Hello guys,
It seems Tiguan's follow me with strange issues, this Tiguan is suffering from odd energy behaviour, if you stop the car and then try to restart after a little while the car looses energy, client tries to open the door with the remote and not response, he unlocks the door manually and alarm turns on when he opens the door but the dash is off and no response (alarm is beeping) after a while the alarms stops beeping and dash energy comes on.
he has tried leaving door unlocked and same issue no energy to the dash like there was no battery after 15 or 20 minutes the dash works and he can start the car, I thought maybe bad battery but he changed it 1 month ago and same issue, dealership told him it was the relays labeled with 100 on the main fuse box on the engine bay but same thing nothing better happens. Here is the auto-scan to see if somebody can shed some light.
Monday,07,January,2019,09:56:59:22246
VIN: WVGZZZ5NZBW000093 License Plate:
Chassis Type: 5N-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 72
VIN: WVGZZZ5NZBW000093 Mileage: 92070km-57209miles
Address 01: Engine (CAW) Labels:. 06J-906-026-CAW.clb
Part No SW: 06J 906 026 CJ HW: 06J 906 026 D
Component: MED17.5 4307
Revision: A7H14--- Serial number:
Coding: 04230003190F0060
Shop #: WSC 01324 020 00200
VCID: 74B1DF3602BE41C78AD-8020
Readiness: 0000 0001
Part No SW: 09G 927 750 FE HW: 09G 927 750 FE
Component: AQ 250 6F 1701
Revision: 00H76000 Serial number:
Coding: 0000328
VCID: 79AFEE0225DC3CAFD9B-802C
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 M HW: 5N0 614 109 M
Component: J104 C4 450 V296 0003
Revision: --H28--- Serial number: 00000002596478
Coding: 0010516
VCID: 35372232494418CF7D3-8060
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
VCID: 7DA7FA123D74008FF53-8028
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 190
Mileage: 92017 km
Date: 2019.01.06
Time: 00:18:59
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 150
Mileage: 89868 km
Date: 2018.12.13
Time: 11:28:01
Part No SW: 5K0 937 086 C HW: 5K0 937 086 C
Component: BCM PQ35 M 011 0028
Revision: BC011001
Coding: 48180A3B9025F3C0400800803400012443513088536D89605C8000000000
VCID: 34311F364E3E01C74AD-8060
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 18021 012 0203
Serial number: N1955119 °203!
Coding: 009795
Component: RLS 210210 05 54 0403
Coding: 03304D
7 Faults Found:
00059 - Terminal 30 for Interior Lighting
Fault Status: 00101011
Reset counter: 179
Term 15 Off
Voltage: 12.95 V
Fault Frequency: 37
Reset counter: 190
Mileage: 89916 km
Date: 2013.05.05
Time: 19:36:52
Term 15 Off
Voltage: 12.85 V
Fault Status: 00100001
Reset counter: 165
Mileage: 91222 km
Date: 2013.05.22
Time: 04:19:28
Term 15 On
Voltage: 13.65 V
00532 - Supply Voltage B+
Reset counter: 182
Mileage: 92017 km
Date: 2013.05.29
Time: 00:00:06
Term 15 Off
Voltage: 7.30 V
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 101
Mileage: 90553 km
Date: 2013.05.14
Time: 04:05:01
Term 15 Off
Voltage: 13.10 V
01598 - Drive Battery Voltage
Fault Frequency: 36
Reset counter: 181
Mileage: 89868 km
Date: 2013.05.05
Time: 11:28:05
Term 15 On
Voltage: 12.90 V
03396 - Supply voltage terminal 30 for central locking
Reset counter: 179
Mileage: 91703 km
Date: 2013.05.27
Time: 03:22:20
Term 15 Off
Voltage: 12.95 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5N0 919 475 B HW: 5N0 919 475
Component: PARKHILFE 4K H07 0023
Revision: -------- Serial number: 11121000701554
Coding: 100102
VCID: 38292B065256E5A7665-806C
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E2P37DX9N
Coding: 0012336
VCID: 44D14FF6129EB147FAD-8010
Subsystem 1 - Serial number: 6332MTS640200340
Subsystem 2 - Serial number: 6342MTS671780350
Subsystem 3 - Serial number: 6351HTS6BP7F86KR
Subsystem 4 - Serial number: 6361HTS6KO0G86KR
Part No SW: 1K0 953 549 CJ HW: 1K0 953 549 CJ
Component: J0527 056 0111
Coding: 0001102
VCID: 7CA1F7162AEE0987C2D-8028
Component: E0221 002 0030
02071 - Local Databus
Part No SW: 5N0 920 871 A HW: 5N0 920 871 A
Component: KOMBI H05 0305
Coding: 110F00
VCID: 2F3B105AA798221F37F-807A
[Supply voltage too low]
Reset counter: 182
Time: 00:00:00
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H20 0592
Revision: H20 Serial number: 090210F1001311
Coding: FDA27F06000202006002
VCID: 6B83C44A5F809E3F5B7-803E
Reset counter: 182
Mileage: 92017 km
Date: 2013.05.29
Time: 00:18:60
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: 4BC364CA3FC07E3F3B7-801E
Component: IMMO H05 0305
VCID: 6A8DC14E5CFA8737201-803E
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2101
Coding: 0000188
VCID: 3635253E544213D7749-8062
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.163 0703
Revision: 1AH03828 Serial number: 00100460242201
Coding: 0000258
VCID: 3A2D310E605AF7B7901-806E
Fault Frequency: 16
Reset counter: 190
Mileage: 89916 km
Date: 2013.05.05
Time: 19:36:51
Voltage: 3.30 V
Voltage: 8.00 V
Voltage: 8.00 V
Not Occup.
Not Occup.
Fault Frequency: 21
Reset counter: 183
Mileage: 90082 km
Date: 2013.05.07
Time: 10:33:10
Voltage: 6.80 V
Voltage: 13.90 V
Voltage: 13.90 V
Not Occup.
Not Occup.
Fault Frequency: 8
Reset counter: 190
Mileage: 90086 km
Date: 2013.05.07
Time: 11:01:26
Voltage: 2.50 V
Voltage: 6.20 V
Voltage: 6.20 V
Not Occup.
Not Occup.
01288 - Terminal 30; Steering Assist
Fault Priority: 9
Reset counter: 186
Term 15 On
(no units): 2.0
Voltage: 4.40 V
Reset counter: 198
Voltage: 0.00 V
Voltage: 4.40 V
Voltage: 0.00 V
Not Occup.
Not Occup.
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0000188
VCID: 372B283A5348EADF6FF-8062
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Part No SW: 3AA 907 801 B HW: 3AA 907 801 B
Component: J540 EPB4 VW-49878 0004
Revision: H17 Serial number: 00000000002306
Coding: 0023057
VCID: 30391326B6263DE72E5-8064
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3009398
Coding: 0500041004
VCID: 629DA96EA44ADF77E81-8036
Reset counter: 190
Reset counter: 190
Mileage: 92017 km
Date: 2013.05.29
Time: 00:18:26
00856 - Radio Antenna
Fault Status: 01101011
Reset counter: 80
Mileage: 89868 km
Date: 2013.05.05
Time: 11:28:24
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01324 020 1012552
VCID: 38292B065E56E5A7665-806C
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
VCID: 392F2E02655CFCAF99B-806C
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:35, VBatt start/end: 13.6V/13.6V)-----------
