Results 1 to 5 of 5
Thread: 2015 S3 Still Misfires after New Coil Packs, New Plugs, Carbon Cleaning. Thoughts?
    Apr 2017
    Hello Everyone and Happy New Year! Back on the board with my 2015 S3, the same one that had transmission issues that you guys helped me out with, and AOA ended up replacing under goodwill.
    Now I have been having misfires for the last few months. Let me list the issues // problems in proper (or as close to) JPPSG:
    1. 2015 Audi S3
    2. Car is modified - Unitronic Stage 2 ECU Tune and Stage 2 DSG Tune as of 60,000 miles. Aftermarket catted downpipe with O2 Sensor still in place, and cold air intake.
    3. Problems started around 73,000 miles. Here's the latest scan:
     Monday,07,January,2019,21:19:18:63824
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WAUBFGFF3F1083628   License Plate:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 55 5F A9 BB
              BC
    VIN: WAUBFGFF3F1083628   Mileage: 124744km-77512miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 0A1D00122426000E3004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
       ROD: EV_ECM20TFS0208V0906259E_AU37.rod
       VCID: 42DE43C884004417C81-8016
    6 Faults Found:
    15125 - Cylinder 1
              P0301 00 [236] - Misfire Detected
                        Mileage: 123794 km
                        Date: 2018.12.18
                        Time: 05:55:44
                        Engine speed: 3125.50 /min
                        Normed load value: 16.9 %
                        Vehicle speed: 26 km/h
                        Coolant temperature: 43 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 13.789 V
                        Engine: operating status: PL
                        N_TOOTH: 3152 /min
                        T_AST_SAE: 33 s
                        Engine oil temperature: 22.0 °C
                        STATE_LS_SAE[1]: CL
                        FUP_H_SAE: 7970.0 kPa
                        FUP_EFP_MES: 11000.8 hPa
    15131 - Cylinder 3
              P0303 00 [236] - Misfire Detected
                        Mileage: 123794 km
                        Date: 2018.12.18
                        Time: 05:55:44
                        N_TOOTH: 3152 /min
                        T_AST_SAE: 33 s
                        STATE_LS_SAE[1]: CL
    15134 - Cylinder 4
              P0304 00 [236] - Misfire Detected
                        Mileage: 123794 km
                        Date: 2018.12.18
                        Time: 05:55:44
                        N_TOOTH: 3152 /min
                        T_AST_SAE: 33 s
                        STATE_LS_SAE[1]: CL
    15128 - Cylinder 2
              P0302 00 [100] - Misfire Detected
                        Mileage: 123794 km
                        Date: 2018.12.18
                        Time: 05:55:44
                        N_TOOTH: 3152 /min
                        T_AST_SAE: 33 s
                        STATE_LS_SAE[1]: CL
    15137 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [096] - -
                        Mileage: 123794 km
                        Date: 2018.12.18
                        Time: 05:55:44
                        Engine speed: 3017.75 /min
                        Normed load value: 15.3 %
                        Vehicle speed: 25 km/h
                        Coolant temperature: 42 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 13.652 V
                        N_TOOTH: 3021 /min
                        T_AST_SAE: 40 s
                        Engine oil temperature: 23.0 °C
                        STATE_LS_SAE[1]: CL
                        FUP_H_SAE: 7880.0 kPa
    15271 - EVAP System
              P0456 00 [096] - Very Small Leak Detected
    Readiness: 0010 0001
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H54 4521
       Revision: 06354004    Serial number: TFK01609010381
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1F18EABC573249FF87F-804A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 62944000003909
       Coding: 31FF6B9254280A6F017D030241CB698CD62A5080C08296B6024100588208
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 48CA51E0A23C6E47165-801C
       Revision: 00021000    Serial number: 0352076171
       Coding: 030C0C
       VCID: 3A2E3B28ECD00CD7901-806E
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000487739
       Coding: 03000014010000000000000000001400
       VCID: 3330160CCBBAFD9F537-8066
       Serial number: EFF80A57000000000001
    328964 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                        Reset counter: 31
                        Mileage: 123972 km
                        Date: 2018.12.19
                        Time: 19:34:06
                        Voltage terminal 30: 13.8 V
                        Interior temperature: 28.6 °C
                        Outside air temperature: 24 °C
                        Front air distribution flap: actual value: 0
                        Front air distribution flap: actual value: 95.5 %
                        Front air distribution flap: specified value: 92
