MMI 3G+ 5F control panel baud rate coding
B5NUT
C?ID=30047
I'm retrofitting 3GP into my C6 A6. I've got the unit installed and CP removed, I'm trying to change the baud rate on the 5F unit, so I can use the existing control panel.
Reading this blog http://mycarfreak.blogspot.co.uk/2012/10/mmi-2g3g-bedienfeld-am-mmi-3gp-verwenden.html I'm trying to change my coding and select "Byte 14 Bit 5" my original coding is 01010101000281E90116031E0020000380000100 and I believe the new coding is 01010101000281E90116031E0020200380000100 but keep getting and out of range error message. Am I doing something wrong here with my coding?
Pleas post an Auto-Scan so people can see exactly what's installed in this car and the systems' overall condition.
B5NUT
C?ID=30047
Here is a full scan of the car.
A little history, the car was MMI 2G and I retrofitted MMI 3G which has been working fine for the last 4 months, so I'm now upgrading to 3GP everything appears on screen but the control panel does not work, and from the blog above I need to change the baud rate to 9600 but it's not accepting the coding.
I also found this thread, but after registering it just points me to the blog in my original post. http://www.digital-eliteboard.com/325888-mmi-3gp-im-a6-4f-fl-mit-mmi-3g-nachruesten.html?
Should add I can perform the reboot command using the control panel so it is working, but functions are limited.
Sunday,16,November,2014,15:13:15:34601
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN:    License Plate: FULL SCAN
Mileage:    Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 57
          5F 61 62 6D 72 76
VIN:   Mileage:
   Part No SW: 4F0 910 401 A    HW: 4F0 907 401 B
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H01---    Serial number:
   Coding: 0011372
   Shop #: WSC 54927 001 1048576
   VCID: 1A3F2A69D51890F181F-804F
   Part No SW: 4F1 910 156 B    HW: 09L 927 156 A
   Component: AG6 09L 3.0lTDI RdW 0030
   Revision: --H01---    Serial number:        4058315
   Coding: 0000001
   Shop #: WSC 02327 785 00200
   VCID: 2341178DE252D139529-8076
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0020876
   VCID: 2D55F1B5B4961749F4D-8078
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10600500211209
   Coding: 0000147
   Shop #: WSC 00836 210 86410
   VCID: 63C1578DA2D29139129-8036
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 IDG   H39 0040
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000074    Serial number: 00000030481776
   Coding: 0001398
   Shop #: WSC 02325 785 00200
   VCID: 1D352175C436E7C964D-8048
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H15 0080
   Coding: 0002121
   Shop #: WSC 02335 785 00200
   VCID: 66C74E9951E0E411F57-8033
   Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Coding: 00141886
   Shop #: WSC 02335
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 15253955FC06BF89ACD-8040
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH29 0260
   Revision: 07H29000    Serial number: 0037LD08VX3X
   Coding: 0013381
   VCID: 295D05A5807E0B69185-807C
   Subsystem 1 - Serial number: 6332CSME0A5C10784
   Subsystem 2 - Serial number: 6342CSME0A2E6F0DM
   Subsystem 3 - Serial number: 6352QSME0448185BI
   Subsystem 4 - Serial number: 6362QSME01483929E
   Subsystem 5 - Serial number: 63734SME022D3649/
   Subsystem 6 - Serial number: 63834SME0221173FX
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90054051780032
   Coding: 0102142
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
   Component: KOMBIINSTR. M73 H15 0630
   Revision: 01000000    Serial number: 4SZ35F475
   Coding: 2049443
   Shop #: WSC 00783 210 06953
   VCID: 214D1D85F84EC329405-8074
Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0071
   Revision: 00H06000    Serial number: 1200B12218801F
   Coding: F551BE7720068600
   Shop #: WSC 42129 143 13149
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00-00000
   Coding: 0003610
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01030427960000
   Coding: 3277563
01403 - Glass-Break Sensors; Rear
                    Fault Status: 01101011
                    Reset counter: 5
   Part No SW: 4H0 035 223     HW: 4H0 035 223
   Component: BOSE G3 D4    H06 0050
   Revision: CI006500    Serial number: 00000000000489
   VCID: 5BB16F6D5AA2A9F95A9-800E
03405 - Bass Loudspeaker
                    Fault Status: 00111011
                    Fault Frequency: 72
                    Reset counter: 45
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000112247
   Coding: 0001103
   VCID: 5EB7667989B0BCD13D7-800B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00-00000
   Coding: 0003610
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0000321
   VCID: 5DB5617584B6A7C924D-8008
   Part No: 8P0 907 357 C
   Coding: 0000003
   VCID: 3A7FCAE975D8B0F161F-806F
