I have a VW Polo AW which has ambient lighting in the dash and front door cards and the colour is set at white...
I would like to change that to other colours,is this possible?if so what coding is required to do this and also have an option in the 5F (Background Lighting)
https://forums.ross-tech.com/showthread.php?16288-Volkswagen-Polo-5DR-1-0TSI-115-SEL-DSG
Here is a scan
Here is a scan
Saturday,03,November,2018,11:27:52:03210
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
Dealer/Shop Name: VCDS
Workshop Code: 444 03743 000001
VIN: WVWZZZAWZKU007157 License Plate: NEW POLO BEFORE BUYING
Mileage: 34km-21mi Repair Order:
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F CA
VIN: WVWZZZAWZKU007157 Mileage: 34km-21miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKRF) Labels: None
Part No SW: 04C 906 025 M HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6196
Revision: D7H20000
Coding: 0125003223041D080000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10TFS01104C906025M 002003
ROD: EV_ECM10TFS011_AU27.rod
VCID: 2A0D01F4AC7FE1F7E01-807E
Readiness: 0010 0001
Part No SW: 0CW 300 042 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1606
Revision: 00005008 Serial number: CU501806176987
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW27.rod
VCID: 372B28806FCD4C1F6FF-8062
Part No SW: 2Q0 614 517 AD HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0223
Serial number: 08514728180704
Coding: 0A034C64354150B432FDAC1B24E142A649124D26226A242444541254452442659248B26444562424222A482AA251D64A3D8A6B52BC
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
VCID: 70B9D39C4A23DB276E5-8024
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 2G0 907 044 L HW: 2G0 907 044 L
Component: Climatronic H03 0501
Coding: 0121000008000100011008000244010D0000000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004017
ROD: EV_ACClimaBHBMQBA0_VW27.rod
VCID: 2D070AE89D91F6CF053-8078
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 090 A HW: 2Q0 937 090
Component: BCM A0 Std+ H98 0926
Serial number: 00001817500231
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204.rod
VCID: 3039139C8AA39B272E5-8064
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SAY18M07D11H03M24S29
Coding: 0038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 2Q2 959 881 D HW: 2Q2 959 881 D
Component: FHSG_DRV 001 0002
Serial number: 00000000000021749146
Coding: 1F0037
Subsystem 3 - Part No SW: 2Q2 959 882 D HW: 2Q2 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000021753752
Coding: 058037
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY181501S2X
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099190056
Subsystem 6 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000022454493
Coding: 1F0000
Subsystem 7 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000022520572
Coding: 070000
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Serial number: 000308418018181
Coding: 0471051011
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 4CC1676C064BDFC732D-8018
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 3200600240FF8748949C8145004087
VCID: 3E253DA440F77D57AC9-806A
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
Component: VW22Airbag 010 0248
Revision: --------
Coding: 88CCC0C0000000005C5400CF008800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 025D8954748FD9B7881-8056
Subsystem 1 - Part No SW: ----------- HW: 442 061 207 18
Serial number: 3577Y20B127578D2E47A
Subsystem 2 - Part No SW: ----------- HW: 442 061 207 18
Serial number: 3587Y20B127578D3D235
Subsystem 3 - Part No SW: ----------- HW: 442 0B0 707 18
Component: SideSensor_Dr 1C7 0148
Serial number: 351778299293EDC5510T
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 707 18
Serial number: 35277829B293EDC3E465
Subsystem 5 - Part No SW: ----------- HW: 442 132 705 18
Component: FrontSensor_D 290 118A
Serial number: 355AG11B5298CB11C69%
Part No SW: 2G0 920 940 B HW: 2G0 920 940 B
Component: KOMBI 310 2500
Coding: 24A4010821802600018862011001000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001029
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 2313ECD0CB5530BFA37-8076
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Serial number: 14061811602488
Coding: 030100046F085600FA0002481C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 3D273AA84DF1664FB53-8068
Component: 1-00-02-00-04
Subsystem 2 - Part No SW: 2G0 959 442 K HW: 2G0 959 442 K
Component: E221__MFL-DC1 H02 0052
Serial number: 39170002831130077484
Coding: 25FFFF
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 10088840
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q2 909 144 J HW: 2Q2 909 144 F
Component: TRW_G4L_MQBA0 620 6030
Serial number: 0646183CB4J1942
Coding: 00000000000000000101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
VCID: 3A2D31B45CDF5177901-806E
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0890
Coding: 02720001BE00000041110101008808001F0500C601200100CF
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 323D199484AFA937581-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV1564256
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 508000727001
VCID: 3B2334B053E5687F8B7-806E
End----------(Elapsed Time: 01:18, VBatt start/end: 12.2V/12.1V)-----------
