Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: MMI 3G+ 5F control panel baud rate coding
    Mar 2020
    Hey guys, I'm working through a similar retrofit on a C6 2010 Avant. MMI 3G+ is from a 2014 D4? A8 (CP removed by independent tech) and center control panel is from a 2013 4L Q7.
    MMI will not respond to the original 3G control panel or the 3G+ panel from donor Q7. I can do the 3-button reset but only with the original 3G panel. As far as I can tell I have enabled the green menu and updated the MMI options to match what is installed on my A6, as well as updated the baud rate with byte 14 bit 5. None of the lights on the control panel come on at any point. (either panel)
    The MMI screen is frozen on the A8 driving mode menu and audio is coming from satellite radio (STUCK ON RAP STATION DEAR LORD HELP ME)
    Here is my auto scan after the updates I've done. Not sure what to try next, any help is appreciated.
    **note I think some of the faults are due to my battery needing to be replaced.
    Tuesday,31,March,2020,22:54:18:58743
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAU4GBFBXAN045143   License Plate: CPTNSLW
    Mileage: 147230km-91484mi   Repair Order: 03
    Chassis Type: FB-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
              56 5F 62 6C 6D 72
    VIN: WAU4GBFBXAN045143   Mileage: 147230km-91484miles
    Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4F1 910 551 D    HW: 4F1 907 551
       Component: 3.0l V6 TFSI        0020
       Revision: --H06---    Serial number:
       Coding: 010D000A190F0120
       Shop #: WSC 02325 785 00200
       VCID: A40444E3673E08A6C6-80F0
    053256 - Please Check DTC Memory in CAN Gateway (J533)
                   U1008 - 000 -
                        Fault Status: 01101000
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:49:11
                        RPM: 800 /min
                        Mass Air / Rev.: 114.5 mg/str
                        Temperature: 31.5∞C
                        Bin. Bits: 00000010
                        Load: 12.2 %
    001378 - System Voltage
                   P0562 - 000 - Too Low - Intermittent
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:55:20
                        RPM: 896 /min
                        Mass Air / Rev.: 81.8 mg/str
                        Temperature: 67.5∞C
                        Bin. Bits: 00000010
                        Voltage: 8.87 V
    001089 - EVAP Emission Control Sys
                   P0441 - 000 - Incorrect Flow
                        Fault Status: 01100010
                        Mileage: 147235 km
                        Date: 2020.03.31
                        Time: 22:50:08
                        RPM: 768 /min
                        Mass Air / Rev.: 87.2 mg/str
                        Temperature: 72.0∞C
                        Bin. Bits: 00000010
                        Load: 8.6 %
    Readiness: 1110 0101
       Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
       Component: AG6 09L 3,0TFSI USA 0020
       Revision: --H05---    Serial number:        4560765
       Shop #: WSC 41184 001 1048576
       VCID: AA18AADB051ADED6FC-80FE
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
       Component: ESP8 quattro    H03 0060
       Coding: 0020921
       VCID: EE9066CBF972F2F660-80BA
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602501435678
       Coding: 0000135
       Shop #: WSC 02324 785 00200
       VCID: A50259E76C04F1AED1-80F0
       Subsystem 1 - Part No: 4F0 910 132 L
       Component: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Part No: 4F0 910 335 B
       Component: FBSAUDIC6 KSG   H03 0020
                        Reset counter: 235
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:55:16
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000074    Serial number: 00000000687979
       Coding: 0524582
       VCID: 9D7271074454396E89-80C8
    01844 - Control Module for Fresh Air Blower (J126)
                        Reset counter: 235
                        Mileage: 147235 km
                        Date: 2020.03.27
                        Time: 14:49:09
                        Temperature: 11.0∞C
                        (no units): 30.0
                        (no units): 215.0
       Part No SW: 4F0 910 279 M    HW: 4F0 907 279 A
       Component: ILM Fahrer      H22 0320
       Coding: 0139123
       Shop #: WSC 02335 785 00200
       VCID: B326B7BFD2D09F1E4F-80E6
       Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
                        Reset counter: 235
                        Mileage: 147232 km
                        Date: 2020.03.30
                        Time: 23:54:00
    00532 - Supply Voltage B+
                        Reset counter: 235
                        Mileage: 147232 km
                        Date: 2020.03.30
                        Time: 23:55:00
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4F0 035 110 A    HW: 4F0 035 110
       Component: CDC-MP3-Alp   H44 0140
       Revision: AA001001
       VCID: 956269277C64612E41-80C0
    Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
       Component: Airbag AU1042 H06 0160
       Revision: --------    Serial number: 003FA0013YUA
       Coding: 303142373034303030324A55304C34463053
       ROD: EV_Airba10AURB4.rod
       VCID: B6208EAB09A28A3668-80E2
       Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
       Component: BF-Gewichtss.  H03 0060
       Serial number: 5810000R0000003CTX