   Part No SW: 4F0 035 061 K    HW: 4F0 035 061
   Component: Radio U DAB   H42 V928
   Revision: AB001007    Serial number: 343DO087507017
   Coding: 010103010000000000
   Shop #: WSC 06745 128 28888
   VCID: 24431491275CD6012B3-8071
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Fault Status: 00101011
                    Fault Frequency: 6
                    Reset counter: 45
                    Mileage: 318066 km
                    Date: 2014.11.12
                    Time: 21:39:44
                    Voltage: 11.60 V
02982 - Connection between Radio and Impedance Converter 2
                    Reset counter: 244
                    Mileage: 317485 km
                    Date: 2014.11.08
                    Time: 12:50:59
                    Voltage: 13.60 V
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Component: HybridTV-DVB  H06 0550
   Revision: R0060000    Serial number: 76300802369001
   Coding: 01020100
   Shop #: WSC 06335 000 00000
   VCID: 306BE8C163A47AA1DFB-8065
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 4H0 035 670 A    HW: 4H0 035 670
   Component: H-BNT-EU      H42 0063
   Revision: --------    Serial number: 410HT097548512
   Coding: 01010101000281E90116031E0020000380000100
   Shop #: WSC 02313 785 00200
   VCID: 224F12893D48D83159F-8077
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Subsystem 3 - Part No: 8R0 060 961
   Component: CD-Database  1886
            000 -  -
                    Reset counter: 5
                    Mileage: 318498 km
                    Date: 2014.11.16
                    Time: 10:51:56
                    Text: DU9466,Front,M,0,0,5
00658 - Control Head
                    Reset counter: 5
                    Mileage: 318498 km
                    Date: 2014.11.16
                    Time: 10:51:44
                    Voltage: 11.90 V
                    Fault Status: 01101100
                    Reset counter: 5
                    Mileage: 318498 km
                    Date: 2014.11.16
                    Time: 10:53:47
                    Voltage: 12.20 V
                    Bin. Bits:      001
            000 -  -
                    Reset counter: 5
                    Mileage: 318498 km
                    Date: 2014.11.16
                    Time: 11:26:09
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
            000 -  -
                    Reset counter: 5
                    Mileage: 318498 km
                    Date: 2014.11.16
                    Time: 10:51:52
                    Bin. Bits: 00000000 00001000
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000072463
   Shop #: WSC 00262 210 58386
   Component: von VA0  1507041306
   Coding: 344630393135313035442056413031353037303431333036
   Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0003074
   VCID: 69DD45A540FECB69D85-803C
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 F
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD33CB14F0CDE41A33-8039
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD01.02.08--H25001001A0034ÿ
   Subsystem 4 - Serial number: 1A0034ÿ
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0003074
   Part No SW: 4F0 910 283 C    HW: 4F0 919 283 C
   Component: Parkhilfe 8-Kan H12 0020
   Revision: 00H12000    Serial number: 11820518300579
   Coding: 0201116
   VCID: 24431491E75CD6012B3-8071
End-------------------------(Elapsed Time: 02:39)--------------------------
B5NUT
C?ID=30047
That's what I set and it's refusing the coding. The 5F module has an early firmware version, so I'm wondering if this function is only available in later versions.
I have now connected up a 3G+ control panel so I know all my wiring is correct and it's working fine.
I'm going to update the firmware in the next few days so will report back.
gupsterg
C?ID=146338
What my thoughts were after reading the motor.de post was to try setting byte 14 bit 5 to a 1.
Are you not getting a 2 there, comparison of your coding from post 1:-
Byte0001020304050607080910111213141516171819
Orig code01010101000281E90116031E00200003800001 00
Refused code01010101000281E90116031E0020200380000100
Are you getting a 2 by setting byte/bit via tick box in long coding helper?
DV52
C?ID=194404
Why not bypass the long Coding Helper entirely. Simply type in the required code directly into the "new coding" box and click Do it! (instead of relying on any part of the long Coding Helper)
B5NUT
C?ID=30047
Thanks guy's but I've already tried all of the above and it simply will not accept any value other than 0 in second digit of byte 14, the first digit will accept 0,1,2,3 & 4 after that all other coding is refused. I'm sure it's down to the firmware.
B5NUT
C?ID=30047
Solution! So still have the problem where the unit refuses the new coding in byte 14. So I purchased a 3G+ control panel that works with the faster baud rate.
