Results 1 to 10 of 19
Thread: 7L6 Touareg disable engine power retardation and RNS510 media system starting
    Jul 2016
    UAE
    Two issues I'm stuck on with on my Touareg:
    1: I don't know the coding table for the ABS/ESP stability control to disable the electronic power retardation feature in the ESP ALLRAD MK25E1 module. It's still originally coded 0008450.
    Even with ESP disabled and centre lock locked, I'm still getting power delivery intervention in times of high power requirements. Pulling a trailer though sand I need wheel spin and power to the ground, electronic lateral differential lock intervention is manageable, but the power retardation isn't, all momentum is suddenly lost in this instance. I can crudely disable ABS with the fuse removal, but this also disables the centre lock.
    2: The RNS510 is sticking on System Starting on the Media page, and is failing to boot the navigation map. After an hour or so or runtime, a three key < > * reboot has everything return to normal operation.
    Do I have anything miscoded that isn't showing? There's no fault codes, also swapping the bluetooth modules and reinstalling the firmware 5238 has not improved this situation. I have a 3C8 035 730E bluetooth module installed, it works perfectly and is also wired for stereo music streaming, the Touareg Can Gateway just cannot communicate with it, so I use my Golf's gateway to communicate, but this bluetooth module was installed and used before this System Starting issue. It's also coded with the wifi off.
    Thanks for any help, also the door malfunctions below were just because I'd removed and reinstalled the doors.
    #hndoc:?docid=00004789&xt=hnh:A0BFF2B51478F5F80BF340B3682EBFF85A9D05DE2E44E676811088FF915713C6
    VCDS Mobile 0.4436.0.4
    VIN: WVGAM27LX9D001159
    Scan: 01 02 03 05 06 08 09 15 16 17 19 22 28 36 37 3C 46 47 55 56
    	 68 69 6C 6D 76 77
    68-Wiper Electr. -- Status: OK 0000
    Address 01: Engine	Labels: 079-907-560-BAR.clb
    	Part No SW: 7L0 907 560 C	HW: 7L0907560
    	Component: 4.2l V8/4V           0050
    	Revision: 75H05---	Serial Number: VWX3Z0H3757642
    	Coding: 04210010590F0960
    	Shop #: WSC 31414 790 00001
    	VCID: 312586C7F24E4B4566FC4A-5184
    No fault codes found.
    Address 02: Auto Trans	Labels: 09D-927-750.lbl
    	Part No SW: 09D 927 750 HF	HW: 09D927750HF
    	Component: AL 750 6A            1409
    	Revision: 00H75000	Serial Number:
    	Coding: 0004458
    	VCID: 79B57EE76ABE43059EAC62-5160
    Address 03: ABS Brakes	Labels: 7L0-907-379-MK25E1.clb
    	Part No SW: 7L0 907 379 L	HW: 7L0907379L
    	Component: ESP ALLRAD MK25E1    0303
    	Revision: 00H53001
    	Coding: 0008450
    	VCID: 42C7D90B47E8C5DD8F868D-8017
    Address 05: Acc/Start Auth.	Labels: 3D0-909-13x-05.lbl
    	Part No SW: 3D0 909 137 F	HW: 3D0909137F
    	Component: 23 Kessy             6850
    	Revision: 00H22070	Serial Number: VWX3Z0H3757642
    	Coding: 0147688
    	VCID: 2A1791ABDF983D9DA7B685-807F
    	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
    	Component: ELV                  XXXX
    Address 06: Seat Mem. Pass	Labels: None
    	Part No SW: 7L0 959 760
    	Component: Sitzverstellung      0701
    	VCID: F7B1F8DFDCAAD07568B8F4-80A2
    Address 08: Auto HVAC	Labels: 7L6-907-044.clb
    	Part No SW: 7L6 907 044 AF
    	Component: CLIMAtronic 2+2      4331
    	Coding: 0021020
    	VCID: 78B37BE351B45F0DE1A27F-802D
    	Subsystem 1 - 	Part No SW: 7L6-907-049-F
    	Component: CLIMAtronic FOND     0503
    Address 09: Cent. Elect.	Labels: 7Lx-937-049-V2.clb
    	Part No SW: 7L6 937 049 AF	HW: 7L6937049AF
    	Component: 2001J519
    	Serial Number: --------------
    	Shop #: WSC 00000 000
    	VCID: 80439303896497CD5912D7-80D5
    Address 15: Airbags	Labels: 7L0-959-655.lbl