       Serial number: 3574SRB40000A21D11A+
       Serial number: 3584SRB40000A340622V
       Serial number: 3516HRB402J9KI9ISKMO
       Serial number: 3526HRB402T9LBCGU4C6
       Serial number: 3554NRB400005217DCC5
       Serial number: 3564NRB4000052B063AY
    13635840 - Supply voltage
              [Powersupply  lower threshold fall short of]
                        Reset counter: 235
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:55:32
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
       Component: J0527               0530
       Revision: 00H06000    Serial number: 90055093140014
       Coding: 0012342
       VCID: A71E53EF1608E3BEE3-80F2
       Component: E0221           H02 0030
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
       Component: KOMBIINSTR.   H08 0144
       Revision: 00100000    Serial number: CN406ELC9
       Coding: 8BD612050B00CF05020201
       Shop #: WSC 02391 823 56573
       VCID: B12ABDB7E8CCAD0E3D-80E4
       Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0035
       Revision: LB100029    Serial number: 2900L09B068181
       Coding: 000303
       VCID: B93A859730BC654E85-80EC
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790803328
    02252 - Generator
                        Fault Status: 00100011
                        Reset counter: 236
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:41:55
                        Bin. Bits:    11111
                        Voltage: 10.50 V
                        Count: 7
    02252 - Generator
                        Fault Status: 00101100
                        Reset counter: 236
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:41:55
                        Bin. Bits:    11111
                        Voltage: 10.50 V
                        Count: 7
                        Fault Frequency: 7
                        Reset counter: 235
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:56:24
                        Bin. Bits:    11000
                        Voltage: 9.50 V
                        Count: 18
       Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
       Component: MEM-FS        H08 0062
       Revision: AA000000    Serial number: 00001010033638
       Coding: 00581B00004011110000
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000102348829
       Coding: 011F57204E40410001
       VCID: C6C0FE6B71421AB6F8-8092
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
       Component: Komfortgeraet   H27 0220
       Revision: 02200027    Serial number: 01238052570000
       Coding: 7764509
       VCID: B228B2BB2DCA961644-80E6
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
       Component: BOSE G3 C6    H01 0100
       Revision: AG001300    Serial number: 00000000049144
       Coding: 05010000
       VCID: A91A55D7C01CD5CEF5-80FC
    Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
       Part No SW: 4F0 910 274 A    HW: 4F0 907 274
       Component: J793  RKA+      H02 0100
       Revision: 00000506    Serial number: 00005061084500
       Coding: 0623301
       VCID: A20842FB7D2A0696B4-80F6
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000534329
       Coding: 0002014
       VCID: DEF0360B09D26276D0-808A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000102365237
       VCID: C5C2F9674C4411AEF1-8090
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000222
       Shop #: WSC 02145 785 00200
       VCID: A10A4DF7782C1D8EAD-80F4
    02443 - Control Head
                        Fault Status: 00111100
                        Fault Frequency: 46
                        Reset counter: 235
                        Mileage: 147232 km
                        Date: 2020.03.27
                        Time: 14:45:33
                        Voltage: 10.46 V
                        Count: 40
       Part No SW: 4L0 910 357     HW: 4L0 907 357
       Component: AFS 1           H01 0060
       Coding: 0000026
       VCID: E99A15D7C09C15CE35-80BC
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H01 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335KZ097540373
       Coding: 020000010000000000
       VCID: 9D7271078454396E89-80C8
                        Reset counter: 235
                        Mileage: 147235 km
                        Date: 2020.03.30
                        Time: 23:56:10
                        Voltage: 9.30 V
       Part No SW: 4H0 035 746 E    HW: 4H0 035 746 C
       Component: H-BNT-NA      H50 0622
       Revision: --------    Serial number: 183BY0D7506544
       Coding: 020200010002E1EE4112831E00000403140001000000000000
       Shop #: WSC 02391 785 00200
       VCID: AA18AADBC51ADED6FC-80FE
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356KH091130021
       Subsystem 3 - Part No: 8R0 060 961 E
       Component: CD-Database  4949
    8 Faults Found:
                        Reset counter: 194
                        Mileage: 147167 km
                        Date: 2020.03.24
                        Time: 15:51:24
                        Text: DU9356,Front,M,0,0,5
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 235
                        Mileage: 147167 km
                        Date: 2020.03.24
                        Time: 16:32:17
                        Voltage: 13.30 V
    00658 - Control Head
                        Reset counter: 194
                        Mileage: 147167 km
                        Date: 2020.03.24
                        Time: 15:51:28
                        Voltage: 13.10 V
