Results 1 to 10 of 11
Thread: Coding information J794, J393, J519, J285
    Jun 2018
    Does anybody has coding information on these units from a 2016 Audi A6? There is no coding help available in VCDS.
    Would be of some great help!
    Thanks in advance
    Chassis Type: 4G8
    Scan: 05 09 17 19 46 5F
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01A8700E000000000000
       VCID: 7CF7EDFBFF987FA47B-8028
       Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
       Component: FBSAUDIB8 IDG  H73 0083
       Serial number: 2118000006370018
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 15020001    Serial number: 00001458392601
       Coding: 2600001400349FE081814083A0001D0CCF9CC20826090201000008206101140200400034030000
       VCID: 74E7C5DBD7C837E433-8020
       Part No SW: 4G8 920 931 R    HW: 4G8 920 931 R
       Component: TDieRdwAcc    H79 0416
       Revision: 28460177    Serial number: 658200212596005
       Coding: 138611001F150008000000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K.rod
       VCID: 3D7120FFAC02B6AC0C-8068
       Part No SW: 4G8 907 468 H    HW: 4G8 907 468
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002363581
       Coding: C0CD072918
       ROD: EV_GatewPkoUDS_002.rod
       Revision: 00002001    Serial number: 0415813125
       Coding: 0102063880BA00000310080008000E470000000000000000000000000000
       Part No SW: 4G1 035 044 F    HW: 4G1 035 044 D
       Component: MU-H-LN-EU    052 0670
       Serial number: A734H0G7506699
       Coding: 017501010000000013110002000A00102F0006E5F1700100DF
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 224BF38335BCE95411-8076
       Subsystem 1 - Part No SW: V03 959 801 FB    HW: -----------
       Component: ECE 2016/2017  --- 0153
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9GY805ZNK
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LC50001Z
       Component: Gracenote2---  --- 1013
    Is there something in particular you are trying to accomplish?
    Jun 2018
    Well the current (bench) setup contains just these units. I was planning to see if certain options can be turned off, so that for example the J285/J519/J393 will no longer expect messages from the TPMS system, Air Suspension, Wipers etc etc
    Besides that, the J794 gives the well known volume "Currently not available" error. Maybe this is due the "Check Software Version Management" DTC but I figure it could also be caused by DTC's 6697, 6702, 6708, 7169, 7170, 7175, 7179, 7184 and/or 7199. Which are all "Function Restricted due to Missing Message(s)" faults.
    Sep 2018
    Spain
    I have a6 4g of 2016. tell me what you need
    Jun 2018
    Well any coding information on the above units would be great. CAN recordings on the J794 and J519 busses would also be great, but that requires some different tools.
    Jun 2018
    Does anyone maybe know how to change the 5F coding from BOSE sound package (8RY) to standard audio system (8RX)?
  7. #7
    Quote Originally Posted by dcggames View Post
    Try changing Byte 11 from 02 to 00.
  8. Likes Dana, dcggames liked this post
  9. #8
    The current 5F label doesn't have coding info but you would have access to experiential coding with one of our current interfaces. The Why Upgrade? thread expands on that.
    We can help you with a file for address 09. Please drop an email to Support with a link in this thread and I'll get it sent off in the morning.
    Although it won't resolve all faults on a bench - you should be able to un-check various modules in that 19-CAN Gateway using the Installation List function to clean up the scan.
  10. Likes Eric, Uwe, dcggames liked this post
  11. #9
    Jun 2018
    That worked! Thanks!!
  12. Likes Dana, Uwe liked this post
  13. #10
    Jun 2018
    I will do that thanks! I'm thinking about upgrading my HEXCAN. The only thing is that I can hardly miss it for more then a few days. I use it very often.
