Results 1 to 8 of 8
Thread: USA DRL on Audi A3
    Jan 2019
    USA DRL on Audi A3
    Hi, just wondering if anyone had any idea how to enable USA DRL (make indicators the DRL) on the Audi A3 2018 (8V facelift). I’ll post the adaption channel for the 09.
    Link to 09: https://cdn.fbsbx.com/v/t59.2708-21/...=5C324262&dl=1
    Thank you
    May 2014
    Quote Originally Posted by Gashhey View Post
    Thank you
    Gashhey: Hi - I'm perfectly happy to be corrected by more knowledgeable colleagues, but I suspect that it ain't possible to implement your requirements through VCDS programming because my suspicion is that the front headlight fittings are controlled by separate light-control-modules (LCMs).
    A better appraisal of my hypothesis would be confirmed by you posting a scan report from your car, but I note from a review of your BCM admap that the normal Leuchte-set for the left-side front indicator (i.e. Leuchte 0 BLK VL B3) is disabled (as a factory setting, I assume) and the normal right-side Leuchte-set (i.e. Leuchte1BLK VRB20) is allocated to an entirely different function. Together, these 2 x observations tend to support the assertion that the BCM on your A3 isn't controlling the front blinkers (I think)
  3. Likes PetrolDave, Uwe liked this post
    Dec 2016
    DE
    Don is correct. Currently it is not known how to perform this tweak on cars wit LCMs.
    Jan 2019
    Hi, apologies for the late response. I do recall seeing a RS3 with the USA DRL enabled which confirms that I know it’s possible, but no idea how or if he used VCDS or other tools etc. Here’s an auto scan, if that’s what you were requesting.
     Saturday,05,January,2019,21:32:39:18214
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WAUZZZ8V6KA004422   License Plate: AS
    Mileage: 13908km-8642mi   Repair Order:
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 08 09 10 15 17 19 29 39 42 44 4B 52 5F BB BC D6 D7
    VIN: WAUZZZ8V6KA004422   Mileage: 13908km-8642miles
    Address 01: Engine (J623-DKRF)       Labels: None
       Part No SW: 04C 906 025 AD    HW: 04C 907 309 BB
       Component: R3 1.0l TFS   H20 6194
       Revision: D7H20000
       Coding: 02250032232401082000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM10TFS01104C906025AD 003005
       ROD: EV_ECM10TFS011_AU37.rod
       VCID: 629DA96234CBC377E8F-8036
       CAN Converter 01:
    17165 - Databus
       Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1609
       Revision: 00005008    Serial number: CU501807167140
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 372B2836CFC9F6DF6F1-8062
       Part No SW: 5Q0 614 517 DG    HW: 5Q0 614 517 AG
       Component: ESC           H62 0654
       Revision: 00000000    Serial number: 62038000001048
       Coding: 12F18AA2242022708B7B0E0260C52448512444D1700624730221F0748208420B00000012121212B835351919323200
       VCID: 79AFEE0EB95D20AFD95-802C
       Part No SW: 8V0 820 043 AE    HW: 8V0 820 043 AE
       Component: AC Automat    H03 0150
       Revision: 20003000    Serial number: 00000001619313
       Coding: 03100003000000001000000000001000
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
       VCID: 75B7E23E954544CFBDD-8020
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 3A029E3900PAG0MUFU03
       Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H38 0273
       Serial number: 00001819801330
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7CA1F71AB66F1587C23-8028
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 180615  043 0580
       Serial number:         180629123450
       Coding: 0A47F7
       Serial number: 21533757X81A955547A0
       Coding: 00006C
       Component: E1 - LDS MQB  H06 0032
       Serial number: 28 05 2018  20000477
       Serial number: 000000000ZY181500W94
       Serial number: 00000000000030423467
       Steering Column Switch:
       Subsystem 6 - Part No SW: 82A 953 521 A    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0060
       Serial number: 00000003081820240486
       Part No SW: 5QA 919 283 C    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0050
       Serial number: 000308419618202
       Coding: 0600040011
       ASAM Dataset: EV_EPHVA14AU3700000 009037
       ROD: EV_EPHVA14AU3700000.rod
       VCID: 4ACD61C2AC3B7B3700F-801E
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Component: AirbagVW21    006 0339
       Serial number: 003VWR4EBYRB
       Coding: 98CCC0000C0000005C5400CA00C8000000C5
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 094F9ECEE9BD302FC95-805C
       Subsystem 1 - Part No SW: -----------    HW: 480 000 108 18
       Serial number: 35700000000756741338
       Subsystem 2 - Part No SW: -----------    HW: 480 000 108 18
       Serial number: 3580000000058674133A
       Subsystem 3 - Part No SW: -----------    HW: 480 400 108 18
       Component: SideSensor_Dr  003 6149
       Serial number: 3510001B929F2612148.
