Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Golf 7 ACC retrofit success
    Apr 2018
    ITALY
    ACC retrofit was completed this morning. when I plugged in the radar, it triggered Component Protection in the Gateway and, of course, in the radar itself. CP was cleared with ODIS online.
    I followed the coding/adapt instructions in the famous spanish PDF, everything was pretty much straight forward. one note: it says to code integration for the ACC into the Driving Profile Selection with ODIS. I was able to do it with VCDS, just had to enable EXPERIMENTAL coding. makes sense since that book was written long ago.
    the radar NEVER flagged the need for calibration. I made sure the donor car was a Golf to ensure the mounting position is the same. honestly I was surprised that it did not ask for calibration, as the tolerance for the radar position is less than one degree.
    I went for two drive tests and it all works fine. now I gotta get used to it, I had never driven with ACC before and it just feels weird sometimes when the car brakes by itself.
    below is a current autoscan with no errors at all. I don't like bragging but I am kinda proud, again I did it by myself.
    the only note is that the steering wheel buttons are not the right ones, because I didn't know when I bought them, and I got the buttons for the standard steering wheel, while my car has the R/GTI style steering wheel. it all works fine, they just don't fit physically. 5G0 959 442 N would be the correct ones, I have them coming soon.
    Monday,07,January,2019,12:43:11:06888
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
    Workshop Code: 011 01357 012345
    VIN: WVWZZZAUZHW0xxxxx   License Plate:
    Mileage: 27505km-17090mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 18 19 20 42 44 52 5F 65
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 27505km-17090miles
    Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2833
       Revision: R7H25---
       Coding: 0119003A23441D082000
       Shop #: WSC 01357 011 12345
       ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
       ROD: EV_ECM14TFS01104E906027HB.rod
       VCID: 6B833BBF03045EDF5B9-803E
       CAN Converter 01:
    Readiness: 0100 0000
       Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
       Component: ESC           H62 0637
       Revision: 00000000    Serial number: 91596000011507
       Coding: 01FA6AA1242219704779060841C62980562498E26082947314205008400903
       VCID: 74B120C35E3A81278A3-8020
       Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
       Revision: 00001K08
       Coding: 00020004104111011005004000101022
       Shop #: WSC 00028 028 00068
       VCID: 73B323DF5B34861F939-8026
       Serial number: 01061633700891
       Coding: 00000946C20102FB0B244080B11407281400000000000000000000000000
       Shop #: WSC 01357 011 00000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 045170030E9AB1A7BA3-8050
       Component: WWS    160522  043 0551
       Serial number:         160601172917
       Coding: 0E4DFD
       Component: RLHS  042 0105
       Serial number: S5Y17M06D01H13M38S50
       Coding: 06A8DD
       Serial number: 000000000ZY15028208R
       Serial number: 00000000000030139763
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617145
       Coding: 0271161041
       ROD: EV_EPHVA2CAU3700000_009_VW37.rod
       VCID: 50F98C538A629D074EB-8004
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 19021303030627
       Coding: 00000300FE030B
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3FDBBFEF27FC127FA71-806A
       Serial number: 003F6R1V1W4Y
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41DFB9175108648FD15-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 35767000000432B44C1Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358670000008B4C4DB17
       Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
       Serial number: 3516502BB205729313D3
       Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
       Serial number: 3526502AF2076340F201
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 35565029B21160C1025X
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 13061608490829
       Coding: 0400
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0D4755275DD0F0EFE5D-8058
       Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
       Component: KOMBI         303 8311
       Coding: 03A501802680000D02883B051401000000000000
       VCID: 26150A8BD866A3B7C47-8072
       Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
       Component: STH-MQB       006 0069
       Coding: 1309
       VCID: 3537DDC715C0D82F7DD-8060
       Component: R64 D208L  004 0401
       Serial number: 00000000000000180382
       Revision: --------    Serial number: 0004271482
       Coding: 030100043F085700FB000258080F00010001050000000000000000000000
