Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Emergency brake flashing via turn signals
    Nov 2018
    Europe - Hungary
    I would like to activate Emergency brake flashing via turn signals.
    Tuesday,11,December,2018,19:37:53:64377
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
    VCDS Version 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: TMBAR7NEXK0036742   License Plate: PYK234
    Mileage: 5744km-3569mi   Repair Order:
    Chassis Type: NE-SK37 (3Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
    VIN: TMBAR7NEXK0036742   Mileage: 5744km-3569miles
    BB-Door Rear Drv -- Status: Not registered 0001
    BC-Door Rear Pass -- Status: Not registered 0001
    Address 01: Engine (J623-DADA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 05E 906 018 AL    HW: 05E 907 309
       Component: R4 1.5l TFS   H22 6084
       Revision: 81H22000
       Coding: 011900322324190800000000000000000000000000000000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM15TFS01105E906018AL 003002
       ROD: EV_ECM15TFS01105E906018AL.rod
       VCID: 6FBBD0C76712BBEF77F-803B
    Readiness: 1110 0001
    Address 03: ABS Brakes (J104)       Labels:* None
       Part No SW: 5Q0 614 517 DF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0974
       Revision: 00000000    Serial number: 62278000000267
       Coding: 24076A9124232172407E060460C5242456248402600624722023F070C009430B00000012121212B835351919323200
       Shop #: WSC 73430 031 12345
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
       ROD: EV_Brake1UDSContiMK100ESP_037_SK37.rod
       VCID: 78A9EB9B125CFC57A65-802D
       Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
       Component: Climatronic   H04 2002
       Revision: 00001K00
       Coding: 01010004000110011005004800101022
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ACClimaBHBVW37X 006147
       VCID: 73B3DCB70B3A9F0F937-8027
       Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
       Component: BCM MQBAB B   H38 0273
       Serial number: 00001823902159
       Shop #: WSC 73430 790 12345
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7AADF1932C50EE47D01-802F
       Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 180811  051 0916
       Serial number: 887353F0401822300929
       Coding: 1E4DFD
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 72290246
       Part No SW: 5QA 919 283 C    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0050
       Serial number: 000308419618240
       Coding: 0601050001
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_EPHVA14AU3700000 009037
       ROD: EV_EPHVA14AU3700000.rod
       VCID: 4ACD61533C30BEC7001-801F
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0712
       Revision: --------    Serial number: 003W4PHN028S
       Shop #: WSC 73430 790 00000
       ROD: EV_AirbaVW21TS6VW48X_VW37.rod
       VCID: 0557926F55AE91BFAD3-8051
       Subsystem 1 - Part No SW: -----------    HW: 454 001 308 18
       Serial number: 3570000000090C38B03I
       Subsystem 2 - Part No SW: -----------    HW: 454 001 608 18
       Serial number: 35800000000F1358313C
       Subsystem 3 - Part No SW: -----------    HW: 454 801 908 18
       Serial number: 35100AD22EF15000000S
       Subsystem 4 - Part No SW: -----------    HW: 454 802 108 18
       Serial number: 352005545B6150000009
       Subsystem 5 - Part No SW: -----------    HW: 454 800 408 18
       Serial number: 3550095843915000000E
       Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 30081820241335
       Coding: 1400
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7EA5FD833078C267EC9-802B
       Part No SW: 5E0 920 740 F    HW: 5E0 920 740 F
       Component: KOMBI         212 2501
       Coding: 07A502002180000801003E001001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009066
       VCID: 2615F5E38868BAA7C49-8073
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   439 4344
       Revision: --------    Serial number: 0008379434
       Coding: 030100047F085700EB000248080F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW37.rod
       VCID: 3D273A8F7DFE197FB53-8069
       Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000D2174290818
       Serial number: 75886002001809012D3D
       Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
       Component: TSG FS        006 0246
       Serial number: 0000336807160
       Coding: 00110120D000020000001100
       VCID: 48C95B5B223C4CD7165-801D
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000023505338
       Coding: 010200
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 856026 00
       Coding: 0100001000400010
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: EV_SteerAssisVWBSMQBGen2_SK37.rod
       VCID: 2B0304D7938A87CF1B7-807F
       Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0246
       Serial number: 0000341102239
       VCID: 47CB58672F2243AF1FF-8013
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000023517010
       Coding: 190200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 840 C    HW: 5Q0 035 840 C
       Component: MU-S--ER      H41 0472
       Serial number: SKZAZ2U0789211
       Coding: 03730100FF00000041110001000002002F0208C40120050003
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2D070ACFAD9E89FF053-8079
       Subsystem 1 - Part No SW: 5E0 919 605 N    HW: 5E0 919 605 N
       Component: ABT_Std-2  H52 8130
       Serial number: SKZ6ZHV2471660
    Address BB: Door Rear Drv
    Address BC: Door Rear Pass
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
    Apr 2018
    ITALY
    please elaborate. first of all, what Skoda is that?