       Subsystem 4 - Part No SW: -----------    HW: 480 400 108 18
       Component: SideSensor_Pr  003 6149
       Serial number: 3520001B529F2613651Y
       Subsystem 5 - Part No SW: -----------    HW: 480 401 307 18
       Component: FrontSensor_D  004 6149
       Serial number: 3550001182B6D2E2F2EI
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 407 18
       Component: PedP_Sensor_D  004 6149
       Serial number: 22800010A2B7F1A5B425
       Subsystem 7 - Part No SW: -----------    HW: 480 401 407 18
       Component: PedP_Sensor_P  004 6149
       Serial number: 22900011C2B6D2E35142
       Subsystem 8 - Part No SW: -----------    HW: 480 002 807 18
       Serial number: I0M000000008D168233+
       Subsystem 9 - Part No SW: -----------    HW: 480 002 807 18
       Serial number: I0N000000000F168233-
       Part No SW: 8V0 920 950     HW: 8V0 920 950
       Component: KOMBI         H20 2601
       Coding: 27AD0A082B8006000104FA001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009065
       VCID: 77ABE8368F4936DFAF1-8022
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_Audio_0x31 keine Kommunikation]
                        Fault Frequency: 9
                        Reset counter: 59
                        Mileage: 10734 km
                        Date: 2018.12.22
                        Time: 20:23:11
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   439 4344
       Revision: --------    Serial number: 0008237786
       Coding: 030100043F0857005B00004A100B00000001010000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW37.rod
       VCID: 3D273A1EEDF5DC8FB5D-8068
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0004
       Serial number: 20180625173551 22127
       Serial number: 758860019118072308A0
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H07 0022
       VCID: 42DD49E2940BA377C8F-8016
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0287
       Serial number: YE007RGL2342D
       Coding: 001C8A205001000000001002
       VCID: 44D14FFA8E1FAD47FA3-8010
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1081
       Coding: 81170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73B3DC269B315AFF939-8026
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0342
       Serial number: 19071810800959
       Coding: 000000050900146600102B03020000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002004
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 3537223ED5C504CF7DD-8060
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0287
       Serial number: YE007RGH1028A
       Coding: 001C82205C01000000001002
       VCID: 43D34CE68B11AA7FC39-8016
       Part No SW: 81A 035 192 E    HW: 81A 035 192
       Component: MU-HS-LND-EU  050 0235
       Coding: 01730301FF0A000011111101000A00102F002CC601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP_AU37.rod
       VCID: 2313EC666B518A7FA39-8076
       Subsystem 1 - Part No SW: 8W0 919 866 AF    HW: -----------
       Component: ECE 2018/2019  --- 0035
       Component: DU High  H49 0014
       Serial number: AUZ8Z9J1Y0CP5V
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL131051800050127
       Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
       Component: TSG HFS003 0187
       Serial number: YE007RGE25444
       Coding: 000C82204001000000001002
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 4EC56DD2505357175C7-801A
       Component: TSG HBFS003 0187
       Serial number: YE007RGE25531
       ROD: EV_DCU2RearPasseMAXHCONT.rod
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 176BC8B6AF09D6DF4F1-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.0V)-----------
  6. Likes DV52 liked this post
    May 2014
    ^^^ yes, it's as I suspected (and as TBAx has confirmed) - the modules at address hex29 and hex39 in your autoscan report are LCMs. As for your response about the RS3, I have no doubt that it was indeed possible to make the change to the BCM. However, "I would bet London to a brick" that in that vehicle, the autoscan would not report hex29 & hex39 modules.
    Uwe: is it too forward of me to suggest that perhaps "LCM" be defined in the forum's lexicon?
    It has been for a while. But that only works if the acronym is standalone, like LCM , quotes or pluralization by appending an 's' will cause it to fail.
  9. Likes DV52 liked this post
  10. #7
    Jan 2019
    Thanks to all who’ve commented, I appreciate the fast response.
  11. #8
    Jan 2019
    Not sure if this is anymore help to the DRL. Below I'll post both Adaptions and Measuring Values.
