Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 134
Thread: mk6 xenon retrofit
  1. #21
    OK. You cannot perform Basic Settings until the master and sub-system control modules are coded. As mentioned in 2a) this doesn't look good: that No End-of-Line Programming fault may prevent both of you from getting these controllers coded.
    http://wiki.ross-tech.com/wiki/index...on_with_AFS%29
    Did either of you try my suggested baseline coding of 081200000B000000 with non zero WSC/Importer/Equipment numbers?
    Edit: Hussein those links aren't working for me but please post a new in the current condition after correcting or testing the #1, 2A and 2B suggestions.
    I tried this exact coding with the supplied 12345 ws codes and still get error 22
  2. #22
    Mar 2014
    Saudi Arabia
    Quote Originally Posted by verebs1 View Post
    Dana, 1) I tried the same as Verebs1 also I copied coding from Golf MK6 and tried to used it does not work...
    2) can i do reset for byte 18??? after I change it to 8C my LED headlights stopped working and it show faults in dash...
  3. #23
    United States
    OK Guys. That No End-of-Line Programming fault may be cause by incorrect or missing Firmware in the 55 modules so I would recommend replacing that controller with a known good used one in one of these vehicles. verebs1's retrofit appears to be straight forward because the BCM coding isn't corrupted and both of the Xenon range subsystem headlights are communicating. For this reason I would try the known good used 55 controller in that vehicle.
    husseinayash, I would not modify Byte 18. If you already did please post another complete Auto-Scan so I can see is any of these concerns were resolved:
    http://forums.ross-tech.com/showthre...ull=1#post1254
  4. #24
    Bi Xenon w/ AFS Coding 2013 Golf NAR
    I installed factory Bi-Xenon w/ AFS in my 2013 Golf TDI (NAR) this past weekend. I am having a few coding issues and would appreceate any help anyone can provide. I have included the most recent scan and the original long coding for the 09 CECM/BCM module. I do have an 086T version, which actually supports both Xenon and LED DRLs. Up until this install I have been running OEM LED tail lights with Byte 18 coded as 1F without issues.
    The issues I am having are:
    1. High beam Out Warning (Byte 18 coded to 21)
    2. LEDs on with headlights, but not as DRL (Byte 18 coded to 21) - I may be missing a wire jumpper
    3. AFS keeps moving headlights to the down position, I need to verify sensor install position.
    4. Measuring blocks shows input of the steering angle sensor under Module 55, but no side to side movement.
    Original byte 18 coding (From Factory) - 6F180A1A90272AC4008800C17000854448010386534D8560648020200040
    Current byte 18 coding: 6F180A1A90272AC4008800C170000DAC48212186534D8560E48420240040
    Most recent Scan, I reset everything to original coding and have tried a few combinations of things, this gives me the best result (see above problems) to date.
    Wednesday,16,April,2014,13:17:55:58983
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WVWDM7AJ5DW139548   License Plate:
    Mileage: 10616   Repair Order:
    Chassis Type: AJ (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 62 72
              77
    VIN: WVWDM7AJ5DW
    Address 01: Engine (CJA)       Labels: None
       Part No SW: 03L 906 019 HC    HW: 03L 907 309 AA
       Component: R4 2,0L EDC G000AG  4816
       Revision: 12H16---    Serial number:
       Coding: 0050078
       VCID: 73E5288312534F86965-8026
    Readiness: 0 0 0 1 1
       Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3528
       Revision: 05651213    Serial number: 00001304200357
       VCID: 24471BDFE73D983EDFF-8071
       Revision: 00H31001
       Coding: 114B400C49250003881002E892210042B70000
       VCID: 7DF10EBBE41709F6F01-8028
    Address 08: Auto HVAC (J301)       Labels: 7N0-907-426.clb
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001019
       Coding: 0010002002
       ROD: EV_ACManueBHBVW36X_SE36.rod
       VCID: 7BF500A3F20307C6CE5-802E
       Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
       Component: BCM PQ35  M   111 0709
       Revision: AC111709
       Coding: 6F180A1A90272AC4008800C170000DAC48212186534D8560E48420240040
       VCID: 4189B24BD86FAD16D49-8014
       Component: Wischer 19041  26  0512
       Coding: 009795
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 202
                        Mileage: 17086 km
                        Date: 2010.14.21
                        Time: 13:12:33
                        Voltage: 14.00 V
                            Term 50 Off
                        Reset counter: 202
                        Mileage: 17086 km
                        Date: 2010.14.21
                        Time: 13:12:33
                        Voltage: 14.00 V
                            Term 50 Off
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R0208P4
       Coding: 00004737
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C77C3BFB78DC0FE87F-8069
       Serial number: ---0000R--00006C8500
       Serial number: 3572MSME14572079ZZZS
       Serial number: 3582MSME09682279ZZZ.
