Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Changed longcoding of central electric 09 byte 18
    Verified VCDS User Cuckoosnake's Avatar
    Nov 2018
    I messed around with an illegal vcds and was really sure i saved the longcoding but after i did, it wasn't
    now i bought a legal version and now i'm a verified user
    i tried to change in central electric 09, byte 18 because my DRL worked without my taillights and thats a little bit dangerous when it's getting dark in the afternoon.
    so i read that in the US it was allowed to drive with DRL and taillights at the same time, and the mk6 is driving with it, and in some european MK6 it would work to.
    Here in the Netherlands it's also allowed to drive with both lights at the same time now, so i would try to change it.
    this did'nt work so after that i had to change the settings to wat it was, wich i did'nt save....
    i made a autoscan and this is what came out of it
    Saturday,29,December,2018,15:28:23:32559
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ1KZCW122928   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 69
              72 77
    VIN: WVWZZZ1KZCW122928   Mileage: 85130km-52897miles
    Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 GE    HW: 03F 907 309 A
       Component: SIMOS10.13H03 2671
       Revision: --H03---    Serial number: 00000000000000
       Coding: 00250096232401080000
       ASAM Dataset: EV_ECM12TFS02103F906070GE 004003
       ROD: EV_ECM12TFS02103F906070GC.rod
       VCID: 6B823108530202AF5B9-803E
    Readiness: 0110 0101
       Part No SW: 0AM 300 060 D    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6219
       Revision: 00043014    Serial number: CU501109086044
       Shop #: WSC 62409 001 1048576
       VCID: 2B02F1089F02C2AF1B9-807E
       Revision: 00H31001
       Coding: 113B200D212400FC881404E684210050310000
       VCID: 7BA2014823E2922FCB9-802E
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001003
       Coding: 0000004003
       VCID: 7F5AF558377A8E0FE71-802A
       Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 100020286101C7C0085C0028B004B180706002004171C9200000A0000040
       VCID: 3A2CC44C6C586B2790F-806E
       Component: Wischer 11091  26  0512
       Coding: 009795
       Component: RLS 050911 05  54  0403
       Coding: 0230AD
       Component: LIN BACKUP HO  H11 9005
    01800 - Light Switch (E1)
                        Reset counter: 85
                        Mileage: 85135 km
                        Date: 2013.05.21
                        Time: 15:23:39
                        Voltage: 13.35 V
                            Term 50 On
    03395 - Control Module for High Beam Assistant
                        Reset counter: 85
                        Mileage: 85135 km
                        Date: 2013.05.21
                        Time: 15:23:39
                        Voltage: 13.35 V
                            Term 50 On
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RAA39FC
       Coding: 00004431
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313EE360B1AEA87F215-8064
       Serial number: 3572MSME580D3463ZZZZ
       Serial number: 3582MSME23171242ZZZG
       Serial number: 3512QSME664D5B05ZZZ+
       Serial number: 3522QSME50315B23ZZZM
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440KI900033
       Coding: 189A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76B4107C1840CF47B47-8022
       Serial number: 30000000000000372457
       Coding: E30000
       Part No SW: 5K0 920 872     HW: 5K0 920 872
       Coding: 170B00
       VCID: 6C803214560C0597523-8038
       Part No SW: 7N0 907 530 J    HW: 1K0 907 951
       Component: J533  Gateway H43 1620
       Revision:   H43       Serial number: 050911F2000453
       Coding: 350002
       VCID: 372ADD785F4A764F6F1-8062
       Component: IMMO          H03 0607
       VCID: 6A8C340C5CF81BA720F-803E
       Revision: A1001003    Serial number: 7660846673
       Coding: 020000
       VCID: 290E0B0099FED0BFE95-807C
    Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
       Part No SW: 3C0 035 270 B    HW: 3C0 035 270
       Component: RNS310        H19 0357
       Revision: 11000000    Serial number: VWZ1Z2L7277681
       Coding: 040004010400000000000000
       ASAM Dataset: VW_RNS310 A02007
       ROD: EV_VWRNS310UDS.rod
       VCID: 196E3BC0C91E403F795-804C
       Coding: 0132276
       VCID: 313EE360BD2EA87F215-8064
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 68     3201
       Revision: 00H20000
       VCID: 3430EA74423C9D574A3-8060
       Coding: 0132276
       VCID: 323CEC6CB828936758F-8066
       Component: Batt.regelung H43 1620
       Coding: 032B1864
       VCID: 71BE236071AEE87F615-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900483437
       Coding: 0132240
       Shop #: WSC 01357 011 1012552
       VCID: 3536D7704946845F7DD-8060
    Address 69: Trailer        Labels: RETROFIT69.lbl
       Part No SW: SW0 408     HW: 5F0 07V 010 1
       Component: TOWBARMODULE ECS    0010
       VCID: 76B4107C14C0CF47B47-8022
       Coding: 0132240
       VCID: 3634D07C54408F47747-8062
       Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
       Component: Telefon       011 0723
       Revision: --------    Serial number: 35909603233705
       Coding: 020000000100000000000000
       ASAM Dataset: EV_UHVPremi A02003
       ROD: EV_UHVPremi_A02.rod
       VCID: 221C1C2CE44803E7A8F-8076
    End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.3V)-----------
    now there are several things that don't work anymore and i don't like that at all..