    then, what do you exactly want? you want the brake lights to flash together with the turning signal? I don't know if that would be more weird or more illegal
    as your BCM has no coding we will need an admap. and go remind the Gateway that you have rear doors :P
    Apr 2018
    ITALY
    and, lucky you! you don't have a single module in the car that needs Extended CAN-BUS, but still you have a HIGH Gateway.
    pimp her up
    US 2014 GTI Drivers Edition/DSG
    some vw's can flash the turn signals (like emergency flashers) when the brakes are activated for an emergency stop (probably whenever the ABS kicks in or whatever).
    So the brake lights work normally (solid no flash) while the turn signals activate both sides and flash.
    https://www.youtube.com/watch?v=XByKBKdd5J8
    Nov 2018
    Europe - Hungary
    My car is an 2018.09 (MY2019) Skoda Octavia.
    I would like the function like this:
    https://www.youtube.com/watch?v=xa4HIPxhu8c
    When the car stops after emergency braking the hazard warning (both turn signal) blinks. When the car starts again the turn signals switch off automatically.
    This was the old way but the long coding not working anymore.
    I don't know what does it mean: Gateway that modules BB and BC are installed
    ;SW:5Q0-937-084-DA   HW:5Q0-937-084-CD ---  Cent. Elect. --- SA: 31347
    ;Component:BCM MQBAB B   H38 0273	Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BCMMQB	19001	EV_BCMBOSCH_019_VW37.rod
    ;Saturday	6	October	2018	07:06:02:35062
    ;VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
    ;VCID: 7AB80619FD57AF9A9B-802E
    IDE00001-ENG99061-Production mode-Access control	not active	3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active	3
    IDE00002-Transport mode	active	1
    IDE00820-Activating and deactivating all development messages	not active	1
    IDE01550-Service position	157.999843 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate	10
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active	10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active	10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active	10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active	10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal	10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active	10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active	10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	not active	10
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active	10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active	10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
    IDE02332-Deactivate production mode	0	3
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active	8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active	8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-0.3 °	16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	0.0 %/s	16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides	16
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	0.0 °C	16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	0.0 °C	16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	65 °	16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	0.0 °C	16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	40 °	16
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119	16
    IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
    IDE03787-Activate left/right hand drive switch-over	not active	1
    IDE04927-IDE01446-Window heater-Running time of heated front window	600 s	11
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
    IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
    IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed	11
    IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed	11
    IDE04927-ENG126845-Window heater-FSH Automatik	active	11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s	11
    IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed	11
    IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed	11
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage	not installed	11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	not active	11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active	11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv	-2.0 °C	11
    IDE04927-ENG141962-Window heater-Waschduesenheizung	not installed	11
    IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
    IDE04928-MAS01577-Anti-theft device-Parking heater	not installed	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active	8
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated	8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	not active	8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active	8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active	8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active	8
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active	8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	not installed	8
    IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed	8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No	8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm	activ	8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active	8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No	8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No	8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme	8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor	No	8
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active	8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	2 sekunden verzoegerung	8
    IDE05143-MAS02985-Writing parameter-Value	130	5
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00	5
    IDE05144-Read parameter address	FE 00 00	3
    IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 08 09 1B 1E 00 1B 14 00 64 00 00 00 04 4C 00 4C 08 0A 1B 1E 00 1B 14 00 64 00 00 00 01 48 00 49 08 09 7F 1E 00 7F 14 00 7F 00 00 00 01 4C 00 4B 08 0A 7F 1E 00 7F 14 00 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00	224
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler	0	30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	not_installed	30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	30 s	30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	1.10 °C	30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	33.00 °C	30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	32.00 °C	30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	33.00 °C	30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	32.00 °C	30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	37.50 °C	30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	36.50 °C	30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	37.50 °C	30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	36.50 °C	30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	41.00 °C	30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	40.00 °C	30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	41.00 °C	30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	40.00 °C	30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung	30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung	30
    IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed	30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.0 V	30
    IDE06425-Roller test bench mode: functional	not active	1
    IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop	8
    IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed	8
    IDE06507-MAS13132-Button in center console-Function of button 3	not coded/not installed	8
    IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed	8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed	8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	not_active	8
    IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active	8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	not_active	8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	not_active	8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	not active	8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed	8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut	not installed	8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	not active	8
    IDE07356-Position during interval mode	16.999983 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit	6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	not active	6
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active	9
    IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed	9
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	sensitive	9
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active	9
    IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active	9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	not installed	9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed	9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	0	19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active	19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active	19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	not active	19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.25 s	19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80 %	19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	20 %	19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80 %	19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	0 %	19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	0 %	19
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active	19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active	19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	active	19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active	19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung	19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active	19
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed	19
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active	19
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed	19
    IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed	19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active	19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	not installed	19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active	19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	1	5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active	5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed	5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed	5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed	5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active	5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active	5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed	5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed	5
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed	5
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed	5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed	5
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active	5
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active	5
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed	5
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed	5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30 %	17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	30 %	17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30 %	17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	30 %	17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	50 %	17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	50 %	17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	50 %	17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	50 %	17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	50 %	17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	50 %	17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	70 %	17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	70 %	17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed	17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed	17
    IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed	17
    IDE10298-Alternating park position 1	0.000000 °	2