Once you have control of the MMI system you need to enable the hidden menu (info on this can be found here http://www.audi-resource.com/mmi3ghiddenmenu.php)
Go into the hidden menu and select frontctrl
Set both values to 9600 and reboot the system
This was my coding before changing the baud rate
This was after the change
Nothing had changed in the coding:confused:, so this could be down to my firmware version as it is very old (2010) or it could be down to a specific model of MMI3G+ A4, Q7, A8 etc or a bug in the latest version of VCDS, I have no idea which, however I do know it works using the hidden menu option, problem with this is you have to have a 3P+ control panel to get into the hidden menu to change the setting.
Point to note once you set these values, the 3G+ control panel no longer works, but at least your old 2G control panel will now work:D
Jeff V.
C?ID=236576
I know this is an old thread, but I wanted to add this for anyone who comes across it in the future.
I was able to successfully reset my baud rate by setting byte 14 bit 5 to 1. Module info is below. The software version on the head unit is HN+_US_AU3G_K0814. (Note the coding string is from before I changed the baud rate)
VCDS Version: Release 17.1.3 (x64)
Control Module Part Number: 8R1 035 746 G
  Component and/or Version: H-BNT-NA      H42 0901
           Software Coding: 160200060005A1EF51028B5E00000403140000000000000000
            Work Shop Code: WSC 06335
                      VCID: BB3670813AF419997C-80EE
Thanks to this, I'm able to run a 2008 S5 control panel with a 2014 3GP head unit on my test bench. The 'car' and 'tel' buttons are reversed, but it's good enough for bench testing.
pploeser
C?ID=401051
Hey guys, I'm working through a similar retrofit on a C6 2010 Avant. MMI 3G+ is from a 2014 D4? A8 (CP removed by independent tech) and center control panel is from a 2013 4L Q7.
MMI will not respond to the original 3G control panel or the 3G+ panel from donor Q7. I can do the 3-button reset but only with the original 3G panel. As far as I can tell I have enabled the green menu and updated the MMI options to match what is installed on my A6, as well as updated the baud rate with byte 14 bit 5. None of the lights on the control panel come on at any point. (either panel)
The MMI screen is frozen on the A8 driving mode menu and audio is coming from satellite radio (STUCK ON RAP STATION DEAR LORD HELP ME)
Here is my auto scan after the updates I've done. Not sure what to try next, any help is appreciated.
**note I think some of the faults are due to my battery needing to be replaced.
Tuesday,31,March,2020,22:54:18:58743
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WAU4GBFBXAN045143   License Plate: CPTNSLW
Mileage: 147230km-91484mi   Repair Order: 03
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 6D 72
VIN: WAU4GBFBXAN045143   Mileage: 147230km-91484miles
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0020
   Revision: --H06---    Serial number:
   Coding: 010D000A190F0120
   VCID: A40444E3673E08A6C6-80F0
053256 - Please Check DTC Memory in CAN Gateway (J533)
               U1008 - 000 -
                    Fault Status: 01101000
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:49:11
                    RPM: 800 /min
                    Mass Air / Rev.: 114.5 mg/str
                    Temperature: 31.5∞C
                    Bin. Bits: 00000010
                    Load: 12.2 %
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:55:20
                    RPM: 896 /min
                    Mass Air / Rev.: 81.8 mg/str
                    Temperature: 67.5∞C
                    Bin. Bits: 00000010
                    Voltage: 8.87 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow
                    Fault Status: 01100010
                    Mileage: 147235 km
                    Date: 2020.03.31
                    Time: 22:50:08
                    RPM: 768 /min
                    Mass Air / Rev.: 87.2 mg/str
                    Temperature: 72.0∞C
                    Bin. Bits: 00000010
                    Load: 8.6 %
Readiness: 1110 0101
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0020
   Revision: --H05---    Serial number:        4560765
   Shop #: WSC 41184 001 1048576
   VCID: AA18AADB051ADED6FC-80FE
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: EE9066CBF972F2F660-80BA
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501435678
   Coding: 0000135
   Shop #: WSC 02324 785 00200
   VCID: A50259E76C04F1AED1-80F0
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 335 B
   Component: FBSAUDIC6 KSG   H03 0020
                    Reset counter: 235
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:55:16
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Revision: 00000074    Serial number: 00000000687979
   Coding: 0524582
   VCID: 9D7271074454396E89-80C8
01844 - Control Module for Fresh Air Blower (J126)
                    Reset counter: 235
                    Mileage: 147235 km