    the rear lid doesn't work by central (un)lock (only by the middle button of the remote), and if i mark lock and unlock on byte 00 it unlocks and openes the lid for a cm by the remote unlock button.
    the DRL isn't working at all now altough i marked it on in my MFA
    the mirror heating doesn't work
    light in the trunk doesn't work
    CH/LH doesn't work altough i marked it on in my MFA
    i posted this thread first in 'product support' but i think it should be here...
    hope someone can help me with this
    kind regards Jimmy
    Time is money, free time is priceless
    Quote Originally Posted by Cuckoosnake View Post
    Actually, it belongs in the Tweaks section. Car is only broken because it has been incorrectly tweaked.
    Have you looked for these files?
    https://forums.ross-tech.com/showthread.php?1029
    Dec 2016
    DE
    Have you checked the CodingLog.csv inside your VCDS' Debug directory? Maybe you can revert the value using the old coding, which should fix most of the issues. However if the old coding contained a 0x00 at Byte 18 you are a little out of luck as for the problems with the exterior lights.
    There are certain ways to fix this adapting the control modules EEPROM. However VCDS is not capable of doing so.
    You might be able to find someone with a VCP System or similiar who can fix this and will also enable what you want (parking light on for the tail lights together wit DRL). If you are willing for a trip to Berlin, Germany, I can also help you.
  4. Likes Uwe liked this post
    Nov 2018
    I’m affraid that those codingfiles are deleted with the program what belonged by the chinese cable.
    But i will look for it, maybe it’s still in my laptop
    Nov 2018
    There is a big opportunity that the code is 00, but Berlin is a little bit to far, thanks anyway :lol
    I must find someone in my own region.
    Jun 2017
    I tried to find a pattern how the clone screwed up your BCM, but couldn't recognize any.
    I'd suggest to go to your dealer to get an online replication of your factory coding....
  8. Likes TBAx, Mari, PetrolDave liked this post
    Changing byte 18 on a BCM where it is zero is playing a dangerous game, which often ends up this way.
    Maybe VCDS should include a warning box (that the result may be unexpected and irreversible without a dealer visit) when an attempt is made to change byte 18 of a relevant BCM from zero?
  10. Likes Uwe liked this post
  11. #8
    Nov 2018
    Yes, i was thinking of that to, but also i’m thinking i bought an original VCDS cable, i should be able to help myself now.
    And than i’m curious where and how deep the information behind the 00 of byte 18 sits.
    Is it accessible with VCDS, is it the coding of the adaption what need to be changed.....
    If it is something you can’t see or reach with VCDS than i need the help of the dealer.
    Anyway, my motto always is......’i can’t’ isn’t in my dictionary, until i have to write it in it myself.
  12. #9
    Unfortunately, it is not accessible to VCDS. It's really quite nasty the way they did this.
  13. #10
    Võru, Estonia
    I don't see to what You changed it and what it was?
    I guess trying 02 doesn't hurt.
    The world is my oyster...