    IDE10299-Alternating park position 2	13.999986 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	0	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	1	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100 %	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	0 %	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	100 %	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100 %	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100 %	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100 %	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100 %	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100 %	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	100 %	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100 %	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	0 %	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	100 %	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100 %	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100 %	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100 %	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100 %	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100 %	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	100 %	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100 %	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	0 %	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	100 %	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100 %	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100 %	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100 %	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100 %	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100 %	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	100 %	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100 %	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	0 %	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	100 %	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100 %	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100 %	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100 %	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100 %	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100 %	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	100 %	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100 %	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	0 %	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	100 %	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100 %	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100 %	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100 %	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100 %	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100 %	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	100 %	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100 %	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	0 %	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	100 %	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100 %	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100 %	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100 %	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100 %	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100 %	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0 %	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100 %	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	0 %	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	100 %	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100 %	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100 %	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100 %	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100 %	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100 %	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	100 %	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100 %	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	0 %	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127 %	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100 %	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100 %	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100 %	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100 %	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100 %	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127 %	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126 %	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	0 %	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126 %	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0 %	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126 %	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126 %	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126 %	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126 %	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126 %	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100 %	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	0 %	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127 %	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100 %	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100 %	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100 %	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100 %	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100 %	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127 %	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100 %	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	0 %	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126 %	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100 %	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100 %	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100 %	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100 %	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100 %	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126 %	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100 %	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	0 %	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	100 %	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100 %	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100 %	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100 %	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100 %	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100 %	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	100 %	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100 %	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	0 %	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	127 %	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100 %	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100 %	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100 %	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100 %	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100 %	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	100 %	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100 %	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	0 %	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	127 %	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100 %	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100 %	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100 %	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100 %	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100 %	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	100 %	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100 %	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	0 %	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	100 %	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100 %	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100 %	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100 %	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100 %	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100 %	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	100 %	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	1.0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed	3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy	not installed	3
    IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber	not active	3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active	3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active	3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active	3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit	not active	3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit	not active	3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	active	3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor	Not available	6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor	Not available	6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch	Not available	6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module	Not available	6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit	Not available	6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System	Not available	6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn	Not available	6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof	Not available	6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module	Not available	6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind	Not available	6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender	Not available	6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left	Not available	6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right	Not available	6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left	Not available	6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left	Not available	6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right	Not available	6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right	Not available	6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control	Not available	6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch	Not available	6
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
    IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
    MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active	5
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active	5
    MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed	5
    MAS01490-ENG141950-Energy management-Hybrid vehicle	No	5
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active	5
    MAS01490-ENG141978-Energy management-Recuperation	active	5
    MAS01490-ENG142037-Energy management-Zweitbatterie	not installed	5
    MAS05055-lower turn position	16.999983 °	2
    MAS05056-upper turn position	157.999843 °	2
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	1000 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 50	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	4000 lx	24
    MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active	24
    MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active	24
    MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh	24
    MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active	24
    MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	6000 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active	9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00	9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc	9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	active	4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	active	4
    ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed	4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed	60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Sollspannungsanforderung 13.5	23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active	10
    ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active	10
    ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte	10
    ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active	10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active	10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active	10
    ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active	10
    ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
    ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active	10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig	10
    ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active	10
    ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	4	10
    ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active	10
    ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active	10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active	10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv	10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	not active	10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	not active	10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active	10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active	10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active	10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active	10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active	10
    ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max	120 min	10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	not active	10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	not active	10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active	10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active	10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7	9
    ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren	not active	9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	50 km/h	9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	50 km/h	9
    ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights	9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active	9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active	9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active	9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed	9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active	9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active	9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active	9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active	9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active	9
    ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active	9
    ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active	9
    ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active	9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen	9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No	5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	active	5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active	5
    ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed	5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed	18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	abschaltbar über Energiemanagement	18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	abschaltbar über Energiemanagement	18
    ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung	18
    ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf	0 ms	18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam	18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	Not Present	18
    ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	ignition	18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active	18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis	18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten	18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Keine_Spannungsanforderung	18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Keine_Spannungsanforderung	18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
    ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No	18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung	18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	FALSE	18
    ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	No	18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	Yes	18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes	18
    ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes	18
    ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	not enabled	18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete	18
    ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig	18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed	18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Keine_Spannungsanforderung	18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren	18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds	18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds	18
    ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	not active	18
    ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	not active	18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	One-sided	18
    ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active	18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	active	18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	24 s	18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Keine_Spannungsanforderung	18
    ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active	18
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general	not installed	3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle	not active	3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion	not active	3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer	not active	3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle	not active	3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion	not active	3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer	not active	3
    ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.0 %	6
    ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.0 %	6
    ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.0 %	6
    ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.0 %	6
    ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.0 %	6
    ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.0 %	6
    ENG122934-erase_error_table	00 00 00	3
    ENG122933-error_mask	0 bit	2
    ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present	6
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	Basis	6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	active	6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present	6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	Not Present	6
    ENG141685-Front_wash_function	10	2
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active	6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
    ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active	6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active	6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung	6
    ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active	6
    ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN	6
    ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active	6
    ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active	6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating	6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	0 ms	6
    ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active	6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active	6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	active	6
    ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active	6
    ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active	6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	active	6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active	6
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed	8
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed	8
    ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed	8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed	8
    ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed	8
    ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active	8
    ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed	8
    ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed	8
    ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed	8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed	8
    ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed	8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active	8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active	8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00 %	30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	83.00 %	30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	67.00 %	30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	50.00 %	30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	33.00 %	30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	17.00 %	30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	-0.00 %	30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	0	30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	-0.00 %	30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	-0.00 %	30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	44.0 %	30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	38.0 %	30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	33.0 %	30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	28.0 %	30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	24.0 %	30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	17.0 %	30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	10.0 %	30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	10.0 %	30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	10.0 %	30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	10.0 %	30
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active	16
    ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize	16
    ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize	16
    ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize	16
    ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
    ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
    ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
    ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	0	16
    ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	36 - LED Kleinleistung	16
    ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always	16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Warnblinktaster_Suchbeleuchtung	16
    ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active	16
    ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active	16
    ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active	16
    ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active	16
    ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active	16
    ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active	16
    ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	2B	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	9	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	34 - LED Bremsleuchten	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	2D	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	19	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	34 - LED Bremsleuchten	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	32	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	34 - LED Bremsleuchten	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	Quittierungsfunktion 1	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	127	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	32 - allgemeine LED bis 12W	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Parklicht links (beidseitiges Parklicht aktiviert li & re)	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Coming Home oder Leaving Home aktiv	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	127	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	32 - allgemeine LED bis 12W	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Parking light right	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Coming Home oder Leaving Home aktiv	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0C	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	9 - allgemeine Glühlampe 27W: auch H15	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	0	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	1C	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	not active	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	not active	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	27	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	27	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	100	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Coming Home oder Leaving Home aktiv	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Daytime running lights	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	20 - 4* 5W	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 2	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 3	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 4	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	27	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	27	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	100	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	Parking light right	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Coming Home oder Leaving Home aktiv	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Daytime running lights	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	127	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	48	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Coming Home oder Leaving Home aktiv	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Daytime running lights	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	127	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	4C	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	Parking light right	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Coming Home oder Leaving Home aktiv	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Daytime running lights	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active	16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 64 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 64 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 24 00 20 00 00 00 00 00 00 20 0A 00 29 08 09 7F 1E 00 7F 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 1E 00 7F 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 09 0C 00 2E 1A 00 64 00 00 00 00 00 00 00 00 00 00 1C 00 2F 00 00 00 00 00 00 00 00 00 00 00 00 09 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00	192
