10:50:47:55476
                    Address 46: Central Conv.  (7L0 959 933 E)
    10:50:45 Group 008: Rear Left Door
      Not Oper.  WR-Button (E52) Rear Left Door
      No  Window Regulator Therm. Prot. (V26)
      Not Oper.  Lock Butt. (E310) Rear Left Door
      Not Oper.  Rear Left Outside Lock Butt. (E371)
    10:50:45 Group 009: Rear Right Door
      Not Oper.  WR-Button (E54) Rear Right Door
      No  Window Regulator Therm. Prot. (V27)
      Not Oper.  Lock Butt. (E311) Rear Right Door
      Activated  Right Left Outside Lock Butt. (E372)
    Also when I opush that botton on rear left or front right, I hear a relay under the stearing wheel, and I dont ear it on my rear right botton. So I'm going to test more directly for that switch.
    I always had issue unlocking and opening the rear left door, maybe it's related?
    Dec 2018
    I removed extenral door handle and I kinda broken the switch, removing the bottom mecanism, error still stay, because I suppose of the short to ground somewhere else.
    I do not find the wiring diagram of this. anybody knows what wires I could cut to remove the external switch connection?
    5 of them goes to the handle.
  9. #8
    The way the wiring diagram shows this, the E372 is a simple "normally open" switch, when activated, /1 and /3 are shorted together.
    The current live data implies /1 and /3 are shorted together, thus the E372 is "Activated".
    46-08-009.4, does the data change if you unplug the wiring harness from the exterior door handle?
    With the right rear door handle unplugged, ohm test /1 and /3 of the door handle, what is the value?
    A crappy wiring diagram appears:
    Jef
  10. Likes Uwe, jyoung8607, TkNorris liked this post
  11. #9
    Dec 2018
    It seems indeed it was like you described. I mean, it was shorted activated. I was not too sure which wire was doing what, because it seems the plug going from the window motor controller to the door handle has wires serving other purpose than the door handle. I think I fixed it. I tried disconnecting wire one by one and test. I think I disconnected the one which is #3 on your diagram. After clearing DTCs, I do not see an error anymore!
  12. #10
    The door control module isn't involved here... at least as the wiring diagram shows it. The E372 is part of the right rear exterior door handle and none of the wiring from the exterior door handle goes to the door control module (power window motor). As the crapping wiring diagram shows, the E372 switch goes to the CCM (J389).
    Maybe the wire that comes off /1 is shorting to ground (chassis) and in wiggling/moving the wiring around, you fixed the issue for now.
    Jef
  13. Likes Uwe liked this post