                    Date: 2020.03.27
                    Time: 14:49:09
                    Temperature: 11.0∞C
                    (no units): 30.0
                    (no units): 215.0
   Part No SW: 4F0 910 279 M    HW: 4F0 907 279 A
   Component: ILM Fahrer      H22 0320
   Coding: 0139123
   VCID: B326B7BFD2D09F1E4F-80E6
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 235
                    Mileage: 147232 km
                    Date: 2020.03.30
                    Time: 23:54:00
00532 - Supply Voltage B+
                    Reset counter: 235
                    Mileage: 147232 km
                    Date: 2020.03.30
                    Time: 23:55:00
   Revision: AA001001
   VCID: 956269277C64612E41-80C0
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA0013YUA
   Coding: 303142373034303030324A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: B6208EAB09A28A3668-80E2
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000003CTX
   Serial number: 3574SRB40000A21D11A+
   Serial number: 3584SRB40000A340622V
   Serial number: 3516HRB402J9KI9ISKMO
   Serial number: 3526HRB402T9LBCGU4C6
   Serial number: 3554NRB400005217DCC5
   Serial number: 3564NRB4000052B063AY
13635840 - Supply voltage
          [Powersupply  lower threshold fall short of]
                    Reset counter: 235
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:55:32
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90055093140014
   Coding: 0012342
   VCID: A71E53EF1608E3BEE3-80F2
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H08 0144
   Revision: 00100000    Serial number: CN406ELC9
   Coding: 8BD612050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: B12ABDB7E8CCAD0E3D-80E4
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L09B068181
   Coding: 000303
   VCID: B93A859730BC654E85-80EC
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790803328
02252 - Generator
                    Fault Status: 00100011
                    Reset counter: 236
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:41:55
                    Bin. Bits:    11111
                    Voltage: 10.50 V
                    Count: 7
02252 - Generator
                    Fault Status: 00101100
                    Reset counter: 236
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:41:55
                    Bin. Bits:    11111
                    Voltage: 10.50 V
                    Count: 7
                    Fault Frequency: 7
                    Reset counter: 235
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:56:24
                    Bin. Bits:    11000
                    Voltage: 9.50 V
                    Count: 18
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010033638
   Coding: 00581B00004011110000
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102348829
   Coding: 011F57204E40410001
   VCID: C6C0FE6B71421AB6F8-8092
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01238052570000
   Coding: 7764509
   VCID: B228B2BB2DCA961644-80E6
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000049144
   Coding: 05010000
   VCID: A91A55D7C01CD5CEF5-80FC
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000506    Serial number: 00005061084500
   Coding: 0623301
   VCID: A20842FB7D2A0696B4-80F6
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000534329
   Coding: 0002014
   VCID: DEF0360B09D26276D0-808A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102365237
   VCID: C5C2F9674C4411AEF1-8090
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: A10A4DF7782C1D8EAD-80F4
02443 - Control Head
                    Fault Status: 00111100
                    Fault Frequency: 46
                    Reset counter: 235
                    Mileage: 147232 km
                    Date: 2020.03.27
                    Time: 14:45:33
                    Voltage: 10.46 V
                    Count: 40
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000026
   VCID: E99A15D7C09C15CE35-80BC
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335KZ097540373
   Coding: 020000010000000000
   VCID: 9D7271078454396E89-80C8
                    Reset counter: 235
                    Mileage: 147235 km
                    Date: 2020.03.30
                    Time: 23:56:10
                    Voltage: 9.30 V
   Part No SW: 4H0 035 746 E    HW: 4H0 035 746 C
   Component: H-BNT-NA      H50 0622
   Revision: --------    Serial number: 183BY0D7506544
   Coding: 020200010002E1EE4112831E00000403140001000000000000
   Shop #: WSC 02391 785 00200
   VCID: AA18AADBC51ADED6FC-80FE
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356KH091130021
   Subsystem 3 - Part No: 8R0 060 961 E
   Component: CD-Database  4949
8 Faults Found:
                    Reset counter: 194
                    Mileage: 147167 km
                    Date: 2020.03.24
                    Time: 15:51:24
                    Text: DU9356,Front,M,0,0,5
00384 - Optical Databus
                    Reset counter: 235
                    Mileage: 147167 km
                    Date: 2020.03.24