    ENG141662-Leuchtenkonfiguration_Sonstiges	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00	128
    ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR	62
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	2700 mm	62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active	62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	100.0 %	62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	0.0 %	62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-114.3 ms	62
    ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15 %	62
    ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	5.00 mm/%	62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	5.00 mm/%	62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	5.00 mm/%	62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	3.00 mm/%	62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	3.00 mm/%	62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	3.00 mm/%	62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1	62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	44.0 %	62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.03 Hz	62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	Inverted	62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative	62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	550 mm	62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	680 mm	62
    ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.0 %	62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	5.0 %	62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	255 km/h	62
    ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.03 Hz	62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM	62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed	62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active	62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	0.0 %	62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active	62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	1000.0 %/s	62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	0.0 %	62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	HIM	62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	0.00 s	62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1	2.0 s	7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang	10 s	7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion	active	7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik	active	7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS	Nicht_verbaut	7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark	not active	7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze	100 m	7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul	lds	7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config	1	7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle	30 km/h	7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig	not active	7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter	active	7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig	active	7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig	not active	7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter	active	7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig	active	7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig	not active	7
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active	1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.0 %	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.0 %	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.0 %	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.0 %	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.0 %	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.0 %	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.0 %	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.0 %	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.0 %	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.0 %	12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-3.71 %	20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-2.96 %	20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-2.04 %	20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-1.48 %	20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-0.37 %	20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-0.2	20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-0.1	20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-0.05	20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-0.01	20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	0	20
    ENG122979-ENG141954-Networking-A/C electronics	installed	8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed	8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed	8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet	not installed	8
    ENG122979-ENG99457-Networking-Head area heater	not installed	8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed	8
    ENG122979-ENG141969-Networking-UGDO	not installed	8
    ENG124714-ENG142044-OCU-DWA_push	not active	8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active	8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management	not installed	8
    ENG124714-OCU-	not installed	8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active	8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	not active	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	not active	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	not active	16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_inactive	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	not active	16
    ENG98831-ENG142030-Personalization-Profil_Variante	Schluessel	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	not active	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	not active	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active	16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand	Skoda	5
    ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active	5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	active	5
    ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active	5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active	5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31	5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Keine_Spannungsanforderung	5
    ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active	5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed	5
    ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active	5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left	5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right	5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10	10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed	10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	not active	10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	2000 ms	10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	600 ms	10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	600 ms	10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung	10
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG	not installed	4
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	SMLS	4
    ENG116588-Sonderfunktionen-	not enabled	4
    ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed	4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	active	5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by look command via remote control key	5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	active	5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	not active	5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	active	5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	not active	5
    ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active	5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	not active	5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	active	5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	active	5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250	10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN	10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	1000 ms	10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
    ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
    ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
    ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
    ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
    ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
    ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
    ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
    ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
    ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
    ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
    ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
    ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
    ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
    ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
    ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
    ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
    ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
    ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
    ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
    ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
    ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
    ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.0 %	22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	72.0 %	22
    ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.0 %	22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	48.0 %	22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	33.0 %	22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	18.0 %	22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	12.0 %	22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	8.0 %	22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	6.0 %	22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	4.0 %	22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	2.0 %	22
    ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	HMI	21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	0.0 s	21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	0.0 s	21
    ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active	21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active	21
    ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active	21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	0	21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	60 %	21
    ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi	21
    ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active	21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	20.0 %	21
    ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
    ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
    ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
    ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
    ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
    ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
    ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
    ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
    ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
    ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
    ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
    ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
    ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
    ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
    ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
    ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
    ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
    ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
    ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
    ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
    ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.0 %	22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.0 %	22
    ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.0 %	22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.0 %	22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.0 %	22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.0 %	22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.0 %	22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.0 %	22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.0 %	22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.0 %	22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.0 %	22
    ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
    ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
    ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
    ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
    ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
    ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
    ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
    ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
    ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
    ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
    ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	510 lx	8
    ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
    ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
    ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
    ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
    ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.0 %	12
    ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.0 %	12
    ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.0 %	12
    ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.0 %	12
    ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.0 %	12
    ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.0 %	12
    ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
    ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
    ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
    ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
    ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
    ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
    ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
    ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
    ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
    ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
    ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
    ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
    ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
    ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
    ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
    ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
    ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
    ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
    ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
    ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
    ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
    ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
    ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
    ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
    ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
    ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
    ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
    ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
    ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
    ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.0 %	12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.0 %	12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.0 %	12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.0 %	12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.0 %	12
    ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.0 %	12
    ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
    ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
    ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
    ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
    ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
    ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
    ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
    ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
    ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
    ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
    ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
    ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
    ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
    ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
    ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
    ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
    ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.0 %	6
    ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.0 %	6
    ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.0 %	6
    ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.0 %	6
    ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.0 %	6
    ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.0 %	6
    ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	200 lx	12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	400 lx	12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	600 lx	12
    ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
    ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
    ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	84	12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	166	12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	250	12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	370	12
    ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
    ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
    ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
    ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
    ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
    ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.0 %	10
    ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
    ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
    ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
    ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active	4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	not active	4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting	4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed	4
    ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed	4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed	4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN	4
    ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed	9
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	active	9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active	9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active	9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed	9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active	9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active	9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active	9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active	9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active	9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always	9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always	9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed	9
    ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active	9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	active	9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	active	9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active	9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	active	9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active	9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active	9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active	9
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar	not active	9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed	9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version	Version_1_2	9
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00	20
    ENG124901-Wischer_Fehlermaske_Mitsuba_Entw	0 bit	4
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	40	3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	60	3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30	3
    ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active	7
    ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active	7
    ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active	7
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	not active	7
    ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active	7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	installed	7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	installed	7
    ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active	7
    ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active	7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active	7
    ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active	7
    ENG141651-ENG141957-ZV allgemein-Radio freq.	434.42MHz	7
    ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional	7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch	7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Globale Entriegelung	7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed	7
    ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active	3
    ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active	3
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active	3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR	not active	3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active	3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable	3
    ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active	4
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active	4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active	4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active	7
    ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active	7
    ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active	7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	not installed	7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active	7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active	7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	No	7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Pulse control	7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active	7
    ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No	7
    ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active	7
    ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active	7
    ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator	7
    ENG141681-IDE02021-ZV Komfort-Comfort closing	active	8
    ENG141681-IDE02022-ZV Komfort-Comfort opening	active	8
    ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes	8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active	8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	active	8
    ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
    ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active	8
    ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active	8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active	8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	active	8
    ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active	8
    ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active	8
    ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable	8
    ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active	8
    ENG141681-ENG246991-ZV Komfort-pa_Two_Keys	not active	8
    ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once	8
    ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active	8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	active	8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	active	8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser	5
    ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert	5
    ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed	5
    ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed	5
    ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No	5
    ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No	5
    ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed	5
    ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side	5
    ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active	5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes	5
    ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes	5
    Elapsed Time: 01:44
    Apr 2018
    ITALY
    go into 19 Gateway and click INSTALLATION LIST, then UNTICK modules BB and BC from the list, and save.
    you don't have BB and BC modules because rear door modules are slaves to 42 and 52 (front doors).
    I don't know how to activate that light functions, maybe somebody will chime in.
  7. #7
    Dec 2016
    DE
    Setting ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2 to active should do the job.
  8. Likes PetrolDave, Uwe, darkchina811 liked this post
  9. #8
    Nov 2018
    Europe - Hungary
    Unfortunately this is not working.
  10. #9
    Dec 2016
    DE
    Is the stop light flashing (either from factory or by coding)?
    This is mandatory to add the indicators if the car goes below a certain speed, as seen in the video above from the Golf MK6.
    If it currently does not do any full brake/hazard flashing. Then we have to start to enable it beforehand..
  11. #10
    Apr 2018
    ITALY
    Quote Originally Posted by TBAx
    I am pretty sure a setting to make brake lights flash does not exist on MQB cars. if it did, my third brake light would flash
