Results 1 to 10 of 14
Thread: MMI 3G+ 5F control panel baud rate coding
    I'm retrofitting 3GP into my C6 A6. I've got the unit installed and CP removed, I'm trying to change the baud rate on the 5F unit, so I can use the existing control panel.
    Reading this blog http://mycarfreak.blogspot.co.uk/201...verwenden.html I'm trying to change my coding and select "Byte 14 Bit 5" my original coding is 01010101000281E90116031E0020000380000100 and I believe the new coding is 01010101000281E90116031E0020200380000100 but keep getting and out of range error message. Am I doing something wrong here with my coding?
    Pleas post an Auto-Scan so people can see exactly what's installed in this car and the systems' overall condition.
    Here is a full scan of the car.
    A little history, the car was MMI 2G and I retrofitted MMI 3G which has been working fine for the last 4 months, so I'm now upgrading to 3GP everything appears on screen but the control panel does not work, and from the blog above I need to change the baud rate to 9600 but it's not accepting the coding.
    I also found this thread, but after registering it just points me to the blog in my original post. http://www.digital-eliteboard.com/32...hruesten.html?
    Should add I can perform the reboot command using the control panel so it is working, but functions are limited.
    Sunday,16,November,2014,15:13:15:34601
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN:    License Plate: FULL SCAN
    Mileage:    Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 57
              5F 61 62 6D 72 76
    VIN:   Mileage:
       Part No SW: 4F0 910 401 A    HW: 4F0 907 401 B
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H01---    Serial number:
       Coding: 0011372
       Shop #: WSC 54927 001 1048576
       VCID: 1A3F2A69D51890F181F-804F
       Part No SW: 4F1 910 156 B    HW: 09L 927 156 A
       Component: AG6 09L 3.0lTDI RdW 0030
       Revision: --H01---    Serial number:        4058315
       Shop #: WSC 02327 785 00200
       VCID: 2341178DE252D139529-8076
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H04 0090
       Coding: 0020876
       VCID: 2D55F1B5B4961749F4D-8078
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10600500211209
       Coding: 0000147
       Shop #: WSC 00836 210 86410
       VCID: 63C1578DA2D29139129-8036
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H44 0070
       Component: FBSAUDIC6 IDG   H39 0040
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000074    Serial number: 00000030481776
       Coding: 0001398
       Shop #: WSC 02325 785 00200
       VCID: 1D352175C436E7C964D-8048
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H15 0080
       Coding: 0002121
       Shop #: WSC 02335 785 00200
       VCID: 66C74E9951E0E411F57-8033
       Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4F0 035 110 A    HW: 4F0 035 110
       Component: CDC-MP3-Alp   H44 0140
       Revision: AA001001
       VCID: 15253955FC06BF89ACD-8040
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH29 0260
       Revision: 07H29000    Serial number: 0037LD08VX3X
       Coding: 0013381
       VCID: 295D05A5807E0B69185-807C
       Subsystem 1 - Serial number: 6332CSME0A5C10784
       Subsystem 2 - Serial number: 6342CSME0A2E6F0DM
       Subsystem 3 - Serial number: 6352QSME0448185BI
       Subsystem 4 - Serial number: 6362QSME01483929E
       Subsystem 5 - Serial number: 63734SME022D3649/
       Subsystem 6 - Serial number: 63834SME0221173FX
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90054051780032
       Coding: 0102142
       Shop #: WSC 02323 785 00200
       Component: Lenkradmodul    H07 0080
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4SZ35F475
       Coding: 2049443
       Shop #: WSC 00783 210 06953
       VCID: 214D1D85F84EC329405-8074
    Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0071
       Revision: 00H06000    Serial number: 1200B12218801F
       Coding: F551BE7720068600
       Shop #: WSC 42129 143 13149
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00-00000
       Coding: 0003610
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01030427960000
       Coding: 3277563
    01403 - Glass-Break Sensors; Rear
                        Reset counter: 5
       Part No SW: 4H0 035 223     HW: 4H0 035 223
       Component: BOSE G3 D4    H06 0050
       Revision: CI006500    Serial number: 00000000000489
       VCID: 5BB16F6D5AA2A9F95A9-800E
    03405 - Bass Loudspeaker
                        Fault Status: 00111011
