Hello everybody,
Happy new year for those that already are on 2019!
I just installed a set of OEM bi-xenon headlamps I bought a set that include AFS which I don't have the rest of accessories to use properly (5N1941032T 5N1941031T), I purchased a kufatec wiring adaptor and headlamps are working perfectly but have a persistent DTC indicating a bad high beam bulb, I tried coding to solve it without any luck (coincidentally my horn said good bye to me so disregard that fault as replacements are coming) I remember helping a guy like 5 or 6 years ago with a retrofit exactly like this and I remember he telling me he had to pay a guy to do some BIT coding to be able to solve the DTC's not sure, I also found that some change the Central Electronics module to open up different options with a modern version (which might be a bit too crazy or expensive) but not really sure.
Monday,31,December,2018,15:40:50:22246
VIN: License Plate:
Chassis Type: 5N (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 22 25 42 44 46 52 53 56 62 72 77
VIN: Mileage: 184540km-114667miles
Address 01: Engine (CAW) Labels:. 06J-906-026-CAW.clb
Part No SW: 06J 906 026 CH HW: 06J 906 026 D
Component: MED17.5 4306
Revision: A7H06--- Serial number: VWX7Z0I23NH7XG
Coding: 04230003180F0060
Shop #: WSC 00191 264 15243
VCID: 72BDD92E78AA4FF7981-8026
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction - Intermittent
Fault Frequency: 6
Mileage: 184452 km
Time: 17:14:39
RPM: 2666 /min
Load: 7.1 %
Speed: 53.0 km/h
Temperature: 97.0°C
Temperature: 35.0°C
Absolute Pres.: 840.0 mbar
Voltage: 13.716 V
Readiness: 0100 0101
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000001832503
Coding: 0011530
Shop #: WSC 01324 020 00200
VCID: 392F2E02655CFCAF99B-806C
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FBBD05A6B98621F77F-803A
Revision: 00H54000 Serial number: 00000009480963
Coding: 018C4FB300041C0047190000140000000019FF475C400104420000000000
VCID: 33331C2A473006FF537-8066
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 240309 012 0203
Coding: 00038805
Shop #: WSC 01324
00906 - Horn (H1)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 99
Mileage: 184548 km
Voltage: 12.40 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 99
Mileage: 184548 km
Voltage: 12.40 V
Reset counter: 99
Mileage: 184548 km
Voltage: 12.30 V
Reset counter: 99
Mileage: 184548 km
Voltage: 12.30 V
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E2P5ADP3E
Coding: 0012336
VCID: 44D14FF6129EB147FAD-8010
Subsystem 1 - Serial number: 6332MTS615590609
Subsystem 2 - Serial number: 6342MTS632110609
Subsystem 3 - Serial number: 6351HTS6KCIPV5KR
Subsystem 4 - Serial number: 6361HTS6SPJPV5KJ
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000704
Shop #: WSC 12345 123 12345
VCID: 7AADF10E20DA37B7D01-802E
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
Part No SW: 5N0 920 870 C HW: 5N0 920 870 C
Component: KOMBIINSTRUMENT VDD 2422
Revision: V0005000 Serial number: VWX7Z0I23NH7XG
Coding: 0004104
Shop #: WSC 00241 865 88878
VCID: 30391326B6263DE72E5-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 140309F1001824
Coding: F9827F06001602009002
Shop #: WSC 00865 241 88878
VCID: 372B283A5348EADF6FF-8062
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T4V7Q03
VCID: 7DA7FA1231F4008FF53-8028
Address 22: AWD Labels: None
Part No SW: 563 tun ere l HW: 563 tun ere l
Component: Haldex 4Motion T200
Coding: 0000001
VCID: 1D67DA92D1B4A08F953-8048
Reset counter: 138
Mileage: 184548 km
Time: 15:38:02
Component: IMMO VDD 2422
Part No SW: 5N0 959 701 B HW: 5N0 959 701 B
Component: Tuer-SG 008 2005
Coding: 0000188
VCID: 34311F36423E01C74AD-8060
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.0 0502
Revision: 1AH01263 Serial number: 00082130090802
Coding: 0000258
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Coding: 91800A0052830C7F3F04840D70084FCEF0FC00
VCID: 03538CEA5710767F837-8056
Subsystem 2 - Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
Part No SW: 5N0 959 702 B HW: 5N0 959 702 B
Coding: 0000188
VCID: 35372232494418CF7D3-8060
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 B HW: 5N0 907 801 D
Component: J540 EPB3 VW-09384 0005
Revision: H10 Serial number: 00000000010153
Coding: 0000057
VCID: 2E050D5EAC122B173C9-807A
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 04555GD2221585
Coding: 0000040102000A
Shop #: WSC 00081 790 00123
VCID: 45D752F215A4884FED3-8010
Reset counter: 82
Mileage: 169319 km
Time: 17:46:26
Part No SW: 5N0 959 703 B HW: 5N0 959 703 B
Component: Tuer-SG 007 2001
Coding: 0000144
Shop #: WSC 01324 020 1012552
VCID: 3635253E544213D7749-8062
Part No SW: 5N0 959 704 B HW: 5N0 959 704 B
Coding: 0000144
Address 77: Telephone
End----------(Elapsed Time: 01:19, VBatt start/end: 12.5V/12.5V)-----------