    328967 - Position Sensor for Front Air Distribution Flap Motor
              B1099 15 [008] - Open or Short to Plus
                        Reset counter: 57
                        Mileage: 122983 km
                        Date: 2018.12.09
                        Time: 09:58:26
                        Voltage terminal 30: 14.4 V
                        Interior temperature: 27.4 °C
                        Outside air temperature: 23.5 °C
                        Front air distribution flap: actual value: 768
                        Front air distribution flap: actual value: 0.0 %
                        Front air distribution flap: specified value: 934
       Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
       Component: BCM MQBAB HNA H18 0137
       Serial number: 01011430701262
       Coding: 04151A46C04122F541C04004511807A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7AAEFB28AC50CCD7D01-802E
       Component: WWS371 141009  042 0585
       Serial number:         141108082028
       Coding: 0A47F7
       Serial number: 23391689
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 10 09 2014  00001191
       Serial number: 00000000000060929188
       Sun Roof:
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0000ZE5I00000
       Coding: 101F00
       Serial number: 003GCR00YML6
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47C852DCAF22613F1FF-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34178311B13111470353
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34178312B11111470450
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 6940000Y1400018DCA0G
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 000 611 14
       Serial number: 357000000008AC10811D
       Subsystem 5 - Part No SW: -----------    HW: 480 000 611 14
       Serial number: 358000000008EB10811H
       Subsystem 6 - Part No SW: -----------    HW: 480 403 010 14
       Serial number: 3510002A11860BC2A0B/
       Subsystem 7 - Part No SW: -----------    HW: 480 403 010 14
       Serial number: 35200029F1860BC1F0AE
       Subsystem 8 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3550002A9175A921D062
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3560002A9175A92490EA
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 11111408490509
       Coding: A018
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 0A4EABE8FCB0DC57C01-805E
       Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
       Component: KOMBI         H02 4291
       Coding: 0BED181B2B80D7050201A8001800000000000000
       VCID: 4CC26DF0B644826732D-8018
       Revision: --------    Serial number: 21101410802153
       Coding: 0101000830085A005B00022C180B00000001010000000000000000000000
       ROD: EV_GatewConti_011_VW37.rod
       VCID: 72BED308F420B497981-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 01 11 2014  F0001478
       Serial number: HA1-00007.10.14
       Coding: 0001
       VCID: 46D65FD8A8287837E49-8012
       Revision: 00000000    Serial number: 14000294069005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34321510CEB4FAA74AD-8060
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 22101401101049
       Coding: 00511F204000048000000002
       Coding: 8102
       VCID: 3728221CDFC211BF6FF-8062
       Part No SW: 8V0 035 465 C    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0410
       Serial number: AUZ8ZAEN900T2KA
       Coding: 01030300AAAA2AAA01
       ASAM Dataset: EV_AMPMst16C1ALPI 004024
       ROD: EV_AMPMst16C1ALPI_004_AU37.rod
       VCID: 382A2120D2DC1EC7665-806C
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 29101401101712
       Coding: 005117204000048000000002
       VCID: 41DC4CC481065F0FD1B-8014
       Coding: 012A000101000000
       VCID: 75B4E814854EA3AFBD3-8020
       Part No SW: 8V0 035 844     HW: 8V0 035 844
       Component: MU-S-S-US     013 0626
       Serial number: A7A00411140352
       Coding: 017301000000000021220002001A00002F0002240100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 76B6EF189848A8B7B49-8022
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY307904
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Serial number: C1000011071400020161
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0012
       Serial number: 140925200908
       VCID: 7DA4F034BD7EFBEFF53-8028
       Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0028
       Serial number: 03111403111856
       Coding: 004117204000048000000002
       Component: TSG HBFS      020 0028
       Serial number: 03111402081849
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
    4. Once again the CEL went on and i ran a scan. I got the above misfire codes and a "small EVAP leak" code. So i changed the N80 valve, spark plugs and coil packs, all parts were OEM and stock to car (S3). Cleared the codes and was good to go for about 73,000 miles. The CEL went on again with misfire codes. This time i went with "upgraded" coils (RS3) and plugs (colder RS7), reset the code and was good to go for a few miles. Then AGAIN i got a CEL.