                        Fault Status: 01101100
                        Reset counter: 195
                        Time Indication: 15
                        Voltage: 10.80 V
                        Bin. Bits:      111
                        Fault Frequency: 21
                        Reset counter: 236
                        Mileage: 147235 km
                        Date: 2020.03.31
                        Time: 22:51:03
                        Bin. Bits: 00110011 10000010
                        Bin. Bits: 00000000 00010001
                        Bin. Bits: 00000000 00000000
    01043 - Control Module; Incorrect Software Version
                        Reset counter: 194
                        Mileage: 147167 km
                        Date: 2020.03.24
                        Time: 15:51:26
                        Bin. Bits: 10000000 00000000
                        Bin. Bits: 00000000 00000010
    01524 - Antenna for Telephone
                        Fault Status: 01101011
                        Reset counter: 194
                        Mileage: 147167 km
                        Date: 2020.03.24
                        Time: 15:51:35
                        Voltage: 13.00 V
                        Reset counter: 194
                        Mileage: 147167 km
                        Date: 2020.03.24
                        Time: 15:52:01
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00001000
       Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
       Revision:             Serial number: 0000102379026
       Coding: 010E57204040220001
       VCID: C3C6E77F42702F9EDF-8096
       Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
       Component: J772__Rearview      0030
       Revision: --H03---    Serial number: 525PA8-J9Y21HR
       Coding: 1000305
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 G
       Component: ValeoHeckdeckel H29 0410
       Revision: --H29001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: EC946CC3CF6E00E64E-80B8
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: RD23.11.09--H29001001B0190ˇ
       Subsystem 4 - Serial number: 1B0190ˇ
       Revision:             Serial number: 0000102378995
    End----(Elapsed Time: 02:26, VBatt start/end: 11.0V/11.1V. VIgn 11.1V)-----
  2. #12
    Mar 2020
    I replaced the battery today and cleared all voltage related faults. Coded new battery (non OEM) by incrementing existing serial number. *shrug*
    I'm down to 6 faults (from 8) on the 5F control panel now. Is this some kind of firmware issue? Not sure if there are different versions for this panel and/or if it can be updated. Still no response at all from the new panel. Old panel can still do the 3-button MMI reset, but nothing else.
    Wednesday,01,April,2020,20:16:21:58743
    Mileage: 147240km-91490mi   Repair Order: 01
              56 5F 62 6C 6D 72
    VIN: WAU4GBFBXAN045143   Mileage: 147240km-91490miles
    Readiness: 1110 1101
       Coding: 0020921
       Coding: 0000135
       Coding: 0524582
       Coding: 0139123
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
       Revision: AA001001
       Coding: 0012342
       Coding: 8BD712050B00CF05020201
       Coding: 000303
       Coding: 7764509
       Coding: 05010000
       Coding: 0623301
       Coding: 0002014
       Revision: --H05---
       Coding: 0000222
       Coding: 0000026
                        Reset counter: 197
                        Mileage: 147241 km
                        Date: 2009.06.02
                        Time: 09:06:21
                        Reset counter: 197
                        Mileage: 147241 km
                        Date: 2009.06.02
                        Time: 09:06:20
                        Voltage: 14.50 V
                        Fault Frequency: 7
                        Reset counter: 197
                        Mileage: 147241 km
                        Date: 2009.06.02
                        Time: 09:06:34
                        Bin. Bits: 00110011 00000010
                        Reset counter: 197
                        Mileage: 147241 km
                        Date: 2009.06.02
                        Time: 09:06:23
                        Reset counter: 197
                        Mileage: 147241 km
                        Date: 2009.06.02
                        Time: 09:06:31
                        Voltage: 14.50 V
                        Reset counter: 197
                        Mileage: 147241 km
                        Date: 2009.06.02
                        Time: 09:06:31
       Coding: 1000305
    End----------(Elapsed Time: 01:59, VBatt start/end: 14.6V/14.4V)-----------
  3. #13
    Mar 2020
    I also noticed that the LEDs on the new panel very dimly flash periodically. Not sure if this provides any other clues. I captured a short video clip (viewing the circuit board below the buttons):
  4. #14
    Mar 2020
    Finally got my original control panel to talk to the new MMI unit.
    I ended up scanning my wife’s 2015 Q7 to see the long coding on hers. We had different values in byte 14 so I changed mine to match what hers had and did a reset via the control panel and now it’s working.
    I guess I did the baud rate change incorrectly. Don’t understand that one but very fortunate for me I had a working vehicle to scan.
    I still have some settings to update but we’re making progress. Will do another scan to make sure all faults have been cleared.
  5. Likes Uwe liked this post
