Results 1 to 7 of 7
Thread: Polo 6R/6C 1.4 TDI Trip computer buttons
    Verified VCDS User Speedparts's Avatar
    Greece
    Greetings guys , I have a Polo 1.4 TDI .
    on the right of the steering wheel , it has no buttons for trip computer like other models
    I retrofited one . Front and rear washers work ok , but not the buttons
    I have an autoscan . Can the Polo have the trip computer work ? Or is it an Instrument cluster limitation.
    THank you
    Tuesday,08,January,2019,12:31:08:19672
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    Dealer/Shop Name:
    VIN: WVWZZZ6RZFY316138   License Plate:
    Mileage: 76362km-47449mi   Repair Order:
    Chassis Type: 6R-VW26 (6C0)
    Scan: 01 03 08 09 15 17 19 44 5F
    VIN: WVWZZZ6RZFY316138   Mileage: 76362km-47449miles
    Address 01: Engine (J623-CUSA)       Labels: None
       Part No SW: 04B 997 027     HW: 04B 907 445
       Component: R3 1.4l TDI   H08 9430
       Revision: 21006001
       Coding: 01114012420400080000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_ECM14TDI03004B997027 004006
       ROD: EV_ECM14TDI03004B997027G.rod
       VCID: 68884F6272F716C7365-803C
    Readiness: N/A
       Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0003
       Serial number: 08508856150412
       Coding: 21DD2485892433C60915006C0059842491CC90000007C9098F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       VCID: 3332E80E7BB1A51F537-8066
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6C0 820 045     HW: 6C0 820 045
       Component: AC Manuell    H03 0108
       Serial number:  1503261B-1955
       Coding: 201000000000000200
       ROD: EV_ACManueKMMValeoPQ26.rod
       VCID: 5CE063B2B6AF4A67A2D-8008
    1048834 - Functional Limitation due to Energy Management
              B10CD 00 [012] -  -
              [Funktionseinschrδnkung  durch Energiemanagment]
                        Reset counter: 101
                        Mileage: 76299 km
                        Date: 2019.01.05
                        Time: 21:47:00
                        Voltage terminal 30: 14.8 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: no_enabling
                        Auxiliary heater: in stages-Act.val.: 0
                        Auxiliary heater: in stages-Specified value for control: 0
    Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
       Part No SW: 6C0 937 087 B    HW: 6C0 937 087
       Component: BCM PQ26 Me4R H07 0065
       Serial number: 001088055146
       Coding: 00000840401300534B844000400703000000580051010000000000000000
       ASAM Dataset: EV_BCMA0 004008
       ROD: EV_MQBA0.rod
       VCID: 2D06FE769D95F3EF053-8078
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 8612
       Serial number: KU0KU019031550783227
       Coding: 0000A0
       Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 8612
       Serial number: KU0KU024031550834488
       Coding: 1000A0
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 E    HW: 6C0 959 655 E
       Component: VW20Airbag00B 001 0360
       Revision: --------    Serial number: 003RH000617I
       Coding: 88C0C000000000005C000000000800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3536D61675C5BB2F7D3-8060
       Subsystem 1 - Part No SW: -----------    HW: 410 820 304 15
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00BD19E15A3821T
       Subsystem 2 - Part No SW: -----------    HW: 410 820 304 15
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H000828BDAC3D2D4
       Subsystem 3 - Part No SW: -----------    HW: 442 150 504 15
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00AB1A72834F04F
       Subsystem 4 - Part No SW: -----------    HW: 442 150 404 15
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00AD1A728354318
       Part No SW: 6C0 920 731 B    HW: 6C0 920 731 B
       Component: KOMBI         110 0290
       Coding: 0720090021000008000808000000000000000000
       VCID: 211E1246D14D278FB1B-8074
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 087
       Component: GW MQB A0     H07 0065
       Revision: --------    Serial number: 001088055146
       Coding: 01000008180A590071000000000000000001010000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_001_VW26.rod
       VCID: 6596465685E50BAF0D3-8030
       Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3211
       Serial number: PF4M0765
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 323CED0A84ABAC17581-8066
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 6C0 035 885 A    HW: 6C0 035 885 A
       Component: MU-E--ER      820 6230
       Serial number: 04021500010186
       Coding: 026200003C0000004011000101000000000000040000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001017
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 270A0C5EBF69D9BFFFF-8072
    End----------(Elapsed Time: 00:32, VBatt start/end: 12.6V/14.9V)-----------
    Only Original Tools
    Jan 2019
    I think you might need a different steering wheel controller and suitable coding for both sets of buttons to work. I have a 6R Polo in the family but not had much exploration with it yet. It is also without the right MFSW buttons - I am sure I have seen other forum threads on this subject where owners have retrofitted entirely new wheels. clock spring modules and airbags to get MFSW functionality as the non MFSW wheel has different airbag.
