Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 2015 Golf MK7 TDI Sportwagen heated seats retrofit...
    Sep 2018
    The BCM module I bought is a 5Q0-937-087-S-Z00
    Here is my auto scan...
    Tuesday,08,January,2019,23:27:53:61936
    VCDS Version: 18.9.0.2 (x64)
    VIN: 3VWCA7AU5FM5XXXXX   License Plate: NOTODAY
    Mileage: 58021km-36052mi   Repair Order: 1
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
    VIN: 3VWCA7AU5FM5XXXXX   Mileage: 58021km-36052miles
    Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 D    HW: 04L 907 309
       Component: R4 2.0l TDI   H23 9283
       Revision: 85H23---
       Coding: 011D0012032410081000
       Shop #: WSC 36151 003 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021D 004017
       ROD: EV_ECM20TDI01104L906021D_004.rod
       VCID: 2643EF7B5916FD7A8F-8072
    Readiness: 0 0 0 1 1
       Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4512
       Revision: 05853104    Serial number: TFK01501051455
       Shop #: WSC 00066 790 00202
       ROD: EV_TCMDQ250021.rod
       VCID: 2345F66F2A240852E8-8076
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 50115000001486
       Coding: 04FA6AA12420096F007D020381C32520562490004081A4B200630050C002
       Shop #: WSC 01383 790 50316
       VCID: 479D42FFFE5C047254-8012
       Revision: 00021000    Serial number: 0357606012
       Coding: 030C0C
       VCID: 3A7B2B0BBDAE699ADB-806E
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Revision: 00001K01
       Coding: 02020104200100000000000000000000
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 050188F784D0D662E6-8050
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86581201151521
       Coding: 000118424041804169E44000000403001800000000000000000000000000
       Shop #: WSC 00066 790 00082
       ROD: EV_BCMBOSCH_014.rod
       VCID: 499944C7E848F20242-801C
       Component: WWS    140902  043 0581
       Serial number:         150224221522
       Serial number: 003GCR016CTK
       ROD: EV_AirbaVW20SMEVW37X.rod
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J150002C9HR09
       Coding: 303138
       Subsystem 2 - Part No SW: -----------    HW: 480 001 912 14
       Serial number: 357000000003E3751218
       Subsystem 3 - Part No SW: -----------    HW: 480 000 601 15
       Serial number: 35800000000386B4721F
       Subsystem 4 - Part No SW: -----------    HW: 480 400 601 15
       Serial number: 3510002B5196FF6532DG
       Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
       Serial number: 352000299188FC126344
       Subsystem 6 - Part No SW: -----------    HW: 480 401 612 14
       Serial number: 3550002A1196FF6491DJ
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 612 14
       Serial number: 35600029F196FF60E23P
       Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150113500232
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 040795F38FEAEF6AF1-8050
       Part No SW: 5G1 920 841     HW: 5G1 920 841
       Component: KOMBI         243 4270
       Coding: 0BA4121A2180CF0502086A001000000000000000
       VCID: 65C1A8776490366246-8030
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 18011510001204
       Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07029
       VCID: 71E9CC27A058EAC22A-8024
       Component: E221__MFL-DC1  H16 0101
       Serial number: 27150000258390015071
       Coding: 29FFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0022795
       Revision: 00000000    Serial number: 15000012285004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346705339FCA9FEA01-8060
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 0602150605083K
       Coding: 003013200000040000000000
       VCID: 3E73271BA18645BAE7-806A
       Serial number: 00000000000000422528
       Coding: 011000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 438556EFCA64285288-8016
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 060215060508WF
       VCID: 3D712017AC805EA2FE-8068
       Serial number: 00000000000000611382
       Coding: 091000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B01501153354
       Coding: 02730200FF00000021220001001800001F0100140100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64C7B5736FAA4F6A51-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS5018GT
    0007 - Connection between Antenna Amp 1 for Radio and Antenna
              B1272 13 [009] - Open Circuit
                        Reset counter: 1
                        Mileage: 58021 km
                        Date: 2019.01.09
                        Time: 00:23:12
                        Voltage terminal 30: 14.3 V
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Open circuit
                        Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2821A017F1E06000000
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB.rod
    End-------------------------(Elapsed Time: 03:42)--------------------------
  2. #12
    Apr 2018
    ITALY
    I definitely forgot about this, please forgive me. here's a screenshot from ETKA:
    https://www.dropbox.com/s/xnb1wjpwedm9joh/ETKA0003.PNG
    as you can see, the S BCM is "also to be used for" Q and R.
    variant Z0S is for PR code QQ0 "without add. lights (interior lighting)"
    variant Z0T is for PR code QQ3 "interior ambient lighting and surround lighting"
    both variants were superseded in 2016 by variant Z0W, so long story short, you need 5Q0 937 087 S Z0W. don't worry, I believe Z00 is ok too, maybe my ETKA is not 100% accurate because it doesn't have online access.
    I also checked the AC panel, even if we didn't talk about it. you need 5GM 907 426 A WZU, hope you got that. here's a screenshot.
    https://www.dropbox.com/s/pr1enz0hywh64r5/ETKA0004.PNG
    let me know if you need anything else.