                    Time: 16:32:17
                    Voltage: 13.30 V
                    Reset counter: 194
                    Mileage: 147167 km
                    Date: 2020.03.24
                    Time: 15:51:28
                    Voltage: 13.10 V
                    Reset counter: 195
                    Time Indication: 15
                    Voltage: 10.80 V
                    Bin. Bits:      111
                    Fault Frequency: 21
                    Reset counter: 236
                    Mileage: 147235 km
                    Date: 2020.03.31
                    Time: 22:51:03
                    Bin. Bits: 00110011 10000010
                    Bin. Bits: 00000000 00010001
01043 - Control Module; Incorrect Software Version
                    Reset counter: 194
                    Mileage: 147167 km
                    Date: 2020.03.24
                    Time: 15:51:26
                    Bin. Bits: 10000000 00000000
                    Bin. Bits: 00000000 00000010
01524 - Antenna for Telephone
                    Reset counter: 194
                    Mileage: 147167 km
                    Date: 2020.03.24
                    Time: 15:51:35
                    Voltage: 13.00 V
                    Reset counter: 194
                    Mileage: 147167 km
                    Date: 2020.03.24
                    Time: 15:52:01
                    Bin. Bits: 00001000 00000000
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000102379026
   Coding: 010E57204040220001
   VCID: C3C6E77F42702F9EDF-8096
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Component: J772__Rearview      0030
   Revision: --H03---    Serial number: 525PA8-J9Y21HR
   Coding: 1000305
   Part No SW: 4F9 910 591     HW: 4F9 827 851 G
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: E5030000B
   VCID: EC946CC3CF6E00E64E-80B8
   Subsystem 3 - Serial number: RD23.11.09--H29001001B0190ˇ
   Subsystem 4 - Serial number: 1B0190ˇ
   Revision:             Serial number: 0000102378995
End----(Elapsed Time: 02:26, VBatt start/end: 11.0V/11.1V. VIgn 11.1V)-----
pploeser
C?ID=401051
I replaced the battery today and cleared all voltage related faults. Coded new battery (non OEM) by incrementing existing serial number. *shrug*
I'm down to 6 faults (from 8) on the 5F control panel now. Is this some kind of firmware issue? Not sure if there are different versions for this panel and/or if it can be updated. Still no response at all from the new panel. Old panel can still do the 3-button MMI reset, but nothing else.
Wednesday,01,April,2020,20:16:21:58743
Mileage: 147240km-91490mi   Repair Order: 01
          56 5F 62 6C 6D 72
VIN: WAU4GBFBXAN045143   Mileage: 147240km-91490miles
Readiness: 1110 1101
   Coding: 0020921
   Coding: 0000135
   Coding: 0524582
   Coding: 0139123
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Revision: AA001001
   Coding: 0012342
   Coding: 8BD712050B00CF05020201
   Coding: 000303
   Coding: 7764509
   Coding: 05010000
   Coding: 0623301
   Coding: 0002014
   Revision: --H05---
   Coding: 0000222
   Coding: 0000026
                    Reset counter: 197
                    Mileage: 147241 km
                    Date: 2009.06.02
                    Time: 09:06:21
                    Reset counter: 197
                    Mileage: 147241 km
                    Date: 2009.06.02
                    Time: 09:06:20
                    Voltage: 14.50 V
                    Fault Frequency: 7
                    Reset counter: 197
                    Mileage: 147241 km
                    Date: 2009.06.02
                    Time: 09:06:34
                    Bin. Bits: 00110011 00000010
                    Reset counter: 197
                    Mileage: 147241 km
                    Date: 2009.06.02
                    Time: 09:06:23
                    Reset counter: 197
                    Mileage: 147241 km
                    Date: 2009.06.02
                    Time: 09:06:31
                    Voltage: 14.50 V
                    Reset counter: 197
                    Mileage: 147241 km
                    Date: 2009.06.02
                    Time: 09:06:31
   Coding: 1000305
End----------(Elapsed Time: 01:59, VBatt start/end: 14.6V/14.4V)-----------
pploeser
C?ID=401051
I also noticed that the LEDs on the new panel very dimly flash periodically. Not sure if this provides any other clues. I captured a short video clip (viewing the circuit board below the buttons):
pploeser
C?ID=401051
Finally got my original control panel to talk to the new MMI unit.
I ended up scanning my wife’s 2015 Q7 to see the long coding on hers. We had different values in byte 14 so I changed mine to match what hers had and did a reset via the control panel and now it’s working.
I guess I did the baud rate change incorrectly. Don’t understand that one but very fortunate for me I had a working vehicle to scan.
I still have some settings to update but we’re making progress. Will do another scan to make sure all faults have been cleared.