                        Fault Frequency: 72
                        Reset counter: 45
       Revision:             Serial number: 00000000112247
       Coding: 0001103
       VCID: 5EB7667989B0BCD13D7-800B
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00-00000
       Coding: 0003610
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000321
       VCID: 5DB5617584B6A7C924D-8008
       Part No: 8P0 907 357 C
       Coding: 0000003
       VCID: 3A7FCAE975D8B0F161F-806F
       Part No SW: 4F0 035 061 K    HW: 4F0 035 061
       Component: Radio U DAB   H42 V928
       Revision: AB001007    Serial number: 343DO087507017
       Coding: 010103010000000000
       Shop #: WSC 06745 128 28888
       VCID: 24431491275CD6012B3-8071
    02983 - Connection between Impedance Converter 1 and Window Antenna
                        Fault Status: 00101011
                        Reset counter: 45
                        Mileage: 318066 km
                        Date: 2014.11.12
                        Time: 21:39:44
                        Voltage: 11.60 V
    02982 - Connection between Radio and Impedance Converter 2
                        Reset counter: 244
                        Mileage: 317485 km
                        Date: 2014.11.08
                        Time: 12:50:59
                        Voltage: 13.60 V
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4F0 919 129 G    HW: 4F0 919 129
       Component: HybridTV-DVB  H06 0550
       Revision: R0060000    Serial number: 76300802369001
       Coding: 01020100
       Shop #: WSC 06335 000 00000
       VCID: 306BE8C163A47AA1DFB-8065
       Part No SW: 4H0 035 670 A    HW: 4H0 035 670
       Component: H-BNT-EU      H42 0063
       Revision: --------    Serial number: 410HT097548512
       Coding: 01010101000281E90116031E0020000380000100
       Shop #: WSC 02313 785 00200
       VCID: 224F12893D48D83159F-8077
       Subsystem 1 - Part No: 8R0 060 884 R
       Component: EUR 2010  1106
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0098
       Subsystem 3 - Part No: 8R0 060 961
       Component: CD-Database  1886
                        Reset counter: 5
                        Mileage: 318498 km
                        Date: 2014.11.16
                        Time: 10:51:56
                        Text: DU9466,Front,M,0,0,5
    00658 - Control Head
                        Reset counter: 5
                        Mileage: 318498 km
                        Date: 2014.11.16
                        Time: 10:51:44
                        Voltage: 11.90 V
                        Reset counter: 5
                        Mileage: 318498 km
                        Date: 2014.11.16
                        Time: 10:53:47
                        Voltage: 12.20 V
                        Bin. Bits:      001
                        Reset counter: 5
                        Mileage: 318498 km
                        Date: 2014.11.16
                        Time: 11:26:09
                        Bin. Bits: 00000100 00000000
                        Bin. Bits: 00000000 00000000
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 5
                        Mileage: 318498 km
                        Date: 2014.11.16
                        Time: 10:51:52
                        Bin. Bits: 00000000 00001000
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000072463
       Shop #: WSC 00262 210 58386
       Component: von VA0  1507041306
       Coding: 344630393135313035442056413031353037303431333036
       Shop #: WSC 00000 384 00290
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0003074
       VCID: 69DD45A540FECB69D85-803C
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 F
       Component: ValeoHeckdeckel H25 0290
       Revision: --H25001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CD33CB14F0CDE41A33-8039
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: RD01.02.08--H25001001A0034ÿ
       Subsystem 4 - Serial number: 1A0034ÿ
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0003074
       Part No SW: 4F0 910 283 C    HW: 4F0 919 283 C
       Component: Parkhilfe 8-Kan H12 0020
       Revision: 00H12000    Serial number: 11820518300579
       Coding: 0201116
       VCID: 24431491E75CD6012B3-8071
    End-------------------------(Elapsed Time: 02:39)--------------------------
    Last edited by B5NUT; 11-16-2014 at 09:47 AM. Reason: Wrapped CODE tags around Auto-Scan
    Verified VCDS User gupsterg's Avatar
    Sep 2014
    Hi B5NUT,
    How about setting byte 14 bit 5 to 1?