    LEFT LIGHT:
    ;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Left Light
    ;Component:LCM_MQB       H07 0022	 Coding:
    ;EV_LCMLeftCONTIAU426	1009	EV_LCMLeftCONTIAU426_VW41.rod
    ;Sunday	6	January	2019	17:45:25:18214
    ;VCDS Version: Release 18.9.0 (x64)  Data version: 20181017 DS296.0
    ;VCID: 42DD49E2940BA377C8F-8016
    Group	Description	Actual
    IDE00030	Status of actuator test	not active
    IDE00323	Security Access: Number of invalid keys	0
    IDE00767-MAS01478	No. of unscheduled ECU resets-Insuff. voltage	127
    IDE00767-MAS03945	No. of unscheduled ECU resets-Watchdog Reset	19
    IDE00773	Terminal 15 status via CAN	On
    IDE02486	Data logger triggering	not active
    IDE03680-MAS01468	Supply voltages-Terminal 15	Not available
    IDE03680-MAS09376	Supply voltages-Supply via vehicle elec. sys. ctrl. unit	12	 V
    IDE06876-MAS01482	Signature light bulb-Hardwareversion	not installed
    IDE06876-MAS01483	Signature light bulb-Softwareversion	not installed
    IDE06876-MAS12381	Signature light bulb-Software subversion	0F
    IDE06876-ENG14244	Signature light bulb-Software_sub_version_Textual	Not available
    IDE06926-IDE02068	History memory: reset counter-Time stamp	44 1A 4D 4C 00
    IDE06926-MAS09176	History memory: reset counter-Reset reason	Watchdog Reset
    IDE08742-MAS01155	Operating time-Control module	302.51	 H
    IDE08742-MAS03835	Operating time-Parking light	159.59	 H
    IDE08742-MAS09325	Operating time-Daytime running lights	129.59	 H
    IDE08742-MAS09330	Operating time-Cover for low beam headlight	0	 H
    IDE08742-MAS09332	Operating time-Turn signal	1.37	 H
    IDE08742-MAS09333	Operating time-Side-marker light	0	 H
    IDE08742-MAS09334	Operating time-Parking light	4.47	 H
    IDE09492-MAS01155	Temperatures-Control module	63	 °C
    IDE09492-MAS09339	Temperatures-extern. temperature sensor 1	51	 °C
    IDE09492-MAS09340	Temperatures-extern. temperature sensor 2	58	 °C
    IDE09768-MAS04121	LED channel 1-Voltage	15.46	 V
    IDE09768-MAS04136	LED channel 1-Current	896	 mA
    IDE09768-MAS09022	LED channel 1-PWM value	89	 %
    IDE09768-MAS09327	LED channel 1-LED brightness class	2
    IDE09768-MAS09328	LED channel 1-Primary function	Daytime running lights
    IDE09768-MAS09329	LED channel 1-Secondary function	Daytime running lights
    IDE09769-MAS04121	LED channel 2-Voltage	0	 V
    IDE09769-MAS04136	LED channel 2-Current	0	 mA
    IDE09769-MAS09022	LED channel 2-PWM value	0	 %
    IDE09769-MAS09327	LED channel 2-LED brightness class	2
    IDE09769-MAS09328	LED channel 2-Primary function	Turn signal
    IDE09769-MAS09329	LED channel 2-Secondary function	Turn signal
    IDE09770-MAS04136	High side channel 1-Current	0	 mA
    IDE09770-MAS09022	High side channel 1-PWM value	0	 %
    IDE09770-MAS09326	High side channel 1-Function	no function
    IDE09771-MAS04136	High side channel 2-Current	0	 mA
    IDE09771-MAS09022	High side channel 2-PWM value	0	 %
    IDE09771-MAS09326	High side channel 2-Function	no function
    IDE09772-MAS04136	High side channel 3-Current	0	 mA
    IDE09772-MAS09022	High side channel 3-PWM value	0	 %
    IDE09772-MAS09326	High side channel 3-Function	no function
    IDE09774-MAS03835	Number of activations-Parking light	728
    IDE09774-MAS09325	Number of activations-Daytime running lights	779
    IDE09774-MAS09330	Number of activations-Cover for low beam headlight	0
    IDE09774-MAS09332	Number of activations-Turn signal	13093
    IDE09774-MAS09333	Number of activations-Side-marker light	0
    IDE09774-MAS09334	Number of activations-Parking light	36
    IDE09775-MAS09336	High temperature operating times for control unit-°C	58.28	 H
    IDE09775-MAS09337	High temperature operating times for control unit-between 105°C and 115°C	26.2	 H
    IDE09775-MAS09338	High temperature operating times for control unit-over 115°C	18.38	 H
    IDE09795-MAS09342	Operating times for motor of headlight range adjustment-between 0% and 30%	68.51	 %
    IDE09795-MAS09343	Operating times for motor of headlight range adjustment-between 30% and 60%	0	 %
    IDE09795-MAS09344	Operating times for motor of headlight range adjustment-over 60%	0	 %
    IDE09828-MAS00890	Head lamp variant-via CAN	E0 44
    IDE09828-MAS01155	Head lamp variant-Control module	E0 44
    IDE09916-MAS09563	Data set names-Number of data set names	1
    IDE09916-MAS09564	Data set names-Data set ID	28929
    IDE09916-MAS09565	Data set names-Data set name	A3PALEDSWECE