       Serial number: 3512QSME4C032F1AZZZ
       Serial number: 3522QSME600F2D67ZZZ+
       Serial number: 35527SME0A445C2FZZZS
       Crash sensor for front airbag; passenger side:
       Serial number: 35627SME4350532FZZZE
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90440MDR000KE
       Coding: 189A140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 76E31197C9215AAEB1B-8023
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Serial number: 40000000000000857330
       Coding: E30000
       Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
       Coding: 270F01
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 3169E28B60CF3D96249-8064
       Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
       Component: J533  Gateway H52 1634
       Revision:   H52       Serial number: 250413F1000815
       Coding: 350002
       VCID: 74E72B9FD75D48BE8FF-8021
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RNKYX07
       VCID: FEF389B7A91192EE69B-80AB
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EADBB5E70D990E4EA53-80BF
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664703023
       Coding: 010100
       VCID: 2A5BF5E745194E4EE53-807F
       Coding: 0001204
       VCID: 3169E28BA8CF3D96249-8064
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       VCID: 377DDC9346ABE3A66AD-8062
       Coding: 0001204
       VCID: 326BED87ADC9068E5D3-8067
    Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
       Coding: 1442844
       VCID: 3467EB9F57DD08BE4FF-8061
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Coding: 00000022
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7N1115038
       Coding: 01000400040005
       VCID: 64C75BDF67BDD83E1FF-8031
                        Reset counter: 202
                        Mileage: 17086 km
                        Date: 2010.14.21
                        Time: 13:06:19
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 3561D69B5CA711B6781-8060
       Coding: 0001168
       VCID: 3663D19741A11AAE71B-8063
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007664714641
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A7BC5A7BDB9FECE953-806F
  5. #25
    United States
    Quote Originally Posted by b3miller View Post
       Revision: AC111709
       Coding: 1442844
       Coding: 00000022
       Coding: 00000022
    Hello Ryan,
    This scan looks a lot better with the 55-Xenon Sub-system (Slave) AFS modules online and communicating. Problems like this are common and answers in forum will be searchable in the future so I am posting the original scan clip from 55 for example:
    Coding: 8388607
    Subsystem 1 - Part No: ID-L fehlt
    Component: AFS-Lst.-Modul l ....
    Coding: 00000255
    Subsystem 2 - Part No: ID-R fehlt
    Component: AFS-Lst.-Modul r ....
    Coding: 00000255
    02071 - Local Databus
    014 - Defective - MIL ON
    000 - - - MIL ON
    02656 - Power Output Stage for Left Headlight (J667); Not Coded
    000 - - - MIL ON
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
    000 - - - MIL ON
    That problem was already diagnoses and resolved per the factory level wiring diagrams, which allowed him to code the 55 control module, but I have this noted under the Special Notes section on the VW Golf (1K) Headlight Aim Control (Xenon with AFS) Wiki page as well.
    Now, moving onto the current condition
    55 is coded for Row rather than NAR so I would change that from 1442844 -to- 1446940. If the level sensor value isn't correct you can use measuring block group 004 to view the sensor value. On that note, the 55 controller is only coded for one level sensor so please let us know if two are installed.