    I might do this on our 6R Polo if it can be done at little expense - where you able to fit the right side button panel without any other changes on the wheel or airbag etc ?
    Jan 2019
    Have a look at coding sections of this thread in a UK Polo forum - it might be useful.
    https://uk-polos.net/viewtopic.php?t=54171
    Greece
    Thank you for your replies guys. I am talking about the right lever , not msfw buttons . The stock Polo on the right lever has no buttons for Trip computer. I installed one . Evetrything works but the buttons ofcourse
    I have tried some Longcodings but nothing works.
    Only Original Tools
    Jan 2019
    Oh sorry for confusion on that. Our 6R does have buttons on the right stalk control which go through basic menus on the cluster for average speed, consumption etc. I will post up an auto scan later today. I think VW classify this as 'midline' package where you get one half of MFSW and basic computer functions but I could be wrong.
    There are extended trip computer functions available with right MFSW panel buttons and corresponding button controller & cluster combinations.
    Jan 2019
    Oh I have it on this computer already...
    Friday,04,January,2019,11:32:58:30756
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
    VCDS Version 18.9.0.4  HEX-NET CB: 0.4437.4
    VIN: WVWZZZ6RZDYxxxxxx   License Plate:
    Mileage: 91930km-57122mi   Repair Order:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
    VIN: WVWZZZ6RZDYxxxxxx   Mileage: 91930km-57122miles
    Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 AK    HW: 03P 907 425 A
       Component: R3 1.2 DCM3.7 H09 3317
       Revision: 11002001    Serial number:
       Coding: 00114014000500080000
       ASAM Dataset: EV_ECM12TDI03103P906021AK 001005
       ROD: EV_ECM12TDI03103P906021AJ.rod
       VCID: 71AAD168A0D13EC224-8025
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       Coding: 230224E3416D00B9C42924E282D400821300
       VCID: 02488EA49977355ACD-8057
       Component: LENKW.SENSOR  H06 0060
       Serial number: 090465LJ5000ZR
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EB0FA54E18F51BAA9-802B
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 393A2948B021B682DC-806D
       Part No SW: 6R0 937 087 K    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0254
       Revision: BF046001    Serial number: 0434 266121636
       Coding: 25B029BF08A10000012808002D2B0ED90000410F60060000200000000000
       Shop #: WSC 12469 483 00190
       VCID: 45C255B8CCD9C262A8-8011
       Component: RLS 210912 05  54  0403
       Coding: 03302D
       Subsystem 2 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  008 1621
       Serial number: KU0KU020091200018422
       Coding: 18BC30
       Subsystem 3 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  008 1621
       Serial number: KU0KU017091200010077
       Coding: 18BC30
       Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0285424
       Coding: 020000
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag01X H10 0020
       Revision: --------    Serial number: 003GX01EFA8E
       Coding: 003158
       Shop #: WSC 01383 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4AD86684EDC72D1A45-801F
       Serial number: 3575HRB40511KADSGHBT
       Serial number: 3585HRB404T1KADSF0UF
       Serial number: 3515RRB405H1GLOM6HSP
       Serial number: 3525RRB401C4UHC45H7L
       Part No SW: 6R0 920 961 K    HW: 6R0 920 961 K
       Component: KOMBI         H05 0605
       Coding: 440A01
       VCID: 3E303A54A10F91BAE9-806B
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H46 0254
       Revision: BF046001
       Coding: 002100
       VCID: 70ACD46CA3DB37CA2B-8025
       Component: IMMO          H05 0605
       VCID: 6A98C6048D07CD1A65-803F
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663521386
       Coding: 010100
       VCID: 2A18060445870D1AA5-807F
       Part No: 6R0 423 156 C
       Component: LenkhilfeTRW        V278
       Coding: 11230
       Shop #: WSC 00788
       VCID: 302C146CF75B77CA6B-8065
       Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
       Component: Radio RCD310  004 0119
       Revision: 01000001    Serial number: VWZ1Z2M2186438
       Coding: 01000400020001
       VCID: 352225789C3952E238-8061
    End----------(Elapsed Time: 01:06, VBatt start/end: 14.2V/14.1V)-----------
  7. #7
    Aug 2016
    Switzerland
    The 6R is a completely different beast from the 6C. Yours is a Polo 6C.
    - Both have the stalk buttons for MFD/MFA wired directly to the cluster resp BCM. There is no SWCM (0x16) or whatever involved.
    - Both have the MFS wired directly to the BCM via LIN. There is no SWCM (0x16) or whatsoever involved.
    TS verify wiring for MFD as in Polo 6C
    T10 = right hand side T10 on stalks
    T10/8 to BCM T73a/16
    T10/9 to BCM T73a/15
    T10/10 to BCM T73a/17
    GND should be present already for other switches.
    Enable byte 1 bit 2 in 0x17 and perhaps something in the BCM.
  8. Likes Uwe liked this post