    With my mileage i suspected carbon buildup. I went to a reputable car repair shop (not sure if i can post their name) and they ran a diagnostic. I DID not tell them i suspected carbon buildup so as to get a "transparent" diagnosis. They said the car needed a carbon cleaning and showed me photos of what appeared to be a bat cave (probe photos via intake manifold). I went ahead with the carbon cleaning and i noticed a MUCH smoother idle and acceleration. These guys also replaced the injector gasket and the intake manifold gasket as well as replaced the water pump (had a small leak and they gave me a GREAT deal on replacing it since they were in there already).
    That was about 3,000 - 4,000 miles ago and here we are with MORE misfires. The above scan is the latest.
    5. Here is what i am thinking about doing: flash car back to stock. Perform a smoke test and find the cause of the EVAP leak (need to buy a decent smoke machine that won't break the bank, opinions are welcome). I was thinking it might be the PCV also? Maybe replace that?
    Thanks for any help!
    1. 2015 Audi S3
    Vehicle Identification No. WAUBFGFF3F1083628
    Model Audi S3 sal. Qu. 2.0
    A3
    Date of production 24.11.2014
    Year 2015
    Sales type 8VS51L
    Engine Code CYFB
    Transmission Code QSP
    Nice post..........
    Is sump with fuel contamination or clean?
    Don't you think you should Un-modify car and observe coil packs, plugs and ignition system connectivity + HPP for leak into sump thinning oil & verify the spray pattern, injector hold or replace injectors and you don't need a smoke machine, use a mighty vac and trims in VCDS to guide the test path and isolate for false air?
    Did you verify G28 isn't a dirty signal?
    Is CAT plugged or part blocked?
    OP can you post mode 9 data for this car in VCDS OBD2 mode in main screen please?
  3. Likes lordjop liked this post
    Apr 2017
    Thanks for your help. I work some crazy hours so i am limited in what i can do with the car at this point. However, i was able to get the Mode 9 info you requested:
     Wednesday,09,January,2019,11:01:02:63824
    VIN: WAUBFGFF3F1083628   License Plate: MOD 9 OFF
    Mode 9 : Calibration Identification
    Type 02 - VIN : WAUBFGFF3F1083628 (Address E8)
    Type 04 - Calibration ID : 8V0259E 0001AVCK (Address E8)
    Type 04 - Calibration ID : 0D9300012L  4521 (Address E9)
    Type 06 - Calibration Verification Number : 77749A10 (Address E8)
    Type 06 - Calibration Verification Number : 0000AFEB (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 526
        Ignition cycle count : 1273
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 0 / 334
             Catalyst monitor bank 2 : 0 / 0
             O2 Sensor monitor bank 1 : 0 / 337
             O2 Sensor monitor bank 2 : 0 / 0
             EGR-VVT monitor : 1007 / 525
             AIR monitor : 0 / 0
             EVAP monitor : 78 / 198
             Secondary O2 Sensor monitor bank 1 : 0 / 334
             Secondary O2 Sensor monitor bank 2 : 0 / 0
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
    You mentioned a possible dirty signal from the G28? I believe that is the engine speed sensor? It shows an RPM value of around 3,000 RPM and that is exactly when the misfire occurred. I live in a warm climate and the day the CEL went on i was driving down my block and felt a hesitation as i slowly accelerated. Once the car warmed up and got to operating temperature there were ZERO issues. It appears that it is a cold start misfire issue.
    Today i had to run an errand in the morning and the car felt like it misfired upon startup, but ran fine after warming up. After my errand I connected the VCDS while the car was running and logged for any potential misfires (about 5 minutes) and saw NONE.
    I also want to mention the shop ran a compression test on each cylinder and everything looked good, i.e a consistent 135 PSI for cylinders 1 - 4. So it doesn't sound like weak valve springs or sticky valves, although i'm sure the shop would've mentioned that.
    I have a hunch the small EVAP leak is the culprit and when i have off (Monday) i want to run some more tests and trace down the leak. Just to be sure i will also check the injectors, and the HPFP and try to troubleshoot things. I will keep you all posted and thanks again for your help so far !!
    Affirmative!
    May 2016
    Would appear a lean burn as somewhat goes away once warm, also misses at 3,000 so pushing it a bit.
    Would be curious to watch fuel pressure when this happens and what the fuel trim, is at that point?
    But as JACK stated with tuning all bets off.
    LARIMORE.
