Results 1 to 3 of 3
Thread: Security access login
    Verified VCDS User jamofighter's Avatar
    Dec 2018
    Hi!
    i got new injectors, egr, and throttle body ready to install (Audi RS4 b7 2007) and i bought this hex-v2 interface as i thought (understood what i was reading about it) that its possible to manage Audis engine electronics and do component adaptions and learnig as well but so far i got no luck with this one as i get stuck at login for engine as it requires login code.
    I cant find login codes from any manuals (i bought all what was available to buy and from erwin as well).
    I did try to change settings on other modules, and i can do changes for radio example and comfort but those are not realy things i need this hex-v2 for...
    could someone point me to the right direction where to find login codes?
    is it even nessesary?
    sorry is not even possible and i just wasted my money while buying this hex-v2 thing?
    below is autoscan
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN:
    Mileage: 198610km-123410mi   Repair Order:
              67 69 75 76 77
    VIN: Mileage: 198610km-123410miles
    Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560     HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     ª0080
       Revision: --H13---    Serial number: XXXXXXXXXXXXXX
       Coding: 010C0003180F0160
       Shop #: WSC 00191 264 15243
       VCID: 6393511B2753926FE37-8036
    012403 - Fuel Pump Circuit
                   P3073 - 002 - Electrical Malfunction - Intermittent
                        Mileage: 198594 km
                        RPM: 836 /min
                        Load: 24.3 %
                        Temperature: 79.0°C
                        Temperature: 15.0°C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 13.462 V
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Component: ESP8 quattro    H06 0150
       Coding: 0004533
       Shop #: WSC 06335 000 00000
       VCID: 2B03F93B0F031A2F1B7-807E
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6D873723F487D41F453-50F4
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 0907
       Coding: 11021
       Shop #: WSC 65536
       VCID: 3D27C763E467849FB53-4AA4
    Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H12 3730
       Revision: 91H12373    Serial number: 0036M0G34E8X
       Coding: 0430612
       VCID: 3B23C97BFF638AAF8B7-806E
       Subsystem 1 - Serial number: 6332DRB403C58A0EZ
       Subsystem 2 - Serial number: 6342DRB403C54C36T
       Subsystem 3 - Serial number: 6352ARB4002B12042
       Subsystem 4 - Serial number: 6362ARB4002B122BC
       Subsystem 5 - Serial number: 63729RB4018CFBA2%
       Subsystem 6 - Serial number: 63829RB4018CFC1C2
    Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
       Part No: 8E0 953 549 T
       Component: Lenksáulenmodul     0301
       Coding: 06022
       Shop #: WSC 06335
       VCID: 44D1B287878DF557FAD-4AC2
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 931 G    HW: 8E0 920 931 G
       Component: KOMBI+WFS 4     H14 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0023001
       Shop #: WSC 80093 222 69422
       VCID: 2C01FA270A1D1D1712D-50F4
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023001
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       Shop #: WSC 45013
       VCID: 6B83393BCA93DA2F5B7-508A
       Part No: 8E0 959 433 CH
       Component: Komfortgerát T3B    4135
       Coding: 06944
       Shop #: WSC 45013
       VCID: 79AF1373B0CF78BFD9B-4AA4
       Component: Tõrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tõrsteuer.BF BRM 0706
       Component: Tõrsteuer.HL BRM 0606
       Component: Tõrsteuer.HR BRM 0606
       Coding: 0000019
       VCID: 290F033305FF083FE9B-807C
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H03 0010
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH03 0010
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 K    HW: 8E0 035 192 K
       Component: RNS-E HIGH EU   H72 0650
       Revision:      01S    Serial number: AUZBZ7F1177798
       Coding: 0309713
       Shop #: WSC 12300 205 79111
       VCID: 2C01FA270A2D1D1712D-5160
    16352 - Control Module - Electrical Error
                        Fault Status: 00101110
                        Reset counter: 101
                        Date: 2016.03.30
                        Time: 15:28:40
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0022523
       Shop #: WSC 02197 785 00200
       VCID: 2A0DFC3F00D90327E01-5160
                        Fault Status: 11100100
                        Reset counter: 40
                        (no units): 12.0
                        Voltage: 13.40 V
                        (no units): 61.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Raw, Index/Key Err.: 228 000 000
    01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
                        Reset counter: 40
                        (no units): 61.0
                        Voltage: 13.60 V
                        (no units): 130.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Idle Stabilization: -0.00°KW
       Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
       Component: FSE_255x BT     H25 0290
       Revision: 00000000    Serial number: 00000005009440
       Coding: 0010711
       VCID: 3B23C97BFF738AAF8B7-50D0
    End----(Elapsed Time: 04:45, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
    Sep 2018
    Hi JamoFighter, you may want to say hello in the New User Forum. You can also ask questions before buying VCDS in the Pre-sales forum, here.
    Good news though - VCDS is a very powerful piece of hardware & software that is capable of what you require. However, it cannot work magic and cannot bypass the security requirement of the controllers. I would recommend speaking with Uwe, unless he replies to this thread to enquire about known security codes for your engine controller.
    By the way, the preferred way to post autoscans is detailed in this post, here.
    I don't think injectors need to be coded on that engine. That normally only a CR-TDI thing.
    After installing the throttle body, you'll want to do an "alignment" / calibration. That's done with a Basic Setting, on your engine it should be Group 060. The only thing I'm not sure about is whether that's handled in 01 (ECU1) or 31 (the functional address for both ECUs simultaneously).
    What do you think you need a Login or Security access code for?