    IDE10175	Capturing statistic data: status	active
    IDE10301-MAS01155	Number of excess temp. protection activations-Control module	0
    IDE10301-MAS03835	Number of excess temp. protection activations-Parking light	0
    IDE10301-MAS09325	Number of excess temp. protection activations-Daytime running lights	5
    IDE10301-MAS09332	Number of excess temp. protection activations-Turn signal	0
    IDE11124-MAS12195	Headlight beam adjusting motor-Reference run status	performed
    IDE11124-MAS12196	Headlight beam adjusting motor-Fault position	not approached
    IDE11124-MAS12199	Headlight beam adjusting motor-Adjustment speed	normal
    IDE11124-MAS12206	Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke)	36.8	 %
    IDE11124-MAS12207	Headlight beam adjusting motor-Low beam inclination	-449.5	 mm
    IDE11125-MAS12195	Dynamic cornering light adjusting motor-Reference run status	not performed
    IDE11125-MAS12196	Dynamic cornering light adjusting motor-Fault position	not approached
    IDE11125-MAS12199	Dynamic cornering light adjusting motor-Adjustment speed	normal
    IDE11125-MAS12206	Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke)	0	 %
    IDE11125-MAS12209	Dynamic cornering light adjusting motor-Swivel angle	Unknown
    IDE11276-MAS01482	Power output stage for headlamp aux. functions-Hardwareversion	not installed
    IDE11276-MAS01483	Power output stage for headlamp aux. functions-Softwareversion	not installed
    IDE11276-MAS12381	Power output stage for headlamp aux. functions-Software subversion	0F
    IDE11276-ENG14244	Power output stage for headlamp aux. functions-Software_sub_version_Textual	Not available
    IDE11347-MAS12195	Variable headlamp positioning motor-Reference run status	not performed
    IDE11347-MAS12196	Variable headlamp positioning motor-Fault position	not approached
    IDE11347-MAS12199	Variable headlamp positioning motor-Adjustment speed	normal
    IDE11347-MAS12212	Variable headlamp positioning motor-Calibrated light index setting	Unknown
    Elapsed Time: 00:03
    ;Sunday	6	January	2019	17:45:28:18214
    IDE00820-MAS02165-Activating and deactivating all development messages-Group 1	not activated 	1
    IDE00820-MAS02166-Activating and deactivating all development messages-Group 2	not activated 	1
    IDE00820-MAS05859-Activating and deactivating all development messages-Group 3	not activated 	1
    IDE00820-MAS05860-Activating and deactivating all development messages-Group 4	not activated 	1
    IDE00820-MAS05861-Activating and deactivating all development messages-Group 5	not activated 	1
    IDE00820-MAS05862-Activating and deactivating all development messages-Group 6	not activated 	1
    IDE00820-MAS05863-Activating and deactivating all development messages-Group 7	not activated 	1
    IDE00820-MAS05864-Activating and deactivating all development messages-Group 8	not activated 	1
    IDE01550-Service position	not active 	1
    Elapsed Time: 00:01
    Right Light:
    ;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Right Light
    ;EV_LCMRightCONTIAU426	1009	EV_LCMLeftCONTIAU426_VW41.rod
    ;Sunday	6	January	2019	17:45:45:18214
    Elapsed Time: 00:01
    ;Sunday	6	January	2019	17:45:41:18214
    IDE06926-IDE02068	History memory: reset counter-Time stamp	00 00 00 00 00
    IDE08742-MAS01155	Operating time-Control module	298.11	 H
    IDE08742-MAS03835	Operating time-Parking light	159.61	 H
    IDE08742-MAS09325	Operating time-Daytime running lights	129.61	 H
    IDE08742-MAS09332	Operating time-Turn signal	1.5	 H
    IDE09492-MAS01155	Temperatures-Control module	61	 °C
    IDE09492-MAS09339	Temperatures-extern. temperature sensor 1	52	 °C
    IDE09492-MAS09340	Temperatures-extern. temperature sensor 2	55	 °C
    IDE09774-MAS03835	Number of activations-Parking light	729
    IDE09774-MAS09332	Number of activations-Turn signal	14715
    IDE09775-MAS09336	High temperature operating times for control unit-°C	59.99	 H
    IDE09775-MAS09337	High temperature operating times for control unit-between 105°C and 115°C	38.02	 H
    IDE09775-MAS09338	High temperature operating times for control unit-over 115°C	20.98	 H
    IDE09795-MAS09342	Operating times for motor of headlight range adjustment-between 0% and 30%	68.73	 %
    IDE10301-MAS09325	Number of excess temp. protection activations-Daytime running lights	54
    IDE10301-MAS09332	Number of excess temp. protection activations-Turn signal	1
    Elapsed Time: 00:03
  12. Likes Uwe liked this post