    	Part No SW: 7L0 959 655	HW: 7L0959655
    	Component: J234__36 VW8T        0250
    	Revision: 92012025	Serial Number: 0039P0053KCY
    	Coding: 0013110
    	VCID: FAB7E1EBEFB8CD1D17D695-80AF
    Address 16: Steering wheel	Labels: 7L6-953-549.lbl
    	Part No SW: 7L6 953 549 G
    	Component: J527                 3601
    	Coding: 0011012
    	VCID: 43C9DC0F58F2CCD584B0B0-8016
    Address 17: Instruments	Labels: 7L6-920-xxx-7L6.lbl
    	Part No SW: 7L6 920 885 P	HW: 7L6920885P
    	Component: J285 KOMBI-INST.     7520
    	Revision: KHH06V02
    	Coding: 0007701
    	Shop #: WSC 76700 819 105401
    	VCID: 49D5CE277ADE12854ECC72-801C
    Address 19: CAN Gateway	Labels: 6N0-909-901-19.lbl
    	Part No SW: 6N0 909 901	HW: 7L6920885P
    	Component: J533  GW-K-CAN TP20  7520
    	Coding: 77E6EFFFCA046002
    	VCID: F0A3C3C3B9C4834DA97207-80A5
    Address 22: AWD	Labels: 0A-22.lbl
    	Part No SW: 0AD 927 755 BG
    	Component: TRANSFERCASE         0126
    	VCID: 81459607826E9BC5561CDA-5184
    Address 28: Failed to respond
    Address 36: Seat Mem. Drvr	Labels: None
    	Component: Sitzverstellung      0703
    Address 37: Navigation  (J0506)	Labels: 1T0-035-680.clb
    	Part No SW: 7L6 035 680 C	HW: 7L6 035 680 A
    	Component: RNS-MID       H04 5238
    	Revision: AB001001
    	Coding: 02050000000000120000
    	VCID: 322789CBF748F15D1FE67D-8067
    	Subsystem 1 - 	Part No SW: 7L6-919-859-F
    	Component: AGCC V9      8296
    Address 3C: Lane Change	Labels: 7L-3c.clb
    	Part No SW: 7L6 907 566 B	HW: 7L6907568A
    	Component: J0769_SWA_MasterH10  0070
    	Revision: 00H10000	Serial Number: 6PZ 009 014-01
    	Coding: 0000051
    	VCID: 3C3BA7F3250CB32DC54AC3-8069
    	Subsystem 1 - 	Part No SW: 7L6-907-568-B
    	Component: J0770_SWA_Slave_H08  0070
    	Serial Number: 6PZ 009 014-21
    Address 46: Central Conv.	Labels: 7L0-959-933.lbl
    	Part No SW: 7L6 959 933 A
    	Component: 24 HSG               0601
    	Coding: 0000085
    	VCID: 40C3D30349E4D2CD999297-4B1E
    	Subsystem 1 - 	Part No SW: 7L0-959-701-P
    	Component: Tuersteuergeraet FS  6303
    	Subsystem 2 - 	Part No SW: 7L0-959-702-P
    	Component: Tuersteuergeraet BF  6302
    	Subsystem 3 - 	Part No SW: 7L0-959-703-D
    	Component: Tuersteuergeraet HL  0201
    	Subsystem 4 - 	Part No SW: 7L0-959-704-D
    	Component: Tuersteuergeraet HR  0201
    	Subsystem 5 - 	Part No SW: 7L0-907-719-A
    	Component:    Neigungssensor    0020
    	Subsystem 6 - 	Part No SW: 7L6-951-171-B
    	Component:    Innenraumsensor   0020
    01134 - Alarm Horn (H12)
    	000 -  -
    Address 47: Sound System	Labels: 7Lx-035-4xx-47.lbl
    	Part No SW: 7L6 035 466 C	HW: 7L6035466C
    	Component: DSP 10 Kanal         0020
    	Revision: 00H05001	Serial Number: 75835000495503
    	VCID: 342B8FD30D5C7F6D0D1A6B-8061
    Address 55: Xenon Range	Labels: 7L6-907-357-A.lbl
    	Part No SW: 7L6 907 357 A	HW: 7L6941329B
    	Component: AFS-Steuergeraet     0001
    	Revision:   H02   	Serial Number:
    	Coding: 1286275
    	VCID: 3935BEE72A3E8605DE2C22-806C
    	Subsystem 1 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
    	Component: AFS-Lst.-Modul l     S002
    	Coding: 0000019
    	Subsystem 2 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
    	Component: AFS-Lst.-Modul r     S002
    	Coding: 0000019
    Address 56: Radio  (J0506)	Labels: 1T0-035-680.clb
    	Revision: AB001001
    Address 68: Wiper Electr.	Labels: 7L0-955-119-V2.clb
    	Part No SW: 7L6 955 119 B
    	Component: J400__ Front Wiper   5301
    	Coding: 0001397
    	VCID: 3935BEE72A3E8205DE2C22-806C
    Address 69: Trailer	Labels: 7L0-907-383-1D2.lbl
    	Part No SW: 7L0 907 383 N	HW: 7L0907383N
    	Component: J345  Anhaenger      0080