  3. Likes Uwe liked this post
  4. #13
    Sep 2018
    No worries at all! Thank you for your help!
    I think based on what the dealer told me that Z00 superseded the other model numbers so it does sound like I have the correct part luckily. Now I just need help figuring out the steps needed to swap the BCM modules with VAG-COM and or dealer tools.
    I have that exact part.
    Right now it seems as if I have all of the correct parts, just not the knowledge on how to code them to my car. Do you have any guidance on that?
  5. #14
    Apr 2018
    ITALY
    full car backup and AC panel swap was discussed at the beginning. do that first, it's easy.
    go on youtube and find a video to understand how to remove the level that opens the hood. you'll never figure it out by yourself but once you see (and you do it once), it's easy. then you need to gain physical access to the BCM, it won't be very easy if you never did it before, and I don't really know how to detail it, try googling it, there might be videos on youtube. it's tight as hell, that is for sure.
    1) disconnect the battery. if that was not clear, DISCONNECT THE BATTERY;
    2) unplug the three BCM connectors. they all have a lever that needs to go top to bottom, but it won't move before pushing a small latch. the center connector has to travel outside and then down in the white plastic rails;
    3) BCM can come out now, you need to swivel the bottom out of its holder, then BCM comes down vertically. yes, it's tight.
    CHECK IF YOU HAVE WIRES IN THESE POSITIONS: 1, 2, 5 of connector A and 40, 43, 56 of connector C.
    4) basically reverse the procedure and put in the new BCM. you are allowed to swear
    5) re-connect the three plugs, do not swap A with C. I don't think the wires are long enough anyway.
    6) connect battery. as soon as you switch the ignition on, CP will kick in.
    7) set Long Coding of old BCM to the new one.
    8) dump admap of new BCM and use WinMerge to compare to the old one. you need to manually set all adaptations to the old values, it will be A LOT, like hundreds. took me more than two hours. it's easier if you have a second computer with WinMerge, and another person that dictates you the adaptation and the value.
    9) when you're finished, cycle ignition (wait a minute) and clear all errors. if you are left with CP errors only (in BCM, and maybe other modules), you're good.
    10) drive to dealer, have CP removed and keyfobs taught. bring them all.
    if you don't have the wires in those six positions, you need to buy the loom and install it. that will be another PITA. do the modules first. do not put back all the dash trims you removed, especially DO NOT PUT BACK the hood level, leave it in the door pocket and use it on the fly if you need to open the hood.
  6. #15
    Sep 2018
    I am good all the way through step 6, but before I do any of it, how do I dump the admap of the old BCM? Is there a video somewhere on that?
    A little confused on what is involved to finish step 8 too. Any walk throughs on this? I have searched but haven't found much.
    Step 10, what do I specifically ask the dealer? Should I know the name of the system they need to use and what steps they need to complete?
  7. #16
    Quote Originally Posted by MK7 View Post
    [Applications]
    [Controller Channel Map]
    Controller Address = 09
    Login or security access code: [Hopefully someone will recommend one]
    Function: Adaptations
    Output: CSV file
    [Go]
    See also:
    http://www.ross-tech.com/vcds/tour/c...annels-map.php
  8. #17
    Apr 2018
    ITALY
    step 6) as Uwe said, do that for EVERY module listed in the autoscan, then save the autoscan as well. that's your car's stock backup. you should already have done that. set all files as read only and make two copies, you never know. ah, security access is not needed when reading admaps.
    step 8) I don't know how to say it easier. WinMerge is a program that will take both admaps and show you the differences. so load the NEW admap on the left and the OLD one on the right. you want to input values on the right.
    something I forgot, it goes between steps 7) and 8). before you set all adaptations to your old values, your lights will all be misconfigured. I mean, when I did it, high beams were on all the time. that can drain the battery fast, so if you notice something similar, pull the light fuse or pull the connector from the headlight. it will trigger faults that will be easily cleared at the end.
    step 10) tell the dealer "I replaced the BCM, I need Component Protection removed and all my keyfobs re-matched, please". if he doesn't know, acknowledge politely and exit. call VW USA and report the dealer for incompetence. go to another dealer. yo buddy, I really don't know what to say :P
  9. #18
    Sep 2018
    I knew going into the whole project that I am in over my head, but I do learn fast. So, thank you so much for your help! I will post back when I find time to start the swap.
    Also, One more question. When I first got the car I changed some settings using VAG-COM regarding door open chimes set to off versus on, seat belt chime disabled by switching some setting to something other than USA. When you mentioned I should do a full backup, I am concerned that I messed up by not doing one before I made those changes. Am I all good since everything is functioning as I would like now before I start the swap?
  10. #19
    Apr 2018
    ITALY
    yes you're fine, that's every newbie's mistake. you just won't have a backup 100% as stock, but if you changed little things there is nothing to worry about.
    for example, I also don't have a full stock backup, but I'll tell you what: any backup I make which has zero errors I consider as safe. actually the last backup is the best for me, it's not like I am gonna remove all the things I retrofitted if I sold the car.
  11. Likes Uwe liked this post