    mit VCDS Programmiergerät Byte 14 Bit 5 auf 1 setzt.
    So above here Link:- http://www.motor-talk.de/forum/mmi-b...65.html?page=1
  5. Likes Uwe liked this post
    That's what I set and it's refusing the coding. The 5F module has an early firmware version, so I'm wondering if this function is only available in later versions.
    I have now connected up a 3G+ control panel so I know all my wiring is correct and it's working fine.
    I'm going to update the firmware in the next few days so will report back.
    Sep 2014
    Quote Originally Posted by B5NUT View Post
    What my thoughts were after reading the motor.de post was to try setting byte 14 bit 5 to a 1.
    Are you not getting a 2 there, comparison of your coding from post 1:-
    Byte 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19
    Orig code 01 01 01 01 00 02 81 E9 01 16 03 1E 00 20 00 03 80 00 01 00
    Refused code 01 01 01 01 00 02 81 E9 01 16 03 1E 00 20 20 03 80 00 01 00
    Are you getting a 2 by setting byte/bit via tick box in long coding helper?
    Why not bypass the long Coding Helper entirely. Simply type in the required code directly into the "new coding" box and click Do it! (instead of relying on any part of the long Coding Helper)
  9. Likes gupsterg liked this post
  10. #8
    Thanks guy's but I've already tried all of the above and it simply will not accept any value other than 0 in second digit of byte 14, the first digit will accept 0,1,2,3 & 4 after that all other coding is refused. I'm sure it's down to the firmware.
  11. Likes gupsterg liked this post
  12. #9
    Solution! So still have the problem where the unit refuses the new coding in byte 14. So I purchased a 3G+ control panel that works with the faster baud rate.
    Once you have control of the MMI system you need to enable the hidden menu (info on this can be found here http://www.audi-resource.com/mmi3ghiddenmenu.php)
    Go into the hidden menu and select frontctrl
    Set both values to 9600 and reboot the system
    This was my coding before changing the baud rate
    This was after the change
    Nothing had changed in the coding, so this could be down to my firmware version as it is very old (2010) or it could be down to a specific model of MMI3G+ A4, Q7, A8 etc or a bug in the latest version of VCDS, I have no idea which, however I do know it works using the hidden menu option, problem with this is you have to have a 3P+ control panel to get into the hidden menu to change the setting.
    Point to note once you set these values, the 3G+ control panel no longer works, but at least your old 2G control panel will now work
  13. Likes Uwe, gupsterg, jyoung8607 liked this post
  14. #10
    Jan 2015
    I know this is an old thread, but I wanted to add this for anyone who comes across it in the future.
    I was able to successfully reset my baud rate by setting byte 14 bit 5 to 1. Module info is below. The software version on the head unit is HN+_US_AU3G_K0814. (Note the coding string is from before I changed the baud rate)
    VCDS Version: Release 17.1.3 (x64)
    Control Module Part Number: 8R1 035 746 G
      Component and/or Version: H-BNT-NA      H42 0901
               Software Coding: 160200060005A1EF51028B5E00000403140000000000000000
                Work Shop Code: WSC 06335
                          VCID: BB3670813AF419997C-80EE
    Thanks to this, I'm able to run a 2008 S5 control panel with a 2014 3GP head unit on my test bench. The 'car' and 'tel' buttons are reversed, but it's good enough for bench testing.
  15. Likes Eric, Uwe, jyoung8607 liked this post