    Modifications to Byte 18 shouldn't be necessary for Xenon headlights or LED DRLs but those tail lights require a modified lighting scheme. Hex 21 should work with LED taillights and no rear fog (2 reverse lights). I would try coding that BCM to:
    6F180A1A90272AC4008800C170000DEC48252186534D8560E48420240040
    .. to see if the DRL problem is resolved or not.
    -Dana
  6. Likes Uwe, b3miller liked this post
  7. #26
    Thank you for the help Dana. Those two bits of code in the CECM and the AFS ultimately got the system fully functional. However I have learned a few things that I have only read one other place. They made the difference between hair pulling failure and success.
    1) Before updating the coding, at least for 55 AFS, make sure the ignition is running, lights are on, and most important PARKING BRAKE OFF.
    2) Be sure to clear any and all fault codes from the AFS module. The lights appear to take coding if a fault code exist, however the lights will not move if there is one.
    Again THANK YOU THANK YOU for all of your assistance.
    I do have one small issue remaining.
    The parking/position lights (Amber) in the front bumper mirror the ON/OFF and intensity of the LED DRLs. Any thoughts on this from anyone would be appreciated.
  8. Likes Uwe, Dana liked this post
  9. #27
    United States
    Excellent! Thanks for the update.
    I'm not sure about that parking light and DRL operation but the 2010 Gti I had (factory Xenon lights pre-LED) used a single wire from the BCM -to- the city light and amber side marker in the bumper. The left and right sides of the vehicle had separate wires, but my point is it was nothing more than a splice. When Byte 18 wasn't correct my side markers would be dim.. but in a car with separate DRLs (LED -or- conventional halogen) those circuits would need to be isolated IMO. Separate wires are absolutely necessary for winking DRL operation (with the turn signal like an Audi).
    I suspect this is a wiring config but please post the current scan or a clip from the current 09 condition so I can make sure we didn't miss anything. If you want to experiment see what happens when you enable "Daytime Running Lights (DRLs) inactive with Turn Signals active" in Byte 15. If the side marker in the bumper turns off with the turn signal my theory may be correct.
    -Dana
    P.S. I fixed a brain fart in my last post (it read ..."shouldn't be necessary for LED headlights or LED DRLs" when I meant Xenon -or- LED DRLs) but I didn't tweak anything else.
  10. #28
    Great I will look into the wiring on that fixture.
    One more problem I am running across. Sorry I don't have a scan of it with me at the moment. I get 7 error codes in the 55 module, hover they only occur when I start the car. They are "Intermittent communication with ..... Steering Angle Sensor ..... L Headlight ....... R Headlight.....CANBUS". I will post a scan when I get home.
  11. #29
    United States
    I bet the 55 module is running on switched fuse power rather than battery (terminal 30) power per the factory design. If that's the case 55 isn't getting out of bed instantaneously (when his fellow powertrain buddies are) resulting in a bunch of faults. Double check that when you are digging into the BCM diagrams for those DRL/parking lights.
  12. #30
    Xenon AFS Issues Resolved, I think...no I didn't
    Dana,
    I went over all the wiring and everything seems to be correct. I kept getting these errors. They only occur when I start the car, and it appears only after it completely powers down. If I turn the car off the right back on, no issues. Once I clear the error everything works correctly. I am only getting the error in the 55 module. See error below.
    Monday,21,April,2014,21:04:34:58983
    VIN:    License Plate:
    Control Module Part Number: 5M0 907 357 C    HW: 5M0 907 357 C
      Component and/or Version: AFS-Steuergeraet    0148
               Software Coding: 1446940
                Work Shop Code: WSC 00000 000 00000
               Additional Info: 7L6941329B  AFS-Lst.-Modul l    0004   7L6941329B  AFS-Lst.-Modul r    0004
    7 Faults Found:
    01312 - Powertrain Data Bus
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
    02233 - Left Headlight Power Output Stage (J667)
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
                        Reset counter: 253
                            Invalid
                            Invalid
                            Invalid
    Any troubleshooting steps to look at when be much appreciated.