    	Revision: 4A009002	Serial Number: 00000177341264
    	Coding: 0016385
    	VCID: 3FC1D0FF341AA835E068EC-806A
    Address 6C: Back-up Cam.	Labels: 5N0-907-441.clb
    	Part No SW: 7L6 907 441 B	HW: 7L6907441B
    	Component: J772__Rearview       0033
    	Revision: 00H13000	Serial Number:    PA8 J840916
    	Coding: 0000001
    Address 6D: Trunk Elect.	Labels: 7L6-959-107.clb
    	Part No SW: 7L6 959 107 B	HW: 7L6959107B
    	Component: J605  HECKKLAPPE     1310
    	Revision: --H05---	Serial Number: --------034243
    	Coding: 0122110
    	VCID: 3A37A1EB2F388D1DD756D5-806F
    Address 76: Park Assist	Labels: None
    	Part No SW: 7L0 919 283 F
    	Component: 0D Einparkhilfe      1107
    Address 77: Failed to respond
    May 2016
    KIMIMIKE, loss of intermittent power.
    Read a case study one time and noted you pulling a trailer in sand. Just a thought here, and off the cuff for 2019, but sometimes noise transmitted through a trailer hitch will cause knock sensors to intervene, anyway, just a thought as can really kick your butt.
    LARIMORE
    Jun 2014
    The 7L6 hitch receiver is annoyingly noisy...oversized.. even with a clamp on it.
    Jul 2016
    UAE
    Thanks for the replies guys. In my case it’s ESP kicking in and reducing wheelspin by reducing engine power after it gives up dancing with the brakes for electronic differential control. On a straight face with all wheels spinning equally, it’s normally ok, but go up something obliquely, or in a curve and it thinks itself to death, perhaps the yaw sensor vs wheels speed vs ground speed and steering angle all come into play. It happens without pulling anything too. ESP off seems to just have a longer time delay before intervention, but it reduces the yaw sensor sensitivity.
    On the RNS510 issue, it might just be the hard drive spindle seizing up in the cold? Once things are warmed up the Media page and GPS maps all come back. I’m still testing that theory before buying, cloning and installing a new 2.5” IDE drive.
    Jul 2016
    UAE
    Mines just a manually removable Westfalia, it’s been sublime. https://goo.gl/images/L5d6Rg
    Didn’t feel like being lazy and installing the more expensive electrically retractable one.
  6. #6
    I'm skeptical that it's the hitch that's causing the behavior in question.
    For laughs, you could take a look at Adaptation Channel 90 in the ABS. I would suppose that the value there is a 1. If so, try changing it to 0. That should turn ESP off. However, I would also guess that this setting will not survive an ignition cycle. I'm also not sure whether this will kill the power reduction.
    I'm not aware of any other way to accomplish what you're looking to do.
  7. Likes Larry Manton liked this post
    Jul 2016
    UAE
    Thanks Uwe, I'll investigate that and see how I get on.
    I can now confirm the HD in my RNS510 is packing in and why the Media page is waiting on System Starting... and Navigation maps are timing out and not loading.
    Here's when it warmed up and running properly.
    https://photos.app.goo.gl/A3rqnQXtsiqCQeBw5
    Here's when it is cold and not working.
    https://photos.app.goo.gl/uy67td8NkSaYtjL1A
  9. #8
    Quote Originally Posted by kiwimike View Post
    I think I've heard of people replacing then with SSDs...?
  10. #9
    Tartu, Estonia
    There are guides for it on web.
    The world is my oyster...
  11. Likes Uwe liked this post
  12. #10
    Jul 2016
    UAE
    Yes. Impressive build quality in the RNS510, love the precision in the metalwork. I think anything will be faster than the 30GB 4200 Hitachi that’s currenty in it.
    SSD should be quite vibration resilient, China has a few IDE SSD options. Will probably need IDE to SATA converter as well to format in FAT32 and clone.
