Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Fault Codes and cruise control not working.
    Jul 2014
    Hmm, that Google image loads in FF and Chrome but IE isn't showing it on a Win 7 PC. This is the direct URL https://photos.app.goo.gl/8iEFJcRs6So1bqkd9
    Address 16: Steering wheel (J524) is the new module so that's what I'd try coding to 0D00 if the factory coding isn't known.
    Thank you for your reply and picture.
    As the vehicle has adaptive cruise control would this be the correct coding?
    (The control for cruise is on the steering wheel)
    If so I assume your picture would suggest that the "E221 MFSW slave" handles the request for cruise control as opposed to the "16-Steering Wheel module "
  2. Likes Dana liked this post
  3. #12
    United States
    Yeah, my coding should be correct based on Automatic trans scans with ACC from good baseline cars.
    I re-worded that to read "Cruise Control NOT installed -or- Cruise Control handled by E221 MFSW slave of J533". If there aren't any objections that will make it to the next dataversion. (It didn't make it to Release 18.9.1 this afternoon).
  4. Likes Uwe liked this post
  5. #13
    Jul 2014
    Okay just to update.
    Coding 0D10 was a Error 31 coding rejected out of range.
    I managed to code to OE10 but have the following error code.
    The wiper washer stick front and rear does operate and now so does the cruise control now.
    Also I no longer have loads of data bus errors so prehaps the other code may have been preexisting
    Thursday,17,January,2019,09:28:40:06086
    VCDS Version: 18.9.0.2 (x64)
    VIN: WVWZZZAUZEP534346   License Plate: R666GFE
                    Address 16: Steering wheel       Labels: 5Q0-953-549.clb
    Control Module Part Number: 5Q0 953 569 A    HW: 5Q0 953 569 A
      Component and/or Version: Lenks.Modul   075 0235
               Software Coding: 0E10
                Work Shop Code: WSC 01286 386 08256
                  ASAM Dataset: EV_SMLSVALEOMQB 001016 (VW37)
                           ROD: EV_SMLSVALEOMQB.rod
                          VCID: 3C77EA25B77C61AAC9-8068
              B1149 13 [009] - Open Circuit
                        Reset counter: 24
                        Mileage: 96248 km
                        Date: 2019.01.17
                        Time: 09:18:26
                        Ubat 30 Voltage: 11.50 V
                        Ignition State: On
                        Terminal 15: 10.70 V
                        A/D #1: 97.25 %
                        A/D #2: 20.78 %
                        A/D #3: 0.00 %
  6. Likes Dana liked this post
