Page 14 of 14 FirstFirst ... 4121314
Results 131 to 134 of 134
Thread: mk6 xenon retrofit
  1. #131
    Mar 2016
    Romania
    Hello
    Thans Husseinayash
    I resolv the problem with AFS.
    First was programming and after that i can codding with VCDS
  2. Likes Uwe liked this post
  3. #132
    Mar 2014
    Saudi Arabia
    Hello rentearobert,
    it is good to hear that your issue solved, can you help me and show me how you resolve the problem with AFS.
    how you do programing, do you use VCDS for programing, what about codding what are the steps.
    Regards.
  4. #133
    Mar 2014
    Saudi Arabia
    Hi Dana,
    Latest update, finally i get ride of 6 or 7 faults in AFS, I bought used AFS and with Help of friend we get it coded and replace with my previous one.
    the point here still i have one fault it is about Batabus - missing message as you can see below latest VCDS scan; I need you help in this issue...
    Sunday,09,October,2016,15:51:25:21343
    VCDS Version: 16.8.1.3
    Data version: 20160902 DS256
    VIN: WVWSV116XCM002175   License Plate: 5834 VGB
    Mileage: 82230km-51095mi   Repair Order: 120-2016
    Chassis Type: 16 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 1C 25 2B 2E 42 46 4F 52 55
              56 62 72 77
    VIN: WVWSV116XCM002175   Mileage: 82230km-51095miles
    Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
       Part No SW: 06G 906 055 Q    HW: 06G 906 055 B
       Component: 2,0L 85KW       G01 1308
       Revision: T5H04---    Serial number: 00000000000000
       Coding: 0001015
       Shop #: WSC 72400 819 92971
       VCID: 377DC06D461EDBFA5F-8062
       Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
       Component: AQ 250 6F           2330
       Revision: 00H90000    Serial number:
       Coding: 0000328
       VCID: 7F0DE84D2EAE23BAD7-802A
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
       Component: MK70 M MASR         0106
       Revision: 00H35001
       Coding: 0004465
       Shop #: WSC 00066 000 00000
       VCID: 7BF51C5D3AB63F9AFB-802E
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 086 1101
       Revision: 00086000    Serial number: 0191047223
       Coding: 030C0C
       Shop #: WSC 33200 001 104857
       ROD: EV_KESSYPQ35G.rod
       VCID: 3467F7619F6830E27A-8060
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00001003
       Coding: 0000001002
       Shop #: WSC 00066 000 00121
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 6ED32509B1C45A324C-803A
       Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
       Component: BCM PQ35 H    021 0068
       Revision: BE021001
       Coding: 47000A3AE43FE3C040080080140009E003F4000854A08DF0E4840004A040
       Shop #: WSC 12345 123 61029
       VCID: 4487A7A1C7C88062CA-8010
       Component: RLS 270812 05  54  0403
       Coding: 07300A
       Subsystem 2 - Part No: 1K8 951 171
       Subsystem 3 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
    Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
       Part No SW: 5C6 919 475     HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0005
       Revision: --------    Serial number: 84091114302826
       Coding: 308101
       Shop #: WSC 00066 123 00121
       ASAM Dataset: EV_EPHVA18VW3610000 001003
       ROD: EV_EPHVA18VW3610000.rod
       VCID: 71E93E75A0FA45CA51-8024
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Component: AirbagVW10    013 0613
       Serial number: 003G6D052TD1
       Coding: 00003242
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 326BF179657C3ED268-8066
       Serial number: 3572MSME6B70005DZZZZ
       Serial number: 3582MSME3355235FZZZZ
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3516KSME54457310ZZZI
       Serial number: 3526KSME3E457310ZZZR
       Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20110404201176
       Coding: 0002140000
       Shop #: WSC 00066 000 00185
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 7DF11245ECA231AAC5-8028
       Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Coding: 820000
       Part No SW: 5C6 920 870     HW: 5C6 920 870
       Coding: 671B01
       ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
       VCID: 68DF53119320840206-803C
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 09061101200024
       Coding: 351002
       Shop #: WSC 00066 123 12345
       VCID: 3169FE75687A05CA11-8064
       Revision: 00001000    Serial number: 1225223RBRC006
       VCID: 7EF3154929A42AB2DC-802A
       Coding: 000007
       VCID: 6ADB29198D2CB61210-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000112897001
       Coding: 4900000000000000
       Shop #: WSC 00066 790 50316
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E53E50971441A320C-807A
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669901703
       VCID: 285F13115BA04402C6-807C
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0515
       Revision: 13110009    Serial number: 0002392853
       Coding: 0010B7
       Shop #: WSC 01383 790 50316
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 5BB57CDD5276DF9A9B-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1508
       Serial number: 00000005819248
       Coding: 000090
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Component: EZE_2         H35 0614
       Coding: 01030100
       VCID: 6FED380DBECE533A47-803A
       Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.019  H08 0006
       Serial number:     WRH00025AB+
       Coding: 180000
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0515
       Revision: 15110009    Serial number: 0002460535
       Coding: 0010B6
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 5CB77FC15778D8A292-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1508
       Serial number: 00000005849027
       Coding: 000090
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Coding: 081A00000B000200
       Shop #: WSC 12121 121 12121
       VCID: 377DC06D8E1EDBFA5F-8062
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0010
       Coding: 860000
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0010
       Coding: 860000
    13705474 - Databus
              U1121 00 [137] - Missing Message
                        Reset counter: 121
                        Mileage: 82234 km
                        Date: 2016.10.09
                        Time: 15:46:22
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  041 0167
       Revision: 00000001    Serial number: VWZ1Z3L5207698
       Coding: 0100044004
       VCID: 62CB41397D1CEE52D8-8036
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007669857382
       Coding: 0A01000000010101
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: 244707212F88A062EA-8070
    End-------------------------(Elapsed Time: 03:56)--------------------------
  5. Likes Dana liked this post
  6. #134
    United States
    The Databus fault could be internal (related to the subsystems) or external (related to the other master modules on the Bus including the power up timing). You have an undocumented coding bit enabled in Byte 1, bit 3 so I would start with coding to something more like: 081200000B000200
    You may even want to tinker with the static cornering light options over in Byte 6. If my suggestions aren't helpful, simply paste 081A00000B000200 back into the controller and re-calibrate the basic settings.
    If you don't receive any additional suggestions I'd make sure the headlight subsystems and the 55 master module are powered per factory design (terminal 15 switched versus terminal 30 constant power).
  7. Likes Uwe, rentearobert liked this post