       VCID: 7CA108E3766AC967C23-8028
       Serial number: 47170000035760051538
       Coding: 2CFFFF
       Serial number: 8442320304
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 3G0 857 511 AE    HW: 3G0 857 511 AE
       Component: FLA           H10 0003
       Revision: AA001001
       Coding: 0101000000000000000000
       ASAM Dataset: EV_HighBeamAssisAU33X 001017
       ROD: EV_HighBeamAssisAU33X_VW37.rod
       Serial number: 300516EEU02971
       Coding: 003B0220D000040100001000
       VCID: 43D3B31F4B14769FC39-8016
       Coding: 8307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCEFB3CDE375790F-806E
       Serial number: 280516EER24731
       Coding: 003B0020DE00040100801000
       VCID: 42DDB61B540E7F97C8F-8016
       Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
       Component: MU-S--ER      710 0744
       Coding: 02730000AA0000005111000100080A001F0206D40120010003
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 2C01F8A3C68A99E7123-8078
       Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
       Component: ABT_Std-2  H50 8120
       Serial number: VWZ6ZHT1541317
       Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0009
       Serial number: 40000000018766
       ROD: EV_RDKBERU30_006_VW37.rod
       VCID: 3431E0C31EBAC1274A3-8060
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.5V/12.5V)-----------
  2. Likes downtime, D-Dub, Uwe, jyoung8607, Spacewalker, Dana liked this post
  3. #2
    May 2017
    Get it calibrated. For me it did not trigger a need for calibration either but it was way off when calibrated. I experienced some hair rising automatic braking with ACC enabled on buses on bus stop etc
    Calibration is not that expensive to do.
    Apr 2018
    ITALY
    it's not about the money. like all retrofits, when I asked the closest dealer for assistance the looked at me like I came down from Mars.
    Jul 2014
    Tallinn, Estonia
    And if the dealer doesn't look at you like an alien, the factory order is to calibrate everything at once. When I asked about calibrating only the lane assist camera, they basically want to do an axle alignment, ACC and lane camera calibration all at once, which was close to 4 hours of work.
    May 2017
    Yes, because the calibration needs the mechanic to do alignment check before starting the calibration, but they don't have to do the actual wheel alignment if everything is ok. And 4 hours is bullshit. For me it took less than an hour to do the calibration of both ACC and lane assist camera. And you can do only the other one, no need to do both, ODIS has separate guided functions for them. Of course they both are done at the same trouble as the calibration procedure is almost the same for both and the equipment is the same.
    Why are people investing a lot of money to retrofit ACC and lane assist camera but are not able to invest 200 € for official calibration??? C'mon guys, these are SAFETY features. After this people are whining why VAG is preventing these retrofits with codes.
    If the dealer however does not know what is the calibration procedure, I would stay far away from them. It does not matter if it's a retrofitted or factory original ACC or camera, just follow the guided functions in ODIS and that's it. It guides them visually how to do it.
  7. Likes PetrolDave, Uwe liked this post
    Apr 2018
    ITALY
    ... just remember they never managed to restore FeC in my Gateway. and they didn't try for free.
    Nov 2014
    World
    Problem is that, as soon as you retrofit a newer module than the ones originally available for your model, ODIS will just refuse to work with your retrofitted module, like in my case where I installed a current camera in my 2015 Alhambra.
  10. #8
    Apr 2018
    ITALY
    Quote Originally Posted by Detlef Trapp
    I don't understand how this relates to the ACC discussion, and I am not really sure what you mean. if you are talking about the Gateway, I installed the very one ETKA told me to. it was not ODIS who didn't want to talk to the module. dealer lacked the expertise to perform the FeC restoration. why? I have a theory, but cannot make it public
    when I found somebody who knew what he was doing, I heard ODIS and the Gateway sing a duet.
  11. #9
    May 2017
    Quote Originally Posted by Detlef Trapp View Post
    To clarify a little bit. This means that you cannot code, load software or re-parameterize the unit directly through factory connection using factory code database (or SVM). That it refuses saying the module is not valid for the car. BUT, basic settings, adaptations etc. all work just fine with ODIS as well.
  12. Likes Uwe liked this post
  13. #10
    Apr 2018
    ITALY
    https://www.golfmk7.com/forums/showthread.php?t=49365
    this guy apparently just retrofitted a flat radar. what the hell?
