I am trying to edit these two adaptations in the Park Assist 3.0 module:
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang
I login with the code that is suggested, don't remember it out of the blue. when I try to change the value I get "Request out of range", no matter what.
the module came used and I do not know the donor car. could it be that it is not parameterized for Golf? below are the details:
Sunday,30,December,2018,17:30:19:06888
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
Workshop Code: 011 01357 012345
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 42 44 52 5F 65
VIN: WVWZZZAUZHW0xxxxx   Mileage: 26926km-16731miles
20-High Beam Assist. -- Status: Malfunction 0010
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617145
   Coding: 0271161041
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50F98C538A629D074EB-8004
